--- ray/doc/ray.html 2023/12/12 20:12:47 1.36 +++ ray/doc/ray.html 2024/12/09 19:21:38 1.39 @@ -1,5 +1,5 @@ - +
+ mod WGMDfunc id + 13+ rs_mod rs rs_urough rs_vrough + ts_mod ts ts_urough ts_vrough + td_mod + ux uy uz funcfile transform + 0 + 9+ rfdif gfdif bfdif + rbdif gbdif bbdif + rtdif gtdif btdif + A10 .. ++ +The sum of specular reflectance (rs), specular transmittance (ts), +diffuse reflectance (rfdif gfdif bfdif for front and rbdif gbdif bbdif for back) +and diffuse transmittance (rtdif gtdif btdif) should be less than 1 for each +channel. + +
+ +Unique to this material, separate modifier channels are +provided for each component. +The main modifier is used on the diffuse reflectance, both +front and back. +The rs_mod modifier is used for specular reflectance. +If "void" is given for rs_mod, +then the specular reflection color will be white. +The special "inherit" keyword may also be given, in which case +specular reflectance will share the main modifier. +This behavior is replicated for the specular transmittance modifier +ts_mod, which also has its own independent roughness expressions. +Finally, the diffuse transmittance modifier is given as +td_mod, which may also be "void" or "inherit". +Note that any spectra or color for specular components must be +carried by the named modifier(s). + +
+ +The main advantage to this material over +BRTDfunc and +other programmable types described below is that the specular sampling is +well-defined, so that all components are fully computed. + +
mod specfunc id
- 2+ sval funcfile transform
+ 2+ sfunc funcfile transform
0
2+ nmA nmB A3 ..
@@ -1552,6 +1608,61 @@ or:
This function is fed a wavelenth sample
between nmA and nmB as its only argument,
and it returns the corresponding spectral intensity.
++ mod specdata id + 3+n+ + func datafile + funcfile x1 x2 .. xn transform + 0 + m A1 A2 .. Am ++ +
+ The data file must have one more dimension than the coordinate + variable count, as this final dimension corresponds to the covered + spectrum. + The starting and ending wavelengths are specified in "datafile" + as well as the number of spectral samples. + The function "func" will be called with two parameters, the + interpolated spectral value for the current coordinate and the + associated wavelength. + If the spectrum is broken into 12 components, then 12 calls + will be made to "func" for the relevant ray evaluation. + +
+ mod specpict id + 5+ + func specfile + funcfile u v transform + 0 + m A1 A2 .. Am ++ +
+ The function "func" is called with the interpolated pixel value + and the wavelength sample in nanometers, the same as specdata, + with as many calls made as there are components in "specfile".
