--- ray/doc/ray.html 2018/10/08 20:04:09 1.27 +++ ray/doc/ray.html 2023/05/11 17:18:39 1.31 @@ -1,8 +1,8 @@ - + -The RADIANCE 5.2 Synthetic Imaging System +The RADIANCE 5.4 Synthetic Imaging System @@ -10,7 +10,7 @@ The RADIANCE 5.2 Synthetic Imaging System
@@ -83,7 +83,7 @@ The diagram in Figure 1 shows the flow between program (ovals). The central program is rpict, which produces a picture from a scene description. -Rview is a variation of rpict that computes and displays images +Rvu is a variation of rpict that computes and displays images interactively, and rtrace computes single ray values. Other programs (not shown) connect many of these elements together, such as the executive programs @@ -822,6 +822,8 @@ unless the line integrals consider enclosed geometry. Also, rather than roughness, specular power is used, which has no physical meaning other than larger numbers are equivalent to a smoother surface. + Unlike other material types, total reflectance is the sum of + diffuse and specular colors, and should be adjusted accordingly.
 	mod ashik2 id
 	4+ ux uy uz funcfile transform
@@ -1807,7 +1809,7 @@ The details of this process  are  not  important, but
 directs the use of a scene description.
