--- ray/doc/ray.html 2018/06/25 20:49:10 1.25
+++ ray/doc/ray.html 2023/12/13 23:26:16 1.38
@@ -1,8 +1,8 @@
-The RADIANCE 5.2 Synthetic Imaging System
+The RADIANCE 6.0 Synthetic Imaging System
@@ -10,7 +10,7 @@ The RADIANCE 5.2 Synthetic Imaging System
@@ -83,7 +83,7 @@ The diagram in Figure 1 shows the flow between program
(ovals).
The central program is rpict, which produces a picture from a scene
description.
-Rview is a variation of rpict that computes and displays images
+Rvu is a variation of rpict that computes and displays images
interactively, and rtrace computes single ray values.
Other programs (not shown) connect many of these elements together,
such as the executive programs
@@ -822,6 +822,8 @@ unless the line integrals consider enclosed geometry.
Also, rather than roughness, specular power is used, which has no
physical meaning other than larger numbers are equivalent to a smoother
surface.
+ Unlike other material types, total reflectance is the sum of
+ diffuse and specular colors, and should be adjusted accordingly.
mod ashik2 id
4+ ux uy uz funcfile transform
@@ -1154,22 +1156,23 @@ unless the line integrals consider enclosed geometry.
- sBSDF
+ aBSDF
- The sBSDF material is identical to the BSDF type with two
+ The aBSDF material is identical to the BSDF type with two
important differences. First, proxy geometry is not
supported, so there is no thickness parameter. Second, an
- sBSDF is assumed to have some specular through component,
+ aBSDF is assumed to have some specular through component
+ (the ’a’ stands for "aperture"),
which is treated specially during the direct calculation
and when viewing the material. Based on the BSDF data, the
coefficient of specular transmission is determined and used
for modifying unscattered shadow and view rays.
- mod sBSDF id
+ mod aBSDF id
5+ BSDFfile ux uy uz funcfile transform
0
0|3|6|9
@@ -1181,7 +1184,7 @@ unless the line integrals consider enclosed geometry.
If a material has no specular transmitted component, it is
much better to use the BSDF type with a zero thickness
- than to use sBSDF.
+ than to use aBSDF.
@@ -1458,6 +1461,153 @@ or:
A section of text meant to depict a picture, perhaps using a special purpose font such as hexbit4x1.fnt, calls for uniform spacing.
Reasonable magnitudes for proportional spacing are between 0.1 (for tightly spaced characters) and 0.3 (for wide spacing).
+ Spectrum
+ The spectrum primitive is the most basic type for introducing spectral
+ color to a material.
+ Since materials only provide RGB parameters, spectral patterns
+ are the only way to superimpose wavelength-dependent behavior.
+ mod spectrum id
+ 0
+ 0
+ 5+ nmA nmB s1 s2 .. sN
+ The first two real arguments indicate the extrema of the
+ spectral range in nanometers.
+ Subsequent real values correspond to multipliers at each wavelength.
+ The nmA wavelength may be greater or less than nmB,
+ but they may not be equal, and their ordering matches
+ the order of the spectral values.
+ A minimum of 3 values must be given, which would act
+ more or less the same as a constant RGB multiplier.
+ As with RGB values, spectral quantities normally range between 0
+ and 1 at each wavelength, or average to 1.0 against a standard
+ sensitivity functions such as V(lambda).
+ The best results obtain when the spectral range and number
+ of samples match rendering options, though resampling will handle
+ any differences, zero-filling wavelenths outside the nmA to nmB
+ range.
+ A warning will be issued if the given wavelength range does not
+ adequately cover the visible spectrum.
+ Specfile
+ The specfile primitive is equivalent to the spectrum type, but
+ the wavelength range and values are contained in a 1-dimensional
+ data file.
+ This may be a more convenient way to specify a spectral color,
+ especially one corresponding to a standard illuminant such as D65
+ or a library of measured spectra.
+ mod specfile id
+ 1 datafile
+ 0
+ 0
+ As with the spectrum type, rendering wavelengths outside the defined
+ range will be zero-filled.
+ Unlike the spectrum type, the file may contain non-uniform samples.
+ Specfunc
+ The specfunc primitive offers dynamic control over a spectral
+ pattern, similar to the colorfunc type.
+ mod specfunc id
+ 2+ sfunc funcfile transform
+ 0
+ 2+ nmA nmB A3 ..
+ Like the spectrum primitive, the wavelength range is specified
+ in the first two real arguments, and additional real values are
+ set in the evaluation context.
+ This function is fed a wavelenth sample
+ between nmA and nmB as its only argument,
+ and it returns the corresponding spectral intensity.
+ Specdata
+ Specdata is like brightdata and colordata, but with more
+ than 3 specular samples.
+ mod specdata id
+ 3+n+
+ func datafile
+ funcfile x1 x2 .. xn transform
+ 0
+ m A1 A2 .. Am
+ The data file must have one more dimension than the coordinate
+ variable count, as this final dimension corresponds to the covered
+ spectrum.
+ The starting and ending wavelengths are specified in "datafile"
+ as well as the number of spectral samples.
+ The function "func" will be called with two parameters, the
+ interpolated spectral value for the current coordinate and the
+ associated wavelength.
+ If the spectrum is broken into 12 components, then 12 calls
+ will be made to "func" for the relevant ray evaluation.
+ Specpict
+ Specpict is a special case of specdata, where the pattern is
+ a hyperspectral image stored in the common-exponent file format.
+ The dimensions of the image data are determined by the picture
+ just as with the colorpict primitive.
+ mod specpict id
+ 5+
+ func specfile
+ funcfile u v transform
+ 0
+ m A1 A2 .. Am
+ The function "func" is called with the interpolated pixel value
+ and the wavelength sample in nanometers, the same as specdata,
+ with as many calls made as there are components in "specfile".
@@ -1806,7 +1956,7 @@ The details of this process are not important, but
directs the use of a scene description.
-Rview is ray-tracing program for viewing a scene interactively.
+Rvu is ray-tracing program for viewing a scene interactively.
When the user specifies a new perspective, rvu quickly displays a rough image on the terminal,
then progressively increases the resolution as the user looks on.
He can select a particular section of the image to improve, or move to a different view and start over.
@@ -1842,7 +1992,7 @@ Pictures may be displayed directly under X11 using the
or converted a standard image format using one of the following
translators:
- - Ra_bmp
- Ra_bmp
converts to and from BMP image format.
- Ra_ppm
converts to and from Poskanzer Portable Pixmap formats.
@@ -1871,7 +2021,7 @@ or converted a standard image format using one of the
The Radiance Software License, Version 1.0
-Copyright (c) 1990 - 2014 The Regents of the University of California,
+Copyright (c) 1990 - 2021 The Regents of the University of California,
through Lawrence Berkeley National Laboratory. All rights reserved.
Redistribution and use in source and binary forms, with or without
@@ -1944,6 +2094,39 @@ Ecole Polytechnique Federale de Lausanne (EPFL Unive
+ - Ward, Gregory J., Bruno Bueno, David Geisler-Moroder,
+ Lars O. Grobe, Jacob C. Jonsson, Eleanor
+ S. Lee, Taoning Wang, Helen Rose Wilson,
+ "Daylight
+ Simulation Workflows Incorporating Measured Bidirectional
+ Scattering Distribution Functions"
+ Energy & Buildings, Vol. 259, No. 11890, 2022.
- Wang, Taoning, Gregory Ward, Eleanor Lee,
+ "Efficient
+ modeling of optically-complex, non-coplanar exterior shading:
+ Validation of matrix algebraic methods"
+ Energy & Buildings, vol. 174, pp. 464-83, Sept. 2018.
- Lee, Eleanor S., David Geisler-Moroder, Gregory Ward,
+ "Modeling
+ the direct sun component in buildings using matrix
+ algebraic approaches: Methods and
+ validation," Solar Energy,
+ vol. 160, 15 January 2018, pp 380-395.
- Narain, Rahul, Rachel A. Albert, Abdullah Bulbul,
+ Gregory J. Ward, Marty Banks, James F. O'Brien,
+ "Optimal
+ Presentation of Imagery with Focus
+ Cues on Multi-Plane Displays,"
+ SIGGRAPH 2015.
- Ward, Greg, Murat Kurt, and Nicolas Bonneel,
+ "Reducing
+ Anisotropic BSDF Measurement to Common Practice,"
+ Workshop on Material Appearance Modeling, 2014.
- Banks, Martin, Abdullah Bulbul, Rachel Albert, Rahul Narain,
+ James F. O'Brien, Gregory Ward,
+ "The
+ Perception of Surface Material from Disparity and Focus Cues,"
+ VSS 2014.
- McNeil, A., C.J. Jonsson, D. Appelfeld, G. Ward, E.S. Lee,
A validation of a ray-tracing tool used to generate
