--- ray/doc/ray.html 2017/08/26 16:07:22 1.24
+++ ray/doc/ray.html 2018/06/25 20:49:10 1.25
@@ -1,5 +1,5 @@
The RADIANCE 5.2 Synthetic Imaging System
@@ -1151,6 +1151,37 @@ unless the line integrals consider enclosed geometry.
the surface will be invisible from behind. Unlike other
data-driven material types, the BSDF type is fully supported
and all parts of the distribution are properly sampled.
+ sBSDF
+ The sBSDF material is identical to the BSDF type with two
+ important differences. First, proxy geometry is not
+ supported, so there is no thickness parameter. Second, an
+ sBSDF is assumed to have some specular through component,
+ which is treated specially during the direct calculation
+ and when viewing the material. Based on the BSDF data, the
+ coefficient of specular transmission is determined and used
+ for modifying unscattered shadow and view rays.
+ mod sBSDF id
+ 5+ BSDFfile ux uy uz funcfile transform
+ 0
+ 0|3|6|9
+ rfdif gfdif bfdif
+ rbdif gbdif bbdif
+ rtdif gtdif btdif
+ If a material has no specular transmitted component, it is
+ much better to use the BSDF type with a zero thickness
+ than to use sBSDF.
