--- ray/doc/ray.html 2011/07/15 20:59:36 1.17
+++ ray/doc/ray.html 2021/11/16 23:12:22 1.30
@@ -1,7 +1,8 @@
-The RADIANCE 4.1 Synthetic Imaging System
+The RADIANCE 5.4 Synthetic Imaging System
@@ -9,7 +10,7 @@ The RADIANCE 4.1 Synthetic Imaging System
@@ -82,7 +83,7 @@ The diagram in Figure 1 shows the flow between program
(ovals).
The central program is rpict, which produces a picture from a scene
description.
-Rview is a variation of rpict that computes and displays images
+Rvu is a variation of rpict that computes and displays images
interactively, and rtrace computes single ray values.
Other programs (not shown) connect many of these elements together,
such as the executive programs
@@ -797,7 +798,8 @@ unless the line integrals consider enclosed geometry.
Trans2 is the anisotropic version of trans.
- The string arguments are the same as for plastic2, and the real arguments are the same as for trans but with an additional roughness value.
+ The string arguments are the same as for plastic2,
+ and the real arguments are the same as for trans but with an additional roughness value.
mod trans2 id
@@ -809,6 +811,27 @@ unless the line integrals consider enclosed geometry.
+ Ashik2
+ Ashik2 is the anisotropic reflectance model by Ashikhmin & Shirley.
+ The string arguments are the same as for plastic2, but the real
+ arguments have additional flexibility to specify the specular color.
+ Also, rather than roughness, specular power is used, which has no
+ physical meaning other than larger numbers are equivalent to a smoother
+ surface.
+ mod ashik2 id
+ 4+ ux uy uz funcfile transform
+ 0
+ 8 dred dgrn dblu sred sgrn sblu u-power v-power
Dielectric
@@ -1131,6 +1154,38 @@ unless the line integrals consider enclosed geometry.
+ aBSDF
+ The aBSDF material is identical to the BSDF type with two
+ important differences. First, proxy geometry is not
+ supported, so there is no thickness parameter. Second, an
+ aBSDF is assumed to have some specular through component
+ (the ’a’ stands for "aperture"),
+ which is treated specially during the direct calculation
+ and when viewing the material. Based on the BSDF data, the
+ coefficient of specular transmission is determined and used
+ for modifying unscattered shadow and view rays.
+ mod aBSDF id
+ 5+ BSDFfile ux uy uz funcfile transform
+ 0
+ 0|3|6|9
+ rfdif gfdif bfdif
+ rbdif gbdif bbdif
+ rtdif gtdif btdif
+ If a material has no specular transmitted component, it is
+ much better to use the BSDF type with a zero thickness
+ than to use aBSDF.
Antimatter
@@ -1414,6 +1469,7 @@ or:
A mixture is a blend of one or more materials or textures and patterns.
+Blended materials should not be light source types or virtual source types.
The basic types are given below.
@@ -1486,7 +1542,6 @@ A mixfunc mixes two modifiers procedurally. It i
arguments, the red, green and blue values
corresponding to the pixel at (u,v).
@@ -1752,7 +1807,7 @@ The details of this process are not important, but
directs the use of a scene description.
-Rview is ray-tracing program for viewing a scene interactively.
+Rvu is ray-tracing program for viewing a scene interactively.
When the user specifies a new perspective, rvu quickly displays a rough image on the terminal,
then progressively increases the resolution as the user looks on.
He can select a particular section of the image to improve, or move to a different view and start over.
@@ -1788,16 +1843,10 @@ Pictures may be displayed directly under X11 using the
or converted a standard image format using one of the following
translators:
- - Ra_avs
- converts to and from AVS image format.
- Ra_pict
- converts to Macintosh 32-bit PICT2 format.
- Ra_bmp
+ converts to and from BMP image format.
- Ra_ppm
converts to and from Poskanzer Portable Pixmap formats.
- Ra_pr
- converts to and from Sun 8-bit rasterfile format.
- Ra_pr24
- converts to and from Sun 24-bit rasterfile format.
- Ra_ps
converts to PostScript color and greyscale formats.
- Ra_rgbe
@@ -1823,7 +1872,7 @@ or converted a standard image format using one of the
The Radiance Software License, Version 1.0
-Copyright (c) 1990 - 2010 The Regents of the University of California,
+Copyright (c) 1990 - 2021 The Regents of the University of California,
through Lawrence Berkeley National Laboratory. All rights reserved.
Redistribution and use in source and binary forms, with or without
@@ -1896,12 +1945,45 @@ Ecole Polytechnique Federale de Lausanne (EPFL Unive
+ - Wang, Taoning, Gregory Ward, Eleanor Lee,
+ "Efficient
+ modeling of optically-complex, non-coplanar exterior shading:
+ Validation of matrix algebraic methods"
+ Energy & Buildings, vol. 174, pp. 464-83, Sept. 2018.
- Lee, Eleanor S., David Geisler-Moroder, Gregory Ward,
+ "Modeling
+ the direct sun component in buildings using matrix
+ algebraic approaches: Methods and
+ validation," Solar Energy,
+ vol. 160, 15 January 2018, pp 380-395.
- Narain, Rahul, Rachel A. Albert, Abdullah Bulbul,
+ Gregory J. Ward, Marty Banks, James F. O'Brien,
+ "Optimal
+ Presentation of Imagery with Focus
+ Cues on Multi-Plane Displays,"
+ SIGGRAPH 2015.
- Ward, Greg, Murat Kurt, and Nicolas Bonneel,
+ "Reducing
+ Anisotropic BSDF Measurement to Common Practice,"
+ Workshop on Material Appearance Modeling, 2014.
- Banks, Martin, Abdullah Bulbul, Rachel Albert, Rahul Narain,
+ James F. O'Brien, Gregory Ward,
+ "The
+ Perception of Surface Material from Disparity and Focus Cues,"
+ VSS 2014.
- McNeil, A., C.J. Jonsson, D. Appelfeld, G. Ward, E.S. Lee,
+ A validation of a ray-tracing tool used to generate
+ bi-directional scattering distribution functions for
+ complex fenestration systems,"
+ Solar Energy, 98, 404-14,
+ November 2013.
- Ward, G., R. Mistrick, E.S. Lee, A. McNeil, J. Jonsson,
"Simulating
the Daylight Performance of Complex Fenestration Systems
Using Bidirectional Scattering Distribution Functions within
Radiance,"
- Journal of the Illuminating Engineering Soc. of North America,
+ Leukos, 7(4)
April 2011.
- Cater, Kirsten, Alan Chalmers, Greg Ward,
"Detail to Attention:
