--- ray/doc/ray.html 2011/06/22 00:12:43 1.14 +++ ray/doc/ray.html 2018/10/08 20:04:09 1.27 @@ -1,7 +1,8 @@ + -The RADIANCE 4.1 Synthetic Imaging System +The RADIANCE 5.2 Synthetic Imaging System @@ -9,7 +10,7 @@ The RADIANCE 4.1 Synthetic Imaging System
@@ -797,7 +798,8 @@ unless the line integrals consider enclosed geometry.
Trans2 is the anisotropic version of trans. - The string arguments are the same as for plastic2, and the real arguments are the same as for trans but with an additional roughness value. + The string arguments are the same as for plastic2, + and the real arguments are the same as for trans but with an additional roughness value.
         mod trans2 id
@@ -809,6 +811,27 @@ unless the line integrals consider enclosed geometry.
+ + Ashik2 + + +
+ Ashik2 is the anisotropic reflectance model by Ashikhmin & Shirley. + The string arguments are the same as for plastic2, but the real + arguments have additional flexibility to specify the specular color. + Also, rather than roughness, specular power is used, which has no + physical meaning other than larger numbers are equivalent to a smoother + surface. +
+	mod ashik2 id
+	4+ ux uy uz funcfile transform
+	0
+	8 dred dgrn dblu sred sgrn sblu u-power v-power
Dielectric @@ -1131,6 +1154,38 @@ unless the line integrals consider enclosed geometry.
+ + aBSDF + + +
+ The aBSDF material is identical to the BSDF type with two + important differences. First, proxy geometry is not + supported, so there is no thickness parameter. Second, an + aBSDF is assumed to have some specular through component + (the ’a’ stands for "aperture"), + which is treated specially during the direct calculation + and when viewing the material. Based on the BSDF data, the + coefficient of specular transmission is determined and used + for modifying unscattered shadow and view rays. + +
+	mod aBSDF id
+	5+ BSDFfile ux uy uz funcfile transform
+	0
+	0|3|6|9
+	     rfdif gfdif bfdif
+	     rbdif gbdif bbdif
+	     rtdif gtdif btdif
+ If a material has no specular transmitted component, it is + much better to use the BSDF type with a zero thickness + than to use aBSDF. +
Antimatter @@ -1414,6 +1469,7 @@ or: A mixture is a blend of one or more materials or textures and patterns. +Blended materials should not be light source types or virtual source types. The basic types are given below.
@@ -1486,7 +1542,6 @@ A mixfunc mixes two modifiers procedurally. It i arguments, the red, green and blue values corresponding to the pixel at (u,v). -
@@ -1788,16 +1843,10 @@ Pictures may be displayed directly under X11 using the or converted a standard image format using one of the following translators:
