Building Technologies Program
Figure 1
The diagram in Figure 1 shows the flow between programs (boxes) and data
(ovals).
The central program is rpict, which produces a picture from a scene
description.
Rview is a variation of rpict that computes and displays images
interactively, and rtrace computes single ray values.
Other programs (not shown) connect many of these elements together,
such as the executive programs
rad
and
ranimate,
the interactive rendering program
rholo,
and the animation program
ranimove.
The program
obj2mesh
acts as both a converter and scene compiler, converting a Wavefront .OBJ
file into a compiled mesh octree for efficient rendering.
A scene description file lists the surfaces and materials
that make up a specific environment.
The current surface types are spheres, polygons, cones, and cylinders.
There is also a composite surface type, called mesh, and a pseudosurface
type, called instance, which facilitates very complex geometries.
Surfaces can be made from materials such as plastic, metal, and glass.
Light sources can be distant disks as well as local spheres, disks
and polygons.
From a three-dimensional scene description and a specified view,
rpict produces a two-dimensional image.
A picture file is a compressed binary representation of the
pixels in the image.
This picture can be scaled in size and brightness,
anti-aliased, and sent to a graphics output device.
A header in each picture file lists the program(s)
and parameters that produced it.
This is useful for identifying a picture without having to display it.
The information can be read by the program getinfo.
The scene description primitives
all have the same general format, and can be either surfaces or modifiers.
A primitive has a modifier, a type, and an identifier.
A modifier is either the
identifier of a previously defined primitive, or "void".
An identifier can be any string
(i.e., any sequence of non-white characters).
The arguments associated with a primitive can be strings or real numbers.
An alias gets its type and arguments from
a previously defined primitive.
This is useful when the same material is
used with a different modifier, or as a convenient naming mechanism.
The reserved modifier name "inherit" may be used to specificy that
an alias will inherit its modifier from the original.
Surfaces cannot be aliased.
A line beginning with an exclamation point, `!',
is interpreted as a command.
It is executed by the shell, and its output is read as input to the program.
The command must not try to read from its standard input, or confusion
will result.
A command may be continued over multiple lines using a
backslash, `\', to escape the newline.
White space is generally ignored, except as a separator.
The exception is the newline character after a command or comment.
Commands, comments and primitives may appear in any
combination, so long as they are not intermingled.
Lawrence Berkeley National Laboratory
1 Cyclotron Rd., 90-3111
Berkeley, CA 94720
http://radsite.lbl.gov/radiance
Overview
1. Introduction
RADIANCE was developed as a research tool for predicting
the distribution of visible radiation in illuminated spaces.
It takes as input a three-dimensional geometric model
of the physical environment, and produces a map of
spectral radiance values in a color image.
The technique of ray-tracing follows light backwards
from the image plane to the source(s).
Because it can produce realistic images from a
simple description, RADIANCE has a wide range of applications
in graphic arts, lighting design,
computer-aided engineering and architecture.
2. Scene Description
A scene description file represents a three-dimensional physical environment in Cartesian (rectilinear) world coordinates.
It is stored as ASCII text, with the following basic format:
# comment
modifier type identifier
n S1 S2 "S 3" .. Sn
0
m R1 R2 R3 .. Rm
modifier alias identifier reference
! command
A comment line begins with a pound sign, `#'.
[ The most recent definition of a modifier is the
one used, and later definitions do not cause relinking
of loaded primitives.
Thus, the same identifier may be used repeatedly,
and each new definition will apply to the primitives following it. ]
2.1. Primitive Types
Primitives can be surfaces,
materials,
textures or
patterns.
Modifiers can be materials,
mixtures,
textures or patterns.
Simple surfaces must have one material in their modifier list.
mod source id 0 0 4 xdir ydir zdir angle
mod sphere id
0
0
4 xcent ycent zcent radius
mod polygon id
0
0
3n
x1 y1 z1
x2 y2 z2
xn yn zn
mod cone id
0
0
8
x0 y0 z0
x1 y1 z1
r0 r1
mod cylinder id
0
0
7
x0 y0 z0
x1 y1 z1
rad
mod ring id
0
0
8
xcent ycent zcent
xdir ydir zdir
r0 r1
mod instance id
1+ octree transform
0
0
If the modifier is "void", then surfaces will
use the modifiers given in the original description.
Otherwise, the modifier specified is used in their place.
The transform moves the octree to the desired location in the scene.
Multiple instances using the same octree take
little extra memory, hence very complex
descriptions can be rendered using this primitive.
There are a number of important limitations to be aware of when using instances. First, the scene description used to generate the octree must stand on its own, without referring to modifiers in the parent description. This is necessary for oconv to create the octree. Second, light sources in the octree will not be incorporated correctly in the calculation, and they are not recommended. Finally, there is no advantage (other than convenience) to using a single instance of an octree, or an octree containing only a few surfaces. An xform command on the subordinate description is prefered in such cases.
mod mesh id
1+ meshfile transform
0
0
use the modifiers given in the original mesh description.
The transform moves the mesh to the desired location in the scene.
Multiple instances using the same meshfile take little extra memory,
and the compiled mesh itself takes much less space than individual
polygons would.
In the case of an unsmoothed mesh, using the mesh primitive reduces
memory requirements by a factor of 30 relative to individual triangles.
If a mesh has smoothed surfaces, we save a factor of 50 or more,
permitting very detailed geometries that would otherwise exhaust the
available memory.
In addition, the mesh primitive can have associated (u,v) coordinates
for pattern and texture mapping.
These are made available to function files via the Lu and Lv variables.
mod light id
0
0
3 red green blue
mod illum id
1 material
0
3 red green blue
mod glow id
0
0
4 red green blue maxrad
If maxrad is zero, then the surface will never be tested for shadow, although it may participate in an interreflection calculation.
If maxrad is negative, then the surface will never contribute to scene illumination.
Glow sources will never illuminate objects on the other side of an illum surface.
This provides a convenient way to illuminate local light fixture geometry without overlighting nearby objects.
mod spotlight id
0
0
7 red green blue angle xdir ydir zdir
mod mirror id
1 material
0
3 red green blue
mod prism1 id
5+ coef dx dy dz funcfile transform
0
n A1 A2 .. An
The new direction variables dx, dy and dz need not produce a normalized vector.
For convenience, the variables DxA, DyA and DzA are defined as the normalized direction to the target light source.
See section 2.2.1 on function files for further information.
mod prism2 id
9+ coef1 dx1 dy1 dz1 coef2 dx2 dy2 dz2 funcfile transform
0
n A1 A2 .. An
3 source1 mirror1>source10 mirror2>mirror1>source3Normally, only one source is given per mist material, and there is an upper limit of 32 to the total number of active scattering sources. The extinction coefficient, if given, is added the the global coefficient set on the command line. Extinction is in units of 1/distance (distance based on the world coordinates), and indicates the proportional loss of radiance over one unit distance. The scattering albedo, if present, will override the global setting within the volume. An albedo of 0 0 0 means a perfectly absorbing medium, and an albedo of 1 1 1 means a perfectly scattering medium (no absorption). The scattering eccentricity parameter will likewise override the global setting if it is present. Scattering eccentricity indicates how much scattered light favors the forward direction, as fit by the Henyey-Greenstein function:
P(theta) = (1 - g*g) / (1 + g*g - 2*g*cos(theta))^1.5A perfectly isotropic scattering medium has a g parameter of 0, and a highly directional material has a g parameter close to 1. Fits to the g parameter may be found along with typical extinction coefficients and scattering albedos for various atmospheres and cloud types in USGS meteorological tables. (A pattern will be applied to the extinction values.)
mod mist id N src1 src2 .. srcN 0 0|3|6|7 [ rext gext bext [ ralb galb balb [ g ] ] ]There are two usual uses of the mist type. One is to surround a beam from a spotlight or laser so that it is visible during rendering. For this application, it is important to use a cone (or cylinder) that is long enough and wide enough to contain the important visible portion. Light source photometry and intervening objects will have the desired effect, and crossing beams will result in additive scattering. For this application, it is best to leave off the real arguments, and use the global rendering parameters to control the atmosphere. The second application is to model clouds or other localized media. Complex boundary geometry may be used to give shape to a uniform medium, so long as the boundary encloses a proper volume. Alternatively, a pattern may be used to set the line integral value through the cloud for a ray entering or exiting a point in a given direction. For this application, it is best if cloud volumes do not overlap each other, and opaque objects contained within them may not be illuminated correctly unless the line integrals consider enclosed geometry.
mod plastic id
0
0
5 red green blue spec rough
mod trans id
0
0
7 red green blue spec rough trans tspec
mod plastic2 id
4+ ux uy uz funcfile transform
0
6 red green blue spec urough vrough
mod trans2 id
0
8 red green blue spec urough vrough trans tspec
mod dielectric id
0
0
5 rtn gtn btn n hc
mod interface id
0
0
8 rtn1 gtn1 btn1 n1 rtn2 gtn2 btn2 n2
tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn
Standard 88% transmittance glass has a transmissivity of 0.96.
(A pattern modifying glass will affect the transmissivity.)
If a fourth real argument is given, it is interpreted as the index of refraction to use instead of 1.52.
mod glass id
0
0
3 rtn gtn btn
mod plasfunc id
2+ refl funcfile transform
0
4+ red green blue spec A5 ..
The function refl takes four arguments, the x, y and z
direction towards the incident light, and the solid angle
subtended by the source.
The solid angle is provided to facilitate averaging, and is usually
ignored.
The refl function should integrate to 1 over
the projected hemisphere to maintain energy balance.
At least four real arguments must be given, and these are made available along with any additional values to the reflectance function.
Currently, only the contribution from direct light sources is considered in the specular calculation.
As in most material types, the surface normal is always altered to face the incoming ray.
mod transfunc id
2+ brtd funcfile transform
0
6+ red green blue rspec trans tspec A7 ..
Where trans is the total light transmitted and tspec is the non-Lambertian fraction of transmitted light.
The function brtd should integrate to 1 over each projected hemisphere.
mod BRTDfunc id
10+ rrefl grefl brefl
rtrns gtrns btrns
rbrtd gbrtd bbrtd
funcfile transform
0
9+ rfdif gfdif bfdif
rbdif gbdif bbdif
rtdif gtdif btdif
A10 ..
The variables rrefl, grefl and brefl specify the color coefficients for the ideal specular (mirror) reflection of the surface.
The variables rtrns, gtrns and btrns specify the color coefficients for the ideal specular transmission.
The functions rbrtd, gbrtd and bbrtd take the direction to the incident light (and its solid angle) and
compute the color coefficients for the directional diffuse part of reflection and transmission.
As a special case, three identical values of '0' may be given in place of these function names to indicate no directional diffuse component.
Unlike most other material types, the surface normal is not altered to face the incoming ray. Thus, functions and variables must pay attention to the orientation of the surface and make adjustments appropriately. However, the special variables for the perturbed dot product and surface normal, RdotP, NxP, NyP and NzP are reoriented as if the ray hit the front surface for convenience.
A diffuse reflection component may be given for the front side with rfdif, gfdif and bfdif for the front side of the surface or rbdif, gbdif and bbdif for the back side. The diffuse transmittance (must be the same for both sides by physical law) is given by rtdif, gtdif and btdif. A pattern will modify these diffuse scattering values, and will be available through the special variables CrP, CgP and CbP.
Care must be taken when using this material type to produce a physically valid reflection model. The reflectance functions should be bidirectional, and under no circumstances should the sum of reflected diffuse, transmitted diffuse, reflected specular, transmitted specular and the integrated directional diffuse component be greater than one.
mod plasdata id
3+n+
func datafile
funcfile x1 x2 .. xn transform
0
The coordinate indices (x1, x2, etc.) are themselves functions of the x, y and z direction to the incident light, plus the solid angle
subtended by the light source (usually ignored).
The data function (func) takes five variables, the
interpolated value from the n-dimensional data file, followed by the
x, y and z direction to the incident light and the solid angle of the source.
The light source direction and size may of course be ignored by the function.
mod transdata id
3+n+
func datafile
0
mod BSDF id 6+ thick BSDFfile ux uy uz funcfile transform 0 0|3|6|9 rfdif gfdif bfdif rbdif gbdif bbdif rtdif gtdif btdif
The first string argument is a "thickness" parameter that may be used
to hide detail geometry being proxied by an aggregate BSDF material.
If a view or shadow ray hits a BSDF proxy with non-zero thickness,
it will pass directly through as if the surface were not there.
Similar to the illum type, this permits direct viewing and
shadow testing of complex geometry.
The BSDF is used when a scattered (indirect) ray hits the surface,
and any transmitted sample rays will be offset by the thickness amount
to avoid the hidden geometry and gather samples from the other side.
In this manner, BSDF surfaces can improve the results for indirect
scattering from complex systems without sacrificing appearance or
shadow accuracy.
If the BSDF has transmission and back-side reflection data,
a parallel BSDF surface may be
placed slightly less than the given thickness away from the front surface
to enclose the complex geometry on both sides.
The sign of the thickness is important, as it indicates
whether the proxied geometry is behind the
The second string argument is the name of the BSDF file, which is found in the usual auxiliary locations. The following three string parameters name variables for an "up" vector, which together with the surface normal, define the local coordinate system that orients the BSDF. These variables, along with the thickness, are defined in a function file given as the next string argument. An optional transform is used to scale the thickness and reorient the up vector.
If no real arguments are given, the BSDF is used by itself to determine reflection and transmission. If there are at least 3 real arguments, the first triplet is an additional diffuse reflectance for the front side. At least 6 real arguments adds diffuse reflectance to the rear side of the surface. If there are 9 real arguments, the final triplet will be taken as an additional diffuse transmittance. All diffuse components as well as the non-diffuse transmission are modified by patterns applied to this material. The non-diffuse reflection from either side are unaffected. Textures perturb the effective surface normal in the usual way.
The surface normal of this type is not altered to face the incoming ray, so the front and back BSDF reflections may differ. (Transmission is identical front-to-back by physical law.) If back visibility is turned off during rendering and there is no transmission or back-side reflection, only then the surface will be invisible from behind. Unlike other data-driven material types, the BSDF type is fully supported and all parts of the distribution are properly sampled.
mod antimatter id
N mod1 mod2 .. modN
0
0
The first modifier will also be used to shade the area leaving the antimatter volume and entering the regular volume.
If mod1 is void, the antimatter volume is completely invisible.
Antimatter does not work properly with the material type "trans",
and multiple antimatter surfaces should be disjoint.
The viewpoint must be outside all volumes concerned for a correct rendering.
mod texfunc id
4+ xpert ypert zpert funcfile transform
0
n A1 A2 .. An
mod texdata id
8+ xfunc yfunc zfunc xdfname ydfname zdfname vfname x0 x1 .. xf
0
n A1 A2 .. An
mod colorfunc id
4+ red green blue funcfile transform
0
n A1 A2 .. An
mod brightfunc id
0
n A1 A2 .. An
mod colordata id
7+n+
rfunc gfunc bfunc rdatafile gdatafile bdatafile
0
m A1 A2 .. Am
mod brightdata id
3+n+
func datafile
0
m A1 A2 .. Am
mod colorpict id
7+
rfunc gfunc bfunc pictfile
funcfile u v transform
0
m A1 A2 .. Am
mod colortext id
2 fontfile textfile
0
15+
Ox Oy Oz
Rx Ry Rz
Dx Dy Dz
rfore gfore bfore
rback gback bback
[spacing]
or:
mod colortext id
2+N fontfile . This is a line with N words ...
0
15+
Ox Oy Oz
Rx Ry Rz
Dx Dy Dz
rfore gfore bfore
rback gback bback
[spacing]
mod brighttext id
2 fontfile textfile
0
11+
Ox Oy Oz
Rx Ry Rz
Dx Dy Dz
foreground background
[spacing]
or:
mod brighttext id
0
11+
Ox Oy Oz
Rx Ry Rz
Dx Dy Dz
[spacing]
By default, a uniform spacing algorithm is used that guarantees every character will appear in a precisely determined position. Unfortunately, such a scheme results in rather unattractive and difficult to read text with most fonts. The optional spacing value defines the distance between characters for proportional spacing. A positive value selects a spacing algorithm that preserves right margins and indentation, but does not provide the ultimate in proportionally spaced text. A negative value insures that characters are properly spaced, but the placement of words then varies unpredictably. The choice depends on the relative importance of spacing versus formatting. When presenting a section of formatted text, a positive spacing value is usually preferred. A single line of text will often be accompanied by a negative spacing value. A section of text meant to depict a picture, perhaps using a special purpose font such as hexbit4x1.fnt, calls for uniform spacing. Reasonable magnitudes for proportional spacing are between 0.1 (for tightly spaced characters) and 0.3 (for wide spacing).
mod mixfunc id
4+ foreground background vname funcfile transform
0
n A1 A2 .. An
Foreground and background are modifier names that must be
defined earlier in the scene description.
If one of these is a material, then
the modifier of the mixfunc must be "void".
(Either the foreground or background modifier may be "void",
which serves as a form of opacity control when used with a material.)
Vname is the coefficient defined in funcfile that determines the influence of foreground.
The background coefficient is always (1-vname).
mod mixdata id
5+n+
foreground background func datafile
0
m A1 A2 .. Am
mod mixpict id
7+
foreground background func pictfile
0
m A1 A2 .. Am
The mixing coefficient function "func" takes three arguments, the red, green and blue values corresponding to the pixel at (u,v).
mod mixtext id
4 foreground background fontfile textfile
0
9+
Ox Oy Oz
Rx Ry Rz
Dx Dy Dz
[spacing]
or:
mod mixtext id
4+N
foreground background fontfile .
0
9+
Ox Oy Oz
Rx Ry Rz
Dx Dy Dz
[spacing]
This is a comment, enclosed in curly braces.
{Comments can be nested.}
{ standard expressions use +,-,*,/,^,(,) }
vname = Ny * func(A1) ;
{ constants are defined with a colon }
const : sqrt(PI/2) ;
{ user-defined functions add to library }
func(x) = 5 + A1*sin(x/3) ;
{ functions may be passed and recursive }
rfunc(f,x) = if(x,f(x),f(-x)*rfunc(f,x+1)) ;
{ constant functions may also be defined }
cfunc(x) : 10*x / sqrt(x) ;
Many variables and functions are already defined by the program, and they are listed in the file rayinit.cal.
The following variables are particularly important:
Dx, Dy, Dz - incident ray direction
Nx, Ny, Nz - surface normal at intersection point
Px, Py, Pz - intersection point
T - distance from start
Ts - single ray (shadow) distance
Rdot - cosine between ray and normal
arg(0) - number of real arguments
arg(i) - i'th real argument
For mesh objects, the local surface coordinates are available:
Lu, Lv - local (u,v) coordinates
For BRDF types, the following variables are defined as well:
NxP, NyP, NzP - perturbed surface normal
RdotP - perturbed dot product
CrP, CgP, CbP - perturbed material color
A unique context is set up for each file so
that the same variable may appear in different
function files without conflict.
The variables listed above and any others defined in
rayinit.cal are available globally.
If no file is needed by a given primitive because all
the required variables are global,
a period (`.') can be given in place of the file name.
It is also possible to give an expression instead
of a straight variable name in a scene file.
Functions (requiring parameters) must be given
as names and not as expressions.
Constant expressions are used as an optimization in function files. They are replaced wherever they occur in an expression by their value. Constant expressions are evaluated only once, so they must not contain any variables or values that can change, such as the ray variables Px and Ny or the primitive argument function arg(). All the math library functions such as sqrt() and cos() have the constant attribute, so they will be replaced by immediate values whenever they are given constant arguments. Thus, the subexpression cos(PI*sqrt(2)) is immediately replaced by its value, -.266255342, and does not cause any additional overhead in the calculation.
It is generally a good idea to define constants and variables before they are referred to in a function file. Although evaluation does not take place until later, the interpreter does variable scoping and constant subexpression evaluation based on what it has compiled already. For example, a variable that is defined globally in rayinit.cal then referenced in the local context of a function file cannot subsequently be redefined in the same file because the compiler has already determined the scope of the referenced variable as global. To avoid such conflicts, one can state the scope of a variable explicitly by preceding the variable name with a context mark (a back-quote) for a local variable, or following the name with a context mark for a global variable.
N
beg1 end1 m1
0 0 m2 x2.1 x2.2 x2.3 x2.4 .. x2.m2
begN endN mN
DATA, later dimensions changing faster.
N is the number of dimensions.
For each dimension, the beginning and ending coordinate values and the dimension size is given.
Alternatively, individual coordinate values can be given when the points are not evenly spaced.
These values must either be increasing or decreasing monotonically.
The data is m1*m2*...*mN real numbers in ASCII form.
Comments may appear anywhere in the file, beginning with a pound
sign ('#') and continuing to the end of line.
code n
x0 y0
x1 y1
xn yn
The ASCII codes can appear in any order. N is the number of vertices, and the last is automatically connected to the first.
Separate polygonal sections are joined by coincident sides.
The character coordinate system is a square with lower left corner at (0,0), lower right at (255,0) and upper right at (255,255).
The image generating programs use an octree to efficiently trace rays through the scene. An octree subdivides space into nested octants which contain sets of surfaces. In RADIANCE, an octree is created from a scene description by oconv. The details of this process are not important, but the octree will serve as input to the ray-tracing programs and directs the use of a scene description.
A number of filters are available for manipulating picture files:
Pictures may be displayed directly under X11 using the program ximage, or converted a standard image format using one of the following translators:
The Radiance Software License, Version 1.0
Copyright (c) 1990 - 2010 The Regents of the University of California,
through Lawrence Berkeley National Laboratory. All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
1. Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in
the documentation and/or other materials provided with the
distribution.
3. The end-user documentation included with the redistribution,
if any, must include the following acknowledgment:
"This product includes Radiance software
(http://radsite.lbl.gov/)
developed by the Lawrence Berkeley National Laboratory
(http://www.lbl.gov/)."
Alternately, this acknowledgment may appear in the software itself,
if and wherever such third-party acknowledgments normally appear.
4. The names "Radiance," "Lawrence Berkeley National Laboratory"
and "The Regents of the University of California" must
not be used to endorse or promote products derived from this
software without prior written permission. For written
permission, please contact [email protected].
5. Products derived from this software may not be called "Radiance",
nor may "Radiance" appear in their name, without prior written
permission of Lawrence Berkeley National Laboratory.
THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
SUCH DAMAGE.
Additional work was sponsored by the Swiss federal government under the Swiss LUMEN Project and was carried out in the Laboratoire d'Energie Solaire (LESO Group) at the Ecole Polytechnique Federale de Lausanne (EPFL University) in Lausanne, Switzerland.
See the RADIANCE Reference Materials page for additional information.
SURFACES MATERIALS TEXTURES PATTERNS MIXTURES
Source Light Texfunc Colorfunc Mixfunc Sphere Illum Texdata Brightfunc Mixdata Bubble Glow Colordata Mixtext Polygon Spotlight Brightdata Cone Mirror Colorpict Cup Prism1 Colortext Cylinder Prism2 Brighttext Tube Plastic Ring Metal Instance Trans Mesh Plastic2 Metal2 Trans2 Mist Dielectric Interface Glass Plasfunc Metfunc Transfunc BRTDfunc Plasdata Metdata Transdata BSDF Antimatter
