root/Development/ray/doc/ray.html
Revision 1.44 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jul 22 20:38:43 2025 UTC (3 months, 3 weeks ago) by greg
CVS Tags: rad6R0
Changes since 1.43: +2 -4 lines
Diff to previous 1.43 , to selected 1.42
Revision 1.43 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jul 22 19:43:59 2025 UTC (3 months, 3 weeks ago) by greg
Changes since 1.42: +40 -45 lines
Diff to previous 1.42
chore: Updates for 6.0 official release
Revision 1.42 - (view) (download) (as text) (annotate) - [selected]
Fri May 30 16:35:52 2025 UTC (5 months, 2 weeks ago) by greg
Changes since 1.41: +19 -17 lines
Diff to previous 1.41
docs: Improved wording on new mirror material behavior
Revision 1.41 - (view) (download) (as text) (annotate) - [select for diffs]
Thu May 29 16:42:28 2025 UTC (5 months, 2 weeks ago) by greg
Changes since 1.40: +21 -1 lines
Diff to previous 1.40 , to selected 1.42
fix: Updated behavior of "mirror" type to handle indirect transmission, thanks to Jon Sargent
Revision 1.40 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Dec 13 18:17:17 2024 UTC (11 months ago) by greg
Changes since 1.39: +56 -1 lines
Diff to previous 1.39 , to selected 1.42
docs: Added missing paragraph marks after preformatted block -- does it matter?
Revision 1.39 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Dec 9 19:21:38 2024 UTC (11 months ago) by greg
Changes since 1.38: +57 -1 lines
Diff to previous 1.38 , to selected 1.42
docs: Added description of new WGMDfunc material
Revision 1.38 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Dec 13 23:26:16 2023 UTC (23 months ago) by greg
Changes since 1.37: +56 -1 lines
Diff to previous 1.37 , to selected 1.42
feat(rpict,rvu,rtrace,rcontrib): Added "specdata" and "specpict" pattern primitives
Revision 1.37 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Dec 12 20:25:22 2023 UTC (23 months ago) by greg
Changes since 1.36: +2 -2 lines
Diff to previous 1.36 , to selected 1.42
docs: renamed function
Revision 1.36 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Dec 12 20:12:47 2023 UTC (23 months ago) by greg
Changes since 1.35: +3 -3 lines
Diff to previous 1.35 , to selected 1.42
docs: wording fixes
Revision 1.35 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Nov 17 20:02:07 2023 UTC (23 months, 3 weeks ago) by greg
Changes since 1.34: +3 -5 lines
Diff to previous 1.34 , to selected 1.42
Revision 1.34 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Nov 16 21:57:39 2023 UTC (23 months, 4 weeks ago) by greg
Changes since 1.33: +4 -4 lines
Diff to previous 1.33 , to selected 1.42
docs: minor wording improvements
Revision 1.33 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Nov 15 18:28:10 2023 UTC (23 months, 4 weeks ago) by greg
Changes since 1.32: +97 -3 lines
Diff to previous 1.32 , to selected 1.42
docs: Updated manuals with new hyperspectral pattern primitives
Revision 1.32 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Nov 3 17:41:27 2023 UTC (2 years ago) by greg
Changes since 1.31: +8 -1 lines
Diff to previous 1.31 , to selected 1.42
chore: updating for official 5.4 release
Revision 1.31 - (view) (download) (as text) (annotate) - [select for diffs]
Thu May 11 17:18:39 2023 UTC (2 years, 6 months ago) by greg
Changes since 1.30: +3 -1 lines
Diff to previous 1.30 , to selected 1.42
docs: Added note about setting of ashik2 parameters
Revision 1.30 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Nov 16 23:12:22 2021 UTC (3 years, 11 months ago) by greg
Changes since 1.29: +5 -5 lines
Diff to previous 1.29 , to selected 1.42
docs: updating copyright dates and minor fixes
Revision 1.29 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Sep 3 15:46:32 2020 UTC (5 years, 2 months ago) by greg
Changes since 1.28: +3 -3 lines
Diff to previous 1.28 , to selected 1.42
chore: follow-up to official 5.3 release, working on 5.4 alpha now...
Revision 1.28 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Oct 9 17:57:17 2018 UTC (7 years, 1 month ago) by greg
Changes since 1.27: +3 -3 lines
Diff to previous 1.27 , to selected 1.42
Moving on to version 5.3a
Revision 1.27 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Oct 8 20:04:09 2018 UTC (7 years, 1 month ago) by greg
Changes since 1.26: +27 -1 lines
Diff to previous 1.26 , to selected 1.42
Preparation for 5.2 release
Revision 1.26 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jun 26 14:42:18 2018 UTC (7 years, 4 months ago) by greg
Changes since 1.25: +8 -7 lines
Diff to previous 1.25 , to selected 1.42
Decided to go with "aBSDF" for "aperture BSDF" rather than "sBSDF"
Revision 1.25 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jun 25 20:49:10 2018 UTC (7 years, 4 months ago) by greg
Changes since 1.24: +32 -1 lines
Diff to previous 1.24 , to selected 1.42
Revision 1.24 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Aug 26 16:07:22 2017 UTC (8 years, 2 months ago) by greg
Diff to previous 1.23 , to selected 1.42
Revision 1.23 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jul 10 23:41:37 2016 UTC (9 years, 4 months ago) by greg
Changes since 1.22: +24 -2 lines
Diff to previous 1.22 , to selected 1.42
Added missing definition of ashik2 material type
Revision 1.22 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Dec 1 16:58:16 2015 UTC (9 years, 11 months ago) by greg
Diff to previous 1.21 , to selected 1.42
Added caveat about (virtual) source materials
Revision 1.21 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Sep 25 23:01:12 2015 UTC (10 years, 1 month ago) by greg
Changes since 1.20: +3 -3 lines
Diff to previous 1.20 , to selected 1.42
Starting now on 5.1 alpha
Revision 1.20 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Sep 18 18:29:00 2015 UTC (10 years, 1 month ago) by greg
Changes since 1.19: +3 -2 lines
Diff to previous 1.19 , to selected 1.42
Changes for 5.0 release
Revision 1.19 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jul 31 18:32:41 2014 UTC (11 years, 3 months ago) by greg
Changes since 1.18: +12 -11 lines
Diff to previous 1.18 , to selected 1.42
Preparation for 4.2 release
Revision 1.18 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Oct 17 21:53:55 2011 UTC (14 years, 1 month ago) by greg
Diff to previous 1.17 , to selected 1.42
Fixed Leukos citation
Revision 1.17 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jul 15 20:59:36 2011 UTC (14 years, 4 months ago) by greg
Changes since 1.16: +4 -2 lines
Diff to previous 1.16 , to selected 1.42
Added web link
Revision 1.16 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jul 15 17:47:33 2011 UTC (14 years, 4 months ago) by greg
Diff to previous 1.15 , to selected 1.42
Added missing comma
Revision 1.15 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jul 15 17:45:46 2011 UTC (14 years, 4 months ago) by greg
Changes since 1.14: +36 -31 lines
Diff to previous 1.14 , to selected 1.42
Added recent IES article to reference list
Revision 1.14 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jun 22 00:12:43 2011 UTC (14 years, 4 months ago) by greg
Diff to previous 1.13 , to selected 1.42
Removed emphasis tag (duh-oh)
Revision 1.13 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jun 22 00:12:06 2011 UTC (14 years, 4 months ago) by greg
Diff to previous 1.12 , to selected 1.42
Fixed emphasis tag
Revision 1.12 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jun 21 23:58:00 2011 UTC (14 years, 4 months ago) by greg
Changes since 1.11: +36 -30 lines
Diff to previous 1.11 , to selected 1.42
Added mention of thickness sign for BSDF material
Revision 1.11 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Apr 6 22:03:04 2011 UTC (14 years, 7 months ago) by greg
Changes since 1.10: +4 -4 lines
Diff to previous 1.10 , to selected 1.42
Fixed minor HTML errors
Revision 1.10 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Apr 6 22:00:46 2011 UTC (14 years, 7 months ago) by greg
Changes since 1.9: +75 -2 lines
Diff to previous 1.9 , to selected 1.42
Added new BSDF type
Revision 1.9 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Mar 12 18:43:30 2010 UTC (15 years, 8 months ago) by greg
Changes since 1.8: +10 -14 lines
Diff to previous 1.8 , to selected 1.42
Incorporated other changes
Fri Mar 12 18:34:43 2010 UTC (15 years, 8 months ago) by greg
Diff to previous 1.7 , to selected 1.42
Fixed misspelling of Henyey's name
Revision 1.7 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Oct 17 21:52:43 2006 UTC (19 years, 1 month ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 1.6: +8 -3 lines
Diff to previous 1.6 , to selected 1.42
Version changes for 3.8 release
Wed May 10 19:50:30 2006 UTC (19 years, 6 months ago) by greg
Changes since 1.5: +3 -3 lines
Diff to previous 1.5 , to selected 1.42
Fixed language uses ("virtual" vs. "secondary" light sources)
Sun Jul 24 21:05:08 2005 UTC (20 years, 3 months ago) by greg
Diff to previous 1.4 , to selected 1.42
Updated version in Radiance manual
Thu Oct 21 16:16:14 2004 UTC (21 years ago) by greg
Changes since 1.3: +3 -5 lines
Diff to previous 1.3 , to selected 1.42
Update for 3.6 official release
Thu Jan 1 19:31:44 2004 UTC (21 years, 10 months ago) by greg
Diff to previous 1.2 , to selected 1.42
Revision 1.2 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Apr 7 15:43:08 2003 UTC (22 years, 7 months ago) by greg
Changes since 1.1: +13 -13 lines
Diff to previous 1.1 , to selected 1.42
Updated man pages and fixed ages old bug in conversion of negative colors
Sat Mar 15 17:58:16 2003 UTC (22 years, 8 months ago) by greg
Diff to selected 1.42
Links to HEAD: (view) (download) (as text) (annotate) Links to rad6R0: (view) (download) (as text) (annotate)
