| 1 |
greg |
1.1 |
<html>
| 2 |
greg |
1.47 |
<!-- RCSid $Id: ray.html,v 1.46 2025/08/14 18:16:17 greg Exp $ -->
| 3 |
greg |
1.1 |
<head>
| 4 |
<title>
| 5 |
greg |
1.45 |
The RADIANCE 6.1 Synthetic Imaging System
| 6 |
greg |
1.1 |
</title>
| 7 |
</head>
| 8 |
<body>
| 9 |
| 10 |
<p>
| 11 |
| 12 |
<h1>
| 13 |
greg |
1.45 |
| 14 |
greg |
1.1 |
</h1>
| 15 |
| 16 |
<p>
| 17 |
| 18 |
greg |
1.4 |
Building Technologies Program<br>
| 19 |
greg |
1.1 |
Lawrence Berkeley National Laboratory<br>
| 20 |
1 Cyclotron Rd., 90-3111<br>
| 21 |
Berkeley, CA 94720<br>
| 22 |
<a HREF="http://radsite.lbl.gov/radiance"</a>
| 23 |
http://radsite.lbl.gov/radiance<br>
| 24 |
| 25 |
<p>
| 26 |
<hr>
| 27 |
| 28 |
<h2>
| 29 |
<a NAME="Overview">Overview</a>
| 30 |
</h2>
| 31 |
<ol>
| 32 |
<li><a HREF="#Intro">Introduction</a><!P>
| 33 |
<li><a HREF="#Scene">Scene Description</a><!P>
| 34 |
<ol>
| 35 |
<li><a HREF="#Primitive"> Primitive Types</a>
| 36 |
<ol>
| 37 |
<li><a HREF="#Surfaces">Surfaces</a>
| 38 |
<li><a HREF="#Materials">Materials</a>
| 39 |
<li><a HREF="#Textures">Textures</a>
| 40 |
<li><a HREF="#Patterns">Patterns</a>
| 41 |
<li><a HREF="#Mixtures">Mixtures</a>
| 42 |
</ol><!P>
| 43 |
<li><a HREF="#Auxiliary">Auxiliary Files</a>
| 44 |
<ol>
| 45 |
<li><a HREF="#Function">Function Files</a>
| 46 |
<li><a HREF="#Data">Data Files</a>
| 47 |
<li><a HREF="#Font">Font Files</a>
| 48 |
</ol><!P>
| 49 |
<li><a HREF="#Generators">Generators</a>
| 50 |
</ol><!P>
| 51 |
<li><a HREF="#Image">Image Generation</a><!P>
| 52 |
<li><a HREF="#License">License</a><!P>
| 53 |
<li><a HREF="#Ack">Acknowledgements</a><!P>
| 54 |
<li><a HREF="#Ref">References</a><!P>
| 55 |
<li><a HREF="#Index">Types Index</a><!P>
| 56 |
</ol>
| 57 |
| 58 |
<p>
| 59 |
<hr>
| 60 |
| 61 |
<h2>
| 62 |
<a NAME="Intro">1. Introduction</a>
| 63 |
</h2>
| 64 |
| 65 |
RADIANCE was developed as a research tool for predicting
| 66 |
the distribution of visible radiation in illuminated spaces.
| 67 |
It takes as input a three-dimensional geometric model
| 68 |
of the physical environment, and produces a map of
| 69 |
spectral radiance values in a color image.
| 70 |
The technique of ray-tracing follows light backwards
| 71 |
from the image plane to the source(s).
| 72 |
Because it can produce realistic images from a
| 73 |
simple description, RADIANCE has a wide range of applications
| 74 |
in graphic arts, lighting design,
| 75 |
computer-aided engineering and architecture.
| 76 |
| 77 |
<p>
| 78 |
greg |
1.44 |
<img SRC="diagram1.png">
| 79 |
greg |
1.1 |
<p>
| 80 |
The diagram in Figure 1 shows the flow between programs (boxes) and data
| 81 |
(ovals).
| 82 |
The central program is <i>rpict</i>, which produces a picture from a scene
| 83 |
description.
| 84 |
greg |
1.30 |
<i>Rvu</i> is a variation of rpict that computes and displays images
| 85 |
greg |
1.1 |
interactively, and rtrace computes single ray values.
| 86 |
Other programs (not shown) connect many of these elements together,
| 87 |
such as the executive programs
| 88 |
<i>rad</i>
| 89 |
and
| 90 |
<i>ranimate</i>,
| 91 |
the interactive rendering program
| 92 |
<i>rholo</i>,
| 93 |
and the animation program
| 94 |
<i>ranimove</i>.
| 95 |
The program
| 96 |
<i>obj2mesh</i>
| 97 |
acts as both a converter and scene compiler, converting a Wavefront .OBJ
| 98 |
file into a compiled mesh octree for efficient rendering.
| 99 |
| 100 |
<p>
| 101 |
A scene description file lists the surfaces and materials
| 102 |
that make up a specific environment.
| 103 |
The current surface types are spheres, polygons, cones, and cylinders.
| 104 |
There is also a composite surface type, called mesh, and a pseudosurface
| 105 |
type, called instance, which facilitates very complex geometries.
| 106 |
Surfaces can be made from materials such as plastic, metal, and glass.
| 107 |
Light sources can be distant disks as well as local spheres, disks
| 108 |
and polygons.
| 109 |
| 110 |
<p>
| 111 |
From a three-dimensional scene description and a specified view,
| 112 |
<i>rpict</i> produces a two-dimensional image.
| 113 |
A picture file is a compressed binary representation of the
| 114 |
pixels in the image.
| 115 |
This picture can be scaled in size and brightness,
| 116 |
anti-aliased, and sent to a graphics output device.
| 117 |
| 118 |
<p>
| 119 |
A header in each picture file lists the program(s)
| 120 |
and parameters that produced it.
| 121 |
This is useful for identifying a picture without having to display it.
| 122 |
The information can be read by the program <i>getinfo</i>.
| 123 |
| 124 |
<p>
| 125 |
<hr>
| 126 |
| 127 |
<h2>
| 128 |
<a name="Scene">2. Scene Description</a>
| 129 |
</h2>
| 130 |
| 131 |
A scene description file represents a three-dimensional physical environment in Cartesian (rectilinear) world coordinates.
| 132 |
It is stored as ASCII text, with the following basic format:
| 133 |
| 134 |
<pre>
| 135 |
# comment
| 136 |
| 137 |
modifier type identifier
| 138 |
n S1 S2 "S 3" .. Sn
| 139 |
0
| 140 |
m R1 R2 R3 .. Rm
| 141 |
| 142 |
modifier alias identifier reference
| 143 |
| 144 |
! command
| 145 |
| 146 |
| 147 |
</pre>
| 148 |
| 149 |
greg |
1.40 |
<p>
| 150 |
| 151 |
greg |
1.1 |
A comment line begins with a pound sign, `#'.
| 152 |
| 153 |
<p>
| 154 |
The <a NAME="scene_desc">scene description primitives</a>
| 155 |
all have the same general format, and can be either surfaces or modifiers.
| 156 |
A primitive has a modifier, a type, and an identifier.
| 157 |
<p>
| 158 |
A <a NAME="modifier"><b>modifier</b></a> is either the
| 159 |
identifier of a previously defined primitive, or "void".
| 160 |
<br>
| 161 |
[ The most recent definition of a modifier is the
| 162 |
one used, and later definitions do not cause relinking
| 163 |
of loaded primitives.
| 164 |
Thus, the same identifier may be used repeatedly,
| 165 |
and each new definition will apply to the primitives following it. ]
| 166 |
<p>
| 167 |
An <a NAME="identifier"><b>identifier</b></a> can be any string
| 168 |
(i.e., any sequence of non-white characters).
| 169 |
<p>
| 170 |
The arguments associated with a primitive can be strings or real numbers.
| 171 |
<ul>
| 172 |
<li> The first integer following the identifier is the number of <b>string arguments</b>,
| 173 |
and it is followed by the arguments themselves (separated by white space or enclosed in quotes).
| 174 |
<li> The next integer is the number of integer arguments, and is followed by the <b>integer arguments</b>.
| 175 |
(There are currently no primitives that use them, however.)
| 176 |
<li> The next integer is the real argument count, and it is followed by the <b>real arguments</b>.
| 177 |
</ul>
| 178 |
| 179 |
<p>
| 180 |
An <a NAME="alias"><b>alias</b></a> gets its type and arguments from
| 181 |
a previously defined primitive.
| 182 |
This is useful when the same material is
| 183 |
used with a different modifier, or as a convenient naming mechanism.
| 184 |
The reserved modifier name "inherit" may be used to specificy that
| 185 |
an alias will inherit its modifier from the original.
| 186 |
Surfaces cannot be aliased.
| 187 |
| 188 |
<p>
| 189 |
A line beginning with an exclamation point, `!',
| 190 |
is interpreted as a command.
| 191 |
It is executed by the shell, and its output is read as input to the program.
| 192 |
The command must not try to read from its standard input, or confusion
| 193 |
will result.
| 194 |
A command may be continued over multiple lines using a
| 195 |
backslash, `\', to escape the newline.
| 196 |
| 197 |
<p>
| 198 |
White space is generally ignored, except as a separator.
| 199 |
The exception is the newline character after a command or comment.
| 200 |
Commands, comments and primitives may appear in any
| 201 |
combination, so long as they are not intermingled.
| 202 |
| 203 |
<p>
| 204 |
<hr>
| 205 |
| 206 |
<h3>
| 207 |
<a NAME="Primitive">2.1. Primitive Types</a>
| 208 |
</h3>
| 209 |
| 210 |
Primitives can be <a HREF="#Surfaces">surfaces</a>,
| 211 |
<a HREF="#Materials">materials</a>,
| 212 |
<a HREF="#Textures">textures</a> or
| 213 |
<a HREF="#Patterns">patterns</a>.
| 214 |
Modifiers can be <a HREF="#Materials">materials</a>,
| 215 |
<a HREF="#Mixtures">mixtures</a>,
| 216 |
<a HREF="#Textures">textures</a> or <a HREF="#Patterns">patterns</a>.
| 217 |
Simple surfaces must have one material in their modifier list.
| 218 |
| 219 |
<p>
| 220 |
<hr>
| 221 |
| 222 |
<h4>
| 223 |
<a NAME="Surfaces">2.1.1. Surfaces</a>
| 224 |
</h4>
| 225 |
<dl>
| 226 |
| 227 |
A scene description will consist mostly of surfaces.
| 228 |
The basic types are given below.
| 229 |
| 230 |
<p>
| 231 |
| 232 |
<dt>
| 233 |
<a NAME="Source">
| 234 |
<b>Source </b>
| 235 |
</a>
| 236 |
<dd>
| 237 |
A source is not really a surface, but a solid angle.
| 238 |
It is used for specifying light sources that are very distant.
| 239 |
The direction to the center of the source and the number of degrees subtended by its disk are given as follows:
| 240 |
| 241 |
<pre>
| 242 |
mod source id
| 243 |
0
| 244 |
0
| 245 |
4 xdir ydir zdir angle
| 246 |
</pre>
| 247 |
| 248 |
<p>
| 249 |
| 250 |
<dt>
| 251 |
<a NAME="Sphere">
| 252 |
<b>Sphere</b>
| 253 |
</a>
| 254 |
<dd>
| 255 |
A sphere is given by its center and radius:
| 256 |
| 257 |
<pre>
| 258 |
mod sphere id
| 259 |
0
| 260 |
0
| 261 |
4 xcent ycent zcent radius
| 262 |
</pre>
| 263 |
| 264 |
<p>
| 265 |
| 266 |
<dt>
| 267 |
<a NAME="Bubble">
| 268 |
<b>Bubble</b>
| 269 |
</a>
| 270 |
| 271 |
<dd>
| 272 |
A bubble is simply a sphere whose surface normal points inward.
| 273 |
| 274 |
<p>
| 275 |
| 276 |
<dt>
| 277 |
<a NAME="Polygon">
| 278 |
<b>Polygon</b>
| 279 |
</a>
| 280 |
<dd>
| 281 |
A polygon is given by a list of three-dimensional vertices,
| 282 |
which are ordered counter-clockwise as viewed from the
| 283 |
front side (into the surface normal).
| 284 |
The last vertex is automatically connected to the first.
| 285 |
Holes are represented in polygons as interior vertices
| 286 |
connected to the outer perimeter by coincident edges (seams).
| 287 |
| 288 |
<pre>
| 289 |
mod polygon id
| 290 |
0
| 291 |
0
| 292 |
3n
| 293 |
x1 y1 z1
| 294 |
x2 y2 z2
| 295 |
| 296 |
xn yn zn
| 297 |
</pre>
| 298 |
| 299 |
<p>
| 300 |
| 301 |
<dt>
| 302 |
<a NAME="Cone">
| 303 |
<b>Cone</b>
| 304 |
</a>
| 305 |
<dd>
| 306 |
A cone is a megaphone-shaped object.
| 307 |
It is truncated by two planes perpendicular to its axis,
| 308 |
and one of its ends may come to a point.
| 309 |
It is given as two axis endpoints, and the starting and ending radii:
| 310 |
| 311 |
<pre>
| 312 |
mod cone id
| 313 |
0
| 314 |
0
| 315 |
8
| 316 |
x0 y0 z0
| 317 |
x1 y1 z1
| 318 |
r0 r1
| 319 |
</pre>
| 320 |
| 321 |
<p>
| 322 |
| 323 |
<dt>
| 324 |
<a NAME="Cup">
| 325 |
<b>Cup</b>
| 326 |
</a>
| 327 |
<dd>
| 328 |
A cup is an inverted <a HREF="#Cone">cone</a> (i.e., has an
| 329 |
inward surface normal).
| 330 |
| 331 |
<p>
| 332 |
| 333 |
<dt>
| 334 |
<a NAME="Cylinder">
| 335 |
<b>Cylinder</b>
| 336 |
</a>
| 337 |
<dd>
| 338 |
A cylinder is like a <a HREF="#Cone">cone</a>, but its
| 339 |
starting and ending radii are equal.
| 340 |
| 341 |
<pre>
| 342 |
mod cylinder id
| 343 |
0
| 344 |
0
| 345 |
7
| 346 |
x0 y0 z0
| 347 |
x1 y1 z1
| 348 |
rad
| 349 |
</pre>
| 350 |
| 351 |
<p>
| 352 |
| 353 |
<dt>
| 354 |
<a NAME="Tube">
| 355 |
<b>Tube</b>
| 356 |
</a>
| 357 |
<dd>
| 358 |
A tube is an inverted <a HREF="#Cylinder">cylinder</a>.
| 359 |
| 360 |
<p>
| 361 |
| 362 |
<dt>
| 363 |
<a NAME="Ring">
| 364 |
<b>Ring</b>
| 365 |
</a>
| 366 |
<dd>
| 367 |
A ring is a circular disk given by its center,
| 368 |
surface normal, and inner and outer radii:
| 369 |
| 370 |
<pre>
| 371 |
mod ring id
| 372 |
0
| 373 |
0
| 374 |
8
| 375 |
xcent ycent zcent
| 376 |
xdir ydir zdir
| 377 |
r0 r1
| 378 |
</pre>
| 379 |
| 380 |
<p>
| 381 |
| 382 |
<dt>
| 383 |
<a NAME="Instance">
| 384 |
<b>Instance</b>
| 385 |
</a>
| 386 |
<dd>
| 387 |
An instance is a compound surface, given
| 388 |
by the contents of an octree file (created by oconv).
| 389 |
| 390 |
<pre>
| 391 |
mod instance id
| 392 |
1+ octree transform
| 393 |
0
| 394 |
0
| 395 |
</pre>
| 396 |
| 397 |
greg |
1.40 |
<p>
| 398 |
greg |
1.1 |
If the modifier is "void", then surfaces will
| 399 |
use the modifiers given in the original description.
| 400 |
Otherwise, the modifier specified is used in their place.
| 401 |
The transform moves the octree to the desired location in the scene.
| 402 |
Multiple instances using the same octree take
| 403 |
little extra memory, hence very complex
| 404 |
descriptions can be rendered using this primitive.
| 405 |
| 406 |
<p>
| 407 |
There are a number of important limitations to be aware of
| 408 |
when using instances.
| 409 |
First, the scene description used to generate the octree must
| 410 |
stand on its own, without referring to modifiers in the
| 411 |
parent description.
| 412 |
This is necessary for oconv to create the octree.
| 413 |
Second, light sources in the octree will not be
| 414 |
incorporated correctly in the calculation,
| 415 |
and they are not recommended.
| 416 |
Finally, there is no advantage (other than
| 417 |
convenience) to using a single instance of an octree,
| 418 |
or an octree containing only a few surfaces.
| 419 |
An <a HREF="../man_html/xform.1.html">xform</a> command
| 420 |
on the subordinate description is prefered in such cases.
| 421 |
</dl>
| 422 |
| 423 |
<p>
| 424 |
| 425 |
<dt>
| 426 |
<a NAME="Mesh">
| 427 |
<b>Mesh</b>
| 428 |
</a>
| 429 |
<dd>
| 430 |
A mesh is a compound surface, made up of many triangles and
| 431 |
an octree data structure to accelerate ray intersection.
| 432 |
It is typically converted from a Wavefront .OBJ file using the
| 433 |
<i>obj2mesh</i> program.
| 434 |
| 435 |
<pre>
| 436 |
mod mesh id
| 437 |
1+ meshfile transform
| 438 |
0
| 439 |
0
| 440 |
</pre>
| 441 |
| 442 |
greg |
1.40 |
<p>
| 443 |
| 444 |
greg |
1.1 |
| 445 |
use the modifiers given in the original mesh description.
| 446 |
| 447 |
The transform moves the mesh to the desired location in the scene.
| 448 |
Multiple instances using the same meshfile take little extra memory,
| 449 |
and the compiled mesh itself takes much less space than individual
| 450 |
polygons would.
| 451 |
In the case of an unsmoothed mesh, using the mesh primitive reduces
| 452 |
memory requirements by a factor of 30 relative to individual triangles.
| 453 |
If a mesh has smoothed surfaces, we save a factor of 50 or more,
| 454 |
permitting very detailed geometries that would otherwise exhaust the
| 455 |
available memory.
| 456 |
In addition, the mesh primitive can have associated (u,v) coordinates
| 457 |
for pattern and texture mapping.
| 458 |
These are made available to function files via the Lu and Lv variables.
| 459 |
| 460 |
</dl>
| 461 |
| 462 |
<p>
| 463 |
<hr>
| 464 |
| 465 |
<h4>
| 466 |
<a NAME="Materials">2.1.2. Materials</a>
| 467 |
</h4>
| 468 |
| 469 |
A material defines the way light interacts with a surface. The basic types are given below.
| 470 |
| 471 |
<p>
| 472 |
| 473 |
<dl>
| 474 |
| 475 |
<dt>
| 476 |
<a NAME="Light">
| 477 |
<b>Light</b>
| 478 |
</a>
| 479 |
<dd>
| 480 |
Light is the basic material for self-luminous surfaces (i.e.,
| 481 |
light sources).
| 482 |
In addition to the <a HREF="#Source">source</a> surface type,
| 483 |
<a HREF="#Sphere">spheres</a>,
| 484 |
discs (<a HREF="#Ring">rings</a> with zero inner radius),
| 485 |
<a HREF="#Cylinder">cylinders</a> (provided they are long enough), and <a HREF="#Polygon">polygons</a> can act as light sources.
| 486 |
Polygons work best when they are rectangular.
| 487 |
Cones cannot be used at this time.
| 488 |
A pattern may be used to specify a light output distribution.
| 489 |
Light is defined simply as a RGB radiance value (watts/steradian/m2):
| 490 |
| 491 |
<pre>
| 492 |
mod light id
| 493 |
0
| 494 |
0
| 495 |
3 red green blue
| 496 |
</pre>
| 497 |
| 498 |
<p>
| 499 |
| 500 |
<dt>
| 501 |
<a NAME="Illum">
| 502 |
<b>Illum</b>
| 503 |
</a>
| 504 |
| 505 |
<dd>
| 506 |
Illum is used for secondary light sources with broad distributions.
| 507 |
A secondary light source is treated like any other light source, except when viewed directly.
| 508 |
It then acts like it is made of a different material (indicated by
| 509 |
the string argument), or becomes invisible (if no string argument is given,
| 510 |
or the argument is "void").
| 511 |
Secondary sources are useful when modeling windows or brightly illuminated surfaces.
| 512 |
| 513 |
<pre>
| 514 |
mod illum id
| 515 |
1 material
| 516 |
0
| 517 |
3 red green blue
| 518 |
</pre>
| 519 |
| 520 |
<p>
| 521 |
| 522 |
<dt>
| 523 |
<a NAME="Glow">
| 524 |
<b>Glow</b>
| 525 |
</a>
| 526 |
| 527 |
<dd>
| 528 |
Glow is used for surfaces that are self-luminous, but limited in their effect.
| 529 |
In addition to the radiance value, a maximum radius for shadow testing is given:
| 530 |
| 531 |
<pre>
| 532 |
mod glow id
| 533 |
0
| 534 |
0
| 535 |
4 red green blue maxrad
| 536 |
</pre>
| 537 |
| 538 |
greg |
1.40 |
<p>
| 539 |
greg |
1.1 |
If maxrad is zero, then the surface will never be tested for shadow, although it may participate in an interreflection calculation.
| 540 |
If maxrad is negative, then the surface will never contribute to scene illumination.
| 541 |
Glow sources will never illuminate objects on the other side of an illum surface.
| 542 |
This provides a convenient way to illuminate local light fixture geometry without overlighting nearby objects.
| 543 |
| 544 |
<p>
| 545 |
| 546 |
<dt>
| 547 |
<a NAME="Spotlight">
| 548 |
<b>Spotlight</b>
| 549 |
</a>
| 550 |
| 551 |
<dd>
| 552 |
Spotlight is used for self-luminous surfaces having directed output.
| 553 |
As well as radiance, the full cone angle (in degrees) and orientation (output direction) vector are given.
| 554 |
The length of the orientation vector is the distance of the effective
| 555 |
focus behind the source center (i.e., the focal length).
| 556 |
| 557 |
<pre>
| 558 |
mod spotlight id
| 559 |
0
| 560 |
0
| 561 |
7 red green blue angle xdir ydir zdir
| 562 |
</pre>
| 563 |
| 564 |
<p>
| 565 |
| 566 |
<dt>
| 567 |
<a NAME="Mirror">
| 568 |
<b>Mirror</b>
| 569 |
</a>
| 570 |
| 571 |
<dd>
| 572 |
greg |
1.6 |
Mirror is used for planar surfaces that produce virtual source reflections.
| 573 |
greg |
1.1 |
This material should be used sparingly, as it may cause the light source calculation to blow up if it is applied to many small surfaces.
| 574 |
This material is only supported for flat surfaces such as <a HREF="#Polygon">polygons</a> and <a HREF="#Ring">rings</a>.
| 575 |
The arguments are simply the RGB reflectance values, which should be between 0 and 1.
| 576 |
An optional string argument may be used like the illum type to specify a different material to be used for shading non-source rays.
| 577 |
If this alternate material is given as "void", then the mirror surface will be invisible.
| 578 |
This is only appropriate if the surface hides other (more detailed) geometry with the same overall reflectance.
| 579 |
| 580 |
<pre>
| 581 |
mod mirror id
| 582 |
1 material
| 583 |
0
| 584 |
3 red green blue
| 585 |
</pre>
| 586 |
| 587 |
greg |
1.42 |
While alternate materials that are reflective will appear as normal,
| 588 |
indirect rays will use the mirror's reflectance rather than the
| 589 |
alternate type.
| 590 |
Transmitting materials are an exception, where both transmission and
| 591 |
reflection will use the alternate type for all rays not specifically
| 592 |
targeting virtual light sources.
| 593 |
In this case, it is important that any reflections be purely specular
| 594 |
(mirror-like) and equal to the mirror's reflectivity
| 595 |
to maintain a valid result.
| 596 |
A pure diffuse reflection may be added if desired.
| 597 |
greg |
1.41 |
| 598 |
<p>
| 599 |
| 600 |
greg |
1.42 |
The mirror material type reflects light sources only from the front side
| 601 |
of a surface, regardless of any alternate material.
| 602 |
If virtual source generation is desired on both sides, two coincident
| 603 |
surfaces with opposite normal orientations may be employed to achieve
| 604 |
this effect.
| 605 |
The reflectance and alternate material type may be
| 606 |
different for the overlapped surfaces,
| 607 |
and the two sides will behave accordingly.
| 608 |
greg |
1.41 |
| 609 |
greg |
1.1 |
<p>
| 610 |
| 611 |
<dt>
| 612 |
<a NAME="Prism1">
| 613 |
<b>Prism1</b>
| 614 |
</a>
| 615 |
| 616 |
<dd>
| 617 |
greg |
1.6 |
The prism1 material is for general light redirection from prismatic glazings, generating virtual light sources.
| 618 |
greg |
1.1 |
It can only be used to modify a planar surface
| 619 |
(i.e., a <a HREF="#Polygon">polygon</a> or <a HREF="#Ring">disk</a>)
| 620 |
and should not result in either light concentration or scattering.
| 621 |
The new direction of the ray can be on either side of the material,
| 622 |
greg |
1.6 |
and the definitions must have the correct bidirectional properties to work properly with virtual light sources.
| 623 |
greg |
1.1 |
The arguments give the coefficient for the redirected light and its direction.
| 624 |
| 625 |
<pre>
| 626 |
mod prism1 id
| 627 |
5+ coef dx dy dz funcfile transform
| 628 |
0
| 629 |
n A1 A2 .. An
| 630 |
</pre>
| 631 |
| 632 |
greg |
1.40 |
<p>
| 633 |
| 634 |
greg |
1.1 |
The new direction variables dx, dy and dz need not produce a normalized vector.
| 635 |
For convenience, the variables DxA, DyA and DzA are defined as the normalized direction to the target light source.
| 636 |
See <a HREF="#Function">section 2.2.1</a> on function files for further information.
| 637 |
| 638 |
<p>
| 639 |
| 640 |
<dt>
| 641 |
<a NAME="Prism2">
| 642 |
<b>Prism2</b>
| 643 |
</a>
| 644 |
| 645 |
<dd>
| 646 |
The material prism2 is identical to <a HREF="#Prism1">prism1</a> except that it provides for two ray redirections rather than one.
| 647 |
| 648 |
<pre>
| 649 |
mod prism2 id
| 650 |
9+ coef1 dx1 dy1 dz1 coef2 dx2 dy2 dz2 funcfile transform
| 651 |
0
| 652 |
n A1 A2 .. An
| 653 |
</pre>
| 654 |
| 655 |
<p>
| 656 |
| 657 |
<dt>
| 658 |
<a NAME="Mist">
| 659 |
<b>Mist</b>
| 660 |
</a>
| 661 |
| 662 |
<dd>
| 663 |
Mist is a virtual material used to delineate a volume
| 664 |
of participating atmosphere.
| 665 |
A list of important light sources may be given, along with an
| 666 |
extinction coefficient, scattering albedo and scattering eccentricity
| 667 |
parameter.
| 668 |
The light sources named by the string argument list
| 669 |
will be tested for scattering within the volume.
| 670 |
Sources are identified by name, and virtual light sources may be indicated
| 671 |
by giving the relaying object followed by '>' followed by the source, i.e:
| 672 |
| 673 |
<pre>
| 674 |
3 source1 mirror1>source10 mirror2>mirror1>source3
| 675 |
</pre>
| 676 |
| 677 |
greg |
1.40 |
<p>
| 678 |
greg |
1.1 |
Normally, only one source is given per mist material, and there is an
| 679 |
upper limit of 32 to the total number of active scattering sources.
| 680 |
The extinction coefficient, if given, is added the the global
| 681 |
coefficient set on the command line.
| 682 |
Extinction is in units of 1/distance (distance based on the world coordinates),
| 683 |
and indicates the proportional loss of radiance over one unit distance.
| 684 |
The scattering albedo, if present, will override the global setting within
| 685 |
the volume.
| 686 |
An albedo of 0 0 0 means a perfectly absorbing medium, and an albedo of
| 687 |
1 1 1 means
| 688 |
a perfectly scattering medium (no absorption).
| 689 |
The scattering eccentricity parameter will likewise override the global
| 690 |
setting if it is present.
| 691 |
Scattering eccentricity indicates how much scattered light favors the
| 692 |
greg |
1.8 |
forward direction, as fit by the Henyey-Greenstein function:
| 693 |
greg |
1.1 |
| 694 |
<pre>
| 695 |
P(theta) = (1 - g*g) / (1 + g*g - 2*g*cos(theta))^1.5
| 696 |
</pre>
| 697 |
| 698 |
greg |
1.40 |
<p>
| 699 |
| 700 |
greg |
1.1 |
A perfectly isotropic scattering medium has a g parameter of 0, and
| 701 |
a highly directional material has a g parameter close to 1.
| 702 |
Fits to the g parameter may be found along with typical extinction
| 703 |
coefficients and scattering albedos for various atmospheres and
| 704 |
cloud types in USGS meteorological tables.
| 705 |
(A pattern will be applied to the extinction values.)
| 706 |
| 707 |
<pre>
| 708 |
mod mist id
| 709 |
N src1 src2 .. srcN
| 710 |
0
| 711 |
0|3|6|7 [ rext gext bext [ ralb galb balb [ g ] ] ]
| 712 |
</pre>
| 713 |
| 714 |
greg |
1.40 |
<p>
| 715 |
| 716 |
greg |
1.1 |
There are two usual uses of the mist type.
| 717 |
One is to surround a beam from a spotlight or laser so that it is
| 718 |
visible during rendering.
| 719 |
For this application, it is important to use a <a HREF="#Cone">cone</a>
| 720 |
(or <a HREF="#Cylinder">cylinder</a>) that
| 721 |
is long enough and wide enough to contain the important visible portion.
| 722 |
Light source photometry and intervening objects will have the desired
| 723 |
effect, and crossing beams will result in additive scattering.
| 724 |
For this application, it is best to leave off the real arguments, and
| 725 |
use the global rendering parameters to control the atmosphere.
| 726 |
The second application is to model clouds or other localized media.
| 727 |
Complex boundary geometry may be used to give shape to a uniform medium,
| 728 |
so long as the boundary encloses a proper volume.
| 729 |
Alternatively, a pattern may be used to set the line integral value
| 730 |
through the cloud for a ray entering or exiting a point in a given
| 731 |
direction.
| 732 |
For this application, it is best if cloud volumes do not overlap each other,
| 733 |
and opaque objects contained within them may not be illuminated correctly
| 734 |
unless the line integrals consider enclosed geometry.
| 735 |
| 736 |
<dt>
| 737 |
<a NAME="Plastic">
| 738 |
<b>Plastic</b>
| 739 |
</a>
| 740 |
| 741 |
<dd>
| 742 |
Plastic is a material with uncolored highlights.
| 743 |
It is given by its RGB reflectance, its fraction of specularity, and its roughness value.
| 744 |
Roughness is specified as the rms slope of surface facets.
| 745 |
A value of 0 corresponds to a perfectly smooth surface, and a value of 1 would be a very rough surface.
| 746 |
Specularity fractions greater than 0.1 and roughness values greater than 0.2 are not very realistic.
| 747 |
(A pattern modifying plastic will affect the material color.)
| 748 |
| 749 |
<pre>
| 750 |
mod plastic id
| 751 |
0
| 752 |
0
| 753 |
5 red green blue spec rough
| 754 |
</pre>
| 755 |
| 756 |
<p>
| 757 |
| 758 |
<dt>
| 759 |
<a NAME="Metal">
| 760 |
<b>Metal</b>
| 761 |
</a>
| 762 |
| 763 |
<dd>
| 764 |
Metal is similar to <a HREF="#Plastic">plastic</a>, but specular highlights are modified by the material color.
| 765 |
Specularity of metals is usually .9 or greater.
| 766 |
As for plastic, roughness values above .2 are uncommon.
| 767 |
| 768 |
<p>
| 769 |
| 770 |
<dt>
| 771 |
<a NAME="Trans">
| 772 |
<b>Trans</b>
| 773 |
</a>
| 774 |
| 775 |
<dd>
| 776 |
Trans is a translucent material, similar to <a HREF="#Plastic">plastic</a>.
| 777 |
The transmissivity is the fraction of penetrating light that travels all the way through the material.
| 778 |
The transmitted specular component is the fraction of transmitted light that is not diffusely scattered.
| 779 |
Transmitted and diffusely reflected light is modified by the material color.
| 780 |
Translucent objects are infinitely thin.
| 781 |
| 782 |
<pre>
| 783 |
mod trans id
| 784 |
0
| 785 |
0
| 786 |
7 red green blue spec rough trans tspec
| 787 |
</pre>
| 788 |
| 789 |
<p>
| 790 |
| 791 |
<dt>
| 792 |
<a NAME="Plastic2">
| 793 |
<b>Plastic2</b>
| 794 |
</a>
| 795 |
| 796 |
<dd>
| 797 |
Plastic2 is similar to <a HREF="#Plastic">plastic</a>, but with anisotropic roughness.
| 798 |
This means that highlights in the surface will appear elliptical rather than round.
| 799 |
The orientation of the anisotropy is determined by the unnormalized direction vector ux uy uz.
| 800 |
These three expressions (separated by white space) are evaluated in the context of the function file funcfile.
| 801 |
If no function file is required (i.e., no special variables or functions are required), a period (`.') may be given in its place.
| 802 |
(See the discussion of <a HREF="#Function">Function Files</a> in the Auxiliary Files section).
| 803 |
The urough value defines the roughness along the u vector given projected onto the surface.
| 804 |
The vrough value defines the roughness perpendicular to this vector.
| 805 |
Note that the highlight will be narrower in the direction of the smaller roughness value.
| 806 |
Roughness values of zero are not allowed for efficiency reasons since the behavior would be the same as regular plastic in that case.
| 807 |
| 808 |
<pre>
| 809 |
mod plastic2 id
| 810 |
4+ ux uy uz funcfile transform
| 811 |
0
| 812 |
6 red green blue spec urough vrough
| 813 |
</pre>
| 814 |
| 815 |
<p>
| 816 |
| 817 |
<dt>
| 818 |
<a NAME="Metal2">
| 819 |
<b>Metal2</b>
| 820 |
</a>
| 821 |
| 822 |
<dd>
| 823 |
Metal2 is the same as <a HREF="#Plastic2">plastic2</a>, except that the highlights are modified by the material color.
| 824 |
| 825 |
<p>
| 826 |
| 827 |
<dt>
| 828 |
<a NAME="Trans2">
| 829 |
<b>Trans2</b>
| 830 |
</a>
| 831 |
| 832 |
<dd>
| 833 |
Trans2 is the anisotropic version of <a HREF="#Trans">trans</a>.
| 834 |
greg |
1.23 |
The string arguments are the same as for <a HREF="#Plastic2">plastic2</a>,
| 835 |
and the real arguments are the same as for trans but with an additional roughness value.
| 836 |
greg |
1.1 |
| 837 |
<pre>
| 838 |
mod trans2 id
| 839 |
| 840 |
0
| 841 |
8 red green blue spec urough vrough trans tspec
| 842 |
</pre>
| 843 |
| 844 |
<p>
| 845 |
| 846 |
<dt>
| 847 |
greg |
1.23 |
<a NAME="Ashik2">
| 848 |
<b>Ashik2</b>
| 849 |
</a>
| 850 |
| 851 |
<dd>
| 852 |
Ashik2 is the anisotropic reflectance model by Ashikhmin & Shirley.
| 853 |
The string arguments are the same as for <a HREF="#Plastic2">plastic2</a>, but the real
| 854 |
arguments have additional flexibility to specify the specular color.
| 855 |
Also, rather than roughness, specular power is used, which has no
| 856 |
physical meaning other than larger numbers are equivalent to a smoother
| 857 |
surface.
| 858 |
greg |
1.31 |
Unlike other material types, total reflectance is the sum of
| 859 |
diffuse and specular colors, and should be adjusted accordingly.
| 860 |
greg |
1.23 |
<pre>
| 861 |
mod ashik2 id
| 862 |
| 863 |
0
| 864 |
8 dred dgrn dblu sred sgrn sblu u-power v-power
| 865 |
</pre>
| 866 |
| 867 |
<p>
| 868 |
| 869 |
<dt>
| 870 |
greg |
1.39 |
<a NAME="WGMDfunc">
| 871 |
<b>WGMDfunc</b>
| 872 |
</a>
| 873 |
| 874 |
<dd>
| 875 |
WGMDfunc is a more programmable version of <a HREF="#Trans2">trans2</a>,
| 876 |
with separate modifier paths and variables to control each component.
| 877 |
(WGMD stands for Ward-Geisler-Moroder-Duer, which is the basis for
| 878 |
this empirical model, similar to previous ones beside Ashik2.)
| 879 |
The specification of this material is given below.
| 880 |
<pre>
| 881 |
mod WGMDfunc id
| 882 |
13+ rs_mod rs rs_urough rs_vrough
| 883 |
ts_mod ts ts_urough ts_vrough
| 884 |
td_mod
| 885 |
| 886 |
0
| 887 |
9+ rfdif gfdif bfdif
| 888 |
rbdif gbdif bbdif
| 889 |
rtdif gtdif btdif
| 890 |
A10 ..
| 891 |
</pre>
| 892 |
| 893 |
greg |
1.40 |
<p>
| 894 |
| 895 |
greg |
1.39 |
The sum of specular reflectance (<I>rs</I>), specular transmittance (<I>ts</I>),
| 896 |
diffuse reflectance (<I>rfdif gfdif bfdif</I> for front and <I>rbdif gbdif bbdif</I> for back)
| 897 |
and diffuse transmittance (<I>rtdif gtdif btdif</I>) should be less than 1 for each
| 898 |
channel.
| 899 |
| 900 |
<p>
| 901 |
| 902 |
Unique to this material, separate modifier channels are
| 903 |
provided for each component.
| 904 |
The main modifier is used on the diffuse reflectance, both
| 905 |
front and back.
| 906 |
The <I>rs_mod</I> modifier is used for specular reflectance.
| 907 |
If "void" is given for <I>rs_mod</I>,
| 908 |
then the specular reflection color will be white.
| 909 |
The special "inherit" keyword may also be given, in which case
| 910 |
specular reflectance will share the main modifier.
| 911 |
This behavior is replicated for the specular transmittance modifier
| 912 |
<I>ts_mod</I>, which also has its own independent roughness expressions.
| 913 |
Finally, the diffuse transmittance modifier is given as
| 914 |
<I>td_mod</I>, which may also be "void" or "inherit".
| 915 |
Note that any spectra or color for specular components must be
| 916 |
carried by the named modifier(s).
| 917 |
| 918 |
<p>
| 919 |
| 920 |
The main advantage to this material over
| 921 |
<a HREF="#BRTDfunc">BRTDfunc</a> and
| 922 |
other programmable types described below is that the specular sampling is
| 923 |
well-defined, so that all components are fully computed.
| 924 |
| 925 |
<p>
| 926 |
| 927 |
<dt>
| 928 |
greg |
1.1 |
<a NAME="Dielectric">
| 929 |
<b>Dielectric</b>
| 930 |
</a>
| 931 |
| 932 |
<dd>
| 933 |
A dielectric material is transparent, and it refracts light as well as reflecting it.
| 934 |
Its behavior is determined by the index of refraction and transmission coefficient in each wavelength band per unit length.
| 935 |
Common glass has a index of refraction (n) around 1.5, and a transmission coefficient of roughly 0.92 over an inch.
| 936 |
An additional number, the Hartmann constant, describes how the index of refraction changes as a function of wavelength.
| 937 |
It is usually zero. (A <a HREF="#Patterns">pattern</a> modifies only the refracted value.)
| 938 |
| 939 |
<pre>
| 940 |
mod dielectric id
| 941 |
0
| 942 |
0
| 943 |
5 rtn gtn btn n hc
| 944 |
</pre>
| 945 |
| 946 |
<p>
| 947 |
| 948 |
<dt>
| 949 |
<a NAME="Interface">
| 950 |
<b>Interface</b>
| 951 |
</a>
| 952 |
| 953 |
<dd>
| 954 |
An interface is a boundary between two dielectrics.
| 955 |
The first transmission coefficient and refractive index are for the inside; the second ones are for the outside.
| 956 |
Ordinary dielectrics are surrounded by a vacuum (1 1 1 1).
| 957 |
| 958 |
<pre>
| 959 |
mod interface id
| 960 |
0
| 961 |
0
| 962 |
8 rtn1 gtn1 btn1 n1 rtn2 gtn2 btn2 n2
| 963 |
</pre>
| 964 |
| 965 |
<p>
| 966 |
| 967 |
<dt>
| 968 |
<a NAME="Glass">
| 969 |
<b>Glass</b>
| 970 |
</a>
| 971 |
| 972 |
<dd>
| 973 |
Glass is similar to <a HREF="#Dielectric">dielectric</a>, but it is optimized for thin glass surfaces (n = 1.52).
| 974 |
One transmitted ray and one reflected ray is produced.
| 975 |
By using a single surface is in place of two, internal reflections are avoided.
| 976 |
The surface orientation is irrelevant, as it is for <a HREF="#Plastic">plastic</a>, <a HREF="#Metal">metal</a>, and <a HREF="#Trans">trans</a>.
| 977 |
The only specification required is the transmissivity at normal incidence.
| 978 |
(Transmissivity is the amount of light not absorbed in one traversal
| 979 |
of the material.
| 980 |
Transmittance -- the value usually measured -- is the total light
| 981 |
transmitted through the pane including multiple reflections.)
| 982 |
To compute transmissivity (tn) from transmittance (Tn) use:
| 983 |
| 984 |
<pre>
| 985 |
tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn
| 986 |
</pre>
| 987 |
| 988 |
greg |
1.40 |
<p>
| 989 |
| 990 |
greg |
1.1 |
Standard 88% transmittance glass has a transmissivity of 0.96.
| 991 |
(A <a HREF="#Patterns">pattern</a> modifying glass will affect the transmissivity.)
| 992 |
If a fourth real argument is given, it is interpreted as the index of refraction to use instead of 1.52.
| 993 |
| 994 |
<pre>
| 995 |
mod glass id
| 996 |
0
| 997 |
0
| 998 |
3 rtn gtn btn
| 999 |
</pre>
| 1000 |
| 1001 |
<p>
| 1002 |
| 1003 |
<dt>
| 1004 |
<a NAME="Plasfunc">
| 1005 |
<b>Plasfunc</b>
| 1006 |
</a>
| 1007 |
| 1008 |
<dd>
| 1009 |
Plasfunc in used for the procedural definition of plastic-like materials
| 1010 |
with arbitrary bidirectional reflectance distribution functions (BRDF's).
| 1011 |
The arguments to this material include the color and specularity,
| 1012 |
as well as the function defining the specular distribution and the auxiliary file where it may be found.
| 1013 |
| 1014 |
<pre>
| 1015 |
mod plasfunc id
| 1016 |
2+ refl funcfile transform
| 1017 |
0
| 1018 |
4+ red green blue spec A5 ..
| 1019 |
</pre>
| 1020 |
| 1021 |
greg |
1.40 |
<p>
| 1022 |
| 1023 |
greg |
1.1 |
The function refl takes four arguments, the x, y and z
| 1024 |
direction towards the incident light, and the solid angle
| 1025 |
subtended by the source.
| 1026 |
The solid angle is provided to facilitate averaging, and is usually
| 1027 |
ignored.
| 1028 |
The refl function should integrate to 1 over
| 1029 |
the projected hemisphere to maintain energy balance.
| 1030 |
At least four real arguments must be given, and these are made available along with any additional values to the reflectance function.
| 1031 |
Currently, only the contribution from direct light sources is considered in the specular calculation.
| 1032 |
As in most material types, the surface normal is always altered to face the incoming ray.
| 1033 |
| 1034 |
<p>
| 1035 |
| 1036 |
<dt>
| 1037 |
<a NAME="Metfunc">
| 1038 |
<b>Metfunc</b>
| 1039 |
</a>
| 1040 |
| 1041 |
<dd>
| 1042 |
Metfunc is identical to <a HREF="#Plasfunc">plasfunc</a> and takes the same arguments,
| 1043 |
but the specular component is multiplied also by the material color.
| 1044 |
| 1045 |
<p>
| 1046 |
| 1047 |
<dt>
| 1048 |
<a NAME="Transfunc">
| 1049 |
<b>Transfunc</b>
| 1050 |
</a>
| 1051 |
| 1052 |
<dd>
| 1053 |
Transfunc is similar to <a HREF="#Plasfunc">plasfunc</a> but with an arbitrary bidirectional transmittance distribution
| 1054 |
as well as a reflectance distribution.
| 1055 |
Both reflectance and transmittance are specified with the same function.
| 1056 |
| 1057 |
<pre>
| 1058 |
mod transfunc id
| 1059 |
2+ brtd funcfile transform
| 1060 |
0
| 1061 |
6+ red green blue rspec trans tspec A7 ..
| 1062 |
</pre>
| 1063 |
| 1064 |
greg |
1.40 |
<p>
| 1065 |
| 1066 |
greg |
1.1 |
Where trans is the total light transmitted and tspec is the non-Lambertian fraction of transmitted light.
| 1067 |
The function brtd should integrate to 1 over each projected hemisphere.
| 1068 |
| 1069 |
<p>
| 1070 |
| 1071 |
<dt>
| 1072 |
<a NAME="BRTDfunc">
| 1073 |
<b>BRTDfunc</b>
| 1074 |
</a>
| 1075 |
| 1076 |
<dd>
| 1077 |
The material BRTDfunc gives the maximum flexibility over surface reflectance and transmittance,
| 1078 |
providing for spectrally-dependent specular rays and reflectance and transmittance distribution functions.
| 1079 |
| 1080 |
<pre>
| 1081 |
mod BRTDfunc id
| 1082 |
10+ rrefl grefl brefl
| 1083 |
rtrns gtrns btrns
| 1084 |
rbrtd gbrtd bbrtd
| 1085 |
funcfile transform
| 1086 |
0
| 1087 |
| 1088 |
rbdif gbdif bbdif
| 1089 |
rtdif gtdif btdif
| 1090 |
A10 ..
| 1091 |
</pre>
| 1092 |
| 1093 |
greg |
1.40 |
<p>
| 1094 |
| 1095 |
greg |
1.1 |
The variables rrefl, grefl and brefl specify the color coefficients for the ideal specular (mirror) reflection of the surface.
| 1096 |
The variables rtrns, gtrns and btrns specify the color coefficients for the ideal specular transmission.
| 1097 |
The functions rbrtd, gbrtd and bbrtd take the direction to the incident light (and its solid angle) and
| 1098 |
compute the color coefficients for the directional diffuse part of reflection and transmission.
| 1099 |
As a special case, three identical values of '0' may be given in place of these function names to indicate no directional diffuse component.
| 1100 |
| 1101 |
<p>
| 1102 |
Unlike most other material types, the surface normal is not altered to face the incoming ray.
| 1103 |
Thus, functions and variables must pay attention to the orientation of the surface and make adjustments appropriately.
| 1104 |
However, the special variables for the perturbed dot product and surface normal, RdotP, NxP, NyP and NzP are reoriented
| 1105 |
as if the ray hit the front surface for convenience.
| 1106 |
| 1107 |
<p>
| 1108 |
A diffuse reflection component may be given for the front side with rfdif, gfdif and bfdif for the front side of the surface
| 1109 |
or rbdif, gbdif and bbdif for the back side.
| 1110 |
The diffuse transmittance (must be the same for both sides by physical law) is given by rtdif, gtdif and btdif.
| 1111 |
A pattern will modify these diffuse scattering values, and will be available through the special variables CrP, CgP and CbP.
| 1112 |
| 1113 |
<p>
| 1114 |
Care must be taken when using this material type to produce a physically valid reflection model.
| 1115 |
The reflectance functions should be bidirectional, and under no circumstances should the sum of reflected diffuse,
| 1116 |
transmitted diffuse, reflected specular, transmitted specular and the integrated directional diffuse component be greater than one.
| 1117 |
| 1118 |
<p>
| 1119 |
| 1120 |
<dt>
| 1121 |
<a NAME="Plasdata">
| 1122 |
<b>Plasdata</b>
| 1123 |
</a>
| 1124 |
| 1125 |
<dd>
| 1126 |
Plasdata is used for arbitrary BRDF's that are most conveniently given as interpolated data.
| 1127 |
The arguments to this material are the <a HREF="#Data">data file</a> and coordinate index functions,
| 1128 |
as well as a function to optionally modify the data values.
| 1129 |
| 1130 |
<pre>
| 1131 |
mod plasdata id
| 1132 |
3+n+
| 1133 |
func datafile
| 1134 |
funcfile x1 x2 .. xn transform
| 1135 |
0
| 1136 |
| 1137 |
</pre>
| 1138 |
| 1139 |
greg |
1.40 |
<p>
| 1140 |
| 1141 |
greg |
1.1 |
The coordinate indices (x1, x2, etc.) are themselves functions of the x, y and z direction to the incident light, plus the solid angle
| 1142 |
subtended by the light source (usually ignored).
| 1143 |
The data function (func) takes five variables, the
| 1144 |
interpolated value from the n-dimensional data file, followed by the
| 1145 |
x, y and z direction to the incident light and the solid angle of the source.
| 1146 |
The light source direction and size may of course be ignored by the function.
| 1147 |
| 1148 |
<p>
| 1149 |
| 1150 |
<dt>
| 1151 |
<a NAME="Metdata">
| 1152 |
<b>Metdata</b>
| 1153 |
</a>
| 1154 |
| 1155 |
<dd>
| 1156 |
As metfunc is to plasfunc, metdata is to <a HREF="#Plasdata">plasdata</a>.
| 1157 |
Metdata takes the same arguments as plasdata, but the specular component is modified by the given material color.
| 1158 |
| 1159 |
<p>
| 1160 |
| 1161 |
<dt>
| 1162 |
<a NAME="Transdata">
| 1163 |
<b>Transdata</b>
| 1164 |
</a>
| 1165 |
| 1166 |
<dd>
| 1167 |
Transdata is like <a HREF="#Plasdata">plasdata</a> but the specification includes transmittance as well as reflectance.
| 1168 |
The parameters are as follows.
| 1169 |
| 1170 |
<pre>
| 1171 |
mod transdata id
| 1172 |
3+n+
| 1173 |
func datafile
| 1174 |
| 1175 |
0
| 1176 |
| 1177 |
</pre>
| 1178 |
| 1179 |
<p>
| 1180 |
| 1181 |
<dt>
| 1182 |
greg |
1.10 |
<a NAME="BSDF">
| 1183 |
<b>BSDF</b>
| 1184 |
</a>
| 1185 |
| 1186 |
<dd>
| 1187 |
The BSDF material type loads an XML (eXtensible Markup Language)
| 1188 |
file describing a bidirectional scattering distribution function.
| 1189 |
Real arguments to this material may define additional
| 1190 |
diffuse components that augment the BSDF data.
| 1191 |
String arguments are used to define thickness for proxied
| 1192 |
greg |
1.11 |
surfaces and the "up" orientation for the material.
| 1193 |
greg |
1.10 |
| 1194 |
<pre>
| 1195 |
mod BSDF id
| 1196 |
6+ thick BSDFfile ux uy uz funcfile transform
| 1197 |
0
| 1198 |
0|3|6|9
| 1199 |
rfdif gfdif bfdif
| 1200 |
rbdif gbdif bbdif
| 1201 |
rtdif gtdif btdif
| 1202 |
</pre>
| 1203 |
| 1204 |
<p>
| 1205 |
greg |
1.11 |
The first string argument is a "thickness" parameter that may be used
| 1206 |
greg |
1.10 |
to hide detail geometry being proxied by an aggregate BSDF material.
| 1207 |
If a view or shadow ray hits a BSDF proxy with non-zero thickness,
| 1208 |
it will pass directly through as if the surface were not there.
| 1209 |
Similar to the illum type, this permits direct viewing and
| 1210 |
shadow testing of complex geometry.
| 1211 |
The BSDF is used when a scattered (indirect) ray hits the surface,
| 1212 |
and any transmitted sample rays will be offset by the thickness amount
| 1213 |
to avoid the hidden geometry and gather samples from the other side.
| 1214 |
In this manner, BSDF surfaces can improve the results for indirect
| 1215 |
scattering from complex systems without sacrificing appearance or
| 1216 |
shadow accuracy.
| 1217 |
If the BSDF has transmission and back-side reflection data,
| 1218 |
a parallel BSDF surface may be
| 1219 |
placed slightly less than the given thickness away from the front surface
| 1220 |
to enclose the complex geometry on both sides.
| 1221 |
greg |
1.12 |
The sign of the thickness is important, as it indicates
| 1222 |
greg |
1.14 |
whether the proxied geometry is behind the BSDF
| 1223 |
greg |
1.12 |
surface (when thickness is positive) or in front (when
| 1224 |
thickness is negative).
| 1225 |
<p>
| 1226 |
The second string argument is the name of the BSDF file,
| 1227 |
which is found in the usual auxiliary locations. The
| 1228 |
following three string parameters name variables for an
| 1229 |
"up" vector, which together with the surface
| 1230 |
normal, define the local coordinate system that orients the
| 1231 |
BSDF. These variables, along with the thickness, are defined
| 1232 |
in a function file given as the next string argument. An
| 1233 |
optional transform is used to scale the thickness and
| 1234 |
reorient the up vector.
| 1235 |
<p>
| 1236 |
If no real arguments are given, the BSDF is used by itself
| 1237 |
to determine reflection and transmission. If there are at
| 1238 |
least 3 real arguments, the first triplet is an additional
| 1239 |
diffuse reflectance for the front side. At least 6 real
| 1240 |
arguments adds diffuse reflectance to the rear side of the
| 1241 |
surface. If there are 9 real arguments, the final triplet
| 1242 |
will be taken as an additional diffuse transmittance. All
| 1243 |
diffuse components as well as the non-diffuse transmission
| 1244 |
are modified by patterns applied to this material. The
| 1245 |
non-diffuse reflection from either side are unaffected.
| 1246 |
Textures perturb the effective surface normal in the usual
| 1247 |
way.
| 1248 |
<p>
| 1249 |
The surface normal of this type is not altered to face the
| 1250 |
incoming ray, so the front and back BSDF reflections may
| 1251 |
differ. (Transmission is identical front-to-back by physical
| 1252 |
law.) If back visibility is turned off during rendering and
| 1253 |
there is no transmission or back-side reflection, only then
| 1254 |
the surface will be invisible from behind. Unlike other
| 1255 |
data-driven material types, the BSDF type is fully supported
| 1256 |
and all parts of the distribution are properly sampled.
| 1257 |
greg |
1.10 |
<p>
| 1258 |
| 1259 |
<dt>
| 1260 |
greg |
1.26 |
<a NAME="aBSDF">
| 1261 |
<b>aBSDF</b>
| 1262 |
greg |
1.25 |
</a>
| 1263 |
| 1264 |
<dd>
| 1265 |
greg |
1.26 |
The aBSDF material is identical to the BSDF type with two
| 1266 |
greg |
1.25 |
important differences. First, proxy geometry is not
| 1267 |
supported, so there is no thickness parameter. Second, an
| 1268 |
greg |
1.26 |
aBSDF is assumed to have some specular through component
| 1269 |
(the ’a’ stands for "aperture"),
| 1270 |
greg |
1.25 |
which is treated specially during the direct calculation
| 1271 |
and when viewing the material. Based on the BSDF data, the
| 1272 |
coefficient of specular transmission is determined and used
| 1273 |
for modifying unscattered shadow and view rays.
| 1274 |
| 1275 |
<pre>
| 1276 |
greg |
1.26 |
mod aBSDF id
| 1277 |
greg |
1.25 |
5+ BSDFfile ux uy uz funcfile transform
| 1278 |
0
| 1279 |
0|3|6|9
| 1280 |
rfdif gfdif bfdif
| 1281 |
rbdif gbdif bbdif
| 1282 |
rtdif gtdif btdif
| 1283 |
</pre>
| 1284 |
| 1285 |
<p>
| 1286 |
If a material has no specular transmitted component, it is
| 1287 |
much better to use the BSDF type with a zero thickness
| 1288 |
greg |
1.26 |
than to use aBSDF.
| 1289 |
greg |
1.25 |
<p>
| 1290 |
| 1291 |
<dt>
| 1292 |
greg |
1.1 |
<a NAME="Antimatter">
| 1293 |
<b>Antimatter</b>
| 1294 |
</a>
| 1295 |
| 1296 |
<dd>
| 1297 |
Antimatter is a material that can "subtract" volumes from other volumes.
| 1298 |
A ray passing into an antimatter object becomes blind to all the specified modifiers:
| 1299 |
| 1300 |
<pre>
| 1301 |
mod antimatter id
| 1302 |
N mod1 mod2 .. modN
| 1303 |
0
| 1304 |
0
| 1305 |
</pre>
| 1306 |
| 1307 |
greg |
1.40 |
<p>
| 1308 |
| 1309 |
greg |
1.1 |
The first modifier will also be used to shade the area leaving the antimatter volume and entering the regular volume.
| 1310 |
If mod1 is void, the antimatter volume is completely invisible.
| 1311 |
Antimatter does not work properly with the material type <a HREF="#Trans">"trans"</a>,
| 1312 |
and multiple antimatter surfaces should be disjoint.
| 1313 |
The viewpoint must be outside all volumes concerned for a correct rendering.
| 1314 |
| 1315 |
</dl>
| 1316 |
| 1317 |
<p>
| 1318 |
<hr>
| 1319 |
| 1320 |
<h4>
| 1321 |
<a NAME="Textures">2.1.3. Textures</a>
| 1322 |
</h4>
| 1323 |
| 1324 |
A texture is a perturbation of the surface normal, and is given by either a function or data.
| 1325 |
| 1326 |
<p>
| 1327 |
| 1328 |
<dl>
| 1329 |
| 1330 |
<dt>
| 1331 |
<a NAME="Texfunc">
| 1332 |
<b>Texfunc</b>
| 1333 |
</a>
| 1334 |
| 1335 |
<dd>
| 1336 |
A texfunc uses an auxiliary function file to specify a procedural texture:
| 1337 |
| 1338 |
<pre>
| 1339 |
mod texfunc id
| 1340 |
4+ xpert ypert zpert funcfile transform
| 1341 |
0
| 1342 |
n A1 A2 .. An
| 1343 |
</pre>
| 1344 |
| 1345 |
<p>
| 1346 |
| 1347 |
<dt>
| 1348 |
<a NAME="Texdata">
| 1349 |
<b>Texdata</b>
| 1350 |
</a>
| 1351 |
| 1352 |
<dd>
| 1353 |
A texdata texture uses three data files to get the surface normal perturbations.
| 1354 |
The variables xfunc, yfunc and zfunc take three arguments each from the interpolated values in xdfname, ydfname and zdfname.
| 1355 |
| 1356 |
<pre>
| 1357 |
mod texdata id
| 1358 |
greg |
1.43 |
8+ xfunc yfunc zfunc xdfname ydfname zdfname funcfile x0 x1 .. xf
| 1359 |
greg |
1.1 |
0
| 1360 |
n A1 A2 .. An
| 1361 |
</pre>
| 1362 |
| 1363 |
greg |
1.40 |
<p>
| 1364 |
| 1365 |
greg |
1.1 |
</dl>
| 1366 |
| 1367 |
<p>
| 1368 |
<hr>
| 1369 |
| 1370 |
<h4>
| 1371 |
<a NAME="Patterns">2.1.4. Patterns</a>
| 1372 |
</h4>
| 1373 |
| 1374 |
Patterns are used to modify the reflectance of materials. The basic types are given below.
| 1375 |
| 1376 |
<p>
| 1377 |
| 1378 |
<dl>
| 1379 |
| 1380 |
<dt>
| 1381 |
<a NAME="Colorfunc">
| 1382 |
<b>Colorfunc</b>
| 1383 |
</a>
| 1384 |
| 1385 |
<dd>
| 1386 |
A colorfunc is a procedurally defined color pattern. It is specified as follows:
| 1387 |
| 1388 |
<pre>
| 1389 |
mod colorfunc id
| 1390 |
4+ red green blue funcfile transform
| 1391 |
0
| 1392 |
n A1 A2 .. An
| 1393 |
</pre>
| 1394 |
| 1395 |
<p>
| 1396 |
| 1397 |
<dt>
| 1398 |
<a NAME="Brightfunc">
| 1399 |
<b>Brightfunc</b>
| 1400 |
</a>
| 1401 |
| 1402 |
<dd>
| 1403 |
A brightfunc is the same as a colorfunc, except it is monochromatic.
| 1404 |
| 1405 |
<pre>
| 1406 |
mod brightfunc id
| 1407 |
| 1408 |
0
| 1409 |
n A1 A2 .. An
| 1410 |
</pre>
| 1411 |
| 1412 |
<p>
| 1413 |
| 1414 |
<dt>
| 1415 |
<a NAME="Colordata">
| 1416 |
<b>Colordata</b>
| 1417 |
</a>
| 1418 |
| 1419 |
<dd>
| 1420 |
Colordata uses an interpolated data map to modify a material's color.
| 1421 |
The map is n-dimensional, and is stored in three auxiliary files, one for each color.
| 1422 |
The coordinates used to look up and interpolate the data are defined in another auxiliary file.
| 1423 |
The interpolated data values are modified by functions of one or three variables.
| 1424 |
If the functions are of one variable, then they are passed the corresponding color component (red or green or blue).
| 1425 |
If the functions are of three variables, then they are passed the original red, green, and blue values as parameters.
| 1426 |
| 1427 |
<pre>
| 1428 |
mod colordata id
| 1429 |
7+n+
| 1430 |
rfunc gfunc bfunc rdatafile gdatafile bdatafile
| 1431 |
| 1432 |
0
| 1433 |
m A1 A2 .. Am
| 1434 |
</pre>
| 1435 |
| 1436 |
<p>
| 1437 |
| 1438 |
<dt>
| 1439 |
<a NAME="Brightdata">
| 1440 |
<b>Brightdata</b>
| 1441 |
</a>
| 1442 |
| 1443 |
<dd>
| 1444 |
Brightdata is like colordata, except monochromatic.
| 1445 |
| 1446 |
<pre>
| 1447 |
mod brightdata id
| 1448 |
3+n+
| 1449 |
func datafile
| 1450 |
| 1451 |
0
| 1452 |
m A1 A2 .. Am
| 1453 |
</pre>
| 1454 |
| 1455 |
<p>
| 1456 |
| 1457 |
<dt>
| 1458 |
<a NAME="Colorpict">
| 1459 |
<b>Colorpict</b>
| 1460 |
</a>
| 1461 |
| 1462 |
<dd>
| 1463 |
Colorpict is a special case of colordata, where the pattern is a two-dimensional image stored in the RADIANCE picture format.
| 1464 |
The dimensions of the image data are determined by the picture such that the smaller dimension is always 1,
| 1465 |
and the other is the ratio between the larger and the smaller.
| 1466 |
For example, a 500x338 picture would have coordinates (u,v) in the rectangle between (0,0) and (1.48,1).
| 1467 |
| 1468 |
<pre>
| 1469 |
mod colorpict id
| 1470 |
7+
| 1471 |
rfunc gfunc bfunc pictfile
| 1472 |
funcfile u v transform
| 1473 |
0
| 1474 |
m A1 A2 .. Am
| 1475 |
</pre>
| 1476 |
| 1477 |
<p>
| 1478 |
| 1479 |
<dt>
| 1480 |
<a NAME="Colortext">
| 1481 |
<b>Colortext</b>
| 1482 |
</a>
| 1483 |
| 1484 |
<dd>
| 1485 |
Colortext is dichromatic writing in a polygonal font.
| 1486 |
The font is defined in an auxiliary file, such as helvet.fnt.
| 1487 |
The text itself is also specified in a separate file, or can be part of the material arguments.
| 1488 |
The character size, orientation, aspect ratio and slant is determined by right and down motion vectors.
| 1489 |
The upper left origin for the text block as well as the foreground and background colors must also be given.
| 1490 |
| 1491 |
<pre>
| 1492 |
mod colortext id
| 1493 |
2 fontfile textfile
| 1494 |
0
| 1495 |
15+
| 1496 |
Ox Oy Oz
| 1497 |
Rx Ry Rz
| 1498 |
Dx Dy Dz
| 1499 |
rfore gfore bfore
| 1500 |
rback gback bback
| 1501 |
[spacing]
| 1502 |
</pre>
| 1503 |
| 1504 |
greg |
1.40 |
<p>
| 1505 |
| 1506 |
greg |
1.1 |
or:
| 1507 |
| 1508 |
<pre>
| 1509 |
mod colortext id
| 1510 |
2+N fontfile . This is a line with N words ...
| 1511 |
0
| 1512 |
15+
| 1513 |
Ox Oy Oz
| 1514 |
Rx Ry Rz
| 1515 |
Dx Dy Dz
| 1516 |
rfore gfore bfore
| 1517 |
rback gback bback
| 1518 |
[spacing]
| 1519 |
</pre>
| 1520 |
| 1521 |
<p>
| 1522 |
| 1523 |
<dt>
| 1524 |
<a NAME="Brighttext">
| 1525 |
<b>Brighttext</b>
| 1526 |
</a>
| 1527 |
| 1528 |
<dd>
| 1529 |
Brighttext is like colortext, but the writing is monochromatic.
| 1530 |
| 1531 |
<pre>
| 1532 |
mod brighttext id
| 1533 |
2 fontfile textfile
| 1534 |
0
| 1535 |
11+
| 1536 |
Ox Oy Oz
| 1537 |
Rx Ry Rz
| 1538 |
Dx Dy Dz
| 1539 |
foreground background
| 1540 |
[spacing]
| 1541 |
</pre>
| 1542 |
| 1543 |
greg |
1.40 |
<p>
| 1544 |
| 1545 |
greg |
1.1 |
or:
| 1546 |
| 1547 |
<pre>
| 1548 |
mod brighttext id
| 1549 |
| 1550 |
0
| 1551 |
11+
| 1552 |
Ox Oy Oz
| 1553 |
Rx Ry Rz
| 1554 |
Dx Dy Dz
| 1555 |
| 1556 |
[spacing]
| 1557 |
</pre>
| 1558 |
| 1559 |
<p>
| 1560 |
| 1561 |
By default, a uniform spacing algorithm is used that guarantees every character will appear in a precisely determined position.
| 1562 |
Unfortunately, such a scheme results in rather unattractive and difficult to read text with most fonts.
| 1563 |
The optional spacing value defines the distance between characters for proportional spacing.
| 1564 |
A positive value selects a spacing algorithm that preserves right margins and indentation,
| 1565 |
but does not provide the ultimate in proportionally spaced text.
| 1566 |
A negative value insures that characters are properly spaced, but the placement of words then varies unpredictably.
| 1567 |
The choice depends on the relative importance of spacing versus formatting.
| 1568 |
When presenting a section of formatted text, a positive spacing value is usually preferred.
| 1569 |
A single line of text will often be accompanied by a negative spacing value.
| 1570 |
A section of text meant to depict a picture, perhaps using a special purpose font such as hexbit4x1.fnt, calls for uniform spacing.
| 1571 |
Reasonable magnitudes for proportional spacing are between 0.1 (for tightly spaced characters) and 0.3 (for wide spacing).
| 1572 |
| 1573 |
greg |
1.33 |
<p>
| 1574 |
| 1575 |
<dt>
| 1576 |
<a NAME="Spectrum">
| 1577 |
<b>Spectrum</b>
| 1578 |
</a>
| 1579 |
| 1580 |
<dd>
| 1581 |
The spectrum primitive is the most basic type for introducing spectral
| 1582 |
color to a material.
| 1583 |
Since materials only provide RGB parameters, spectral patterns
| 1584 |
are the only way to superimpose wavelength-dependent behavior.
| 1585 |
| 1586 |
<pre>
| 1587 |
mod spectrum id
| 1588 |
0
| 1589 |
0
| 1590 |
5+ nmA nmB s1 s2 .. sN
| 1591 |
</pre>
| 1592 |
| 1593 |
<p>
| 1594 |
greg |
1.35 |
The first two real arguments indicate the extrema of the
| 1595 |
greg |
1.33 |
spectral range in nanometers.
| 1596 |
greg |
1.36 |
Subsequent real values correspond to multipliers at each wavelength.
| 1597 |
greg |
1.34 |
The nmA wavelength may be greater or less than nmB,
| 1598 |
but they may not be equal, and their ordering matches
| 1599 |
the order of the spectral values.
| 1600 |
greg |
1.33 |
A minimum of 3 values must be given, which would act
| 1601 |
more or less the same as a constant RGB multiplier.
| 1602 |
As with RGB values, spectral quantities normally range between 0
| 1603 |
and 1 at each wavelength, or average to 1.0 against a standard
| 1604 |
greg |
1.47 |
sensitivity function such as V(lambda).
| 1605 |
greg |
1.33 |
The best results obtain when the spectral range and number
| 1606 |
of samples match rendering options, though resampling will handle
| 1607 |
any differences, zero-filling wavelenths outside the nmA to nmB
| 1608 |
range.
| 1609 |
A warning will be issued if the given wavelength range does not
| 1610 |
adequately cover the visible spectrum.
| 1611 |
| 1612 |
<p>
| 1613 |
| 1614 |
<dt>
| 1615 |
<a NAME="Specfile">
| 1616 |
<b>Specfile</b>
| 1617 |
</a>
| 1618 |
| 1619 |
<dd>
| 1620 |
The specfile primitive is equivalent to the spectrum type, but
| 1621 |
the wavelength range and values are contained in a 1-dimensional
| 1622 |
data file.
| 1623 |
This may be a more convenient way to specify a spectral color,
| 1624 |
especially one corresponding to a standard illuminant such as D65
| 1625 |
or a library of measured spectra.
| 1626 |
| 1627 |
<pre>
| 1628 |
mod specfile id
| 1629 |
1 datafile
| 1630 |
0
| 1631 |
0
| 1632 |
</pre>
| 1633 |
| 1634 |
<p>
| 1635 |
As with the spectrum type, rendering wavelengths outside the defined
| 1636 |
range will be zero-filled.
| 1637 |
Unlike the spectrum type, the file may contain non-uniform samples.
| 1638 |
| 1639 |
<p>
| 1640 |
| 1641 |
<dt>
| 1642 |
<a NAME="Specfunc">
| 1643 |
<b>Specfunc</b>
| 1644 |
</a>
| 1645 |
| 1646 |
<dd>
| 1647 |
The specfunc primitive offers dynamic control over a spectral
| 1648 |
pattern, similar to the colorfunc type.
| 1649 |
| 1650 |
<pre>
| 1651 |
mod specfunc id
| 1652 |
greg |
1.37 |
2+ sfunc funcfile transform
| 1653 |
greg |
1.33 |
0
| 1654 |
2+ nmA nmB A3 ..
| 1655 |
</pre>
| 1656 |
| 1657 |
<p>
| 1658 |
Like the spectrum primitive, the wavelength range is specified
| 1659 |
in the first two real arguments, and additional real values are
| 1660 |
greg |
1.36 |
set in the evaluation context.
| 1661 |
greg |
1.33 |
This function is fed a wavelenth sample
| 1662 |
between nmA and nmB as its only argument,
| 1663 |
and it returns the corresponding spectral intensity.
| 1664 |
| 1665 |
greg |
1.38 |
<dt>
| 1666 |
<a NAME="Specdata">
| 1667 |
<b>Specdata</b>
| 1668 |
</a>
| 1669 |
| 1670 |
<dd>
| 1671 |
Specdata is like brightdata and colordata, but with more
| 1672 |
than 3 specular samples.
| 1673 |
| 1674 |
<pre>
| 1675 |
mod specdata id
| 1676 |
3+n+
| 1677 |
func datafile
| 1678 |
| 1679 |
0
| 1680 |
m A1 A2 .. Am
| 1681 |
</pre>
| 1682 |
| 1683 |
<p>
| 1684 |
The data file must have one more dimension than the coordinate
| 1685 |
variable count, as this final dimension corresponds to the covered
| 1686 |
spectrum.
| 1687 |
The starting and ending wavelengths are specified in "datafile"
| 1688 |
as well as the number of spectral samples.
| 1689 |
The function "func" will be called with two parameters, the
| 1690 |
interpolated spectral value for the current coordinate and the
| 1691 |
associated wavelength.
| 1692 |
If the spectrum is broken into 12 components, then 12 calls
| 1693 |
will be made to "func" for the relevant ray evaluation.
| 1694 |
| 1695 |
<dt>
| 1696 |
<a NAME="Specpict">
| 1697 |
<b>Specpict</b>
| 1698 |
</a>
| 1699 |
| 1700 |
<dd>
| 1701 |
Specpict is a special case of specdata, where the pattern is
| 1702 |
a hyperspectral image stored in the common-exponent file format.
| 1703 |
| 1704 |
just as with the colorpict primitive.
| 1705 |
| 1706 |
<pre>
| 1707 |
mod specpict id
| 1708 |
5+
| 1709 |
func specfile
| 1710 |
| 1711 |
0
| 1712 |
m A1 A2 .. Am
| 1713 |
</pre>
| 1714 |
| 1715 |
<p>
| 1716 |
The function "func" is called with the interpolated pixel value
| 1717 |
and the wavelength sample in nanometers, the same as specdata,
| 1718 |
with as many calls made as there are components in "specfile".
| 1719 |
| 1720 |
greg |
1.1 |
</dl>
| 1721 |
| 1722 |
<p>
| 1723 |
<hr>
| 1724 |
| 1725 |
<h4>
| 1726 |
<a NAME="Mixtures">2.1.5. Mixtures</a>
| 1727 |
</h4>
| 1728 |
| 1729 |
A mixture is a blend of one or more materials or textures and patterns.
| 1730 |
greg |
1.22 |
Blended materials should not be light source types or virtual source types.
| 1731 |
greg |
1.1 |
| 1732 |
| 1733 |
<p>
| 1734 |
| 1735 |
<dl>
| 1736 |
| 1737 |
<dt>
| 1738 |
<a NAME="Mixfunc">
| 1739 |
<b>Mixfunc</b>
| 1740 |
</a>
| 1741 |
| 1742 |
<dd>
| 1743 |
A mixfunc mixes two modifiers procedurally. It is specified as follows:
| 1744 |
| 1745 |
<pre>
| 1746 |
mod mixfunc id
| 1747 |
4+ foreground background vname funcfile transform
| 1748 |
0
| 1749 |
n A1 A2 .. An
| 1750 |
</pre>
| 1751 |
| 1752 |
greg |
1.40 |
<p>
| 1753 |
| 1754 |
greg |
1.1 |
Foreground and background are modifier names that must be
| 1755 |
defined earlier in the scene description.
| 1756 |
If one of these is a material, then
| 1757 |
the modifier of the mixfunc must be "void".
| 1758 |
(Either the foreground or background modifier may be "void",
| 1759 |
which serves as a form of opacity control when used with a material.)
| 1760 |
Vname is the coefficient defined in funcfile that determines the influence of foreground.
| 1761 |
The background coefficient is always (1-vname).
| 1762 |
| 1763 |
<p>
| 1764 |
| 1765 |
<dt>
| 1766 |
<a NAME="Mixdata">
| 1767 |
<b>Mixdata</b>
| 1768 |
</a>
| 1769 |
| 1770 |
<dd>
| 1771 |
Mixdata combines two modifiers using an auxiliary data file:
| 1772 |
| 1773 |
<pre>
| 1774 |
mod mixdata id
| 1775 |
5+n+
| 1776 |
foreground background func datafile
| 1777 |
| 1778 |
0
| 1779 |
m A1 A2 .. Am
| 1780 |
</pre>
| 1781 |
| 1782 |
greg |
1.40 |
<p>
| 1783 |
| 1784 |
greg |
1.1 |
<dt>
| 1785 |
<a NAME="Mixpict">
| 1786 |
<b>Mixpict</b>
| 1787 |
</a>
| 1788 |
| 1789 |
<dd>
| 1790 |
Mixpict combines two modifiers based on a picture:
| 1791 |
| 1792 |
<pre>
| 1793 |
mod mixpict id
| 1794 |
7+
| 1795 |
foreground background func pictfile
| 1796 |
| 1797 |
0
| 1798 |
m A1 A2 .. Am
| 1799 |
</pre>
| 1800 |
| 1801 |
<p>
| 1802 |
| 1803 |
The mixing coefficient function "func" takes three
| 1804 |
arguments, the red, green and blue values
| 1805 |
corresponding to the pixel at (u,v).
| 1806 |
| 1807 |
<p>
| 1808 |
| 1809 |
<dt>
| 1810 |
<a NAME="Mixtext">
| 1811 |
<b>Mixtext</b>
| 1812 |
</a>
| 1813 |
| 1814 |
<dd>
| 1815 |
Mixtext uses one modifier for the text foreground, and one for the background:
| 1816 |
| 1817 |
<pre>
| 1818 |
mod mixtext id
| 1819 |
4 foreground background fontfile textfile
| 1820 |
0
| 1821 |
9+
| 1822 |
Ox Oy Oz
| 1823 |
Rx Ry Rz
| 1824 |
Dx Dy Dz
| 1825 |
[spacing]
| 1826 |
</pre>
| 1827 |
| 1828 |
greg |
1.40 |
<p>
| 1829 |
| 1830 |
greg |
1.1 |
or:
| 1831 |
| 1832 |
<pre>
| 1833 |
mod mixtext id
| 1834 |
4+N
| 1835 |
foreground background fontfile .
| 1836 |
| 1837 |
0
| 1838 |
9+
| 1839 |
Ox Oy Oz
| 1840 |
Rx Ry Rz
| 1841 |
Dx Dy Dz
| 1842 |
[spacing]
| 1843 |
</pre>
| 1844 |
| 1845 |
greg |
1.40 |
<p>
| 1846 |
| 1847 |
greg |
1.1 |
</dl>
| 1848 |
| 1849 |
<p>
| 1850 |
<hr>
| 1851 |
| 1852 |
<h3>
| 1853 |
<a NAME="Auxiliary">2.2. Auxiliary Files</a>
| 1854 |
</h3>
| 1855 |
| 1856 |
Auxiliary files used in <a HREF="#Textures">textures</a> and <a HREF="#Patterns">patterns</a>
| 1857 |
are accessed by the programs during image generation.
| 1858 |
These files may be located in the working directory, or in a library directory.
| 1859 |
The environment variable RAYPATH can be assigned an alternate set of search directories.
| 1860 |
Following is a brief description of some common file types.
| 1861 |
| 1862 |
<p>
| 1863 |
| 1864 |
<h4>
| 1865 |
<a NAME="Function">12.2.1. Function Files</a>
| 1866 |
</h4>
| 1867 |
| 1868 |
A function file contains the definitions of variables, functions and constants used by a primitive.
| 1869 |
The transformation that accompanies the file name contains the necessary rotations, translations and scalings
| 1870 |
to bring the coordinates of the function file into agreement with the world coordinates.
| 1871 |
The transformation specification is the same as for the <a HREF="#Generators">xform</a> command.
| 1872 |
An example function file is given below:
| 1873 |
| 1874 |
<pre>
| 1875 |
| 1876 |
This is a comment, enclosed in curly braces.
| 1877 |
{Comments can be nested.}
| 1878 |
| 1879 |
{ standard expressions use +,-,*,/,^,(,) }
| 1880 |
vname = Ny * func(A1) ;
| 1881 |
{ constants are defined with a colon }
| 1882 |
const : sqrt(PI/2) ;
| 1883 |
{ user-defined functions add to library }
| 1884 |
func(x) = 5 + A1*sin(x/3) ;
| 1885 |
{ functions may be passed and recursive }
| 1886 |
rfunc(f,x) = if(x,f(x),f(-x)*rfunc(f,x+1)) ;
| 1887 |
{ constant functions may also be defined }
| 1888 |
cfunc(x) : 10*x / sqrt(x) ;
| 1889 |
</pre>
| 1890 |
| 1891 |
greg |
1.40 |
<p>
| 1892 |
| 1893 |
greg |
1.1 |
Many variables and functions are already defined by the program, and they are listed in the file rayinit.cal.
| 1894 |
The following variables are particularly important:
| 1895 |
| 1896 |
<pre>
| 1897 |
Dx, Dy, Dz - incident ray direction
| 1898 |
Nx, Ny, Nz - surface normal at intersection point
| 1899 |
Px, Py, Pz - intersection point
| 1900 |
T - distance from start
| 1901 |
Ts - single ray (shadow) distance
| 1902 |
Rdot - cosine between ray and normal
| 1903 |
arg(0) - number of real arguments
| 1904 |
arg(i) - i'th real argument
| 1905 |
</pre>
| 1906 |
| 1907 |
greg |
1.40 |
<p>
| 1908 |
| 1909 |
greg |
1.1 |
For mesh objects, the local surface coordinates are available:
| 1910 |
| 1911 |
<pre>
| 1912 |
Lu, Lv - local (u,v) coordinates
| 1913 |
</pre>
| 1914 |
| 1915 |
greg |
1.40 |
<p>
| 1916 |
| 1917 |
greg |
1.1 |
For BRDF types, the following variables are defined as well:
| 1918 |
| 1919 |
<pre>
| 1920 |
NxP, NyP, NzP - perturbed surface normal
| 1921 |
RdotP - perturbed dot product
| 1922 |
CrP, CgP, CbP - perturbed material color
| 1923 |
</pre>
| 1924 |
| 1925 |
greg |
1.40 |
<p>
| 1926 |
| 1927 |
greg |
1.1 |
A unique context is set up for each file so
| 1928 |
that the same variable may appear in different
| 1929 |
function files without conflict.
| 1930 |
The variables listed above and any others defined in
| 1931 |
rayinit.cal are available globally.
| 1932 |
If no file is needed by a given primitive because all
| 1933 |
the required variables are global,
| 1934 |
a period (`.') can be given in place of the file name.
| 1935 |
It is also possible to give an expression instead
| 1936 |
greg |
1.9 |
of a straight variable name in a scene file.
| 1937 |
Functions (requiring parameters) must be given
| 1938 |
greg |
1.1 |
as names and not as expressions.
| 1939 |
| 1940 |
<p>
| 1941 |
Constant expressions are used as an optimization in function files.
| 1942 |
They are replaced wherever they occur in an expression by their value.
| 1943 |
Constant expressions are evaluated only once, so they must not contain any variables or values that can change,
| 1944 |
such as the ray variables Px and Ny or the primitive argument function arg().
| 1945 |
All the math library functions such as sqrt() and cos() have the constant attribute,
| 1946 |
so they will be replaced by immediate values whenever they are given constant arguments.
| 1947 |
Thus, the subexpression cos(PI*sqrt(2)) is immediately replaced by its value, -.266255342,
| 1948 |
and does not cause any additional overhead in the calculation.
| 1949 |
| 1950 |
<p>
| 1951 |
It is generally a good idea to define constants and variables before they are referred to in a function file.
| 1952 |
Although evaluation does not take place until later, the interpreter does variable scoping and
| 1953 |
constant subexpression evaluation based on what it has compiled already.
| 1954 |
For example, a variable that is defined globally in rayinit.cal
| 1955 |
then referenced in the local context of a function file
| 1956 |
cannot subsequently be redefined in the same file
| 1957 |
because the compiler has already determined the scope of the referenced variable as global.
| 1958 |
To avoid such conflicts, one can state the scope of a variable explicitly by
| 1959 |
preceding the variable name with a context mark (a back-quote) for a local variable,
| 1960 |
or following the name with a context mark for a global variable.
| 1961 |
| 1962 |
<p>
| 1963 |
| 1964 |
<h4>
| 1965 |
<a NAME="Data">2.2.2. Data Files</a>
| 1966 |
</h4>
| 1967 |
| 1968 |
Data files contain n-dimensional arrays of real numbers used for interpolation.
| 1969 |
Typically, definitions in a function file determine how to index and use interpolated data values.
| 1970 |
The basic data file format is as follows:
| 1971 |
| 1972 |
<pre>
| 1973 |
N
| 1974 |
beg1 end1 m1
| 1975 |
0 0 m2 x2.1 x2.2 x2.3 x2.4 .. x2.m2
| 1976 |
| 1977 |
begN endN mN
| 1978 |
DATA, later dimensions changing faster.
| 1979 |
</pre>
| 1980 |
| 1981 |
greg |
1.40 |
<p>
| 1982 |
| 1983 |
greg |
1.1 |
N is the number of dimensions.
| 1984 |
For each dimension, the beginning and ending coordinate values and the dimension size is given.
| 1985 |
Alternatively, individual coordinate values can be given when the points are not evenly spaced.
| 1986 |
These values must either be increasing or decreasing monotonically.
| 1987 |
The data is m1*m2*...*mN real numbers in ASCII form.
| 1988 |
Comments may appear anywhere in the file, beginning with a pound
| 1989 |
sign ('#') and continuing to the end of line.
| 1990 |
| 1991 |
<p>
| 1992 |
| 1993 |
<h4>
| 1994 |
<a NAME="Font">2.2.3. Font Files</a>
| 1995 |
</h4>
| 1996 |
| 1997 |
A font file lists the polygons which make up a character set.
| 1998 |
| 1999 |
| 2000 |
All numbers are decimal integers:
| 2001 |
| 2002 |
<pre>
| 2003 |
greg |
1.46 |
code N
| 2004 |
greg |
1.1 |
x1 y1
| 2005 |
greg |
1.46 |
x2 y2
| 2006 |
greg |
1.1 |
| 2007 |
xn yn
| 2008 |
| 2009 |
</pre>
| 2010 |
| 2011 |
greg |
1.40 |
<p>
| 2012 |
| 2013 |
greg |
1.1 |
The ASCII codes can appear in any order. N is the number of vertices, and the last is automatically connected to the first.
| 2014 |
Separate polygonal sections are joined by coincident sides.
| 2015 |
The character coordinate system is a square with lower left corner at (0,0), lower right at (255,0) and upper right at (255,255).
| 2016 |
| 2017 |
<p>
| 2018 |
| 2019 |
<hr>
| 2020 |
| 2021 |
<h3>
| 2022 |
<a NAME="Generators">2.3. Generators</a>
| 2023 |
</h3>
| 2024 |
| 2025 |
A generator is any program that produces a scene description as its output.
| 2026 |
They usually appear as commands in a scene description file.
| 2027 |
An example of a simple generator is genbox.
| 2028 |
| 2029 |
<ul>
| 2030 |
| 2031 |
<li>
| 2032 |
<a NAME="Genbox" HREF="../man_html/genbox.1.html">
| 2033 |
<b>Genbox</b>
| 2034 |
</a>
| 2035 |
takes the arguments of width, height and depth to produce a parallelepiped description.
| 2036 |
<li>
| 2037 |
<a NAME="Genprism" HREF="../man_html/genprism.1.html">
| 2038 |
<b>Genprism</b>
| 2039 |
</a>
| 2040 |
takes a list of 2-dimensional coordinates and extrudes them along a vector to
| 2041 |
produce a 3-dimensional prism.
| 2042 |
<li>
| 2043 |
<a NAME="Genrev" HREF="../man_html/genrev.1.html">
| 2044 |
<b>Genrev</b>
| 2045 |
</a>
| 2046 |
is a more sophisticated generator that produces an object of rotation from parametric functions for radius and axis position.
| 2047 |
<li>
| 2048 |
<a NAME="Gensurf" HREF="../man_html/gensurf.1.html">
| 2049 |
<b>Gensurf</b>
| 2050 |
</a>
| 2051 |
tessellates a surface defined by the parametric functions x(s,t), y(s,t), and z(s,t).
| 2052 |
<li>
| 2053 |
<a NAME="Genworm" HREF="../man_html/genworm.1.html">
| 2054 |
<b>Genworm</b>
| 2055 |
</a>
| 2056 |
links cylinders and spheres along a curve.
| 2057 |
<li>
| 2058 |
<a NAME="Gensky" HREF="../man_html/gensky.1.html">
| 2059 |
<b>Gensky</b>
| 2060 |
</a>
| 2061 |
produces a sun and sky distribution corresponding to a given time and date.
| 2062 |
<li>
| 2063 |
<a NAME="Xform" HREF="../man_html/xform.1.html">
| 2064 |
<b>Xform</b>
| 2065 |
</a>
| 2066 |
is a program that transforms a scene description from one coordinate space to another.
| 2067 |
Xform does rotation, translation, scaling, and mirroring.
| 2068 |
| 2069 |
</ul>
| 2070 |
| 2071 |
<p>
| 2072 |
<hr>
| 2073 |
| 2074 |
<h2>
| 2075 |
<a NAME="Image">3. Image Generation</a>
| 2076 |
</h2>
| 2077 |
| 2078 |
Once the scene has been described in three-dimensions, it is possible to generate a two-dimensional image from a given perspective.
| 2079 |
| 2080 |
<p>
| 2081 |
The image generating programs use an <a NAME="octree"><b>octree</b></a> to efficiently trace rays through the scene.
| 2082 |
An octree subdivides space into nested octants which contain sets of surfaces.
| 2083 |
In RADIANCE, an octree is created from a scene description by <a NAME="oconv1" HREF="../man_html/oconv.1.html"><b>oconv</b></a>.
| 2084 |
The details of this process are not important, but the octree will serve as input to the ray-tracing programs and
| 2085 |
directs the use of a scene description.
| 2086 |
<ul>
| 2087 |
<li>
| 2088 |
greg |
1.30 |
<a NAME="rvu" HREF="../man_html/rvu.1.html"><b>Rvu</b></a> is ray-tracing program for viewing a scene interactively.
| 2089 |
greg |
1.3 |
When the user specifies a new perspective, rvu quickly displays a rough image on the terminal,
| 2090 |
greg |
1.1 |
then progressively increases the resolution as the user looks on.
| 2091 |
He can select a particular section of the image to improve, or move to a different view and start over.
| 2092 |
This mode of interaction is useful for debugging scenes as well as determining the best view for a final image.
| 2093 |
| 2094 |
<li>
| 2095 |
<a NAME="rpict" HREF="../man_html/rpict.1.html"><b>Rpict</b></a> produces a high-resolution picture of a scene from a particular perspective.
| 2096 |
This program features adaptive sampling, crash recovery and progress reporting, all of which are important for time-consuming images.
| 2097 |
</ul>
| 2098 |
<p>
| 2099 |
A number of <a NAME="filters"><b>filters</b></a> are available for manipulating picture files:
| 2100 |
<ul>
| 2101 |
<li> <a HREF="../man_html/pfilt.1.html"><b>Pfilt</b></a>
| 2102 |
sets the exposure and performs antialiasing.
| 2103 |
<li> <a HREF="../man_html/pcompos.1.html"><b>Pcompos</b></a>
| 2104 |
composites (cuts and pastes) pictures.
| 2105 |
<li> <a HREF="../man_html/pcomb.1.html"><b>Pcomb</b></a>
| 2106 |
performs arbitrary math on one or more pictures.
| 2107 |
<li> <a HREF="../man_html/pcond.1.html"><b>Pcond</b></a>
| 2108 |
conditions a picture for a specific display device.
| 2109 |
<li> <a HREF="../man_html/protate.1.html"><b>Protate</b></a>
| 2110 |
rotates a picture 90 degrees clockwise.
| 2111 |
<li> <a HREF="../man_html/pflip.1.html"><b>Pflip</b></a>
| 2112 |
flips a picture horizontally, vertically, or both
| 2113 |
(180 degree rotation).
| 2114 |
<li> <a HREF="../man_html/pvalue.1.html"><b>Pvalue</b></a>
| 2115 |
converts a picture to and from simpler formats.
| 2116 |
</ul>
| 2117 |
| 2118 |
<p>
| 2119 |
Pictures may be displayed directly under X11 using the program
| 2120 |
<a HREF="../man_html/ximage.1.html">ximage</a>,
| 2121 |
or converted a standard image format using one of the following
| 2122 |
<b>translators</b>:
| 2123 |
<ul>
| 2124 |
greg |
1.30 |
<li> <a HREF="../man_html/ra_bmp.1.html"><b>Ra_bmp</b></a>
| 2125 |
greg |
1.19 |
converts to and from BMP image format.
| 2126 |
greg |
1.1 |
<li> <a HREF="../man_html/ra_ppm.1.html"><b>Ra_ppm</b></a>
| 2127 |
converts to and from Poskanzer Portable Pixmap formats.
| 2128 |
<li> <a HREF="../man_html/ra_ps.1.html"><b>Ra_ps</b></a>
| 2129 |
converts to PostScript color and greyscale formats.
| 2130 |
<li> <a HREF="../man_html/ra_rgbe.1.html"><b>Ra_rgbe</b></a>
| 2131 |
converts to and from Radiance uncompressed picture format.
| 2132 |
<li> <a HREF="../man_html/ra_t16.1.html"><b>Ra_t16</b></a>
| 2133 |
converts to and from Targa 16 and 24-bit image formats.
| 2134 |
<li> <a HREF="../man_html/ra_t8.1.html"><b>Ra_t8</b></a>
| 2135 |
converts to and from Targa 8-bit image format.
| 2136 |
<li> <a HREF="../man_html/ra_tiff.1.html"><b>Ra_tiff</b></a>
| 2137 |
converts to and from TIFF.
| 2138 |
<li> <a HREF="../man_html/ra_xyze.1.html"><b>Ra_xyze</b></a>
| 2139 |
converts to and from Radiance CIE picture format.
| 2140 |
</ul>
| 2141 |
| 2142 |
<p>
| 2143 |
| 2144 |
<hr>
| 2145 |
| 2146 |
<h2>
| 2147 |
<a NAME="License">4. License</a>
| 2148 |
</h2>
| 2149 |
| 2150 |
<pre>
| 2151 |
greg |
1.43 |
The Radiance Software License, Version 2.0
| 2152 |
greg |
1.1 |
| 2153 |
greg |
1.43 |
Radiance v6.0 Copyright (c) 1990 to 2025, The Regents of the University of
| 2154 |
California, through Lawrence Berkeley National Laboratory (subject to receipt
| 2155 |
of any required approvals from the U.S. Dept. of Energy). All rights reserved.
| 2156 |
greg |
1.1 |
| 2157 |
Redistribution and use in source and binary forms, with or without
| 2158 |
greg |
1.43 |
modification, are permitted provided that the following conditions are met:
| 2159 |
greg |
1.1 |
| 2160 |
greg |
1.43 |
(1) Redistributions of source code must retain the above copyright notice,
| 2161 |
this list of conditions and the following disclaimer.
| 2162 |
greg |
1.1 |
| 2163 |
greg |
1.43 |
(2) Redistributions in binary form must reproduce the above copyright
| 2164 |
notice, this list of conditions and the following disclaimer in the
| 2165 |
documentation and/or other materials provided with the distribution.
| 2166 |
| 2167 |
(3) Neither the name of the University of California, Lawrence Berkeley
| 2168 |
National Laboratory, U.S. Dept. of Energy nor the names of its contributors
| 2169 |
may be used to endorse or promote products derived from this software
| 2170 |
without specific prior written permission.
| 2171 |
| 2172 |
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
| 2173 |
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
| 2174 |
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
| 2175 |
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
| 2176 |
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
| 2177 |
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
| 2178 |
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
| 2179 |
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
| 2180 |
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
| 2181 |
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
| 2182 |
POSSIBILITY OF SUCH DAMAGE.
| 2183 |
| 2184 |
You are under no obligation whatsoever to provide any bug fixes, patches,
| 2185 |
or upgrades to the features, functionality or performance of the source
| 2186 |
code ("Enhancements") to anyone; however, if you choose to make your
| 2187 |
Enhancements available either publicly, or directly to Lawrence Berkeley
| 2188 |
National Laboratory, without imposing a separate written license agreement
| 2189 |
for such Enhancements, then you hereby grant the following license: a
| 2190 |
non-exclusive, royalty-free perpetual license to install, use, modify,
| 2191 |
prepare derivative works, incorporate into other computer software,
| 2192 |
distribute, and sublicense such enhancements or derivative works thereof,
| 2193 |
in binary and source code form.
| 2194 |
greg |
1.1 |
</pre>
| 2195 |
| 2196 |
greg |
1.40 |
<p>
| 2197 |
| 2198 |
greg |
1.1 |
<hr>
| 2199 |
| 2200 |
<h2>
| 2201 |
<a NAME="Ack">5. Acknowledgements</a>
| 2202 |
</h2>
| 2203 |
| 2204 |
This work was supported by the Assistant Secretary of Conservation and Renewable Energy,
| 2205 |
Office of Building Energy Research and Development,
| 2206 |
Buildings Equipment Division of the U.S. Department of Energy under Contract No. DE-AC03-76SF00098.
| 2207 |
| 2208 |
<p>
| 2209 |
Additional work was sponsored by the Swiss federal government
| 2210 |
under the Swiss LUMEN Project and was carried out in the
| 2211 |
Laboratoire d'Energie Solaire (LESO Group) at the
| 2212 |
Ecole Polytechnique Federale de Lausanne (EPFL University) in Lausanne, Switzerland.
| 2213 |
| 2214 |
<p>
| 2215 |
| 2216 |
<hr>
| 2217 |
| 2218 |
<h2>
| 2219 |
<a NAME="Ref">6.</a> References
| 2220 |
</h2>
| 2221 |
<p>
| 2222 |
<ul>
| 2223 |
greg |
1.32 |
<li>Ward, Gregory J., Bruno Bueno, David Geisler-Moroder,
| 2224 |
Lars O. Grobe, Jacob C. Jonsson, Eleanor
| 2225 |
S. Lee, Taoning Wang, Helen Rose Wilson,
| 2226 |
"<a href="https://doi.org/10.1016/j.enbuild.2022.111890">Daylight
| 2227 |
Simulation Workflows Incorporating Measured Bidirectional
| 2228 |
Scattering Distribution Functions</a>"
| 2229 |
<em>Energy & Buildings</em>, Vol. 259, No. 11890, 2022.
| 2230 |
greg |
1.27 |
<li>Wang, Taoning, Gregory Ward, Eleanor Lee,
| 2231 |
"<a href="https://authors.elsevier.com/a/1XQ0a1M7zGwT7v">Efficient
| 2232 |
modeling of optically-complex, non-coplanar exterior shading:
| 2233 |
Validation of matrix algebraic methods</a>"
| 2234 |
<em>Energy & Buildings</em>, vol. 174, pp. 464-83, Sept. 2018.
| 2235 |
<li>Lee, Eleanor S., David Geisler-Moroder, Gregory Ward,
| 2236 |
"<a href="https://eta.lbl.gov/sites/default/files/publications/solar_energy.pdf">Modeling
| 2237 |
the direct sun component in buildings using matrix
| 2238 |
algebraic approaches: Methods and
| 2239 |
validation</a>," <em>Solar Energy</em>,
| 2240 |
vol. 160, 15 January 2018, pp 380-395.
| 2241 |
<li>Narain, Rahul, Rachel A. Albert, Abdullah Bulbul,
| 2242 |
Gregory J. Ward, Marty Banks, James F. O'Brien,
| 2243 |
"<a href="http://graphics.berkeley.edu/papers/Narain-OPI-2015-08/index.html">Optimal
| 2244 |
Presentation of Imagery with Focus
| 2245 |
Cues on Multi-Plane Displays</a>,"
| 2246 |
<em>SIGGRAPH 2015</em>.
| 2247 |
<li>Ward, Greg, Murat Kurt, and Nicolas Bonneel,
| 2248 |
"<a href="papers/WMAM14_Tensor_Tree_Representation.pdf">Reducing
| 2249 |
Anisotropic BSDF Measurement to Common Practice</a>,"
| 2250 |
<em>Workshop on Material Appearance Modeling</em>, 2014.
| 2251 |
<li>Banks, Martin, Abdullah Bulbul, Rachel Albert, Rahul Narain,
| 2252 |
James F. O'Brien, Gregory Ward,
| 2253 |
"<a href="http://graphics.berkeley.edu/papers/Banks-TPO-2014-05/index.html">The
| 2254 |
Perception of Surface Material from Disparity and Focus Cues</a>,"
| 2255 |
<em>VSS 2014</em>.
| 2256 |
greg |
1.19 |
<li>McNeil, A., C.J. Jonsson, D. Appelfeld, G. Ward, E.S. Lee,
| 2257 |
"<a href="http://gaia.lbl.gov/btech/papers/4414.pdf">
| 2258 |
A validation of a ray-tracing tool used to generate
| 2259 |
bi-directional scattering distribution functions for
| 2260 |
complex fenestration systems</a>,"
| 2261 |
<em>Solar Energy</em>, 98, 404-14,
| 2262 |
November 2013.
| 2263 |
greg |
1.15 |
<li>Ward, G., R. Mistrick, E.S. Lee, A. McNeil, J. Jonsson,
| 2264 |
greg |
1.17 |
"<a href="http://gaia.lbl.gov/btech/papers/4414.pdf">Simulating
| 2265 |
the Daylight Performance of Complex Fenestration Systems
| 2266 |
Using Bidirectional Scattering Distribution Functions within
| 2267 |
Radiance</a>,"
| 2268 |
greg |
1.18 |
<em>Leukos</em>, 7(4)
| 2269 |
greg |
1.15 |
April 2011.
| 2270 |
greg |
1.7 |
<li>Cater, Kirsten, Alan Chalmers, Greg Ward,
| 2271 |
greg |
1.9 |
"<a href="http://www.anyhere.com/gward/papers/egsr2003.pdf">Detail to Attention:
| 2272 |
greg |
1.7 |
Exploiting Visual Tasks for Selective Rendering</a>,"
| 2273 |
<em>Eurographics Symposium
| 2274 |
on Rendering 2003</em>, June 2003.
| 2275 |
greg |
1.1 |
<li>Ward, Greg, Elena Eydelberg-Vileshin,
| 2276 |
greg |
1.15 |
"<a HREF="http://www.anyhere.com/gward/papers/egwr02/index.html">Picture Perfect RGB
| 2277 |
Rendering Using Spectral Prefiltering and Sharp Color Primaries</a>,"
| 2278 |
greg |
1.1 |
Thirteenth Eurographics Workshop on Rendering (2002),
| 2279 |
P. Debevec and S. Gibson (Editors), June 2002.
| 2280 |
<li>Ward, Gregory,
| 2281 |
greg |
1.15 |
"<a HREF="http://www.anyhere.com/gward/papers/cic01.pdf">High Dynamic Range Imaging</a>,"
| 2282 |
greg |
1.1 |
Proceedings of the Ninth Color Imaging Conference, November 2001.
| 2283 |
<li>Ward, Gregory and Maryann Simmons,
| 2284 |
greg |
1.15 |
"<a HREF="http://www.anyhere.com/gward/papers/tog99.pdf">
| 2285 |
greg |
1.1 |
The Holodeck Ray Cache: An Interactive Rendering System for Global Illumination in Nondiffuse
| 2286 |
greg |
1.15 |
Environments</a>," ACM Transactions on Graphics, 18(4):361-98, October 1999.
| 2287 |
<li>Larson, G.W., "<a HREF="http://www.anyhere.com/gward/papers/ewp98.pdf">The Holodeck: A Parallel
| 2288 |
Ray-caching Rendering System</a>," Proceedings of the Second
| 2289 |
greg |
1.1 |
Eurographics Workshop on Parallel Graphics and Visualisation,
| 2290 |
September 1998.
| 2291 |
<li>Larson, G.W. and R.A. Shakespeare,
| 2292 |
greg |
1.2 |
<a HREF="http://radsite.lbl.gov/radiance/book/index.html"><em>Rendering with Radiance:
| 2293 |
greg |
1.1 |
the Art and Science of Lighting Visualization</em></a>,
| 2294 |
Morgan Kaufmann Publishers, 1998.
| 2295 |
<li>Larson, G.W., H. Rushmeier, C. Piatko,
| 2296 |
greg |
1.15 |
"<a HREF="http://radsite.lbl.gov/radiance/papers/lbnl39882/tonemap.pdf">A Visibility
| 2297 |
greg |
1.1 |
Matching Tone Reproduction Operator for
| 2298 |
greg |
1.15 |
High Dynamic Range Scenes</a>," LBNL Technical Report 39882,
| 2299 |
greg |
1.1 |
January 1997.
| 2300 |
greg |
1.15 |
<li>Ward, G., "<a HREF="http://radsite.lbl.gov/radiance/papers/erw95.1/paper.html">Making
| 2301 |
Global Illumination User-Friendly</a>," Sixth
| 2302 |
greg |
1.1 |
Eurographics Workshop on Rendering, Springer-Verlag,
| 2303 |
Dublin, Ireland, June 1995.</li>
| 2304 |
<li>Rushmeier, H., G. Ward, C. Piatko, P. Sanders, B. Rust,
| 2305 |
greg |
1.15 |
"<a HREF="http://radsite.lbl.gov/mgf/compare.html">
| 2306 |
greg |
1.1 |
Comparing Real and Synthetic Images: Some Ideas about
| 2307 |
greg |
1.15 |
Metrics</a>," Sixth Eurographics Workshop on Rendering,
| 2308 |
greg |
1.1 |
Springer-Verlag, Dublin, Ireland, June 1995.</li>
| 2309 |
greg |
1.15 |
<li>Ward, G., "<a HREF="http://radsite.lbl.gov/radiance/papers/sg94.1/paper.html">The RADIANCE
| 2310 |
Lighting Simulation and Rendering System</a>," <em>Computer
| 2311 |
greg |
1.1 |
Graphics</em>, July 1994.</li>
| 2312 |
greg |
1.15 |
<li>Rushmeier, H., G. Ward, "<a HREF="http://radsite.lbl.gov/radiance/papers/sg94.2/energy.html">Energy
| 2313 |
Preserving Non-Linear Filters</a>," <em>Computer
| 2314 |
greg |
1.1 |
| 2315 |
greg |
1.15 |
<li>Ward, G., "A Contrast-Based Scalefactor for Luminance
| 2316 |
Display," <em>Graphics Gems IV</em>, Edited by Paul Heckbert,
| 2317 |
greg |
1.1 |
Academic Press 1994.</li>
| 2318 |
greg |
1.15 |
<li>Ward, G., "<a HREF="http://radsite.lbl.gov/radiance/papers/sg92/paper.html">Measuring and
| 2319 |
Modeling Anisotropic Reflection</a>," <em>Computer
| 2320 |
greg |
1.1 |
Graphics</em>, Vol. 26, No. 2, July 1992. </li>
| 2321 |
greg |
1.15 |
<li>Ward, G., P. Heckbert, "<a HREF="http://radsite.lbl.gov/radiance/papers/erw92/paper.html">Irradiance
| 2322 |
Gradients</a>," Third Annual Eurographics Workshop on
| 2323 |
greg |
1.1 |
Rendering, Springer-Verlag, May 1992. </li>
| 2324 |
greg |
1.15 |
<li>Ward, G., "<a HREF="http://radsite.lbl.gov/radiance/papers/erw91/erw91.html">Adaptive Shadow
| 2325 |
Testing for Ray Tracing</a>" Photorealistic Rendering in
| 2326 |
greg |
1.1 |
Computer Graphics, proceedings of 1991 Eurographics
| 2327 |
Rendering Workshop, edited by P. Brunet and F.W. Jansen,
| 2328 |
Springer-Verlag. </li>
| 2329 |
greg |
1.15 |
<li>Ward, G., "Visualization," <em>Lighting Design and
| 2330 |
greg |
1.1 |
Application</em>, Vol. 20, No. 6, June 1990. </li>
| 2331 |
greg |
1.15 |
<li>Ward, G., F. Rubinstein, R. Clear, "<a HREF="http://radsite.lbl.gov/radiance/papers/sg88/paper.html">A Ray Tracing Solution for
| 2332 |
Diffuse Interreflection</a>," <em>Computer Graphics</em>,
| 2333 |
greg |
1.1 |
Vol. 22, No. 4, August 1988. </li>
| 2334 |
greg |
1.15 |
<li>Ward, G., F. Rubinstein, "A New Technique for Computer
| 2335 |
Simulation of Illuminated Spaces," <em>Journal of the
| 2336 |
greg |
1.1 |
Illuminating Engineering Society</em>, Vol. 17, No. 1,
| 2337 |
Winter 1988. </li>
| 2338 |
</ul>
| 2339 |
<p>
| 2340 |
See the <a HREF="index.html">RADIANCE Reference Materials</a> page
| 2341 |
for additional information.
| 2342 |
<hr>
| 2343 |
| 2344 |
<a NAME="Index"><h2>7. Types Index</h2></a>
| 2345 |
| 2346 |
<pre>
| 2347 |
<h4>
| 2348 |
SURFACES MATERIALS TEXTURES PATTERNS MIXTURES</h4>
| 2349 |
<a HREF="#Source">Source</a> <a HREF="#Light">Light</a> <a HREF="#Texfunc">Texfunc</a> <a HREF="#Colorfunc">Colorfunc</a> <a HREF="#Mixfunc">Mixfunc</a>
| 2350 |
<a HREF="#Sphere">Sphere</a> <a HREF="#Illum">Illum</a> <a HREF="#Texdata">Texdata</a> <a HREF="#Brightfunc">Brightfunc</a> <a HREF="#Mixdata">Mixdata</a>
| 2351 |
<a HREF="#Bubble">Bubble</a> <a HREF="#Glow">Glow</a> <a HREF="#Colordata">Colordata</a> <a HREF="#Mixtext">Mixtext</a>
| 2352 |
<a HREF="#Polygon">Polygon</a> <a HREF="#Spotlight">Spotlight</a> <a HREF="#Brightdata">Brightdata</a>
| 2353 |
<a HREF="#Cone">Cone</a> <a HREF="#Mirror">Mirror</a> <a HREF="#Colorpict">Colorpict</a>
| 2354 |
<a HREF="#Cup">Cup</a> <a HREF="#Prism1">Prism1</a> <a HREF="#Colortext">Colortext</a>
| 2355 |
<a HREF="#Cylinder">Cylinder</a> <a HREF="#Prism2">Prism2</a> <a HREF="#Brighttext">Brighttext</a>
| 2356 |
<a HREF="#Tube">Tube</a> <a HREF="#Plastic">Plastic</a>
| 2357 |
<a HREF="#Ring">Ring</a> <a HREF="#Metal">Metal</a>
| 2358 |
<a HREF="#Instance">Instance</a> <a HREF="#Trans">Trans</a>
| 2359 |
<a HREF="#Mesh">Mesh</a> <a HREF="#Plastic2">Plastic2</a>
| 2360 |
<a HREF="#Metal2">Metal2</a>
| 2361 |
<a HREF="#Trans2">Trans2</a>
| 2362 |
<a HREF="#Mist">Mist</a>
| 2363 |
<a HREF="#Dielectric">Dielectric</a>
| 2364 |
<a HREF="#Interface">Interface</a>
| 2365 |
<a HREF="#Glass">Glass</a>
| 2366 |
<a HREF="#Plasfunc">Plasfunc</a>
| 2367 |
<a HREF="#Metfunc">Metfunc</a>
| 2368 |
<a HREF="#Transfunc">Transfunc</a>
| 2369 |
| 2370 |
<a HREF="#Plasdata">Plasdata</a>
| 2371 |
<a HREF="#Metdata">Metdata</a>
| 2372 |
<a HREF="#Transdata">Transdata</a>
| 2373 |
greg |
1.10 |
<a HREF="#BSDF">BSDF</a>
| 2374 |
greg |
1.1 |
<a HREF="#Antimatter">Antimatter</a>
| 2375 |
| 2376 |
</pre>
| 2377 |
| 2378 |
<p>
| 2379 |
| 2380 |
| 2381 |
<hr>
| 2382 |
<center>Last Update: October 22, 1997</center>
| 2383 |
</body>
| 2384 |
</html>
| 2385 |
