--- ray/doc/ray.1 2018/10/08 20:18:27 1.37 +++ ray/doc/ray.1 2023/11/17 20:02:07 1.43 @@ -1,8 +1,8 @@ -.\" RCSid "$Id: ray.1,v 1.37 2018/10/08 20:18:27 greg Exp $" +.\" RCSid "$Id: ray.1,v 1.43 2023/11/17 20:02:07 greg Exp $" .\" Print using the -ms macro package -.DA 10/08/2018 +.DA 11/13/2023 .LP -.tl """Copyright \(co 2018 Regents, University of California +.tl """Copyright \(co 2023 Regents, University of California .sp 2 .TL The @@ -630,6 +630,8 @@ arguments have additional flexibility to specify the s Also, rather than roughness, specular power is used, which has no physical meaning other than larger numbers are equivalent to a smoother surface. +Unlike other material types, total reflectance is the sum of +diffuse and specular colors, and should be adjusted accordingly. .DS mod ashik2 id 4+ ux uy uz funcfile transform @@ -1192,6 +1194,71 @@ A section of text meant to depict a picture, perhaps u font such as hexbit4x1.fnt, calls for uniform spacing. Reasonable magnitudes for proportional spacing are between 0.1 (for tightly spaced characters) and 0.3 (for wide spacing). +.LP +.UL Spectrum +.PP +The spectrum primitive is the most basic type for introducing spectral +color to a material. +Since materials only provide RGB parameters, spectral patterns +are the only way to superimpose wavelength-dependent behavior. +.DS +mod spectrum id +0 +0 +5+ nmA nmB s1 s2 .. sN +.DE +The first two real arguments indicate the extrema of the +spectral range in nanometers. +Subsequent real values correspond to multipliers in at each wavelength. +The nmA wavelength may be greater or less than nmB, +but they may not be equal, and their ordering matches +the order of the spectral values. +A minimum of 3 values must be given, which would act +more or less the same as a constant RGB multiplier. +As with RGB values, spectral quantities normally range between 0 +and 1 at each wavelength, or average to 1.0 against a standard +sensitivity functions such as V(lambda). +The best results obtain when the spectral range and number +of samples match rendering options, though resampling will handle +any differences, zero-filling wavelenths outside the nmA to nmB +range. +A warning will be issued if the given wavelength range does not +adequately cover the visible spectrum. +.LP +.UL Specfile +.PP +The specfile primitive is equivalent to the spectrum type, but +the wavelength range and values are contained in a 1-dimensional +data file. +This may be a more convenient way to specify a spectral color, +especially one corresponding to a standard illuminant such as D65 +or a library of measured spectra. +.DS +mod specfile id +1 datafile +0 +0 +.DE +As with the spectrum type, rendering wavelengths outside the defined +range will be zero-filled. +Unlike the spectrum type, the file may contain non-uniform samples. +.LP +.UL Specfunc +.PP +The specfunc primitive offers dynamic control over a spectral +pattern, similar to the colorfunc type. +.DS +mod specfunc id +2+ sval funcfile transform +0 +2+ nmA nmB A3 .. +.DE +Like the spectrum primitive, the wavelength range is specified +in the first two real arguments, and additional real values are +accessible to the sval function. +This function is fed a wavelenth sample +between nmA and nmB as its only argument, +and it returns the corresponding spectral intensity. .NH 3 Mixtures .PP @@ -1593,6 +1660,14 @@ the Ecole Polytechnique Federale de Lausanne (EPFL Uni in Lausanne, Switzerland. .NH 1 References +.LP +Ward, Gregory J., Bruno Bueno, David Geisler-Moroder, +Lars O. Grobe, Jacob C. Jonsson, Eleanor +S. Lee, Taoning Wang, Helen Rose Wilson, +``Daylight Simulation Workflows Incorporating +Measured Bidirectional Scattering Distribution Functions,'' +.I "Energy & Buildings", +Vol. 259, No. 111890, 2022. .LP Wang, Taoning, Gregory Ward, Eleanor Lee, ``Efficient modeling of optically-complex, non-coplanar
