--- ray/doc/ray.1 2011/06/21 23:58:00 1.20 +++ ray/doc/ray.1 2014/07/31 18:32:41 1.26 @@ -1,8 +1,8 @@ -.\" RCSid "$Id" +.\" RCSid "$Id: ray.1,v 1.26 2014/07/31 18:32:41 greg Exp $" .\" Print using the -ms macro package -.DA 2/17/2011 +.DA 07/31/2014 .LP -.tl """Copyright \(co 2011 Regents, University of California +.tl """Copyright \(co 2014 Regents, University of California .sp 2 .TL The @@ -899,9 +899,7 @@ a parallel BSDF surface may be placed slightly less than the given thickness away from the front surface to enclose the complex geometry on both sides. The sign of the thickness is important, as it indicates whether the -proxied geometry is behind the. -.I BSDF -surface (when thickness is positive) +proxied geometry is behind the BSDF surface (when thickness is positive) or in front (when thickness is negative). .LP The second string argument is the name of the BSDF file, which is @@ -1553,6 +1551,20 @@ the Ecole Polytechnique Federale de Lausanne (EPFL Uni in Lausanne, Switzerland. .NH 1 References +.LP +McNeil, A., C.J. Jonsson, D. Appelfeld, G. Ward, E.S. Lee, +``A validation of a ray-tracing tool used to generate +bi-directional scattering distribution functions for +complex fenestration systems,'' +.I "Solar Energy", +98, 404-14, November 2013. +.LP +Ward, G., R. Mistrick, E.S. Lee, A. McNeil, J. Jonsson, +``Simulating the Daylight Performance of Complex Fenestration Systems +Using Bidirectional Scattering Distribution Functions within Radiance,'' +.I "Leukos", +7(4), +April 2011. .LP Cater, K., A. Chalmers, G. Ward, ``Detail to Attention: Exploiting Visual Tasks for Selective Rendering,''
