--- ray/doc/ray.1 2011/02/20 06:34:19 1.19 +++ ray/doc/ray.1 2011/07/15 17:45:46 1.22 @@ -898,6 +898,9 @@ If the BSDF has transmission and back-side reflection a parallel BSDF surface may be placed slightly less than the given thickness away from the front surface to enclose the complex geometry on both sides. +The sign of the thickness is important, as it indicates whether the +proxied geometry is behind the BSDF surface (when thickness is positive) +or in front (when thickness is negative). .LP The second string argument is the name of the BSDF file, which is found in the usual auxiliary locations. @@ -1548,6 +1551,12 @@ the Ecole Polytechnique Federale de Lausanne (EPFL Uni in Lausanne, Switzerland. .NH 1 References +.LP +Ward, G., R. Mistrick, E.S. Lee, A. McNeil, J. Jonsson, +``Simulating the Daylight Performance of Complex Fenestration Systems +Using Bidirectional Scattering Distribution Functions within Radiance'' +.I "Journal of the Illuminating Engineering Soc. of North America", +April 2011. .LP Cater, K., A. Chalmers, G. Ward, ``Detail to Attention: Exploiting Visual Tasks for Selective Rendering,''
