--- ray/doc/ray.1 2003/03/11 19:20:20 1.1 +++ ray/doc/ray.1 2003/03/11 19:29:04 1.2 @@ -129,6 +129,8 @@ by the real arguments. An alias gets its type and arguments from a previously defined primitive. This is useful when the same material is used with a different modifier, or as a convenient naming mechanism. +The reserved modifier name "inherit" may be used to specificy that +an alias will inherit its modifier from the original. Surfaces cannot be aliased. .PP A line beginning with an exclamation point, `!',
