root/radiance/ray/doc/ray.1
Revision: 1.48
Committed: Thu May 29 16:42:28 2025 UTC (2 months, 1 week ago) by greg
Changes since 1.47: +18 -1 lines
fix: Updated behavior of "mirror" type to handle indirect transmission, thanks to Jon Sargent
1 .\" RCSid "$Id: ray.1,v 1.47 2024/12/09 19:21:38 greg Exp $"
2 .\" Print using the -ms macro package
3 .DA 12/09/2024
4 .LP
5 .tl """Copyright \(co 2024 Regents, University of California
6 .sp 2
7 .TL
8 The
9 .so ../src/rt/VERSION
10 .br
11 Synthetic Imaging System
12 .AU
13 Building Technologies Department
14 .br
15 Lawrence Berkeley Laboratory
16 .br
17 1 Cyclotron Rd., MS 90-3111
18 .br
19 Berkeley, CA 94720
20 .NH 1
21 Introduction
22 .PP
23 RADIANCE was developed as a research tool
24 for predicting the distribution of visible radiation in
25 illuminated spaces.
26 It takes as input a three-dimensional geometric model of
27 the physical environment, and produces a map of
28 spectral radiance values in a color image.
29 The technique of ray-tracing follows light backwards
30 from the image plane to the source(s).
31 Because it can produce realistic images from a simple description,
32 RADIANCE has a wide range of applications in graphic arts,
33 lighting design, computer-aided engineering and architecture.
34 .KF
35 .sp 25
36 .ce
37 .B "Figure 1."
38 .sp
39 .KE
40 .PP
41 The diagram in Figure 1 shows the flow between programs (boxes) and
42 data (ovals).
43 The central program is
44 .I rpict,
45 which produces a picture from a scene description.
46 .I Rview
47 is a variation of
48 .I rpict
49 that computes and displays images interactively.
50 Other programs (not shown) connect many of these elements together,
51 such as the executive programs
52 .I rad
53 and
54 .I ranimate,
55 the interactive rendering program
56 .I rholo,
57 and the animation program
58 .I ranimove.
59 The program
60 .I obj2mesh
61 acts as both a converter and scene compiler, converting a Wavefront .OBJ
62 file into a compiled mesh octree for efficient rendering.
63 .PP
64 A scene description file lists the surfaces and materials
65 that make up a specific environment.
66 The current surface types are spheres, polygons, cones, and cylinders.
67 There is also a composite surface type, called mesh, and a pseudosurface
68 type, called instance, which facilitates very complex geometries.
69 Surfaces can be made from materials such as plastic, metal, and glass.
70 Light sources can be distant disks as well as local spheres, disks
71 and polygons.
72 .PP
73 From a three-dimensional scene description and a specified view,
74 .I rpict
75 produces a two-dimensional image.
76 A picture file is a compressed binary representation of the
77 pixels in the image.
78 This picture can be scaled in size and
79 brightness, anti-aliased, and sent to a graphics output device.
80 .PP
81 A header in each picture file lists the program(s) and
82 parameters that produced it.
83 This is useful for identifying a picture
84 without having to display it.
85 The information can be read by the program
86 .I getinfo.
87 .NH 1
88 Scene Description
89 .PP
90 A scene description file represents a
91 three-dimensional physical environment
92 in Cartesian (rectilinear) world coordinates.
93 It is stored as ASCII text, with the following basic format:
94 .DS
95 # comment
96
97 modifier type identifier
98 n S1 S2 "S 3" .. Sn
99 0
100 m R1 R2 R3 .. Rm
101
102 modifier alias identifier reference
103
104 ! command
105
106 ...
107 .DE
108 .PP
109 A comment line begins with a pound sign, `#'.
110 .PP
111 The scene description
112 .I primitives
113 all have the same general format, and can
114 be either surfaces or modifiers.
115 A primitive has a modifier, a type, and an identifier.
116 A modifier is either the identifier of a
117 .I "previously defined"
118 primitive, or "void"\(dg.
119 .FS
120 \(dgThe most recent definition of a modifier is the one used,
121 and later definitions do not cause relinking of loaded
122 primitives.
123 Thus, the same identifier may be used repeatedly, and each new
124 definition will apply to the primitives following it.
125 .FE
126 An identifier can be any string (i.e., any sequence of non-white characters).
127 The
128 .I arguments
129 associated with a primitive can be strings or real numbers.
130 The first integer following the identifier is the number
131 of string arguments, and it is followed by the arguments themselves
132 (separated by white space or enclosed in quotes).
133 The next integer is the number of integer arguments, and is followed
134 by the integer arguments.
135 (There are currently no primitives that use them, however.)
136 The next integer is the real argument count, and it is followed
137 by the real arguments.
138 .PP
139 An alias gets its type and arguments from a previously defined primitive.
140 This is useful when the same material is used with a different
141 modifier, or as a convenient naming mechanism.
142 The reserved modifier name "inherit" may be used to specificy that
143 an alias will inherit its modifier from the original.
144 Surfaces cannot be aliased.
145 .PP
146 A line beginning with an exclamation point, `!',
147 is interpreted as a command.
148 It is executed by the shell, and its output is read as input to
149 the program.
150 The command must not try to read from its standard input, or
151 confusion will result.
152 A command may be continued over multiple lines using a backslash, `\\',
153 to escape the newline.
154 .PP
155 White space is generally ignored, except as a separator.
156 The exception is the newline character after a command or comment.
157 Commands, comments and primitives may appear in any combination, so long
158 as they are not intermingled.
159 .NH 2
160 Primitive Types
161 .PP
162 Primitives can be surfaces, materials, textures or patterns.
163 Modifiers can be materials, mixtures, textures or patterns.
164 Simple surfaces must have one material in their modifier list.
165 .NH 3
166 Surfaces
167 .PP
168 A scene description will consist mostly of surfaces.
169 The basic types are given below.
170 .LP
171 .UL Source
172 .PP
173 A source is not really a surface, but a solid angle.
174 It is used for specifying light sources that are very distant.
175 The direction to the center of the source and the number of degrees
176 subtended by its disk are given as follows:
177 .DS
178 mod source id
179 0
180 0
181 4 xdir ydir zdir angle
182 .DE
183 .LP
184 .UL Sphere
185 .PP
186 A sphere is given by its center and radius:
187 .DS
188 mod sphere id
189 0
190 0
191 4 xcent ycent zcent radius
192 .DE
193 .LP
194 .UL Bubble
195 .PP
196 A bubble is simply a sphere whose surface normal points inward.
197 .LP
198 .UL Polygon
199 .PP
200 A polygon is given by a list of three-dimensional vertices,
201 which are ordered counter-clockwise as viewed from
202 the front side (into the surface normal).
203 The last vertex is automatically connected to the first.
204 Holes are represented in polygons as interior vertices connected to
205 the outer perimeter by coincident edges (seams).
206 .DS
207 mod polygon id
208 0
209 0
210 3n
211 x1 y1 z1
212 x2 y2 z2
213 ...
214 xn yn zn
215 .DE
216 .LP
217 .UL Cone
218 .PP
219 A cone is a megaphone-shaped object.
220 It is truncated by two planes perpendicular to its axis,
221 and one of its ends may come to a point.
222 It is given as two axis endpoints, and the starting
223 and ending radii:
224 .DS
225 mod cone id
226 0
227 0
228 8
229 x0 y0 z0
230 x1 y1 z1
231 r0 r1
232 .DE
233 .LP
234 .UL Cup
235 .PP
236 A cup is an inverted cone (i.e., has an inward surface normal).
237 .LP
238 .UL Cylinder
239 .PP
240 A cylinder is like a cone, but its starting and ending radii are
241 equal.
242 .DS
243 mod cylinder id
244 0
245 0
246 7
247 x0 y0 z0
248 x1 y1 z1
249 rad
250 .DE
251 .LP
252 .UL Tube
253 .PP
254 A tube is an inverted cylinder.
255 .LP
256 .UL Ring
257 .PP
258 A ring is a circular disk given by its center, surface
259 normal, and inner and outer radii:
260 .DS
261 mod ring id
262 0
263 0
264 8
265 xcent ycent zcent
266 xdir ydir zdir
267 r0 r1
268 .DE
269 .LP
270 .UL Mesh
271 .PP
272 A mesh is a compound surface, made up of many triangles and
273 an octree data structure to accelerate ray intersection.
274 It is typically converted from a Wavefront .OBJ file using the
275 .I obj2mesh
276 program.
277 .DS
278 mod mesh id
279 1+ meshfile transform
280 0
281 0
282 .DE
283 If the modifier is "void", then surfaces will use the modifiers given
284 in the original mesh description.
285 Otherwise, the modifier specified is used in their place.
286 The transform moves the mesh to the desired location in the scene.
287 Multiple instances using the same meshfile take little extra memory,
288 and the compiled mesh itself takes much less space than individual
289 polygons would.
290 In the case of an unsmoothed mesh, using the mesh primitive reduces
291 memory requirements by a factor of 30 relative to individual triangles.
292 If a mesh has smoothed surfaces, we save a factor of 50 or more,
293 permitting very detailed geometries that would otherwise exhaust the
294 available memory.
295 In addition, the mesh primitive can have associated (u,v) coordinates
296 for pattern and texture mapping.
297 These are made available to function files via the Lu and Lv variables.
298 .LP
299 .UL Instance
300 .PP
301 An instance is a compound surface, given by the contents of an
302 octree file (created by oconv).
303 .DS
304 mod instance id
305 1+ octree transform
306 0
307 0
308 .DE
309 If the modifier is "void", then surfaces will use the modifiers given
310 in the original description.
311 Otherwise, the modifier specified is used in their place.
312 The transform moves the octree to the desired location in the scene.
313 Multiple instances using the same octree take little extra memory,
314 hence very complex descriptions can be rendered using this primitive.
315 .PP
316 There are a number of important limitations to be aware of when using
317 instances.
318 First, the scene description used to generate the octree must stand on
319 its own, without referring to modifiers in the parent description.
320 This is necessary for oconv to create the octree.
321 Second, light sources in the octree will not be incorporated correctly
322 in the calculation, and they are not recommended.
323 Finally, there is no advantage (other than convenience) to
324 using a single instance of an octree, or an octree containing only a
325 few surfaces.
326 An xform command on the subordinate description is prefered in such cases.
327 .NH 3
328 Materials
329 .PP
330 A material defines the way light interacts with a surface.
331 The basic types are given below.
332 .LP
333 .UL Light
334 .PP
335 Light is the basic material for self-luminous surfaces (i.e., light
336 sources).
337 In addition to the source surface type, spheres, discs (rings with zero
338 inner radius), cylinders (provided they are long enough), and
339 polygons can act as light sources.
340 Polygons work best when they are rectangular.
341 Cones cannot be used at this time.
342 A pattern may be used to specify a light output distribution.
343 Light is defined simply as a RGB radiance value (watts/steradian/m2):
344 .DS
345 mod light id
346 0
347 0
348 3 red green blue
349 .DE
350 .LP
351 .UL Illum
352 .PP
353 Illum is used for secondary light sources with broad distributions.
354 A secondary light source is treated like any other
355 light source, except when viewed directly.
356 It then acts like it is made of a different material (indicated by
357 the string argument), or becomes invisible (if no string argument is given,
358 or the argument is "void").
359 Secondary sources are useful when modeling windows or
360 brightly illuminated surfaces.
361 .DS
362 mod illum id
363 1 material
364 0
365 3 red green blue
366 .DE
367 .LP
368 .UL Glow
369 .PP
370 Glow is used for surfaces that are self-luminous, but limited
371 in their effect.
372 In addition to the radiance value, a maximum radius for
373 shadow testing is given:
374 .DS
375 mod glow id
376 0
377 0
378 4 red green blue maxrad
379 .DE
380 If maxrad is zero, then the surface will never be tested
381 for shadow, although it may participate in an interreflection calculation.
382 If maxrad is negative, then the surface will never contribute to scene
383 illumination.
384 Glow sources will never illuminate objects on the other side of an
385 illum surface.
386 This provides a convenient way to illuminate local light fixture
387 geometry without overlighting nearby objects.
388 .LP
389 .UL Spotlight
390 .PP
391 Spotlight is used for self-luminous surfaces having directed output.
392 As well as radiance, the full cone angle (in degrees)
393 and orientation (output direction) vector are given.
394 The length of the orientation vector is the distance
395 of the effective focus behind the source center (i.e., the focal length).
396 .DS
397 mod spotlight id
398 0
399 0
400 7 red green blue angle xdir ydir zdir
401 .DE
402 .LP
403 .UL Mirror
404 .PP
405 Mirror is used for planar surfaces that produce virtual
406 source reflections.
407 This material should be used sparingly, as it may cause the light
408 source calculation to blow up if it is applied to many small surfaces.
409 This material is only supported for flat surfaces such as polygons
410 and rings.
411 The arguments are simply the RGB reflectance values, which should be
412 between 0 and 1.
413 An optional string argument may be used like the illum type to specify a
414 different material to be used for shading non-source rays.
415 If this alternate material is given as "void", then the mirror surface
416 will be invisible.
417 This is only appropriate if the surface hides other (more detailed)
418 geometry with the same overall reflectance.
419 .DS
420 mod mirror id
421 1 material
422 0
423 3 red green blue
424 .DE
425 While alternate materials that are reflective will appear as normal,
426 indirect rays will use the mirror's reflectance rather than the
427 alternate type.
428 Transmitting materials are an exception, where both transmission and
429 reflection will use the alternate type for all rays not specifically
430 targeting virtual light sources.
431 Therefore, transmitting alternate types should only have pure specular
432 reflection if they reflect at all, to maintain a valid calculation.
433 .PP
434 The mirror material type reflects light sources only from the front side
435 of a surface, regardless of any alternate material.
436 If virtual source generation is desired on both sides, two coincident
437 surfaces with opposite normal orientations may be employed to achieve
438 this effect.
439 The reflectance and alternate material type may be
440 different for the overlapped surfaces,
441 and the two sides will behave accordingly.
442 .LP
443 .UL Prism1
444 .PP
445 The prism1 material is for general light redirection from prismatic
446 glazings, generating virtual light sources.
447 It can only be used to modify a planar surface (i.e., a polygon or disk)
448 and should not result in either light concentration or scattering.
449 The new direction of the ray can be on either side of the material,
450 and the definitions must have the correct bidirectional properties
451 to work properly with virtual light sources.
452 The arguments give the coefficient for the redirected light
453 and its direction.
454 .DS
455 mod prism1 id
456 5+ coef dx dy dz funcfile transform
457 0
458 n A1 A2 .. An
459 .DE
460 The new direction variables
461 .I "dx, dy"
462 and
463 .I dz
464 need not produce a normalized vector.
465 For convenience, the variables
466 .I "DxA, DyA"
467 and
468 .I DzA
469 are defined as the normalized direction to the target light source.
470 See section 2.2.1 on function files for further information.
471 .LP
472 .UL Prism2
473 .PP
474 The material prism2 is identical to prism1 except that
475 it provides for two ray redirections rather than one.
476 .DS
477 mod prism2 id
478 9+ coef1 dx1 dy1 dz1 coef2 dx2 dy2 dz2 funcfile transform
479 0
480 n A1 A2 .. An
481 .DE
482 .LP
483 .UL Mist
484 .PP
485 Mist is a virtual material used to delineate a volume
486 of participating atmosphere.
487 A list of important light sources may be given, along with an
488 extinction coefficient, scattering albedo and scattering eccentricity
489 parameter.
490 The light sources named by the string argument list
491 will be tested for scattering within the volume.
492 Sources are identified by name, and virtual light sources may be indicated
493 by giving the relaying object followed by '>' followed by the source, i.e:
494 .DS
495 3 source1 mirror1>source10 mirror2>mirror1>source3
496 .DE
497 Normally, only one source is given per mist material, and there is an
498 upper limit of 32 to the total number of active scattering sources.
499 The extinction coefficient, if given, is added to the global
500 coefficient set on the command line.
501 Extinction is in units of 1/distance (distance based on the world coordinates),
502 and indicates the proportional loss of radiance over one unit distance.
503 The scattering albedo, if present, will override the global setting within
504 the volume.
505 An albedo of 0\00\00 means a perfectly absorbing medium, and an albedo of
506 1\01\01\0 means
507 a perfectly scattering medium (no absorption).
508 The scattering eccentricity parameter will likewise override the global
509 setting if it is present.
510 Scattering eccentricity indicates how much scattered light favors the
511 forward direction, as fit by the Henyey-Greenstein function:
512 .DS
513 P(theta) = (1 - g*g) / (1 + g*g - 2*g*cos(theta))^1.5
514 .DE
515 A perfectly isotropic scattering medium has a g parameter of 0, and
516 a highly directional material has a g parameter close to 1.
517 Fits to the g parameter may be found along with typical extinction
518 coefficients and scattering albedos for various atmospheres and
519 cloud types in USGS meteorological tables.
520 (A pattern will be applied to the extinction values.)\0
521 .DS
522 mod mist id
523 N src1 src2 .. srcN
524 0
525 0|3|6|7 [ rext gext bext [ ralb galb balb [ g ] ] ]
526 .DE
527 There are two usual uses of the mist type.
528 One is to surround a beam from a spotlight or laser so that it is
529 visible during rendering.
530 For this application, it is important to use a cone (or cylinder) that
531 is long enough and wide enough to contain the important visible portion.
532 Light source photometry and intervening objects will have the desired
533 effect, and crossing beams will result in additive scattering.
534 For this application, it is best to leave off the real arguments, and
535 use the global rendering parameters to control the atmosphere.
536 The second application is to model clouds or other localized media.
537 Complex boundary geometry may be used to give shape to a uniform medium,
538 so long as the boundary encloses a proper volume.
539 Alternatively, a pattern may be used to set the line integral value
540 through the cloud for a ray entering or exiting a point in a given
541 direction.
542 For this application, it is best if cloud volumes do not overlap each other,
543 and opaque objects contained within them may not be illuminated correctly
544 unless the line integrals consider enclosed geometry.
545 .LP
546 .UL Plastic
547 .PP
548 Plastic is a material with uncolored highlights.
549 It is given by its RGB reflectance, its fraction of specularity,
550 and its roughness value.
551 Roughness is specified as the rms slope of surface facets.
552 A value of 0 corresponds to a perfectly smooth surface, and
553 a value of 1 would be a very rough surface.
554 Specularity fractions greater than 0.1 and
555 roughness values greater than 0.2 are not very
556 realistic.
557 (A pattern modifying plastic will affect the material color.)
558 .DS
559 mod plastic id
560 0
561 0
562 5 red green blue spec rough
563 .DE
564 .LP
565 .UL Metal
566 .PP
567 Metal is similar to plastic, but specular highlights
568 are modified by the material color.
569 Specularity of metals is usually .9 or greater.
570 As for plastic, roughness values above .2 are uncommon.
571 .LP
572 .UL Trans
573 .PP
574 Trans is a translucent material, similar to plastic.
575 The transmissivity is the fraction of penetrating light that
576 travels all the way through the material.
577 The transmitted specular component is the fraction of transmitted
578 light that is not diffusely scattered.
579 Transmitted and diffusely reflected light is modified by the material color.
580 Translucent objects are infinitely thin.
581 .DS
582 mod trans id
583 0
584 0
585 7 red green blue spec rough trans tspec
586 .DE
587 .LP
588 .UL Plastic2
589 .PP
590 Plastic2 is similar to plastic, but with anisotropic
591 roughness.
592 This means that highlights in the surface will appear elliptical rather
593 than round.
594 The orientation of the anisotropy is determined by the unnormalized
595 direction vector
596 .I "ux uy uz".
597 These three expressions (separated by white space) are evaluated in
598 the context of the function file
599 .I funcfile.
600 If no function file is required (i.e., no special variables or
601 functions are required), a period (`.') may be given in its
602 place.
603 (See the discussion of Function Files in the Auxiliary Files section).
604 The
605 .I urough
606 value defines the roughness along the
607 .B u
608 vector given projected onto the surface.
609 The
610 .I vrough
611 value defines the roughness perpendicular to this vector.
612 Note that the highlight will be narrower in the direction of the
613 smaller roughness value.
614 Roughness values of zero are not allowed for efficiency reasons
615 since the behavior would be the same as regular plastic in that
616 case.
617 .DS
618 mod plastic2 id
619 4+ ux uy uz funcfile transform
620 0
621 6 red green blue spec urough vrough
622 .DE
623 .LP
624 .UL Metal2
625 .PP
626 Metal2 is the same as plastic2, except that the highlights are
627 modified by the material color.
628 .LP
629 .UL Trans2
630 .PP
631 Trans2 is the anisotropic version of trans.
632 The string arguments are the same as for plastic2, and the real
633 arguments are the same as for trans but with an additional roughness
634 value.
635 .DS
636 mod trans2 id
637 4+ ux uy uz funcfile transform
638 0
639 8 red green blue spec urough vrough trans tspec
640 .DE
641 .LP
642 .UL Ashik2
643 .PP
644 Ashik2 is the anisotropic reflectance model by Ashikhmin & Shirley.
645 The string arguments are the same as for plastic2, but the real
646 arguments have additional flexibility to specify the specular color.
647 Also, rather than roughness, specular power is used, which has no
648 physical meaning other than larger numbers are equivalent to a smoother
649 surface.
650 Unlike other material types, total reflectance is the sum of
651 diffuse and specular colors, and should be adjusted accordingly.
652 .DS
653 mod ashik2 id
654 4+ ux uy uz funcfile transform
655 0
656 8 dred dgrn dblu sred sgrn sblu u-power v-power
657 .DE
658 .LP
659 .UL WGMDfunc
660 .PP
661 WGMDfunc is a more programmable version of trans2,
662 with separate modifier paths and variables to control each component.
663 (WGMD stands for Ward-Geisler-Moroder-Duer, which is the basis for
664 this empirical model, similar to the previous ones beside Ashik2.)\0
665 The specification of this material is given below.
666 .DS
667 mod WGMDfunc id
668 13+ rs_mod rs rs_urough rs_vrough
669 ts_mod ts ts_urough ts_vrough
670 td_mod
671 ux uy uz funcfile transform
672 0
673 9+ rfdif gfdif bfdif
674 rbdif gbdif bbdif
675 rtdif gtdif btdif
676 A10 ..
677 .DE
678 The sum of specular reflectance (
679 .I rs
680 ), specular transmittance (
681 .I ts
682 ), diffuse reflectance (
683 .I "rfdif gfdif bfdif"
684 for front and
685 .I "rbdif gbdif bbdif"
686 for back)
687 and diffuse transmittance (
688 .I "rtdif gtdif btdif"
689 ) should be less than 1 for each
690 channel.
691 .PP
692 Unique to this material, separate modifier channels are
693 provided for each component.
694 The main modifier is used on the diffuse reflectance, both
695 front and back.
696 The
697 .I rs_mod
698 modifier is used for specular reflectance.
699 If "void" is given for
700 .I rs_mod,
701 then the specular reflection color will be white.
702 The special "inherit" keyword may also be given, in which case
703 specular reflectance will share the main modifier.
704 This behavior is replicated for the specular transmittance modifier
705 .I ts_mod,
706 which has its own independent roughness expressions.
707 Finally, the diffuse transmittance modifier is given as
708 .I td_mod,
709 which may also be "void" or "inherit".
710 Note that any spectra or color for specular components must be
711 carried by the named modifier(s).
712 .PP
713 The main advantage to this material over BRTDfunc and
714 other programmable types described below is that the specular sampling is
715 well-defined, so that all components are fully computed.
716 .LP
717 .UL Dielectric
718 .PP
719 A dielectric material is transparent, and it refracts light
720 as well as reflecting it.
721 Its behavior is determined by the index of refraction and
722 transmission coefficient in each wavelength band per unit length.
723 Common glass has a index of refraction (n) around 1.5,
724 and a transmission coefficient of roughly 0.92 over an inch.
725 An additional number, the Hartmann constant, describes how
726 the index of refraction changes as a function of wavelength.
727 It is usually zero.
728 (A pattern modifies only the refracted value.)
729 .DS
730 mod dielectric id
731 0
732 0
733 5 rtn gtn btn n hc
734 .DE
735 .LP
736 .UL Interface
737 .PP
738 An interface is a boundary between two dielectrics.
739 The first transmission coefficient and refractive index are for the inside;
740 the second ones are for the outside.
741 Ordinary dielectrics are surrounded by a vacuum (1 1 1 1).
742 .DS
743 mod interface id
744 0
745 0
746 8 rtn1 gtn1 btn1 n1 rtn2 gtn2 btn2 n2
747 .DE
748 .LP
749 .UL Glass
750 .PP
751 Glass is similar to dielectric, but it is optimized for thin glass
752 surfaces (n = 1.52).
753 One transmitted ray and one reflected ray is produced.
754 By using a single surface is in place of two, internal reflections
755 are avoided.
756 The surface orientation is irrelevant, as it is for plastic,
757 metal, and trans.
758 The only specification required is the transmissivity at normal
759 incidence.
760 (Transmissivity is the amount of light not absorbed in one traversal
761 of the material.
762 Transmittance -- the value usually measured -- is the total light
763 transmitted through the pane including multiple reflections.)\0
764 To compute transmissivity (tn) from transmittance (Tn) use:
765 .DS
766 tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn
767 .DE
768 Standard 88% transmittance glass has a transmissivity of 0.96.
769 (A pattern modifying glass will affect the transmissivity.)
770 If a fourth real argument is given, it is interpreted as the index of
771 refraction to use instead of 1.52.
772 .DS
773 mod glass id
774 0
775 0
776 3 rtn gtn btn
777 .DE
778 .LP
779 .UL Plasfunc
780 .PP
781 Plasfunc in used for the procedural definition of plastic-like
782 materials with arbitrary bidirectional reflectance distribution
783 functions (BRDF's).
784 The arguments to this material include the color and specularity,
785 as well as the function defining the specular distribution and the
786 auxiliary file where it may be found.
787 .DS
788 mod plasfunc id
789 2+ refl funcfile transform
790 0
791 4+ red green blue spec A5 ..
792 .DE
793 The function
794 .I refl
795 takes four arguments, the x, y and z
796 direction towards the incident light, and the solid angle
797 subtended by the source.
798 The solid angle is provided to facilitate averaging, and is usually
799 ignored.
800 The
801 .I refl
802 function should integrate to 1 over
803 the projected hemisphere to maintain energy balance.
804 At least four real arguments must be given, and these are made
805 available along with any additional values to the reflectance
806 function.
807 Currently, only the contribution from direct light sources is
808 considered in the specular calculation.
809 As in most material types, the surface normal is always
810 altered to face the incoming ray.
811 .LP
812 .UL Metfunc
813 .PP
814 Metfunc is identical to plasfunc and takes the same arguments, but
815 the specular component is multiplied also by the material color.
816 .LP
817 .UL Transfunc
818 .PP
819 Transfunc is similar to plasfunc but with an arbitrary bidirectional
820 transmittance distribution as well as a reflectance distribution.
821 Both reflectance and transmittance are specified with the same function.
822 .DS
823 mod transfunc id
824 2+ brtd funcfile transform
825 0
826 6+ red green blue rspec trans tspec A7 ..
827 .DE
828 Where
829 .I trans
830 is the total light transmitted and
831 .I tspec
832 is the non-Lambertian fraction of transmitted light.
833 The function
834 .I brtd
835 should integrate to 1 over each projected hemisphere.
836 .LP
837 .UL BRTDfunc
838 .PP
839 The material BRTDfunc gives the maximum flexibility over surface
840 reflectance and transmittance, providing for spectrally-dependent
841 specular rays and reflectance and transmittance distribution functions.
842 .DS
843 mod BRTDfunc id
844 10+ rrefl grefl brefl
845 rtrns gtrns btrns
846 rbrtd gbrtd bbrtd
847 funcfile transform
848 0
849 9+ rfdif gfdif bfdif
850 rbdif gbdif bbdif
851 rtdif gtdif btdif
852 A10 ..
853 .DE
854 The variables
855 .I "rrefl, grefl"
856 and
857 .I brefl
858 specify the color coefficients for
859 the ideal specular (mirror) reflection of the surface.
860 The variables
861 .I "rtrns, gtrns"
862 and
863 .I btrns
864 specify the color coefficients for the ideal specular transmission.
865 The functions
866 .I "rbrtd, gbrtd"
867 and
868 .I bbrtd
869 take the direction to the incident light (and its solid angle)
870 and compute the color coefficients for the directional diffuse part of
871 reflection and transmission.
872 As a special case, three identical values of '0' may be given in place of
873 these function names to indicate no directional diffuse component.
874 .PP
875 Unlike most other material types, the surface normal is not altered to
876 face the incoming ray.
877 Thus, functions and variables must pay attention to the orientation of
878 the surface and make adjustments appropriately.
879 However, the special variables for the perturbed dot product and surface
880 normal,
881 .I "RdotP, NxP, NyP"
882 and
883 .I NzP
884 are reoriented as if the ray hit the front surface for convenience.
885 .PP
886 A diffuse reflection component may be given for the front side with
887 .I "rfdif, gfdif"
888 and
889 .I bfdif
890 for the front side of the surface or
891 .I "rbdif, gbdif"
892 and
893 .I bbdif
894 for the back side.
895 The diffuse transmittance (must be the same for both sides by physical law)
896 is given by
897 .I "rtdif, gtdif"
898 and
899 .I btdif.
900 A pattern will modify these diffuse scattering values,
901 and will be available through the special variables
902 .I "CrP, CgP"
903 and
904 .I CbP.
905 .PP
906 Care must be taken when using this material type to produce a physically
907 valid reflection model.
908 The reflectance functions should be bidirectional, and under no circumstances
909 should the sum of reflected diffuse, transmitted diffuse, reflected specular,
910 transmitted specular and the integrated directional diffuse component be
911 greater than one.
912 .LP
913 .UL Plasdata
914 .PP
915 Plasdata is used for arbitrary BRDF's that are most conveniently
916 given as interpolated data.
917 The arguments to this material are the data file and coordinate index
918 functions, as well as a function to optionally modify the data
919 values.
920 .DS
921 mod plasdata id
922 3+n+
923 func datafile
924 funcfile x1 x2 .. xn transform
925 0
926 4+ red green blue spec A5 ..
927 .DE
928 The coordinate indices
929 .I "(x1, x2,"
930 etc.) are themselves functions of
931 the x, y and z direction to the incident light, plus the solid angle
932 subtended by the light source (usually ignored).
933 The data function
934 .I (func)
935 takes five variables, the
936 interpolated value from the n-dimensional data file, followed by the
937 x, y and z direction to the incident light and the solid angle of the source.
938 The light source direction and size may of course be ignored by the function.
939 .LP
940 .UL Metdata
941 .PP
942 As metfunc is to plasfunc, metdata is to plasdata.
943 Metdata takes the same arguments as plasdata, but the specular
944 component is modified by the given material color.
945 .LP
946 .UL Transdata
947 .PP
948 Transdata is like plasdata but the specification includes transmittance
949 as well as reflectance.
950 The parameters are as follows.
951 .DS
952 mod transdata id
953 3+n+
954 func datafile
955 funcfile x1 x2 .. xn transform
956 0
957 6+ red green blue rspec trans tspec A7 ..
958 .DE
959 .LP
960 .UL BSDF
961 .PP
962 The BSDF material type loads an XML (eXtensible Markup Language)
963 file describing a bidirectional scattering distribution function.
964 Real arguments to this material may define additional
965 diffuse components that augment the BSDF data.
966 String arguments are used to define thickness for proxied
967 surfaces and the "up" orientation for the material.
968 .DS
969 mod BSDF id
970 6+ thick BSDFfile ux uy uz funcfile transform
971 0
972 0|3|6|9
973 rfdif gfdif bfdif
974 rbdif gbdif bbdif
975 rtdif gtdif btdif
976 .DE
977 The first string argument is a "thickness" parameter that may be used
978 to hide detail geometry being proxied by an aggregate BSDF material.
979 If a view or shadow ray hits a BSDF proxy with non-zero thickness,
980 it will pass directly through as if the surface were not there.
981 Similar to the illum type, this permits direct viewing and
982 shadow testing of complex geometry.
983 The BSDF is used when a scattered (indirect) ray hits the surface,
984 and any transmitted sample rays will be offset by the thickness amount
985 to avoid the hidden geometry and gather samples from the other side.
986 In this manner, BSDF surfaces can improve the results for indirect
987 scattering from complex systems without sacrificing appearance or
988 shadow accuracy.
989 If the BSDF has transmission and back-side reflection data,
990 a parallel BSDF surface may be
991 placed slightly less than the given thickness away from the front surface
992 to enclose the complex geometry on both sides.
993 The sign of the thickness is important, as it indicates whether the
994 proxied geometry is behind the BSDF surface (when thickness is positive)
995 or in front (when thickness is negative).
996 .LP
997 The second string argument is the name of the BSDF file, which is
998 found in the usual auxiliary locations.
999 The following three string parameters name variables for an "up" vector,
1000 which together with the surface normal, define the
1001 local coordinate system that orients the BSDF.
1002 These variables, along with the thickness, are defined in a function
1003 file given as the next string argument.
1004 An optional transform is used to scale the thickness and reorient the up vector.
1005 .LP
1006 If no real arguments are given, the BSDF is used by itself to determine
1007 reflection and transmission.
1008 If there are at least 3 real arguments, the first triplet is an
1009 additional diffuse reflectance for the front side.
1010 At least 6 real arguments adds diffuse reflectance to the rear side of the surface.
1011 If there are 9 real arguments, the final triplet will be taken as an additional
1012 diffuse transmittance.
1013 All diffuse components as well as the non-diffuse transmission are
1014 modified by patterns applied to this material.
1015 The non-diffuse reflection from either side are unaffected.
1016 Textures perturb the effective surface normal in the usual way.
1017 .LP
1018 The surface normal of this type is not altered to face the incoming ray,
1019 so the front and back BSDF reflections may differ.
1020 (Transmission is identical front-to-back by physical law.)\0
1021 If back visibility is turned off during rendering and there is no
1022 transmission or back-side reflection, only then the surface will be
1023 invisible from behind.
1024 Unlike other data-driven material types, the BSDF type is fully
1025 supported and all parts of the distribution are properly sampled.
1026 .LP
1027 .UL aBSDF
1028 .PP
1029 The aBSDF material is identical to the BSDF type with two important
1030 differences.
1031 First, proxy geometry is not supported, so there is no thickness parameter.
1032 Second, an aBSDF is assumed to have some specular through component
1033 (the 'a' stands for "aperture"), which
1034 is treated specially during the direct calculation and when viewing the
1035 material.
1036 Based on the BSDF data, the coefficient of specular transmission is
1037 determined and used for modifying unscattered shadow and view rays.
1038 .DS
1039 mod aBSDF id
1040 5+ BSDFfile ux uy uz funcfile transform
1041 0
1042 0|3|6|9
1043 rfdif gfdif bfdif
1044 rbdif gbdif bbdif
1045 rtdif gtdif btdif
1046 .DE
1047 .LP
1048 If a material has no specular transmitted component, it is much better
1049 to use the BSDF type with a zero thickness than to use aBSDF.
1050 .LP
1051 .UL Antimatter
1052 .PP
1053 Antimatter is a material that can "subtract" volumes from other volumes.
1054 A ray passing into an antimatter object becomes blind to all the specified
1055 modifiers:
1056 .DS
1057 mod antimatter id
1058 N mod1 mod2 .. modN
1059 0
1060 0
1061 .DE
1062 The first modifier will also be used to shade the area leaving the
1063 antimatter volume and entering the regular volume.
1064 If mod1 is void, the antimatter volume is completely invisible.
1065 If shading is desired at antimatter surfaces, it is important
1066 that the related volumes are closed with outward-facing normals.
1067 Antimatter surfaces should not intersect with other antimatter boundaries,
1068 and it is unwise to use the same modifier in nested antimatter volumes.
1069 The viewpoint must be outside all volumes concerned for a correct
1070 rendering.
1071 .NH 3
1072 Textures
1073 .PP
1074 A texture is a perturbation of the surface normal, and
1075 is given by either a function or data.
1076 .LP
1077 .UL Texfunc
1078 .PP
1079 A texfunc uses an auxiliary function file
1080 to specify a procedural texture:
1081 .DS
1082 mod texfunc id
1083 4+ xpert ypert zpert funcfile transform
1084 0
1085 n A1 A2 .. An
1086 .DE
1087 .LP
1088 .UL Texdata
1089 .PP
1090 A texdata texture uses three data files to get the surface
1091 normal perturbations.
1092 The variables
1093 .I xfunc,
1094 .I yfunc
1095 and
1096 .I zfunc
1097 take three arguments
1098 each from the interpolated values in
1099 .I xdfname,
1100 .I ydfname
1101 and
1102 .I zdfname.
1103 .DS
1104 mod texdata id
1105 8+ xfunc yfunc zfunc xdfname ydfname zdfname vfname x0 x1 .. xf
1106 0
1107 n A1 A2 .. An
1108 .DE
1109 .NH 3
1110 Patterns
1111 .PP
1112 Patterns are used to modify the reflectance of materials.
1113 The basic types are given below.
1114 .LP
1115 .UL Colorfunc
1116 .PP
1117 A colorfunc is a procedurally defined color pattern.
1118 It is specified as follows:
1119 .DS
1120 mod colorfunc id
1121 4+ red green blue funcfile transform
1122 0
1123 n A1 A2 .. An
1124 .DE
1125 .LP
1126 .UL Brightfunc
1127 .PP
1128 A brightfunc is the same as a colorfunc, except it is monochromatic.
1129 .DS
1130 mod brightfunc id
1131 2+ refl funcfile transform
1132 0
1133 n A1 A2 .. An
1134 .DE
1135 .LP
1136 .UL Colordata
1137 .PP
1138 Colordata uses an interpolated data map to modify a material's color.
1139 The map is n-dimensional, and is stored in three
1140 auxiliary files, one for each color.
1141 The coordinates used to look up and interpolate the data are
1142 defined in another auxiliary file.
1143 The interpolated data values are modified by functions of
1144 one or three variables.
1145 If the functions are of one variable, then they are passed the
1146 corresponding color component (red or green or blue).
1147 If the functions are of three variables, then they are passed the
1148 original red, green, and blue values as parameters.
1149 .DS
1150 mod colordata id
1151 7+n+
1152 rfunc gfunc bfunc rdatafile gdatafile bdatafile
1153 funcfile x1 x2 .. xn transform
1154 0
1155 m A1 A2 .. Am
1156 .DE
1157 .LP
1158 .UL Brightdata
1159 .PP
1160 Brightdata is like colordata, except monochromatic.
1161 .DS
1162 mod brightdata id
1163 3+n+
1164 func datafile
1165 funcfile x1 x2 .. xn transform
1166 0
1167 m A1 A2 .. Am
1168 .DE
1169 .LP
1170 .UL Colorpict
1171 .PP
1172 Colorpict is a special case of colordata, where the pattern is
1173 a two-dimensional image stored in the RADIANCE picture format.
1174 The dimensions of the image data are determined by the picture
1175 such that the smaller dimension is always 1, and the other
1176 is the ratio between the larger and the smaller.
1177 For example, a 500x338 picture would have coordinates (u,v)
1178 in the rectangle between (0,0) and (1.48,1).
1179 .DS
1180 mod colorpict id
1181 7+
1182 rfunc gfunc bfunc pictfile
1183 funcfile u v transform
1184 0
1185 m A1 A2 .. Am
1186 .DE
1187 .LP
1188 .UL Colortext
1189 .PP
1190 Colortext is dichromatic writing in a polygonal font.
1191 The font is defined in an auxiliary file, such as
1192 .I helvet.fnt.
1193 The text itself is also specified in a separate file, or
1194 can be part of the material arguments.
1195 The character size, orientation, aspect ratio and slant is
1196 determined by right and down motion vectors.
1197 The upper left origin for the text block as well as
1198 the foreground and background colors
1199 must also be given.
1200 .DS
1201 mod colortext id
1202 2 fontfile textfile
1203 0
1204 15+
1205 Ox Oy Oz
1206 Rx Ry Rz
1207 Dx Dy Dz
1208 rfore gfore bfore
1209 rback gback bback
1210 [spacing]
1211 .DE
1212 or:
1213 .DS
1214 mod colortext id
1215 2+N fontfile . This is a line with N words ...
1216 0
1217 15+
1218 Ox Oy Oz
1219 Rx Ry Rz
1220 Dx Dy Dz
1221 rfore gfore bfore
1222 rback gback bback
1223 [spacing]
1224 .DE
1225 .LP
1226 .UL Brighttext
1227 .PP
1228 Brighttext is like colortext, but the writing is monochromatic.
1229 .DS
1230 mod brighttext id
1231 2 fontfile textfile
1232 0
1233 11+
1234 Ox Oy Oz
1235 Rx Ry Rz
1236 Dx Dy Dz
1237 foreground background
1238 [spacing]
1239 .DE
1240 or:
1241 .DS
1242 mod brighttext id
1243 2+N fontfile . This is a line with N words ...
1244 0
1245 11+
1246 Ox Oy Oz
1247 Rx Ry Rz
1248 Dx Dy Dz
1249 foreground background
1250 [spacing]
1251 .DE
1252 .LP
1253 By default, a uniform spacing algorithm is used that guarantees
1254 every character will appear in a precisely determined position.
1255 Unfortunately, such a scheme results in rather unattractive and difficult to
1256 read text with most fonts.
1257 The optional
1258 .I spacing
1259 value defines the distance between characters for proportional spacing.
1260 A positive value selects a spacing algorithm that preserves right margins and
1261 indentation, but does not provide the ultimate in proportionally spaced text.
1262 A negative value insures that characters are properly spaced, but the
1263 placement of words then varies unpredictably.
1264 The choice depends on the relative importance of spacing versus formatting.
1265 When presenting a section of formatted text, a positive spacing value is
1266 usually preferred.
1267 A single line of text will often be accompanied by a negative spacing value.
1268 A section of text meant to depict a picture, perhaps using a special purpose
1269 font such as hexbit4x1.fnt, calls for uniform spacing.
1270 Reasonable magnitudes for proportional spacing are
1271 between 0.1 (for tightly spaced characters) and 0.3 (for wide spacing).
1272 .LP
1273 .UL Spectrum
1274 .PP
1275 The spectrum primitive is the most basic type for introducing spectral
1276 color to a material.
1277 Since materials only provide RGB parameters, spectral patterns
1278 are the only way to superimpose wavelength-dependent behavior.
1279 .DS
1280 mod spectrum id
1281 0
1282 0
1283 5+ nmA nmB s1 s2 .. sN
1284 .DE
1285 The first two real arguments indicate the extrema of the
1286 spectral range in nanometers.
1287 Subsequent real values correspond to multipliers at each wavelength.
1288 The nmA wavelength may be greater or less than nmB,
1289 but they may not be equal, and their ordering matches
1290 the order of the spectral values.
1291 A minimum of 3 values must be given, which would act
1292 more or less the same as a constant RGB multiplier.
1293 As with RGB values, spectral quantities normally range between 0
1294 and 1 at each wavelength, or average to 1.0 against a standard
1295 sensitivity functions such as V(lambda).
1296 The best results obtain when the spectral range and number
1297 of samples match rendering options, though resampling will handle
1298 any differences, zero-filling wavelenths outside the nmA to nmB
1299 range.
1300 A warning will be issued if the given wavelength range does not
1301 adequately cover the visible spectrum.
1302 .LP
1303 .UL Specfile
1304 .PP
1305 The specfile primitive is equivalent to the spectrum type, but
1306 the wavelength range and values are contained in a 1-dimensional
1307 data file.
1308 This may be a more convenient way to specify a spectral color,
1309 especially one corresponding to a standard illuminant such as D65
1310 or a library of measured spectra.
1311 .DS
1312 mod specfile id
1313 1 datafile
1314 0
1315 0
1316 .DE
1317 As with the spectrum type, rendering wavelengths outside the defined
1318 range will be zero-filled.
1319 Unlike the spectrum type, the file may contain non-uniform samples.
1320 .LP
1321 .UL Specfunc
1322 .PP
1323 The specfunc primitive offers dynamic control over a spectral
1324 pattern, similar to the colorfunc type.
1325 .DS
1326 mod specfunc id
1327 2+ sfunc funcfile transform
1328 0
1329 2+ nmA nmB A3 ..
1330 .DE
1331 Like the spectrum primitive, the wavelength range is specified
1332 in the first two real arguments, and additional real values are
1333 set in the evaluation context.
1334 This function is fed a wavelenth sample
1335 between nmA and nmB as its only argument,
1336 and it returns the corresponding spectral intensity.
1337 .LP
1338 .UL Specdata
1339 .PP
1340 Specdata is like brightdata and colordata, but with more
1341 than 3 specular samples.
1342 .DS
1343 mod specdata id
1344 3+n+
1345 func datafile
1346 funcfile x1 x2 .. xn transform
1347 0
1348 m A1 A2 .. Am
1349 .DE
1350 The data file must have one more dimension than the coordinate
1351 variable count, as this final dimension corresponds to the covered
1352 spectrum.
1353 The starting and ending wavelengths are specified in "datafile"
1354 as well as the number of spectral samples.
1355 The function "func" will be called with two parameters, the
1356 interpolated spectral value for the current coordinate and the
1357 associated wavelength.
1358 If the spectrum is broken into 12 components, then 12 calls
1359 will be made to "func" for the relevant ray evaluation.
1360 .LP
1361 .UL Specpict
1362 .PP
1363 Specpict is a special case of specdata, where the pattern is
1364 a hyperspectral image stored in the common-exponent file format.
1365 The dimensions of the image data are determined by the picture
1366 just as with the colorpict primitive.
1367 .DS
1368 mod specpict id
1369 5+
1370 func specfile
1371 funcfile u v transform
1372 0
1373 m A1 A2 .. Am
1374 .DE
1375 The function "func" is called with the interpolated pixel value
1376 and the wavelength sample in nanometers, the same as specdata,
1377 with as many calls made as there are components in "specfile".
1378 .NH 3
1379 Mixtures
1380 .PP
1381 A mixture is a blend of one or more materials or textures and patterns.
1382 Blended materials should not be light source types or virtual source types.
1383 The basic types are given below.
1384 .LP
1385 .UL Mixfunc
1386 .PP
1387 A mixfunc mixes two modifiers procedurally.
1388 It is specified as follows:
1389 .DS
1390 mod mixfunc id
1391 4+ foreground background vname funcfile transform
1392 0
1393 n A1 A2 .. An
1394 .DE
1395 Foreground and background are modifier names that must be
1396 defined earlier in the scene description.
1397 If one of these is a material, then
1398 the modifier of the mixfunc must be "void".
1399 (Either the foreground or background modifier may be "void",
1400 which serves as a form of opacity control when used with a material.)\0
1401 Vname is the coefficient defined in funcfile that determines the influence
1402 of foreground.
1403 The background coefficient is always (1-vname).
1404 .LP
1405 .UL Mixdata
1406 .PP
1407 Mixdata combines two modifiers using an auxiliary data file:
1408 .DS
1409 mod mixdata id
1410 5+n+
1411 foreground background func datafile
1412 funcfile x1 x2 .. xn transform
1413 0
1414 m A1 A2 .. Am
1415 .DE
1416 .LP
1417 .UL Mixpict
1418 .PP
1419 Mixpict combines two modifiers based on a picture:
1420 .DS
1421 mod mixpict id
1422 7+
1423 foreground background func pictfile
1424 funcfile u v transform
1425 0
1426 m A1 A2 .. Am
1427 .DE
1428 The mixing coefficient function "func" takes three
1429 arguments, the red, green and blue values
1430 corresponding to the pixel at (u,v).
1431 .LP
1432 .UL Mixtext
1433 .PP
1434 Mixtext uses one modifier for the text foreground, and one for the
1435 background:
1436 .DS
1437 mod mixtext id
1438 4 foreground background fontfile textfile
1439 0
1440 9+
1441 Ox Oy Oz
1442 Rx Ry Rz
1443 Dx Dy Dz
1444 [spacing]
1445 .DE
1446 or:
1447 .DS
1448 mod mixtext id
1449 4+N
1450 foreground background fontfile .
1451 This is a line with N words ...
1452 0
1453 9+
1454 Ox Oy Oz
1455 Rx Ry Rz
1456 Dx Dy Dz
1457 [spacing]
1458 .DE
1459 .NH 2
1460 Auxiliary Files
1461 .PP
1462 Auxiliary files used in textures and patterns
1463 are accessed by the programs during image generation.
1464 These files may be located in the working directory, or in
1465 a library directory.
1466 The environment variable
1467 .I RAYPATH
1468 can be assigned an alternate set of search directories.
1469 Following is a brief description of some common file types.
1470 .NH 3
1471 Function Files
1472 .PP
1473 A function file contains the definitions of variables, functions
1474 and constants used by a primitive.
1475 The transformation that accompanies the file name contains the necessary
1476 rotations, translations and scalings to bring the coordinates of
1477 the function file into agreement with the world coordinates.
1478 The transformation specification is the same as for the
1479 .I xform
1480 command.
1481 An example function file is given below:
1482 .DS
1483 {
1484 This is a comment, enclosed in curly braces.
1485 {Comments can be nested.}
1486 }
1487 { standard expressions use +,-,*,/,^,(,) }
1488 vname = Ny * func(A1) ;
1489 { constants are defined with a colon }
1490 const : sqrt(PI/2) ;
1491 { user-defined functions add to library }
1492 func(x) = 5 + A1*sin(x/3) ;
1493 { functions may be passed and recursive }
1494 rfunc(f,x) = if(x,f(x),f(-x)*rfunc(f,x+1)) ;
1495 { constant functions may also be defined }
1496 cfunc(x) : 10*x / sqrt(x) ;
1497 .DE
1498 Many variables and functions are already defined by the program,
1499 and they are listed in the file
1500 .I rayinit.cal.
1501 The following variables are particularly important:
1502 .DS
1503 Dx, Dy, Dz - incident ray direction
1504 Nx, Ny, Nz - surface normal at intersection point
1505 Px, Py, Pz - intersection point
1506 T - distance from start
1507 Ts - single ray (shadow) distance
1508 Rdot - cosine between ray and normal
1509 arg(0) - number of real arguments
1510 arg(i) - i'th real argument
1511 .DE
1512 For mesh objects, the local surface coordinates are available:
1513 .DS
1514 Lu, Lv - local (u,v) coordinates
1515 .DE
1516 For BRDF types, the following variables are defined as well:
1517 .DS
1518 NxP, NyP, NzP - perturbed surface normal
1519 RdotP - perturbed dot product
1520 CrP, CgP, CbP - perturbed material color
1521 .DE
1522 A unique context is set up for each file so that the same variable
1523 may appear in different function files without conflict.
1524 The variables listed above and any others defined in
1525 rayinit.cal are available globally.
1526 If no file is needed by a given primitive because all the required
1527 variables are global, a period (`.') can be given in
1528 place of the file name.
1529 It is also possible to give an expression instead of a straight
1530 variable name in a scene file.
1531 Functions (requiring parameters)
1532 must be given as names and not as expressions.
1533 .PP
1534 Constant expressions are used as an optimization in function
1535 files.
1536 They are replaced wherever they occur in an expression by their
1537 value.
1538 Constant expressions are evaluated only once, so they must not
1539 contain any variables or values that can change, such as the ray
1540 variables Px and Ny or the primitive argument function arg().
1541 All the math library functions such as sqrt() and cos() have the
1542 constant attribute, so they will be replaced by immediate values
1543 whenever they are given constant arguments.
1544 Thus, the subexpression cos(PI*sqrt(2)) is immediately replaced
1545 by its value, -.266255342, and does not cause any additional overhead
1546 in the calculation.
1547 .PP
1548 It is generally a good idea to define constants and variables before
1549 they are referred to in a function file.
1550 Although evaluation does not take place until later, the interpreter
1551 does variable scoping and constant subexpression evaluation based on
1552 what it has compiled already.
1553 For example, a variable that is defined globally in rayinit.cal then
1554 referenced in the local context of a function file cannot
1555 subsequently be redefined in the same file because the compiler
1556 has already determined the scope of the referenced variable as global.
1557 To avoid such conflicts, one can state the scope of a variable explicitly
1558 by preceding the variable name with a context mark (a back-quote) for
1559 a local variable, or following the name with a context mark for a global
1560 variable.
1561 .NH 3
1562 Data Files
1563 .PP
1564 Data files contain n-dimensional arrays of real numbers used
1565 for interpolation.
1566 Typically, definitions in a function file determine how
1567 to index and use interpolated data values.
1568 The basic data file format is as follows:
1569 .DS
1570 N
1571 beg1 end1 m1
1572 0 0 m2 x2.1 x2.2 x2.3 x2.4 .. x2.m2
1573 ...
1574 begN endN mN
1575 DATA, later dimensions changing faster.
1576 .DE
1577 N is the number of dimensions.
1578 For each dimension, the beginning and ending coordinate
1579 values and the dimension size is given.
1580 Alternatively, individual coordinate values can be given when
1581 the points are not evenly spaced.
1582 These values must either be increasing or decreasing monotonically.
1583 The data is m1*m2*...*mN real numbers in ASCII form.
1584 Comments may appear anywhere in the file, beginning with a pound
1585 sign ('#') and continuing to the end of line.
1586 .NH 3
1587 Font Files
1588 .PP
1589 A font file lists the polygons which make up a character set.
1590 Comments may appear anywhere in the file, beginning with a pound
1591 sign ('#') and continuing to the end of line.
1592 All numbers are decimal integers:
1593 .DS
1594 code n
1595 x0 y0
1596 x1 y1
1597 ...
1598 xn yn
1599 ...
1600 .DE
1601 The ASCII codes can appear in any order.
1602 N is the number of vertices, and the last is automatically
1603 connected to the first.
1604 Separate polygonal sections are joined by coincident sides.
1605 The character coordinate system is a square with lower left corner at
1606 (0,0), lower right at (255,0) and upper right at (255,255).
1607 .NH 2
1608 Generators
1609 .PP
1610 A generator is any program that produces a scene description
1611 as its output.
1612 They usually appear as commands in a scene description file.
1613 An example of a simple generator is
1614 .I genbox.
1615 .I Genbox
1616 takes the arguments of width, height and depth to produce
1617 a parallelepiped description.
1618 .I Genprism
1619 takes a list of 2-dimensional coordinates and extrudes them along a vector to
1620 produce a 3-dimensional prism.
1621 .I Genrev
1622 is a more sophisticated generator
1623 that produces an object of rotation from parametric functions
1624 for radius and axis position.
1625 .I Gensurf
1626 tessellates a surface defined by the
1627 parametric functions x(s,t), y(s,t), and z(s,t).
1628 .I Genworm
1629 links cylinders and spheres along a curve.
1630 .I Gensky
1631 produces a sun and sky distribution corresponding
1632 to a given time and date.
1633 .PP
1634 .I Xform
1635 is a program that transforms a scene description from one
1636 coordinate space to another.
1637 .I Xform
1638 does rotation, translation, scaling, and mirroring.
1639 .NH 1
1640 Image Generation
1641 .PP
1642 Once the scene has been described in three-dimensions, it
1643 is possible to generate a two-dimensional image from a
1644 given perspective.
1645 .PP
1646 The image generating programs use an
1647 .I octree
1648 to efficiently trace rays through the scene.
1649 An octree subdivides space into nested octants which
1650 contain sets of surfaces.
1651 In RADIANCE, an octree is created from a scene description by
1652 .I oconv.
1653 The details of this process are not important,
1654 but the octree will serve as input to the ray-tracing
1655 programs and directs the use of a scene description.
1656 .PP
1657 .I Rview
1658 is ray-tracing program for viewing a scene interactively.
1659 When the user specifies a new perspective,
1660 .I rview
1661 quickly displays a rough
1662 image on the terminal, then progressively
1663 increases the resolution as the user looks on.
1664 He can select a particular section of the image to improve,
1665 or move to a different view and start over.
1666 This mode of interaction is useful for debugging scenes
1667 as well as determining the best view for a final image.
1668 .PP
1669 .I Rpict
1670 produces a high-resolution picture of a scene from
1671 a particular perspective.
1672 This program features adaptive sampling, crash
1673 recovery and progress reporting, all of which are important
1674 for time-consuming images.
1675 .PP
1676 A number of filters are available for manipulating picture files.
1677 .I Pfilt
1678 sets the exposure and performs anti-aliasing.
1679 .I Pcompos
1680 composites (cuts and pastes) pictures.
1681 .I Pcond
1682 conditions a picture for a specific display device.
1683 .I Pcomb
1684 performs arbitrary math on one or more pictures.
1685 .I Protate
1686 rotates a picture 90 degrees clockwise.
1687 .I Pflip
1688 flips a picture horizontally, vertically, or both (180 degree rotation).
1689 .I Pvalue
1690 converts a picture to and from simpler formats.
1691 .PP
1692 Pictures may be displayed directly under X11 using the program
1693 .I ximage,
1694 or converted a standard image format.
1695 .I Ra_bmp
1696 converts to and from Microsoft Bitmap images.
1697 .I Ra_ppm
1698 converts to and from Poskanzer Portable Pixmap formats.
1699 .I Ra_ps
1700 converts to PostScript color and greyscale formats.
1701 .I Ra_rgbe
1702 converts to and from Radiance uncompressed picture format.
1703 .I Ra_t16
1704 converts to and from Targa 16 and 24-bit image formats.
1705 .I Ra_t8
1706 converts to and from Targa 8-bit image format.
1707 .I Ra_tiff
1708 converts to and from TIFF.
1709 .I Ra_xyze
1710 converts to and from Radiance CIE picture format.
1711 .NH 1
1712 License
1713 .PP
1714 .DS
1715 The Radiance Software License, Version 1.0
1716
1717 Copyright (c) 1990 - 2008 The Regents of the University of California,
1718 through Lawrence Berkeley National Laboratory. All rights reserved.
1719
1720 Redistribution and use in source and binary forms, with or without
1721 modification, are permitted provided that the following conditions
1722 are met:
1723
1724 1. Redistributions of source code must retain the above copyright
1725 notice, this list of conditions and the following disclaimer.
1726
1727 2. Redistributions in binary form must reproduce the above copyright
1728 notice, this list of conditions and the following disclaimer in
1729 the documentation and/or other materials provided with the
1730 distribution.
1731
1732 3. The end-user documentation included with the redistribution,
1733 if any, must include the following acknowledgment:
1734 "This product includes Radiance software
1735 (http://radsite.lbl.gov/)
1736 developed by the Lawrence Berkeley National Laboratory
1737 (http://www.lbl.gov/)."
1738 Alternately, this acknowledgment may appear in the software itself,
1739 if and wherever such third-party acknowledgments normally appear.
1740
1741 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
1742 and "The Regents of the University of California" must
1743 not be used to endorse or promote products derived from this
1744 software without prior written permission. For written
1745 permission, please contact [email protected].
1746
1747 5. Products derived from this software may not be called "Radiance",
1748 nor may "Radiance" appear in their name, without prior written
1749 permission of Lawrence Berkeley National Laboratory.
1750
1751 THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
1752 WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
1753 OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
1754 DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
1755 ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
1756 SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
1757 LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
1758 USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
1759 ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
1760 OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
1761 OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
1762 SUCH DAMAGE.
1763 .DE
1764 .NH 1
1765 Acknowledgements
1766 .PP
1767 This work was supported by the Assistant Secretary of Conservation
1768 and Renewable Energy, Office of Building Energy Research and
1769 Development, Buildings Equipment Division of the U.S. Department of
1770 Energy under Contract No. DE-AC03-76SF00098.
1771 .PP
1772 Additional work was sponsored by the Swiss federal government
1773 under the Swiss LUMEN Project and was
1774 carried out in the Laboratoire d'Energie Solaire (LESO Group) at
1775 the Ecole Polytechnique Federale de Lausanne (EPFL University)
1776 in Lausanne, Switzerland.
1777 .NH 1
1778 References
1779 .LP
1780 Ward, Gregory J., Bruno Bueno, David Geisler-Moroder,
1781 Lars O. Grobe, Jacob C. Jonsson, Eleanor
1782 S. Lee, Taoning Wang, Helen Rose Wilson,
1783 ``Daylight Simulation Workflows Incorporating
1784 Measured Bidirectional Scattering Distribution Functions,''
1785 .I "Energy & Buildings",
1786 Vol. 259, No. 111890, 2022.
1787 .LP
1788 Wang, Taoning, Gregory Ward, Eleanor Lee,
1789 ``Efficient modeling of optically-complex, non-coplanar
1790 exterior shading: Validation of matrix algebraic methods,''
1791 .I "Energy & Buildings",
1792 vol. 174, pp. 464-83, Sept. 2018.
1793 .LP
1794 Lee, Eleanor S., David Geisler-Moroder, Gregory Ward,
1795 ``Modeling the direct sun component in buildings using matrix
1796 algebraic approaches: Methods and validation,''
1797 .I Solar Energy,
1798 vol. 160, 15 January 2018, pp 380-395.
1799 .LP
1800 Ward, G., M. Kurt & N. Bonneel,
1801 ``Reducing Anisotropic BSDF Measurement to Common Practice,''
1802 .I Workshop on Material Appearance Modeling,
1803 2014.
1804 .LP
1805 McNeil, A., C.J. Jonsson, D. Appelfeld, G. Ward, E.S. Lee,
1806 ``A validation of a ray-tracing tool used to generate
1807 bi-directional scattering distribution functions for
1808 complex fenestration systems,''
1809 .I "Solar Energy",
1810 98, 404-14, November 2013.
1811 .LP
1812 Ward, G., R. Mistrick, E.S. Lee, A. McNeil, J. Jonsson,
1813 ``Simulating the Daylight Performance of Complex Fenestration Systems
1814 Using Bidirectional Scattering Distribution Functions within Radiance,''
1815 .I "Leukos",
1816 7(4),
1817 April 2011.
1818 .LP
1819 Cater, K., A. Chalmers, G. Ward,
1820 ``Detail to Attention: Exploiting Visual Tasks for Selective Rendering,''
1821 .I "Eurograhics Symposium on Rendering",
1822 June 2003.
1823 .LP
1824 Ward, G., Elena Eydelberg-Vileshin,
1825 ``Picture Perfect RGB Rendering Using Spectral Prefiltering and
1826 Sharp Color Primaries,''
1827 13th Eurographics Workshop on Rendering, P. Debevec and
1828 S. Gibson (Editors), June 2002.
1829 .LP
1830 Ward, G. and M. Simmons,
1831 ``The Holodeck Ray Cache: An Interactive Rendering System for Global
1832 Illumination in Nondiffuse Environments,''
1833 .I "ACM Transactions on Graphics,"
1834 18(4):361-98, October 1999.
1835 .LP
1836 Larson, G.W., H. Rushmeier, C. Piatko,
1837 ``A Visibility Matching Tone Reproduction Operator for High Dynamic
1838 Range Scenes,''
1839 .I "IEEE Transactions on Visualization and Computer Graphics",
1840 3(4), 291-306, December 1997.
1841 .LP
1842 Ward, G.,
1843 ``Making Global Illumination User Friendly,''
1844 .I "Sixth Eurographics Workshop on Rendering",
1845 proceedings to be published by Springer-Verlag,
1846 Dublin, Ireland, June 1995.
1847 .LP
1848 Rushmeier, H., G. Ward, C. Piatko, P. Sanders, B. Rust,
1849 ``Comparing Real and Synthetic Images: Some Ideas about Metrics,''
1850 .I "Sixth Eurographics Workshop on Rendering",
1851 proceedings to be published by Springer-Verlag,
1852 Dublin, Ireland, June 1995.
1853 .LP
1854 Ward, G.,
1855 ``The Radiance Lighting Simulation and Rendering System,''
1856 .I "Computer Graphics",
1857 Orlando, July 1994.
1858 .LP
1859 Rushmeier, H., G. Ward,
1860 ``Energy-Preserving Non-Linear Filters,''
1861 .I "Computer Graphics",
1862 Orlando, July 1994.
1863 .LP
1864 Ward, G.,
1865 ``A Contrast-Based Scalefactor for Luminance Display,''
1866 .I "Graphics Gems IV",
1867 Edited by Paul Heckbert,
1868 Academic Press 1994.
1869 .LP
1870 Ward, G.,
1871 ``Measuring and Modeling Anisotropic Reflection,''
1872 .I "Computer Graphics",
1873 Chicago, July 1992.
1874 .LP
1875 Ward, G., P. Heckbert,
1876 ``Irradiance Gradients,''
1877 .I "Third Annual Eurographics Workshop on Rendering",
1878 to be published by Springer-Verlag, held in Bristol, UK, May 1992.
1879 .LP
1880 Ward, G.,
1881 ``Adaptive Shadow Testing for Ray Tracing,''
1882 .I "Second Annual Eurographics Workshop on Rendering",
1883 to be published by Springer-Verlag, held in Barcelona, SPAIN, May 1991.
1884 .LP
1885 Ward, G.,
1886 ``Visualization,''
1887 .I "Lighting Design and Application",
1888 Vol. 20, No. 6, June 1990.
1889 .LP
1890 Ward, G., F. Rubinstein, R. Clear,
1891 ``A Ray Tracing Solution for Diffuse Interreflection,''
1892 .I "Computer Graphics",
1893 Vol. 22, No. 4, August 1988.
1894 .LP
1895 Ward, G., F. Rubinstein,
1896 ``A New Technique for Computer Simulation of Illuminated Spaces,''
1897 .I "Journal of the Illuminating Engineering Society",
1898 Vol. 17, No. 1, Winter 1988.
