root/radiance/ray/doc/ray.1
Revision: 1.19
Committed: Sun Feb 20 06:34:19 2011 UTC (14 years, 2 months ago) by greg
Changes since 1.18: +16 -20 lines
Made BSDF proxy behavior consistent for shadowing, reflection and transmission
1 .\" RCSid "$Id"
2 .\" Print using the -ms macro package
3 .DA 2/17/2011
4 .LP
5 .tl """Copyright \(co 2011 Regents, University of California
6 .sp 2
7 .TL
8 The
9 .so ../src/rt/VERSION
10 .br
11 Synthetic Imaging System
12 .AU
13 Building Technologies Department
14 .br
15 Lawrence Berkeley Laboratory
16 .br
17 1 Cyclotron Rd., MS 90-3111
18 .br
19 Berkeley, CA 94720
20 .NH 1
21 Introduction
22 .PP
23 RADIANCE was developed as a research tool
24 for predicting the distribution of visible radiation in
25 illuminated spaces.
26 It takes as input a three-dimensional geometric model of
27 the physical environment, and produces a map of
28 spectral radiance values in a color image.
29 The technique of ray-tracing follows light backwards
30 from the image plane to the source(s).
31 Because it can produce realistic images from a simple description,
32 RADIANCE has a wide range of applications in graphic arts,
33 lighting design, computer-aided engineering and architecture.
34 .KF
35 .sp 25
36 .ce
37 .B "Figure 1."
38 .sp
39 .KE
40 .PP
41 The diagram in Figure 1 shows the flow between programs (boxes) and
42 data (ovals).
43 The central program is
44 .I rpict,
45 which produces a picture from a scene description.
46 .I Rview
47 is a variation of
48 .I rpict
49 that computes and displays images interactively.
50 Other programs (not shown) connect many of these elements together,
51 such as the executive programs
52 .I rad
53 and
54 .I ranimate,
55 the interactive rendering program
56 .I rholo,
57 and the animation program
58 .I ranimove.
59 The program
60 .I obj2mesh
61 acts as both a converter and scene compiler, converting a Wavefront .OBJ
62 file into a compiled mesh octree for efficient rendering.
63 .PP
64 A scene description file lists the surfaces and materials
65 that make up a specific environment.
66 The current surface types are spheres, polygons, cones, and cylinders.
67 There is also a composite surface type, called mesh, and a pseudosurface
68 type, called instance, which facilitates very complex geometries.
69 Surfaces can be made from materials such as plastic, metal, and glass.
70 Light sources can be distant disks as well as local spheres, disks
71 and polygons.
72 .PP
73 From a three-dimensional scene description and a specified view,
74 .I rpict
75 produces a two-dimensional image.
76 A picture file is a compressed binary representation of the
77 pixels in the image.
78 This picture can be scaled in size and
79 brightness, anti-aliased, and sent to a graphics output device.
80 .PP
81 A header in each picture file lists the program(s) and
82 parameters that produced it.
83 This is useful for identifying a picture
84 without having to display it.
85 The information can be read by the program
86 .I getinfo.
87 .NH 1
88 Scene Description
89 .PP
90 A scene description file represents a
91 three-dimensional physical environment
92 in Cartesian (rectilinear) world coordinates.
93 It is stored as ASCII text, with the following basic format:
94 .DS
95 # comment
96
97 modifier type identifier
98 n S1 S2 "S 3" .. Sn
99 0
100 m R1 R2 R3 .. Rm
101
102 modifier alias identifier reference
103
104 ! command
105
106 ...
107 .DE
108 .PP
109 A comment line begins with a pound sign, `#'.
110 .PP
111 The scene description
112 .I primitives
113 all have the same general format, and can
114 be either surfaces or modifiers.
115 A primitive has a modifier, a type, and an identifier.
116 A modifier is either the identifier of a
117 .I "previously defined"
118 primitive, or "void"\(dg.
119 .FS
120 \(dgThe most recent definition of a modifier is the one used,
121 and later definitions do not cause relinking of loaded
122 primitives.
123 Thus, the same identifier may be used repeatedly, and each new
124 definition will apply to the primitives following it.
125 .FE
126 An identifier can be any string (i.e., any sequence of non-white characters).
127 The
128 .I arguments
129 associated with a primitive can be strings or real numbers.
130 The first integer following the identifier is the number
131 of string arguments, and it is followed by the arguments themselves
132 (separated by white space or enclosed in quotes).
133 The next integer is the number of integer arguments, and is followed
134 by the integer arguments.
135 (There are currently no primitives that use them, however.)
136 The next integer is the real argument count, and it is followed
137 by the real arguments.
138 .PP
139 An alias gets its type and arguments from a previously defined primitive.
140 This is useful when the same material is used with a different
141 modifier, or as a convenient naming mechanism.
142 The reserved modifier name "inherit" may be used to specificy that
143 an alias will inherit its modifier from the original.
144 Surfaces cannot be aliased.
145 .PP
146 A line beginning with an exclamation point, `!',
147 is interpreted as a command.
148 It is executed by the shell, and its output is read as input to
149 the program.
150 The command must not try to read from its standard input, or
151 confusion will result.
152 A command may be continued over multiple lines using a backslash, `\\',
153 to escape the newline.
154 .PP
155 White space is generally ignored, except as a separator.
156 The exception is the newline character after a command or comment.
157 Commands, comments and primitives may appear in any combination, so long
158 as they are not intermingled.
159 .NH 2
160 Primitive Types
161 .PP
162 Primitives can be surfaces, materials, textures or patterns.
163 Modifiers can be materials, mixtures, textures or patterns.
164 Simple surfaces must have one material in their modifier list.
165 .NH 3
166 Surfaces
167 .PP
168 A scene description will consist mostly of surfaces.
169 The basic types are given below.
170 .LP
171 .UL Source
172 .PP
173 A source is not really a surface, but a solid angle.
174 It is used for specifying light sources that are very distant.
175 The direction to the center of the source and the number of degrees
176 subtended by its disk are given as follows:
177 .DS
178 mod source id
179 0
180 0
181 4 xdir ydir zdir angle
182 .DE
183 .LP
184 .UL Sphere
185 .PP
186 A sphere is given by its center and radius:
187 .DS
188 mod sphere id
189 0
190 0
191 4 xcent ycent zcent radius
192 .DE
193 .LP
194 .UL Bubble
195 .PP
196 A bubble is simply a sphere whose surface normal points inward.
197 .LP
198 .UL Polygon
199 .PP
200 A polygon is given by a list of three-dimensional vertices,
201 which are ordered counter-clockwise as viewed from
202 the front side (into the surface normal).
203 The last vertex is automatically connected to the first.
204 Holes are represented in polygons as interior vertices connected to
205 the outer perimeter by coincident edges (seams).
206 .DS
207 mod polygon id
208 0
209 0
210 3n
211 x1 y1 z1
212 x2 y2 z2
213 ...
214 xn yn zn
215 .DE
216 .LP
217 .UL Cone
218 .PP
219 A cone is a megaphone-shaped object.
220 It is truncated by two planes perpendicular to its axis,
221 and one of its ends may come to a point.
222 It is given as two axis endpoints, and the starting
223 and ending radii:
224 .DS
225 mod cone id
226 0
227 0
228 8
229 x0 y0 z0
230 x1 y1 z1
231 r0 r1
232 .DE
233 .LP
234 .UL Cup
235 .PP
236 A cup is an inverted cone (i.e., has an inward surface normal).
237 .LP
238 .UL Cylinder
239 .PP
240 A cylinder is like a cone, but its starting and ending radii are
241 equal.
242 .DS
243 mod cylinder id
244 0
245 0
246 7
247 x0 y0 z0
248 x1 y1 z1
249 rad
250 .DE
251 .LP
252 .UL Tube
253 .PP
254 A tube is an inverted cylinder.
255 .LP
256 .UL Ring
257 .PP
258 A ring is a circular disk given by its center, surface
259 normal, and inner and outer radii:
260 .DS
261 mod ring id
262 0
263 0
264 8
265 xcent ycent zcent
266 xdir ydir zdir
267 r0 r1
268 .DE
269 .LP
270 .UL Mesh
271 .PP
272 A mesh is a compound surface, made up of many triangles and
273 an octree data structure to accelerate ray intersection.
274 It is typically converted from a Wavefront .OBJ file using the
275 .I obj2mesh
276 program.
277 .DS
278 mod mesh id
279 1+ meshfile transform
280 0
281 0
282 .DE
283 If the modifier is "void", then surfaces will use the modifiers given
284 in the original mesh description.
285 Otherwise, the modifier specified is used in their place.
286 The transform moves the mesh to the desired location in the scene.
287 Multiple instances using the same meshfile take little extra memory,
288 and the compiled mesh itself takes much less space than individual
289 polygons would.
290 In the case of an unsmoothed mesh, using the mesh primitive reduces
291 memory requirements by a factor of 30 relative to individual triangles.
292 If a mesh has smoothed surfaces, we save a factor of 50 or more,
293 permitting very detailed geometries that would otherwise exhaust the
294 available memory.
295 In addition, the mesh primitive can have associated (u,v) coordinates
296 for pattern and texture mapping.
297 These are made available to function files via the Lu and Lv variables.
298 .LP
299 .UL Instance
300 .PP
301 An instance is a compound surface, given by the contents of an
302 octree file (created by oconv).
303 .DS
304 mod instance id
305 1+ octree transform
306 0
307 0
308 .DE
309 If the modifier is "void", then surfaces will use the modifiers given
310 in the original description.
311 Otherwise, the modifier specified is used in their place.
312 The transform moves the octree to the desired location in the scene.
313 Multiple instances using the same octree take little extra memory,
314 hence very complex descriptions can be rendered using this primitive.
315 .PP
316 There are a number of important limitations to be aware of when using
317 instances.
318 First, the scene description used to generate the octree must stand on
319 its own, without referring to modifiers in the parent description.
320 This is necessary for oconv to create the octree.
321 Second, light sources in the octree will not be incorporated correctly
322 in the calculation, and they are not recommended.
323 Finally, there is no advantage (other than convenience) to
324 using a single instance of an octree, or an octree containing only a
325 few surfaces.
326 An xform command on the subordinate description is prefered in such cases.
327 .NH 3
328 Materials
329 .PP
330 A material defines the way light interacts with a surface.
331 The basic types are given below.
332 .LP
333 .UL Light
334 .PP
335 Light is the basic material for self-luminous surfaces (i.e., light
336 sources).
337 In addition to the source surface type, spheres, discs (rings with zero
338 inner radius), cylinders (provided they are long enough), and
339 polygons can act as light sources.
340 Polygons work best when they are rectangular.
341 Cones cannot be used at this time.
342 A pattern may be used to specify a light output distribution.
343 Light is defined simply as a RGB radiance value (watts/steradian/m2):
344 .DS
345 mod light id
346 0
347 0
348 3 red green blue
349 .DE
350 .LP
351 .UL Illum
352 .PP
353 Illum is used for secondary light sources with broad distributions.
354 A secondary light source is treated like any other
355 light source, except when viewed directly.
356 It then acts like it is made of a different material (indicated by
357 the string argument), or becomes invisible (if no string argument is given,
358 or the argument is "void").
359 Secondary sources are useful when modeling windows or
360 brightly illuminated surfaces.
361 .DS
362 mod illum id
363 1 material
364 0
365 3 red green blue
366 .DE
367 .LP
368 .UL Glow
369 .PP
370 Glow is used for surfaces that are self-luminous, but limited
371 in their effect.
372 In addition to the radiance value, a maximum radius for
373 shadow testing is given:
374 .DS
375 mod glow id
376 0
377 0
378 4 red green blue maxrad
379 .DE
380 If maxrad is zero, then the surface will never be tested
381 for shadow, although it may participate in an interreflection calculation.
382 If maxrad is negative, then the surface will never contribute to scene
383 illumination.
384 Glow sources will never illuminate objects on the other side of an
385 illum surface.
386 This provides a convenient way to illuminate local light fixture
387 geometry without overlighting nearby objects.
388 .LP
389 .UL Spotlight
390 .PP
391 Spotlight is used for self-luminous surfaces having directed output.
392 As well as radiance, the full cone angle (in degrees)
393 and orientation (output direction) vector are given.
394 The length of the orientation vector is the distance
395 of the effective focus behind the source center (i.e., the focal length).
396 .DS
397 mod spotlight id
398 0
399 0
400 7 red green blue angle xdir ydir zdir
401 .DE
402 .LP
403 .UL Mirror
404 .PP
405 Mirror is used for planar surfaces that produce virtual
406 source reflections.
407 This material should be used sparingly, as it may cause the light
408 source calculation to blow up if it is applied to many small surfaces.
409 This material is only supported for flat surfaces such as polygons
410 and rings.
411 The arguments are simply the RGB reflectance values, which should be
412 between 0 and 1.
413 An optional string argument may be used like the illum type to specify a
414 different material to be used for shading non-source rays.
415 If this alternate material is given as "void", then the mirror surface
416 will be invisible.
417 This is only appropriate if the surface hides other (more detailed)
418 geometry with the same overall reflectance.
419 .DS
420 mod mirror id
421 1 material
422 0
423 3 red green blue
424 .DE
425 .LP
426 .UL Prism1
427 .PP
428 The prism1 material is for general light redirection from prismatic
429 glazings, generating virtual light sources.
430 It can only be used to modify a planar surface (i.e., a polygon or disk)
431 and should not result in either light concentration or scattering.
432 The new direction of the ray can be on either side of the material,
433 and the definitions must have the correct bidirectional properties
434 to work properly with virtual light sources.
435 The arguments give the coefficient for the redirected light
436 and its direction.
437 .DS
438 mod prism1 id
439 5+ coef dx dy dz funcfile transform
440 0
441 n A1 A2 .. An
442 .DE
443 The new direction variables
444 .I "dx, dy"
445 and
446 .I dz
447 need not produce a normalized vector.
448 For convenience, the variables
449 .I "DxA, DyA"
450 and
451 .I DzA
452 are defined as the normalized direction to the target light source.
453 See section 2.2.1 on function files for further information.
454 .LP
455 .UL Prism2
456 .PP
457 The material prism2 is identical to prism1 except that
458 it provides for two ray redirections rather than one.
459 .DS
460 mod prism2 id
461 9+ coef1 dx1 dy1 dz1 coef2 dx2 dy2 dz2 funcfile transform
462 0
463 n A1 A2 .. An
464 .DE
465 .LP
466 .UL Mist
467 .PP
468 Mist is a virtual material used to delineate a volume
469 of participating atmosphere.
470 A list of important light sources may be given, along with an
471 extinction coefficient, scattering albedo and scattering eccentricity
472 parameter.
473 The light sources named by the string argument list
474 will be tested for scattering within the volume.
475 Sources are identified by name, and virtual light sources may be indicated
476 by giving the relaying object followed by '>' followed by the source, i.e:
477 .DS
478 3 source1 mirror1>source10 mirror2>mirror1>source3
479 .DE
480 Normally, only one source is given per mist material, and there is an
481 upper limit of 32 to the total number of active scattering sources.
482 The extinction coefficient, if given, is added to the global
483 coefficient set on the command line.
484 Extinction is in units of 1/distance (distance based on the world coordinates),
485 and indicates the proportional loss of radiance over one unit distance.
486 The scattering albedo, if present, will override the global setting within
487 the volume.
488 An albedo of 0\00\00 means a perfectly absorbing medium, and an albedo of
489 1\01\01\0 means
490 a perfectly scattering medium (no absorption).
491 The scattering eccentricity parameter will likewise override the global
492 setting if it is present.
493 Scattering eccentricity indicates how much scattered light favors the
494 forward direction, as fit by the Henyey-Greenstein function:
495 .DS
496 P(theta) = (1 - g*g) / (1 + g*g - 2*g*cos(theta))^1.5
497 .DE
498 A perfectly isotropic scattering medium has a g parameter of 0, and
499 a highly directional material has a g parameter close to 1.
500 Fits to the g parameter may be found along with typical extinction
501 coefficients and scattering albedos for various atmospheres and
502 cloud types in USGS meteorological tables.
503 (A pattern will be applied to the extinction values.)\0
504 .DS
505 mod mist id
506 N src1 src2 .. srcN
507 0
508 0|3|6|7 [ rext gext bext [ ralb galb balb [ g ] ] ]
509 .DE
510 There are two usual uses of the mist type.
511 One is to surround a beam from a spotlight or laser so that it is
512 visible during rendering.
513 For this application, it is important to use a cone (or cylinder) that
514 is long enough and wide enough to contain the important visible portion.
515 Light source photometry and intervening objects will have the desired
516 effect, and crossing beams will result in additive scattering.
517 For this application, it is best to leave off the real arguments, and
518 use the global rendering parameters to control the atmosphere.
519 The second application is to model clouds or other localized media.
520 Complex boundary geometry may be used to give shape to a uniform medium,
521 so long as the boundary encloses a proper volume.
522 Alternatively, a pattern may be used to set the line integral value
523 through the cloud for a ray entering or exiting a point in a given
524 direction.
525 For this application, it is best if cloud volumes do not overlap each other,
526 and opaque objects contained within them may not be illuminated correctly
527 unless the line integrals consider enclosed geometry.
528 .LP
529 .UL Plastic
530 .PP
531 Plastic is a material with uncolored highlights.
532 It is given by its RGB reflectance, its fraction of specularity,
533 and its roughness value.
534 Roughness is specified as the rms slope of surface facets.
535 A value of 0 corresponds to a perfectly smooth surface, and
536 a value of 1 would be a very rough surface.
537 Specularity fractions greater than 0.1 and
538 roughness values greater than 0.2 are not very
539 realistic.
540 (A pattern modifying plastic will affect the material color.)
541 .DS
542 mod plastic id
543 0
544 0
545 5 red green blue spec rough
546 .DE
547 .LP
548 .UL Metal
549 .PP
550 Metal is similar to plastic, but specular highlights
551 are modified by the material color.
552 Specularity of metals is usually .9 or greater.
553 As for plastic, roughness values above .2 are uncommon.
554 .LP
555 .UL Trans
556 .PP
557 Trans is a translucent material, similar to plastic.
558 The transmissivity is the fraction of penetrating light that
559 travels all the way through the material.
560 The transmitted specular component is the fraction of transmitted
561 light that is not diffusely scattered.
562 Transmitted and diffusely reflected light is modified by the material color.
563 Translucent objects are infinitely thin.
564 .DS
565 mod trans id
566 0
567 0
568 7 red green blue spec rough trans tspec
569 .DE
570 .LP
571 .UL Plastic2
572 .PP
573 Plastic2 is similar to plastic, but with anisotropic
574 roughness.
575 This means that highlights in the surface will appear elliptical rather
576 than round.
577 The orientation of the anisotropy is determined by the unnormalized
578 direction vector
579 .I "ux uy uz".
580 These three expressions (separated by white space) are evaluated in
581 the context of the function file
582 .I funcfile.
583 If no function file is required (i.e., no special variables or
584 functions are required), a period (`.') may be given in its
585 place.
586 (See the discussion of Function Files in the Auxiliary Files section).
587 The
588 .I urough
589 value defines the roughness along the
590 .B u
591 vector given projected onto the surface.
592 The
593 .I vrough
594 value defines the roughness perpendicular to this vector.
595 Note that the highlight will be narrower in the direction of the
596 smaller roughness value.
597 Roughness values of zero are not allowed for efficiency reasons
598 since the behavior would be the same as regular plastic in that
599 case.
600 .DS
601 mod plastic2 id
602 4+ ux uy uz funcfile transform
603 0
604 6 red green blue spec urough vrough
605 .DE
606 .LP
607 .UL Metal2
608 .PP
609 Metal2 is the same as plastic2, except that the highlights are
610 modified by the material color.
611 .LP
612 .UL Trans2
613 .PP
614 Trans2 is the anisotropic version of trans.
615 The string arguments are the same as for plastic2, and the real
616 arguments are the same as for trans but with an additional roughness
617 value.
618 .DS
619 mod trans2 id
620 4+ ux uy uz funcfile transform
621 0
622 8 red green blue spec urough vrough trans tspec
623 .DE
624 .LP
625 .UL Dielectric
626 .PP
627 A dielectric material is transparent, and it refracts light
628 as well as reflecting it.
629 Its behavior is determined by the index of refraction and
630 transmission coefficient in each wavelength band per unit length.
631 Common glass has a index of refraction (n) around 1.5,
632 and a transmission coefficient of roughly 0.92 over an inch.
633 An additional number, the Hartmann constant, describes how
634 the index of refraction changes as a function of wavelength.
635 It is usually zero.
636 (A pattern modifies only the refracted value.)
637 .DS
638 mod dielectric id
639 0
640 0
641 5 rtn gtn btn n hc
642 .DE
643 .LP
644 .UL Interface
645 .PP
646 An interface is a boundary between two dielectrics.
647 The first transmission coefficient and refractive index are for the inside;
648 the second ones are for the outside.
649 Ordinary dielectrics are surrounded by a vacuum (1 1 1 1).
650 .DS
651 mod interface id
652 0
653 0
654 8 rtn1 gtn1 btn1 n1 rtn2 gtn2 btn2 n2
655 .DE
656 .LP
657 .UL Glass
658 .PP
659 Glass is similar to dielectric, but it is optimized for thin glass
660 surfaces (n = 1.52).
661 One transmitted ray and one reflected ray is produced.
662 By using a single surface is in place of two, internal reflections
663 are avoided.
664 The surface orientation is irrelevant, as it is for plastic,
665 metal, and trans.
666 The only specification required is the transmissivity at normal
667 incidence.
668 (Transmissivity is the amount of light not absorbed in one traversal
669 of the material.
670 Transmittance -- the value usually measured -- is the total light
671 transmitted through the pane including multiple reflections.)\0
672 To compute transmissivity (tn) from transmittance (Tn) use:
673 .DS
674 tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn
675 .DE
676 Standard 88% transmittance glass has a transmissivity of 0.96.
677 (A pattern modifying glass will affect the transmissivity.)
678 If a fourth real argument is given, it is interpreted as the index of
679 refraction to use instead of 1.52.
680 .DS
681 mod glass id
682 0
683 0
684 3 rtn gtn btn
685 .DE
686 .LP
687 .UL Plasfunc
688 .PP
689 Plasfunc in used for the procedural definition of plastic-like
690 materials with arbitrary bidirectional reflectance distribution
691 functions (BRDF's).
692 The arguments to this material include the color and specularity,
693 as well as the function defining the specular distribution and the
694 auxiliary file where it may be found.
695 .DS
696 mod plasfunc id
697 2+ refl funcfile transform
698 0
699 4+ red green blue spec A5 ..
700 .DE
701 The function
702 .I refl
703 takes four arguments, the x, y and z
704 direction towards the incident light, and the solid angle
705 subtended by the source.
706 The solid angle is provided to facilitate averaging, and is usually
707 ignored.
708 The
709 .I refl
710 function should integrate to 1 over
711 the projected hemisphere to maintain energy balance.
712 At least four real arguments must be given, and these are made
713 available along with any additional values to the reflectance
714 function.
715 Currently, only the contribution from direct light sources is
716 considered in the specular calculation.
717 As in most material types, the surface normal is always
718 altered to face the incoming ray.
719 .LP
720 .UL Metfunc
721 .PP
722 Metfunc is identical to plasfunc and takes the same arguments, but
723 the specular component is multiplied also by the material color.
724 .LP
725 .UL Transfunc
726 .PP
727 Transfunc is similar to plasfunc but with an arbitrary bidirectional
728 transmittance distribution as well as a reflectance distribution.
729 Both reflectance and transmittance are specified with the same function.
730 .DS
731 mod transfunc id
732 2+ brtd funcfile transform
733 0
734 6+ red green blue rspec trans tspec A7 ..
735 .DE
736 Where
737 .I trans
738 is the total light transmitted and
739 .I tspec
740 is the non-Lambertian fraction of transmitted light.
741 The function
742 .I brtd
743 should integrate to 1 over each projected hemisphere.
744 .LP
745 .UL BRTDfunc
746 .PP
747 The material BRTDfunc gives the maximum flexibility over surface
748 reflectance and transmittance, providing for spectrally-dependent
749 specular rays and reflectance and transmittance distribution functions.
750 .DS
751 mod BRTDfunc id
752 10+ rrefl grefl brefl
753 rtrns gtrns btrns
754 rbrtd gbrtd bbrtd
755 funcfile transform
756 0
757 9+ rfdif gfdif bfdif
758 rbdif gbdif bbdif
759 rtdif gtdif btdif
760 A10 ..
761 .DE
762 The variables
763 .I "rrefl, grefl"
764 and
765 .I brefl
766 specify the color coefficients for
767 the ideal specular (mirror) reflection of the surface.
768 The variables
769 .I "rtrns, gtrns"
770 and
771 .I btrns
772 specify the color coefficients for the ideal specular transmission.
773 The functions
774 .I "rbrtd, gbrtd"
775 and
776 .I bbrtd
777 take the direction to the incident light (and its solid angle)
778 and compute the color coefficients for the directional diffuse part of
779 reflection and transmission.
780 As a special case, three identical values of '0' may be given in place of
781 these function names to indicate no directional diffuse component.
782 .PP
783 Unlike most other material types, the surface normal is not altered to
784 face the incoming ray.
785 Thus, functions and variables must pay attention to the orientation of
786 the surface and make adjustments appropriately.
787 However, the special variables for the perturbed dot product and surface
788 normal,
789 .I "RdotP, NxP, NyP"
790 and
791 .I NzP
792 are reoriented as if the ray hit the front surface for convenience.
793 .PP
794 A diffuse reflection component may be given for the front side with
795 .I "rfdif, gfdif"
796 and
797 .I bfdif
798 for the front side of the surface or
799 .I "rbdif, gbdif"
800 and
801 .I bbdif
802 for the back side.
803 The diffuse transmittance (must be the same for both sides by physical law)
804 is given by
805 .I "rtdif, gtdif"
806 and
807 .I btdif.
808 A pattern will modify these diffuse scattering values,
809 and will be available through the special variables
810 .I "CrP, CgP"
811 and
812 .I CbP.
813 .PP
814 Care must be taken when using this material type to produce a physically
815 valid reflection model.
816 The reflectance functions should be bidirectional, and under no circumstances
817 should the sum of reflected diffuse, transmitted diffuse, reflected specular,
818 transmitted specular and the integrated directional diffuse component be
819 greater than one.
820 .LP
821 .UL Plasdata
822 .PP
823 Plasdata is used for arbitrary BRDF's that are most conveniently
824 given as interpolated data.
825 The arguments to this material are the data file and coordinate index
826 functions, as well as a function to optionally modify the data
827 values.
828 .DS
829 mod plasdata id
830 3+n+
831 func datafile
832 funcfile x1 x2 .. xn transform
833 0
834 4+ red green blue spec A5 ..
835 .DE
836 The coordinate indices
837 .I "(x1, x2,"
838 etc.) are themselves functions of
839 the x, y and z direction to the incident light, plus the solid angle
840 subtended by the light source (usually ignored).
841 The data function
842 .I (func)
843 takes five variables, the
844 interpolated value from the n-dimensional data file, followed by the
845 x, y and z direction to the incident light and the solid angle of the source.
846 The light source direction and size may of course be ignored by the function.
847 .LP
848 .UL Metdata
849 .PP
850 As metfunc is to plasfunc, metdata is to plasdata.
851 Metdata takes the same arguments as plasdata, but the specular
852 component is modified by the given material color.
853 .LP
854 .UL Transdata
855 .PP
856 Transdata is like plasdata but the specification includes transmittance
857 as well as reflectance.
858 The parameters are as follows.
859 .DS
860 mod transdata id
861 3+n+
862 func datafile
863 funcfile x1 x2 .. xn transform
864 0
865 6+ red green blue rspec trans tspec A7 ..
866 .DE
867 .LP
868 .UL BSDF
869 .PP
870 The BSDF material type loads an XML (eXtensible Markup Language)
871 file describing a bidirectional scattering distribution function.
872 Real arguments to this material may define additional
873 diffuse components that augment the BSDF data.
874 String arguments are used to define thickness for proxied
875 surfaces and the "up" orientation for the material.
876 .DS
877 mod BSDF id
878 6+ thick BSDFfile ux uy uz funcfile transform
879 0
880 0|3|6|9
881 rfdif gfdif bfdif
882 rbdif gbdif bbdif
883 rtdif gtdif btdif
884 .DE
885 The first string argument is a "thickness" parameter that may be used
886 to hide detail geometry being proxied by an aggregate BSDF material.
887 If a view or shadow ray hits a BSDF proxy with non-zero thickness,
888 it will pass directly through as if the surface were not there.
889 Similar to the illum type, this permits direct viewing and
890 shadow testing of complex geometry.
891 The BSDF is used when a scattered (indirect) ray hits the surface,
892 and any transmitted sample rays will be offset by the thickness amount
893 to avoid the hidden geometry and gather samples from the other side.
894 In this manner, BSDF surfaces can improve the results for indirect
895 scattering from complex systems without sacrificing appearance or
896 shadow accuracy.
897 If the BSDF has transmission and back-side reflection data,
898 a parallel BSDF surface may be
899 placed slightly less than the given thickness away from the front surface
900 to enclose the complex geometry on both sides.
901 .LP
902 The second string argument is the name of the BSDF file, which is
903 found in the usual auxiliary locations.
904 The following three string parameters name variables for an "up" vector,
905 which together with the surface normal, define the
906 local coordinate system that orients the BSDF.
907 These variables, along with the thickness, are defined in a function
908 file given as the next string argument.
909 An optional transform is used to scale the thickness and reorient the up vector.
910 .LP
911 If no real arguments are given, the BSDF is used by itself to determine
912 reflection and transmission.
913 If there are at least 3 real arguments, the first triplet is an
914 additional diffuse reflectance for the front side.
915 At least 6 real arguments adds diffuse reflectance to the rear side of the surface.
916 If there are 9 real arguments, the final triplet will be taken as an additional
917 diffuse transmittance.
918 All diffuse components as well as the non-diffuse transmission are
919 modified by patterns applied to this material.
920 The non-diffuse reflection from either side are unaffected.
921 Textures perturb the effective surface normal in the usual way.
922 .LP
923 The surface normal of this type is not altered to face the incoming ray,
924 so the front and back BSDF reflections may differ.
925 (Transmission is identical front-to-back by physical law.)\0
926 If back visibility is turned off during rendering and there is no
927 transmission or back-side reflection, only then the surface will be
928 invisible from behind.
929 Unlike other data-driven material types, the BSDF type is fully
930 supported and all parts of the distribution are properly sampled.
931 .LP
932 .UL Antimatter
933 .PP
934 Antimatter is a material that can "subtract" volumes from other volumes.
935 A ray passing into an antimatter object becomes blind to all the specified
936 modifiers:
937 .DS
938 mod antimatter id
939 N mod1 mod2 .. modN
940 0
941 0
942 .DE
943 The first modifier will also be used to shade the area leaving the
944 antimatter volume and entering the regular volume.
945 If mod1 is void, the antimatter volume is completely invisible.
946 Antimatter does not work properly with the material type "trans",
947 and multiple antimatter surfaces should be disjoint.
948 The viewpoint must be outside all volumes concerned for a correct
949 rendering.
950 .NH 3
951 Textures
952 .PP
953 A texture is a perturbation of the surface normal, and
954 is given by either a function or data.
955 .LP
956 .UL Texfunc
957 .PP
958 A texfunc uses an auxiliary function file
959 to specify a procedural texture:
960 .DS
961 mod texfunc id
962 4+ xpert ypert zpert funcfile transform
963 0
964 n A1 A2 .. An
965 .DE
966 .LP
967 .UL Texdata
968 .PP
969 A texdata texture uses three data files to get the surface
970 normal perturbations.
971 The variables
972 .I xfunc,
973 .I yfunc
974 and
975 .I zfunc
976 take three arguments
977 each from the interpolated values in
978 .I xdfname,
979 .I ydfname
980 and
981 .I zdfname.
982 .DS
983 mod texdata id
984 8+ xfunc yfunc zfunc xdfname ydfname zdfname vfname x0 x1 .. xf
985 0
986 n A1 A2 .. An
987 .DE
988 .NH 3
989 Patterns
990 .PP
991 Patterns are used to modify the reflectance of materials.
992 The basic types are given below.
993 .LP
994 .UL Colorfunc
995 .PP
996 A colorfunc is a procedurally defined color pattern.
997 It is specified as follows:
998 .DS
999 mod colorfunc id
1000 4+ red green blue funcfile transform
1001 0
1002 n A1 A2 .. An
1003 .DE
1004 .LP
1005 .UL Brightfunc
1006 .PP
1007 A brightfunc is the same as a colorfunc, except it is monochromatic.
1008 .DS
1009 mod brightfunc id
1010 2+ refl funcfile transform
1011 0
1012 n A1 A2 .. An
1013 .DE
1014 .LP
1015 .UL Colordata
1016 .PP
1017 Colordata uses an interpolated data map to modify a material's color.
1018 The map is n-dimensional, and is stored in three
1019 auxiliary files, one for each color.
1020 The coordinates used to look up and interpolate the data are
1021 defined in another auxiliary file.
1022 The interpolated data values are modified by functions of
1023 one or three variables.
1024 If the functions are of one variable, then they are passed the
1025 corresponding color component (red or green or blue).
1026 If the functions are of three variables, then they are passed the
1027 original red, green, and blue values as parameters.
1028 .DS
1029 mod colordata id
1030 7+n+
1031 rfunc gfunc bfunc rdatafile gdatafile bdatafile
1032 funcfile x1 x2 .. xn transform
1033 0
1034 m A1 A2 .. Am
1035 .DE
1036 .LP
1037 .UL Brightdata
1038 .PP
1039 Brightdata is like colordata, except monochromatic.
1040 .DS
1041 mod brightdata id
1042 3+n+
1043 func datafile
1044 funcfile x1 x2 .. xn transform
1045 0
1046 m A1 A2 .. Am
1047 .DE
1048 .LP
1049 .UL Colorpict
1050 .PP
1051 Colorpict is a special case of colordata, where the pattern is
1052 a two-dimensional image stored in the RADIANCE picture format.
1053 The dimensions of the image data are determined by the picture
1054 such that the smaller dimension is always 1, and the other
1055 is the ratio between the larger and the smaller.
1056 For example, a 500x338 picture would have coordinates (u,v)
1057 in the rectangle between (0,0) and (1.48,1).
1058 .DS
1059 mod colorpict id
1060 7+
1061 rfunc gfunc bfunc pictfile
1062 funcfile u v transform
1063 0
1064 m A1 A2 .. Am
1065 .DE
1066 .LP
1067 .UL Colortext
1068 .PP
1069 Colortext is dichromatic writing in a polygonal font.
1070 The font is defined in an auxiliary file, such as
1071 .I helvet.fnt.
1072 The text itself is also specified in a separate file, or
1073 can be part of the material arguments.
1074 The character size, orientation, aspect ratio and slant is
1075 determined by right and down motion vectors.
1076 The upper left origin for the text block as well as
1077 the foreground and background colors
1078 must also be given.
1079 .DS
1080 mod colortext id
1081 2 fontfile textfile
1082 0
1083 15+
1084 Ox Oy Oz
1085 Rx Ry Rz
1086 Dx Dy Dz
1087 rfore gfore bfore
1088 rback gback bback
1089 [spacing]
1090 .DE
1091 or:
1092 .DS
1093 mod colortext id
1094 2+N fontfile . This is a line with N words ...
1095 0
1096 15+
1097 Ox Oy Oz
1098 Rx Ry Rz
1099 Dx Dy Dz
1100 rfore gfore bfore
1101 rback gback bback
1102 [spacing]
1103 .DE
1104 .LP
1105 .UL Brighttext
1106 .PP
1107 Brighttext is like colortext, but the writing is monochromatic.
1108 .DS
1109 mod brighttext id
1110 2 fontfile textfile
1111 0
1112 11+
1113 Ox Oy Oz
1114 Rx Ry Rz
1115 Dx Dy Dz
1116 foreground background
1117 [spacing]
1118 .DE
1119 or:
1120 .DS
1121 mod brighttext id
1122 2+N fontfile . This is a line with N words ...
1123 0
1124 11+
1125 Ox Oy Oz
1126 Rx Ry Rz
1127 Dx Dy Dz
1128 foreground background
1129 [spacing]
1130 .DE
1131 .LP
1132 By default, a uniform spacing algorithm is used that guarantees
1133 every character will appear in a precisely determined position.
1134 Unfortunately, such a scheme results in rather unattractive and difficult to
1135 read text with most fonts.
1136 The optional
1137 .I spacing
1138 value defines the distance between characters for proportional spacing.
1139 A positive value selects a spacing algorithm that preserves right margins and
1140 indentation, but does not provide the ultimate in proportionally spaced text.
1141 A negative value insures that characters are properly spaced, but the
1142 placement of words then varies unpredictably.
1143 The choice depends on the relative importance of spacing versus formatting.
1144 When presenting a section of formatted text, a positive spacing value is
1145 usually preferred.
1146 A single line of text will often be accompanied by a negative spacing value.
1147 A section of text meant to depict a picture, perhaps using a special purpose
1148 font such as hexbit4x1.fnt, calls for uniform spacing.
1149 Reasonable magnitudes for proportional spacing are
1150 between 0.1 (for tightly spaced characters) and 0.3 (for wide spacing).
1151 .NH 3
1152 Mixtures
1153 .PP
1154 A mixture is a blend of one or more materials or textures and patterns.
1155 The basic types are given below.
1156 .LP
1157 .UL Mixfunc
1158 .PP
1159 A mixfunc mixes two modifiers procedurally.
1160 It is specified as follows:
1161 .DS
1162 mod mixfunc id
1163 4+ foreground background vname funcfile transform
1164 0
1165 n A1 A2 .. An
1166 .DE
1167 Foreground and background are modifier names that must be
1168 defined earlier in the scene description.
1169 If one of these is a material, then
1170 the modifier of the mixfunc must be "void".
1171 (Either the foreground or background modifier may be "void",
1172 which serves as a form of opacity control when used with a material.)\0
1173 Vname is the coefficient defined in funcfile that determines the influence
1174 of foreground.
1175 The background coefficient is always (1-vname).
1176 .LP
1177 .UL Mixdata
1178 .PP
1179 Mixdata combines two modifiers using an auxiliary data file:
1180 .DS
1181 mod mixdata id
1182 5+n+
1183 foreground background func datafile
1184 funcfile x1 x2 .. xn transform
1185 0
1186 m A1 A2 .. Am
1187 .DE
1188 .LP
1189 .UL Mixpict
1190 .PP
1191 Mixpict combines two modifiers based on a picture:
1192 .DS
1193 mod mixpict id
1194 7+
1195 foreground background func pictfile
1196 funcfile u v transform
1197 0
1198 m A1 A2 .. Am
1199 .DE
1200 The mixing coefficient function "func" takes three
1201 arguments, the red, green and blue values
1202 corresponding to the pixel at (u,v).
1203 .LP
1204 .UL Mixtext
1205 .PP
1206 Mixtext uses one modifier for the text foreground, and one for the
1207 background:
1208 .DS
1209 mod mixtext id
1210 4 foreground background fontfile textfile
1211 0
1212 9+
1213 Ox Oy Oz
1214 Rx Ry Rz
1215 Dx Dy Dz
1216 [spacing]
1217 .DE
1218 or:
1219 .DS
1220 mod mixtext id
1221 4+N
1222 foreground background fontfile .
1223 This is a line with N words ...
1224 0
1225 9+
1226 Ox Oy Oz
1227 Rx Ry Rz
1228 Dx Dy Dz
1229 [spacing]
1230 .DE
1231 .NH 2
1232 Auxiliary Files
1233 .PP
1234 Auxiliary files used in textures and patterns
1235 are accessed by the programs during image generation.
1236 These files may be located in the working directory, or in
1237 a library directory.
1238 The environment variable
1239 .I RAYPATH
1240 can be assigned an alternate set of search directories.
1241 Following is a brief description of some common file types.
1242 .NH 3
1243 Function Files
1244 .PP
1245 A function file contains the definitions of variables, functions
1246 and constants used by a primitive.
1247 The transformation that accompanies the file name contains the necessary
1248 rotations, translations and scalings to bring the coordinates of
1249 the function file into agreement with the world coordinates.
1250 The transformation specification is the same as for the
1251 .I xform
1252 command.
1253 An example function file is given below:
1254 .DS
1255 {
1256 This is a comment, enclosed in curly braces.
1257 {Comments can be nested.}
1258 }
1259 { standard expressions use +,-,*,/,^,(,) }
1260 vname = Ny * func(A1) ;
1261 { constants are defined with a colon }
1262 const : sqrt(PI/2) ;
1263 { user-defined functions add to library }
1264 func(x) = 5 + A1*sin(x/3) ;
1265 { functions may be passed and recursive }
1266 rfunc(f,x) = if(x,f(x),f(-x)*rfunc(f,x+1)) ;
1267 { constant functions may also be defined }
1268 cfunc(x) : 10*x / sqrt(x) ;
1269 .DE
1270 Many variables and functions are already defined by the program,
1271 and they are listed in the file
1272 .I rayinit.cal.
1273 The following variables are particularly important:
1274 .DS
1275 Dx, Dy, Dz - incident ray direction
1276 Nx, Ny, Nz - surface normal at intersection point
1277 Px, Py, Pz - intersection point
1278 T - distance from start
1279 Ts - single ray (shadow) distance
1280 Rdot - cosine between ray and normal
1281 arg(0) - number of real arguments
1282 arg(i) - i'th real argument
1283 .DE
1284 For mesh objects, the local surface coordinates are available:
1285 .DS
1286 Lu, Lv - local (u,v) coordinates
1287 .DE
1288 For BRDF types, the following variables are defined as well:
1289 .DS
1290 NxP, NyP, NzP - perturbed surface normal
1291 RdotP - perturbed dot product
1292 CrP, CgP, CbP - perturbed material color
1293 .DE
1294 A unique context is set up for each file so that the same variable
1295 may appear in different function files without conflict.
1296 The variables listed above and any others defined in
1297 rayinit.cal are available globally.
1298 If no file is needed by a given primitive because all the required
1299 variables are global, a period (`.') can be given in
1300 place of the file name.
1301 It is also possible to give an expression instead of a straight
1302 variable name in a scene file.
1303 Functions (requiring parameters)
1304 must be given as names and not as expressions.
1305 .PP
1306 Constant expressions are used as an optimization in function
1307 files.
1308 They are replaced wherever they occur in an expression by their
1309 value.
1310 Constant expressions are evaluated only once, so they must not
1311 contain any variables or values that can change, such as the ray
1312 variables Px and Ny or the primitive argument function arg().
1313 All the math library functions such as sqrt() and cos() have the
1314 constant attribute, so they will be replaced by immediate values
1315 whenever they are given constant arguments.
1316 Thus, the subexpression cos(PI*sqrt(2)) is immediately replaced
1317 by its value, -.266255342, and does not cause any additional overhead
1318 in the calculation.
1319 .PP
1320 It is generally a good idea to define constants and variables before
1321 they are referred to in a function file.
1322 Although evaluation does not take place until later, the interpreter
1323 does variable scoping and constant subexpression evaluation based on
1324 what it has compiled already.
1325 For example, a variable that is defined globally in rayinit.cal then
1326 referenced in the local context of a function file cannot
1327 subsequently be redefined in the same file because the compiler
1328 has already determined the scope of the referenced variable as global.
1329 To avoid such conflicts, one can state the scope of a variable explicitly
1330 by preceding the variable name with a context mark (a back-quote) for
1331 a local variable, or following the name with a context mark for a global
1332 variable.
1333 .NH 3
1334 Data Files
1335 .PP
1336 Data files contain n-dimensional arrays of real numbers used
1337 for interpolation.
1338 Typically, definitions in a function file determine how
1339 to index and use interpolated data values.
1340 The basic data file format is as follows:
1341 .DS
1342 N
1343 beg1 end1 m1
1344 0 0 m2 x2.1 x2.2 x2.3 x2.4 .. x2.m2
1345 ...
1346 begN endN mN
1347 DATA, later dimensions changing faster.
1348 .DE
1349 N is the number of dimensions.
1350 For each dimension, the beginning and ending coordinate
1351 values and the dimension size is given.
1352 Alternatively, individual coordinate values can be given when
1353 the points are not evenly spaced.
1354 These values must either be increasing or decreasing monotonically.
1355 The data is m1*m2*...*mN real numbers in ASCII form.
1356 Comments may appear anywhere in the file, beginning with a pound
1357 sign ('#') and continuing to the end of line.
1358 .NH 3
1359 Font Files
1360 .PP
1361 A font file lists the polygons which make up a character set.
1362 Comments may appear anywhere in the file, beginning with a pound
1363 sign ('#') and continuing to the end of line.
1364 All numbers are decimal integers:
1365 .DS
1366 code n
1367 x0 y0
1368 x1 y1
1369 ...
1370 xn yn
1371 ...
1372 .DE
1373 The ASCII codes can appear in any order.
1374 N is the number of vertices, and the last is automatically
1375 connected to the first.
1376 Separate polygonal sections are joined by coincident sides.
1377 The character coordinate system is a square with lower left corner at
1378 (0,0), lower right at (255,0) and upper right at (255,255).
1379 .NH 2
1380 Generators
1381 .PP
1382 A generator is any program that produces a scene description
1383 as its output.
1384 They usually appear as commands in a scene description file.
1385 An example of a simple generator is
1386 .I genbox.
1387 .I Genbox
1388 takes the arguments of width, height and depth to produce
1389 a parallelepiped description.
1390 .I Genprism
1391 takes a list of 2-dimensional coordinates and extrudes them along a vector to
1392 produce a 3-dimensional prism.
1393 .I Genrev
1394 is a more sophisticated generator
1395 that produces an object of rotation from parametric functions
1396 for radius and axis position.
1397 .I Gensurf
1398 tessellates a surface defined by the
1399 parametric functions x(s,t), y(s,t), and z(s,t).
1400 .I Genworm
1401 links cylinders and spheres along a curve.
1402 .I Gensky
1403 produces a sun and sky distribution corresponding
1404 to a given time and date.
1405 .PP
1406 .I Xform
1407 is a program that transforms a scene description from one
1408 coordinate space to another.
1409 .I Xform
1410 does rotation, translation, scaling, and mirroring.
1411 .NH 1
1412 Image Generation
1413 .PP
1414 Once the scene has been described in three-dimensions, it
1415 is possible to generate a two-dimensional image from a
1416 given perspective.
1417 .PP
1418 The image generating programs use an
1419 .I octree
1420 to efficiently trace rays through the scene.
1421 An octree subdivides space into nested octants which
1422 contain sets of surfaces.
1423 In RADIANCE, an octree is created from a scene description by
1424 .I oconv.
1425 The details of this process are not important,
1426 but the octree will serve as input to the ray-tracing
1427 programs and directs the use of a scene description.
1428 .PP
1429 .I Rview
1430 is ray-tracing program for viewing a scene interactively.
1431 When the user specifies a new perspective,
1432 .I rview
1433 quickly displays a rough
1434 image on the terminal, then progressively
1435 increases the resolution as the user looks on.
1436 He can select a particular section of the image to improve,
1437 or move to a different view and start over.
1438 This mode of interaction is useful for debugging scenes
1439 as well as determining the best view for a final image.
1440 .PP
1441 .I Rpict
1442 produces a high-resolution picture of a scene from
1443 a particular perspective.
1444 This program features adaptive sampling, crash
1445 recovery and progress reporting, all of which are important
1446 for time-consuming images.
1447 .PP
1448 A number of filters are available for manipulating picture files.
1449 .I Pfilt
1450 sets the exposure and performs anti-aliasing.
1451 .I Pcompos
1452 composites (cuts and pastes) pictures.
1453 .I Pcond
1454 conditions a picture for a specific display device.
1455 .I Pcomb
1456 performs arbitrary math on one or more pictures.
1457 .I Protate
1458 rotates a picture 90 degrees clockwise.
1459 .I Pflip
1460 flips a picture horizontally, vertically, or both (180 degree rotation).
1461 .I Pvalue
1462 converts a picture to and from simpler formats.
1463 .PP
1464 Pictures may be displayed directly under X11 using the program
1465 .I ximage,
1466 or converted a standard image format.
1467 .I Ra_bmp
1468 converts to and from Microsoft Bitmap images.
1469 .I Ra_ppm
1470 converts to and from Poskanzer Portable Pixmap formats.
1471 .I Ra_ps
1472 converts to PostScript color and greyscale formats.
1473 .I Ra_rgbe
1474 converts to and from Radiance uncompressed picture format.
1475 .I Ra_t16
1476 converts to and from Targa 16 and 24-bit image formats.
1477 .I Ra_t8
1478 converts to and from Targa 8-bit image format.
1479 .I Ra_tiff
1480 converts to and from TIFF.
1481 .I Ra_xyze
1482 converts to and from Radiance CIE picture format.
1483 .NH 1
1484 License
1485 .PP
1486 .DS
1487 The Radiance Software License, Version 1.0
1488
1489 Copyright (c) 1990 - 2008 The Regents of the University of California,
1490 through Lawrence Berkeley National Laboratory. All rights reserved.
1491
1492 Redistribution and use in source and binary forms, with or without
1493 modification, are permitted provided that the following conditions
1494 are met:
1495
1496 1. Redistributions of source code must retain the above copyright
1497 notice, this list of conditions and the following disclaimer.
1498
1499 2. Redistributions in binary form must reproduce the above copyright
1500 notice, this list of conditions and the following disclaimer in
1501 the documentation and/or other materials provided with the
1502 distribution.
1503
1504 3. The end-user documentation included with the redistribution,
1505 if any, must include the following acknowledgment:
1506 "This product includes Radiance software
1507 (http://radsite.lbl.gov/)
1508 developed by the Lawrence Berkeley National Laboratory
1509 (http://www.lbl.gov/)."
1510 Alternately, this acknowledgment may appear in the software itself,
1511 if and wherever such third-party acknowledgments normally appear.
1512
1513 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
1514 and "The Regents of the University of California" must
1515 not be used to endorse or promote products derived from this
1516 software without prior written permission. For written
1517 permission, please contact [email protected].
1518
1519 5. Products derived from this software may not be called "Radiance",
1520 nor may "Radiance" appear in their name, without prior written
1521 permission of Lawrence Berkeley National Laboratory.
1522
1523 THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
1524 WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
1525 OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
1526 DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
1527 ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
1528 SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
1529 LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
1530 USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
1531 ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
1532 OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
1533 OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
1534 SUCH DAMAGE.
1535 .DE
1536 .NH 1
1537 Acknowledgements
1538 .PP
1539 This work was supported by the Assistant Secretary of Conservation
1540 and Renewable Energy, Office of Building Energy Research and
1541 Development, Buildings Equipment Division of the U.S. Department of
1542 Energy under Contract No. DE-AC03-76SF00098.
1543 .PP
1544 Additional work was sponsored by the Swiss federal government
1545 under the Swiss LUMEN Project and was
1546 carried out in the Laboratoire d'Energie Solaire (LESO Group) at
1547 the Ecole Polytechnique Federale de Lausanne (EPFL University)
1548 in Lausanne, Switzerland.
1549 .NH 1
1550 References
1551 .LP
1552 Cater, K., A. Chalmers, G. Ward,
1553 ``Detail to Attention: Exploiting Visual Tasks for Selective Rendering,''
1554 .I "Eurograhics Symposium on Rendering",
1555 June 2003.
1556 .LP
1557 Ward, G., Elena Eydelberg-Vileshin,
1558 ``Picture Perfect RGB Rendering Using Spectral Prefiltering and
1559 Sharp Color Primaries,''
1560 13th Eurographics Workshop on Rendering, P. Debevec and
1561 S. Gibson (Editors), June 2002.
1562 .LP
1563 Ward, G. and M. Simmons,
1564 ``The Holodeck Ray Cache: An Interactive Rendering System for Global
1565 Illumination in Nondiffuse Environments,''
1566 .I "ACM Transactions on Graphics,"
1567 18(4):361-98, October 1999.
1568 .LP
1569 Larson, G.W., H. Rushmeier, C. Piatko,
1570 ``A Visibility Matching Tone Reproduction Operator for High Dynamic
1571 Range Scenes,''
1572 .I "IEEE Transactions on Visualization and Computer Graphics",
1573 3(4), 291-306, December 1997.
1574 .LP
1575 Ward, G.,
1576 ``Making Global Illumination User Friendly,''
1577 .I "Sixth Eurographics Workshop on Rendering",
1578 proceedings to be published by Springer-Verlag,
1579 Dublin, Ireland, June 1995.
1580 .LP
1581 Rushmeier, H., G. Ward, C. Piatko, P. Sanders, B. Rust,
1582 ``Comparing Real and Synthetic Images: Some Ideas about Metrics,''
1583 .I "Sixth Eurographics Workshop on Rendering",
1584 proceedings to be published by Springer-Verlag,
1585 Dublin, Ireland, June 1995.
1586 .LP
1587 Ward, G.,
1588 ``The Radiance Lighting Simulation and Rendering System,''
1589 .I "Computer Graphics",
1590 Orlando, July 1994.
1591 .LP
1592 Rushmeier, H., G. Ward,
1593 ``Energy-Preserving Non-Linear Filters,''
1594 .I "Computer Graphics",
1595 Orlando, July 1994.
1596 .LP
1597 Ward, G.,
1598 ``A Contrast-Based Scalefactor for Luminance Display,''
1599 .I "Graphics Gems IV",
1600 Edited by Paul Heckbert,
1601 Academic Press 1994.
1602 .LP
1603 Ward, G.,
1604 ``Measuring and Modeling Anisotropic Reflection,''
1605 .I "Computer Graphics",
1606 Chicago, July 1992.
1607 .LP
1608 Ward, G., P. Heckbert,
1609 ``Irradiance Gradients,''
1610 .I "Third Annual Eurographics Workshop on Rendering",
1611 to be published by Springer-Verlag, held in Bristol, UK, May 1992.
1612 .LP
1613 Ward, G.,
1614 ``Adaptive Shadow Testing for Ray Tracing,''
1615 .I "Second Annual Eurographics Workshop on Rendering",
1616 to be published by Springer-Verlag, held in Barcelona, SPAIN, May 1991.
1617 .LP
1618 Ward, G.,
1619 ``Visualization,''
1620 .I "Lighting Design and Application",
1621 Vol. 20, No. 6, June 1990.
1622 .LP
1623 Ward, G., F. Rubinstein, R. Clear,
1624 ``A Ray Tracing Solution for Diffuse Interreflection,''
1625 .I "Computer Graphics",
1626 Vol. 22, No. 4, August 1988.
1627 .LP
1628 Ward, G., F. Rubinstein,
1629 ``A New Technique for Computer Simulation of Illuminated Spaces,''
1630 .I "Journal of the Illuminating Engineering Society",
1631 Vol. 17, No. 1, Winter 1988.
