root/radiance/ray/doc/ray.1
Thu Jul 31 18:32:41 2014 UTC (10 years, 9 months ago) by greg
Changes since 1.25: +10 -3 lines
Diff to previous 1.25
Preparation for 4.2 release
Thu Oct 27 00:51:29 2011 UTC (13 years, 6 months ago) by greg
Diff to previous 1.24
Updated some dates
Mon Oct 17 21:53:55 2011 UTC (13 years, 7 months ago) by greg
Changes since 1.23: +2 -1 lines
Diff to previous 1.23
Fixed Leukos citation
Fri Jul 15 17:47:33 2011 UTC (13 years, 10 months ago) by greg
Changes since 1.22: +1 -1 lines
Diff to previous 1.22
Added missing comma
Fri Jul 15 17:45:46 2011 UTC (13 years, 10 months ago) by greg
Changes since 1.21: +6 -0 lines
Diff to previous 1.21
Added recent IES article to reference list
Wed Jun 22 00:13:25 2011 UTC (13 years, 10 months ago) by greg
Changes since 1.20: +1 -3 lines
Diff to previous 1.20
Removed inconsistent emphasis
Tue Jun 21 23:58:00 2011 UTC (13 years, 10 months ago) by greg
Changes since 1.19: +5 -0 lines
Diff to previous 1.19
Added mention of thickness sign for BSDF material
Sun Feb 20 06:34:19 2011 UTC (14 years, 2 months ago) by greg
Changes since 1.18: +16 -20 lines
Diff to previous 1.18
Made BSDF proxy behavior consistent for shadowing, reflection and transmission
Fri Feb 18 00:40:25 2011 UTC (14 years, 3 months ago) by greg
Changes since 1.17: +70 -2 lines
Diff to previous 1.17
Fri Mar 12 19:57:58 2010 UTC (15 years, 2 months ago) by greg
Changes since 1.16: +2 -8 lines
Diff to previous 1.16
Updated some image converters
Fri Mar 12 18:43:30 2010 UTC (15 years, 2 months ago) by greg
Changes since 1.15: +2 -2 lines
Diff to previous 1.15
Incorporated other changes
Fri Mar 12 18:34:43 2010 UTC (15 years, 2 months ago) by greg
Diff to previous 1.14
Fixed misspelling of Henyey's name
Wed Apr 30 22:00:28 2008 UTC (17 years ago) by greg
Changes since 1.13: +4 -4 lines
Diff to previous 1.13
Minor updates and fixes
Thu Aug 23 04:13:50 2007 UTC (17 years, 8 months ago) by greg
Changes since 1.12: +1 -2 lines
Diff to previous 1.12
Minor wording correction
Fri Jun 1 19:46:07 2007 UTC (17 years, 11 months ago) by greg
Changes since 1.11: +0 -4 lines
Diff to previous 1.11
Removed outdated reference to modifier loops, which were eliminated long ago
Wed Oct 18 00:43:09 2006 UTC (18 years, 7 months ago) by greg
Diff to previous 1.10
Fixed date
Tue Oct 17 21:52:43 2006 UTC (18 years, 7 months ago) by greg
Changes since 1.9: +6 -1 lines
Diff to previous 1.9
Version changes for 3.8 release
Wed May 10 19:50:30 2006 UTC (19 years ago) by greg
Changes since 1.8: +7 -7 lines
Diff to previous 1.8
Fixed language uses ("virtual" vs. "secondary" light sources)
Sun Jul 24 21:05:45 2005 UTC (19 years, 9 months ago) by greg
Diff to previous 1.7
Updated copyright year
Thu Oct 21 16:16:14 2004 UTC (20 years, 7 months ago) by greg
Diff to previous 1.6
Update for 3.6 official release
Tue Sep 21 18:44:09 2004 UTC (20 years, 7 months ago) by greg
Diff to previous 1.5
Fixed RCS Id and grouping of terms from last change for BRDF
Thu Jan 1 19:31:44 2004 UTC (21 years, 4 months ago) by greg
Diff to previous 1.4
Sat Mar 15 17:32:55 2003 UTC (22 years, 2 months ago) by greg
Changes since 1.3: +124 -59 lines
Diff to previous 1.3
Fri Mar 14 21:27:45 2003 UTC (22 years, 2 months ago) by greg
Changes since 1.2: +3 -0 lines
Tue Mar 11 19:29:04 2003 UTC (22 years, 2 months ago) by greg
Tue Mar 11 19:20:20 2003 UTC (22 years, 2 months ago) by greg
Added documentation to repository
