| 1 |
.\" RCSid "$Id$"
| 2 |
.\" Print using the -ms macro package
| 3 |
.DA 07/31/2014
| 4 |
.LP
| 5 |
.tl """Copyright \(co 2014 Regents, University of California
| 6 |
.sp 2
| 7 |
.TL
| 8 |
The
| 9 |
.so ../src/rt/VERSION
| 10 |
.br
| 11 |
Synthetic Imaging System
| 12 |
.AU
| 13 |
Building Technologies Department
| 14 |
.br
| 15 |
Lawrence Berkeley Laboratory
| 16 |
.br
| 17 |
1 Cyclotron Rd., MS 90-3111
| 18 |
.br
| 19 |
Berkeley, CA 94720
| 20 |
.NH 1
| 21 |
Introduction
| 22 |
.PP
| 23 |
RADIANCE was developed as a research tool
| 24 |
for predicting the distribution of visible radiation in
| 25 |
illuminated spaces.
| 26 |
It takes as input a three-dimensional geometric model of
| 27 |
the physical environment, and produces a map of
| 28 |
spectral radiance values in a color image.
| 29 |
The technique of ray-tracing follows light backwards
| 30 |
from the image plane to the source(s).
| 31 |
Because it can produce realistic images from a simple description,
| 32 |
RADIANCE has a wide range of applications in graphic arts,
| 33 |
lighting design, computer-aided engineering and architecture.
| 34 |
.KF
| 35 |
.sp 25
| 36 |
.ce
| 37 |
.B "Figure 1."
| 38 |
.sp
| 39 |
.KE
| 40 |
.PP
| 41 |
The diagram in Figure 1 shows the flow between programs (boxes) and
| 42 |
data (ovals).
| 43 |
The central program is
| 44 |
.I rpict,
| 45 |
which produces a picture from a scene description.
| 46 |
.I Rview
| 47 |
is a variation of
| 48 |
.I rpict
| 49 |
that computes and displays images interactively.
| 50 |
Other programs (not shown) connect many of these elements together,
| 51 |
such as the executive programs
| 52 |
.I rad
| 53 |
and
| 54 |
.I ranimate,
| 55 |
the interactive rendering program
| 56 |
.I rholo,
| 57 |
and the animation program
| 58 |
.I ranimove.
| 59 |
The program
| 60 |
.I obj2mesh
| 61 |
acts as both a converter and scene compiler, converting a Wavefront .OBJ
| 62 |
file into a compiled mesh octree for efficient rendering.
| 63 |
.PP
| 64 |
A scene description file lists the surfaces and materials
| 65 |
that make up a specific environment.
| 66 |
The current surface types are spheres, polygons, cones, and cylinders.
| 67 |
There is also a composite surface type, called mesh, and a pseudosurface
| 68 |
type, called instance, which facilitates very complex geometries.
| 69 |
Surfaces can be made from materials such as plastic, metal, and glass.
| 70 |
Light sources can be distant disks as well as local spheres, disks
| 71 |
and polygons.
| 72 |
.PP
| 73 |
From a three-dimensional scene description and a specified view,
| 74 |
.I rpict
| 75 |
produces a two-dimensional image.
| 76 |
A picture file is a compressed binary representation of the
| 77 |
pixels in the image.
| 78 |
This picture can be scaled in size and
| 79 |
brightness, anti-aliased, and sent to a graphics output device.
| 80 |
.PP
| 81 |
A header in each picture file lists the program(s) and
| 82 |
parameters that produced it.
| 83 |
This is useful for identifying a picture
| 84 |
without having to display it.
| 85 |
The information can be read by the program
| 86 |
.I getinfo.
| 87 |
.NH 1
| 88 |
Scene Description
| 89 |
.PP
| 90 |
A scene description file represents a
| 91 |
three-dimensional physical environment
| 92 |
in Cartesian (rectilinear) world coordinates.
| 93 |
It is stored as ASCII text, with the following basic format:
| 94 |
.DS
| 95 |
# comment
| 96 |
| 97 |
modifier type identifier
| 98 |
n S1 S2 "S 3" .. Sn
| 99 |
0
| 100 |
m R1 R2 R3 .. Rm
| 101 |
| 102 |
modifier alias identifier reference
| 103 |
| 104 |
! command
| 105 |
| 106 |
| 107 |
.DE
| 108 |
.PP
| 109 |
A comment line begins with a pound sign, `#'.
| 110 |
.PP
| 111 |
The scene description
| 112 |
.I primitives
| 113 |
all have the same general format, and can
| 114 |
be either surfaces or modifiers.
| 115 |
A primitive has a modifier, a type, and an identifier.
| 116 |
A modifier is either the identifier of a
| 117 |
.I "previously defined"
| 118 |
primitive, or "void"\(dg.
| 119 |
.FS
| 120 |
\(dgThe most recent definition of a modifier is the one used,
| 121 |
and later definitions do not cause relinking of loaded
| 122 |
primitives.
| 123 |
Thus, the same identifier may be used repeatedly, and each new
| 124 |
definition will apply to the primitives following it.
| 125 |
.FE
| 126 |
An identifier can be any string (i.e., any sequence of non-white characters).
| 127 |
The
| 128 |
.I arguments
| 129 |
associated with a primitive can be strings or real numbers.
| 130 |
The first integer following the identifier is the number
| 131 |
of string arguments, and it is followed by the arguments themselves
| 132 |
(separated by white space or enclosed in quotes).
| 133 |
The next integer is the number of integer arguments, and is followed
| 134 |
by the integer arguments.
| 135 |
(There are currently no primitives that use them, however.)
| 136 |
The next integer is the real argument count, and it is followed
| 137 |
by the real arguments.
| 138 |
.PP
| 139 |
An alias gets its type and arguments from a previously defined primitive.
| 140 |
This is useful when the same material is used with a different
| 141 |
modifier, or as a convenient naming mechanism.
| 142 |
The reserved modifier name "inherit" may be used to specificy that
| 143 |
an alias will inherit its modifier from the original.
| 144 |
Surfaces cannot be aliased.
| 145 |
.PP
| 146 |
A line beginning with an exclamation point, `!',
| 147 |
is interpreted as a command.
| 148 |
It is executed by the shell, and its output is read as input to
| 149 |
the program.
| 150 |
The command must not try to read from its standard input, or
| 151 |
confusion will result.
| 152 |
A command may be continued over multiple lines using a backslash, `\\',
| 153 |
to escape the newline.
| 154 |
.PP
| 155 |
White space is generally ignored, except as a separator.
| 156 |
The exception is the newline character after a command or comment.
| 157 |
Commands, comments and primitives may appear in any combination, so long
| 158 |
as they are not intermingled.
| 159 |
.NH 2
| 160 |
Primitive Types
| 161 |
.PP
| 162 |
Primitives can be surfaces, materials, textures or patterns.
| 163 |
Modifiers can be materials, mixtures, textures or patterns.
| 164 |
Simple surfaces must have one material in their modifier list.
| 165 |
.NH 3
| 166 |
Surfaces
| 167 |
.PP
| 168 |
A scene description will consist mostly of surfaces.
| 169 |
The basic types are given below.
| 170 |
.LP
| 171 |
.UL Source
| 172 |
.PP
| 173 |
A source is not really a surface, but a solid angle.
| 174 |
It is used for specifying light sources that are very distant.
| 175 |
The direction to the center of the source and the number of degrees
| 176 |
subtended by its disk are given as follows:
| 177 |
.DS
| 178 |
mod source id
| 179 |
0
| 180 |
0
| 181 |
4 xdir ydir zdir angle
| 182 |
.DE
| 183 |
.LP
| 184 |
.UL Sphere
| 185 |
.PP
| 186 |
A sphere is given by its center and radius:
| 187 |
.DS
| 188 |
mod sphere id
| 189 |
0
| 190 |
0
| 191 |
4 xcent ycent zcent radius
| 192 |
.DE
| 193 |
.LP
| 194 |
.UL Bubble
| 195 |
.PP
| 196 |
A bubble is simply a sphere whose surface normal points inward.
| 197 |
.LP
| 198 |
.UL Polygon
| 199 |
.PP
| 200 |
A polygon is given by a list of three-dimensional vertices,
| 201 |
which are ordered counter-clockwise as viewed from
| 202 |
the front side (into the surface normal).
| 203 |
The last vertex is automatically connected to the first.
| 204 |
Holes are represented in polygons as interior vertices connected to
| 205 |
the outer perimeter by coincident edges (seams).
| 206 |
.DS
| 207 |
mod polygon id
| 208 |
0
| 209 |
0
| 210 |
3n
| 211 |
x1 y1 z1
| 212 |
x2 y2 z2
| 213 |
| 214 |
xn yn zn
| 215 |
.DE
| 216 |
.LP
| 217 |
.UL Cone
| 218 |
.PP
| 219 |
A cone is a megaphone-shaped object.
| 220 |
It is truncated by two planes perpendicular to its axis,
| 221 |
and one of its ends may come to a point.
| 222 |
It is given as two axis endpoints, and the starting
| 223 |
and ending radii:
| 224 |
.DS
| 225 |
mod cone id
| 226 |
0
| 227 |
0
| 228 |
8
| 229 |
x0 y0 z0
| 230 |
x1 y1 z1
| 231 |
r0 r1
| 232 |
.DE
| 233 |
.LP
| 234 |
.UL Cup
| 235 |
.PP
| 236 |
A cup is an inverted cone (i.e., has an inward surface normal).
| 237 |
.LP
| 238 |
.UL Cylinder
| 239 |
.PP
| 240 |
A cylinder is like a cone, but its starting and ending radii are
| 241 |
equal.
| 242 |
.DS
| 243 |
mod cylinder id
| 244 |
0
| 245 |
0
| 246 |
7
| 247 |
x0 y0 z0
| 248 |
x1 y1 z1
| 249 |
rad
| 250 |
.DE
| 251 |
.LP
| 252 |
.UL Tube
| 253 |
.PP
| 254 |
A tube is an inverted cylinder.
| 255 |
.LP
| 256 |
.UL Ring
| 257 |
.PP
| 258 |
A ring is a circular disk given by its center, surface
| 259 |
normal, and inner and outer radii:
| 260 |
.DS
| 261 |
mod ring id
| 262 |
0
| 263 |
0
| 264 |
8
| 265 |
xcent ycent zcent
| 266 |
xdir ydir zdir
| 267 |
r0 r1
| 268 |
.DE
| 269 |
.LP
| 270 |
.UL Mesh
| 271 |
.PP
| 272 |
A mesh is a compound surface, made up of many triangles and
| 273 |
an octree data structure to accelerate ray intersection.
| 274 |
It is typically converted from a Wavefront .OBJ file using the
| 275 |
.I obj2mesh
| 276 |
program.
| 277 |
.DS
| 278 |
mod mesh id
| 279 |
1+ meshfile transform
| 280 |
0
| 281 |
0
| 282 |
.DE
| 283 |
If the modifier is "void", then surfaces will use the modifiers given
| 284 |
in the original mesh description.
| 285 |
Otherwise, the modifier specified is used in their place.
| 286 |
The transform moves the mesh to the desired location in the scene.
| 287 |
Multiple instances using the same meshfile take little extra memory,
| 288 |
and the compiled mesh itself takes much less space than individual
| 289 |
polygons would.
| 290 |
In the case of an unsmoothed mesh, using the mesh primitive reduces
| 291 |
memory requirements by a factor of 30 relative to individual triangles.
| 292 |
If a mesh has smoothed surfaces, we save a factor of 50 or more,
| 293 |
permitting very detailed geometries that would otherwise exhaust the
| 294 |
available memory.
| 295 |
In addition, the mesh primitive can have associated (u,v) coordinates
| 296 |
for pattern and texture mapping.
| 297 |
These are made available to function files via the Lu and Lv variables.
| 298 |
.LP
| 299 |
.UL Instance
| 300 |
.PP
| 301 |
An instance is a compound surface, given by the contents of an
| 302 |
octree file (created by oconv).
| 303 |
.DS
| 304 |
mod instance id
| 305 |
1+ octree transform
| 306 |
0
| 307 |
0
| 308 |
.DE
| 309 |
| 310 |
in the original description.
| 311 |
| 312 |
The transform moves the octree to the desired location in the scene.
| 313 |
Multiple instances using the same octree take little extra memory,
| 314 |
hence very complex descriptions can be rendered using this primitive.
| 315 |
.PP
| 316 |
There are a number of important limitations to be aware of when using
| 317 |
instances.
| 318 |
First, the scene description used to generate the octree must stand on
| 319 |
its own, without referring to modifiers in the parent description.
| 320 |
This is necessary for oconv to create the octree.
| 321 |
Second, light sources in the octree will not be incorporated correctly
| 322 |
in the calculation, and they are not recommended.
| 323 |
Finally, there is no advantage (other than convenience) to
| 324 |
using a single instance of an octree, or an octree containing only a
| 325 |
few surfaces.
| 326 |
An xform command on the subordinate description is prefered in such cases.
| 327 |
.NH 3
| 328 |
Materials
| 329 |
.PP
| 330 |
A material defines the way light interacts with a surface.
| 331 |
| 332 |
.LP
| 333 |
.UL Light
| 334 |
.PP
| 335 |
Light is the basic material for self-luminous surfaces (i.e., light
| 336 |
sources).
| 337 |
In addition to the source surface type, spheres, discs (rings with zero
| 338 |
inner radius), cylinders (provided they are long enough), and
| 339 |
polygons can act as light sources.
| 340 |
Polygons work best when they are rectangular.
| 341 |
Cones cannot be used at this time.
| 342 |
A pattern may be used to specify a light output distribution.
| 343 |
Light is defined simply as a RGB radiance value (watts/steradian/m2):
| 344 |
.DS
| 345 |
mod light id
| 346 |
0
| 347 |
0
| 348 |
3 red green blue
| 349 |
.DE
| 350 |
.LP
| 351 |
.UL Illum
| 352 |
.PP
| 353 |
Illum is used for secondary light sources with broad distributions.
| 354 |
A secondary light source is treated like any other
| 355 |
light source, except when viewed directly.
| 356 |
It then acts like it is made of a different material (indicated by
| 357 |
the string argument), or becomes invisible (if no string argument is given,
| 358 |
or the argument is "void").
| 359 |
Secondary sources are useful when modeling windows or
| 360 |
brightly illuminated surfaces.
| 361 |
.DS
| 362 |
mod illum id
| 363 |
1 material
| 364 |
0
| 365 |
3 red green blue
| 366 |
.DE
| 367 |
.LP
| 368 |
.UL Glow
| 369 |
.PP
| 370 |
Glow is used for surfaces that are self-luminous, but limited
| 371 |
in their effect.
| 372 |
In addition to the radiance value, a maximum radius for
| 373 |
shadow testing is given:
| 374 |
.DS
| 375 |
mod glow id
| 376 |
0
| 377 |
0
| 378 |
4 red green blue maxrad
| 379 |
.DE
| 380 |
If maxrad is zero, then the surface will never be tested
| 381 |
for shadow, although it may participate in an interreflection calculation.
| 382 |
If maxrad is negative, then the surface will never contribute to scene
| 383 |
illumination.
| 384 |
Glow sources will never illuminate objects on the other side of an
| 385 |
illum surface.
| 386 |
This provides a convenient way to illuminate local light fixture
| 387 |
geometry without overlighting nearby objects.
| 388 |
.LP
| 389 |
.UL Spotlight
| 390 |
.PP
| 391 |
Spotlight is used for self-luminous surfaces having directed output.
| 392 |
As well as radiance, the full cone angle (in degrees)
| 393 |
and orientation (output direction) vector are given.
| 394 |
The length of the orientation vector is the distance
| 395 |
of the effective focus behind the source center (i.e., the focal length).
| 396 |
.DS
| 397 |
mod spotlight id
| 398 |
0
| 399 |
0
| 400 |
7 red green blue angle xdir ydir zdir
| 401 |
.DE
| 402 |
.LP
| 403 |
.UL Mirror
| 404 |
.PP
| 405 |
Mirror is used for planar surfaces that produce virtual
| 406 |
source reflections.
| 407 |
This material should be used sparingly, as it may cause the light
| 408 |
source calculation to blow up if it is applied to many small surfaces.
| 409 |
This material is only supported for flat surfaces such as polygons
| 410 |
and rings.
| 411 |
The arguments are simply the RGB reflectance values, which should be
| 412 |
between 0 and 1.
| 413 |
An optional string argument may be used like the illum type to specify a
| 414 |
different material to be used for shading non-source rays.
| 415 |
If this alternate material is given as "void", then the mirror surface
| 416 |
will be invisible.
| 417 |
This is only appropriate if the surface hides other (more detailed)
| 418 |
geometry with the same overall reflectance.
| 419 |
.DS
| 420 |
mod mirror id
| 421 |
1 material
| 422 |
0
| 423 |
3 red green blue
| 424 |
.DE
| 425 |
.LP
| 426 |
.UL Prism1
| 427 |
.PP
| 428 |
The prism1 material is for general light redirection from prismatic
| 429 |
glazings, generating virtual light sources.
| 430 |
It can only be used to modify a planar surface (i.e., a polygon or disk)
| 431 |
and should not result in either light concentration or scattering.
| 432 |
The new direction of the ray can be on either side of the material,
| 433 |
and the definitions must have the correct bidirectional properties
| 434 |
to work properly with virtual light sources.
| 435 |
The arguments give the coefficient for the redirected light
| 436 |
and its direction.
| 437 |
.DS
| 438 |
mod prism1 id
| 439 |
5+ coef dx dy dz funcfile transform
| 440 |
0
| 441 |
n A1 A2 .. An
| 442 |
.DE
| 443 |
The new direction variables
| 444 |
.I "dx, dy"
| 445 |
and
| 446 |
.I dz
| 447 |
need not produce a normalized vector.
| 448 |
For convenience, the variables
| 449 |
.I "DxA, DyA"
| 450 |
and
| 451 |
.I DzA
| 452 |
are defined as the normalized direction to the target light source.
| 453 |
See section 2.2.1 on function files for further information.
| 454 |
.LP
| 455 |
.UL Prism2
| 456 |
.PP
| 457 |
The material prism2 is identical to prism1 except that
| 458 |
it provides for two ray redirections rather than one.
| 459 |
.DS
| 460 |
mod prism2 id
| 461 |
9+ coef1 dx1 dy1 dz1 coef2 dx2 dy2 dz2 funcfile transform
| 462 |
0
| 463 |
n A1 A2 .. An
| 464 |
.DE
| 465 |
.LP
| 466 |
.UL Mist
| 467 |
.PP
| 468 |
Mist is a virtual material used to delineate a volume
| 469 |
of participating atmosphere.
| 470 |
A list of important light sources may be given, along with an
| 471 |
extinction coefficient, scattering albedo and scattering eccentricity
| 472 |
parameter.
| 473 |
The light sources named by the string argument list
| 474 |
will be tested for scattering within the volume.
| 475 |
Sources are identified by name, and virtual light sources may be indicated
| 476 |
by giving the relaying object followed by '>' followed by the source, i.e:
| 477 |
.DS
| 478 |
3 source1 mirror1>source10 mirror2>mirror1>source3
| 479 |
.DE
| 480 |
Normally, only one source is given per mist material, and there is an
| 481 |
upper limit of 32 to the total number of active scattering sources.
| 482 |
The extinction coefficient, if given, is added to the global
| 483 |
coefficient set on the command line.
| 484 |
Extinction is in units of 1/distance (distance based on the world coordinates),
| 485 |
and indicates the proportional loss of radiance over one unit distance.
| 486 |
The scattering albedo, if present, will override the global setting within
| 487 |
the volume.
| 488 |
An albedo of 0\00\00 means a perfectly absorbing medium, and an albedo of
| 489 |
1\01\01\0 means
| 490 |
a perfectly scattering medium (no absorption).
| 491 |
The scattering eccentricity parameter will likewise override the global
| 492 |
setting if it is present.
| 493 |
Scattering eccentricity indicates how much scattered light favors the
| 494 |
forward direction, as fit by the Henyey-Greenstein function:
| 495 |
.DS
| 496 |
P(theta) = (1 - g*g) / (1 + g*g - 2*g*cos(theta))^1.5
| 497 |
.DE
| 498 |
A perfectly isotropic scattering medium has a g parameter of 0, and
| 499 |
a highly directional material has a g parameter close to 1.
| 500 |
Fits to the g parameter may be found along with typical extinction
| 501 |
coefficients and scattering albedos for various atmospheres and
| 502 |
cloud types in USGS meteorological tables.
| 503 |
(A pattern will be applied to the extinction values.)\0
| 504 |
.DS
| 505 |
mod mist id
| 506 |
N src1 src2 .. srcN
| 507 |
0
| 508 |
0|3|6|7 [ rext gext bext [ ralb galb balb [ g ] ] ]
| 509 |
.DE
| 510 |
There are two usual uses of the mist type.
| 511 |
One is to surround a beam from a spotlight or laser so that it is
| 512 |
visible during rendering.
| 513 |
For this application, it is important to use a cone (or cylinder) that
| 514 |
is long enough and wide enough to contain the important visible portion.
| 515 |
Light source photometry and intervening objects will have the desired
| 516 |
effect, and crossing beams will result in additive scattering.
| 517 |
For this application, it is best to leave off the real arguments, and
| 518 |
use the global rendering parameters to control the atmosphere.
| 519 |
The second application is to model clouds or other localized media.
| 520 |
Complex boundary geometry may be used to give shape to a uniform medium,
| 521 |
so long as the boundary encloses a proper volume.
| 522 |
Alternatively, a pattern may be used to set the line integral value
| 523 |
through the cloud for a ray entering or exiting a point in a given
| 524 |
direction.
| 525 |
For this application, it is best if cloud volumes do not overlap each other,
| 526 |
and opaque objects contained within them may not be illuminated correctly
| 527 |
unless the line integrals consider enclosed geometry.
| 528 |
.LP
| 529 |
.UL Plastic
| 530 |
.PP
| 531 |
Plastic is a material with uncolored highlights.
| 532 |
It is given by its RGB reflectance, its fraction of specularity,
| 533 |
and its roughness value.
| 534 |
Roughness is specified as the rms slope of surface facets.
| 535 |
A value of 0 corresponds to a perfectly smooth surface, and
| 536 |
a value of 1 would be a very rough surface.
| 537 |
Specularity fractions greater than 0.1 and
| 538 |
roughness values greater than 0.2 are not very
| 539 |
realistic.
| 540 |
(A pattern modifying plastic will affect the material color.)
| 541 |
.DS
| 542 |
mod plastic id
| 543 |
0
| 544 |
0
| 545 |
5 red green blue spec rough
| 546 |
.DE
| 547 |
.LP
| 548 |
.UL Metal
| 549 |
.PP
| 550 |
Metal is similar to plastic, but specular highlights
| 551 |
are modified by the material color.
| 552 |
Specularity of metals is usually .9 or greater.
| 553 |
As for plastic, roughness values above .2 are uncommon.
| 554 |
.LP
| 555 |
.UL Trans
| 556 |
.PP
| 557 |
Trans is a translucent material, similar to plastic.
| 558 |
The transmissivity is the fraction of penetrating light that
| 559 |
travels all the way through the material.
| 560 |
The transmitted specular component is the fraction of transmitted
| 561 |
light that is not diffusely scattered.
| 562 |
Transmitted and diffusely reflected light is modified by the material color.
| 563 |
Translucent objects are infinitely thin.
| 564 |
.DS
| 565 |
mod trans id
| 566 |
0
| 567 |
0
| 568 |
7 red green blue spec rough trans tspec
| 569 |
.DE
| 570 |
.LP
| 571 |
.UL Plastic2
| 572 |
.PP
| 573 |
Plastic2 is similar to plastic, but with anisotropic
| 574 |
roughness.
| 575 |
This means that highlights in the surface will appear elliptical rather
| 576 |
than round.
| 577 |
The orientation of the anisotropy is determined by the unnormalized
| 578 |
direction vector
| 579 |
.I "ux uy uz".
| 580 |
These three expressions (separated by white space) are evaluated in
| 581 |
the context of the function file
| 582 |
.I funcfile.
| 583 |
If no function file is required (i.e., no special variables or
| 584 |
functions are required), a period (`.') may be given in its
| 585 |
place.
| 586 |
(See the discussion of Function Files in the Auxiliary Files section).
| 587 |
The
| 588 |
.I urough
| 589 |
value defines the roughness along the
| 590 |
.B u
| 591 |
vector given projected onto the surface.
| 592 |
The
| 593 |
.I vrough
| 594 |
value defines the roughness perpendicular to this vector.
| 595 |
Note that the highlight will be narrower in the direction of the
| 596 |
smaller roughness value.
| 597 |
Roughness values of zero are not allowed for efficiency reasons
| 598 |
since the behavior would be the same as regular plastic in that
| 599 |
case.
| 600 |
.DS
| 601 |
mod plastic2 id
| 602 |
4+ ux uy uz funcfile transform
| 603 |
0
| 604 |
6 red green blue spec urough vrough
| 605 |
.DE
| 606 |
.LP
| 607 |
.UL Metal2
| 608 |
.PP
| 609 |
Metal2 is the same as plastic2, except that the highlights are
| 610 |
| 611 |
.LP
| 612 |
.UL Trans2
| 613 |
.PP
| 614 |
Trans2 is the anisotropic version of trans.
| 615 |
The string arguments are the same as for plastic2, and the real
| 616 |
arguments are the same as for trans but with an additional roughness
| 617 |
value.
| 618 |
.DS
| 619 |
mod trans2 id
| 620 |
| 621 |
0
| 622 |
8 red green blue spec urough vrough trans tspec
| 623 |
.DE
| 624 |
.LP
| 625 |
.UL Dielectric
| 626 |
.PP
| 627 |
A dielectric material is transparent, and it refracts light
| 628 |
as well as reflecting it.
| 629 |
Its behavior is determined by the index of refraction and
| 630 |
transmission coefficient in each wavelength band per unit length.
| 631 |
Common glass has a index of refraction (n) around 1.5,
| 632 |
and a transmission coefficient of roughly 0.92 over an inch.
| 633 |
An additional number, the Hartmann constant, describes how
| 634 |
the index of refraction changes as a function of wavelength.
| 635 |
It is usually zero.
| 636 |
(A pattern modifies only the refracted value.)
| 637 |
.DS
| 638 |
mod dielectric id
| 639 |
0
| 640 |
0
| 641 |
5 rtn gtn btn n hc
| 642 |
.DE
| 643 |
.LP
| 644 |
.UL Interface
| 645 |
.PP
| 646 |
An interface is a boundary between two dielectrics.
| 647 |
The first transmission coefficient and refractive index are for the inside;
| 648 |
the second ones are for the outside.
| 649 |
Ordinary dielectrics are surrounded by a vacuum (1 1 1 1).
| 650 |
.DS
| 651 |
mod interface id
| 652 |
0
| 653 |
0
| 654 |
8 rtn1 gtn1 btn1 n1 rtn2 gtn2 btn2 n2
| 655 |
.DE
| 656 |
.LP
| 657 |
.UL Glass
| 658 |
.PP
| 659 |
Glass is similar to dielectric, but it is optimized for thin glass
| 660 |
surfaces (n = 1.52).
| 661 |
One transmitted ray and one reflected ray is produced.
| 662 |
By using a single surface is in place of two, internal reflections
| 663 |
are avoided.
| 664 |
The surface orientation is irrelevant, as it is for plastic,
| 665 |
metal, and trans.
| 666 |
The only specification required is the transmissivity at normal
| 667 |
incidence.
| 668 |
(Transmissivity is the amount of light not absorbed in one traversal
| 669 |
of the material.
| 670 |
Transmittance -- the value usually measured -- is the total light
| 671 |
transmitted through the pane including multiple reflections.)\0
| 672 |
To compute transmissivity (tn) from transmittance (Tn) use:
| 673 |
.DS
| 674 |
tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn
| 675 |
.DE
| 676 |
Standard 88% transmittance glass has a transmissivity of 0.96.
| 677 |
(A pattern modifying glass will affect the transmissivity.)
| 678 |
If a fourth real argument is given, it is interpreted as the index of
| 679 |
refraction to use instead of 1.52.
| 680 |
.DS
| 681 |
mod glass id
| 682 |
0
| 683 |
0
| 684 |
3 rtn gtn btn
| 685 |
.DE
| 686 |
.LP
| 687 |
.UL Plasfunc
| 688 |
.PP
| 689 |
Plasfunc in used for the procedural definition of plastic-like
| 690 |
materials with arbitrary bidirectional reflectance distribution
| 691 |
functions (BRDF's).
| 692 |
The arguments to this material include the color and specularity,
| 693 |
as well as the function defining the specular distribution and the
| 694 |
auxiliary file where it may be found.
| 695 |
.DS
| 696 |
mod plasfunc id
| 697 |
2+ refl funcfile transform
| 698 |
0
| 699 |
4+ red green blue spec A5 ..
| 700 |
.DE
| 701 |
The function
| 702 |
.I refl
| 703 |
takes four arguments, the x, y and z
| 704 |
direction towards the incident light, and the solid angle
| 705 |
subtended by the source.
| 706 |
The solid angle is provided to facilitate averaging, and is usually
| 707 |
ignored.
| 708 |
The
| 709 |
.I refl
| 710 |
function should integrate to 1 over
| 711 |
the projected hemisphere to maintain energy balance.
| 712 |
At least four real arguments must be given, and these are made
| 713 |
available along with any additional values to the reflectance
| 714 |
function.
| 715 |
Currently, only the contribution from direct light sources is
| 716 |
considered in the specular calculation.
| 717 |
As in most material types, the surface normal is always
| 718 |
altered to face the incoming ray.
| 719 |
.LP
| 720 |
.UL Metfunc
| 721 |
.PP
| 722 |
Metfunc is identical to plasfunc and takes the same arguments, but
| 723 |
the specular component is multiplied also by the material color.
| 724 |
.LP
| 725 |
.UL Transfunc
| 726 |
.PP
| 727 |
Transfunc is similar to plasfunc but with an arbitrary bidirectional
| 728 |
transmittance distribution as well as a reflectance distribution.
| 729 |
Both reflectance and transmittance are specified with the same function.
| 730 |
.DS
| 731 |
mod transfunc id
| 732 |
2+ brtd funcfile transform
| 733 |
0
| 734 |
6+ red green blue rspec trans tspec A7 ..
| 735 |
.DE
| 736 |
Where
| 737 |
.I trans
| 738 |
is the total light transmitted and
| 739 |
.I tspec
| 740 |
is the non-Lambertian fraction of transmitted light.
| 741 |
The function
| 742 |
.I brtd
| 743 |
should integrate to 1 over each projected hemisphere.
| 744 |
.LP
| 745 |
.UL BRTDfunc
| 746 |
.PP
| 747 |
The material BRTDfunc gives the maximum flexibility over surface
| 748 |
reflectance and transmittance, providing for spectrally-dependent
| 749 |
specular rays and reflectance and transmittance distribution functions.
| 750 |
.DS
| 751 |
mod BRTDfunc id
| 752 |
10+ rrefl grefl brefl
| 753 |
rtrns gtrns btrns
| 754 |
rbrtd gbrtd bbrtd
| 755 |
funcfile transform
| 756 |
0
| 757 |
9+ rfdif gfdif bfdif
| 758 |
rbdif gbdif bbdif
| 759 |
rtdif gtdif btdif
| 760 |
A10 ..
| 761 |
.DE
| 762 |
The variables
| 763 |
.I "rrefl, grefl"
| 764 |
and
| 765 |
.I brefl
| 766 |
specify the color coefficients for
| 767 |
the ideal specular (mirror) reflection of the surface.
| 768 |
The variables
| 769 |
.I "rtrns, gtrns"
| 770 |
and
| 771 |
.I btrns
| 772 |
specify the color coefficients for the ideal specular transmission.
| 773 |
The functions
| 774 |
.I "rbrtd, gbrtd"
| 775 |
and
| 776 |
.I bbrtd
| 777 |
take the direction to the incident light (and its solid angle)
| 778 |
and compute the color coefficients for the directional diffuse part of
| 779 |
reflection and transmission.
| 780 |
As a special case, three identical values of '0' may be given in place of
| 781 |
these function names to indicate no directional diffuse component.
| 782 |
.PP
| 783 |
Unlike most other material types, the surface normal is not altered to
| 784 |
| 785 |
Thus, functions and variables must pay attention to the orientation of
| 786 |
the surface and make adjustments appropriately.
| 787 |
However, the special variables for the perturbed dot product and surface
| 788 |
normal,
| 789 |
.I "RdotP, NxP, NyP"
| 790 |
and
| 791 |
.I NzP
| 792 |
are reoriented as if the ray hit the front surface for convenience.
| 793 |
.PP
| 794 |
A diffuse reflection component may be given for the front side with
| 795 |
.I "rfdif, gfdif"
| 796 |
and
| 797 |
.I bfdif
| 798 |
for the front side of the surface or
| 799 |
.I "rbdif, gbdif"
| 800 |
and
| 801 |
.I bbdif
| 802 |
for the back side.
| 803 |
The diffuse transmittance (must be the same for both sides by physical law)
| 804 |
is given by
| 805 |
.I "rtdif, gtdif"
| 806 |
and
| 807 |
.I btdif.
| 808 |
A pattern will modify these diffuse scattering values,
| 809 |
and will be available through the special variables
| 810 |
.I "CrP, CgP"
| 811 |
and
| 812 |
.I CbP.
| 813 |
.PP
| 814 |
Care must be taken when using this material type to produce a physically
| 815 |
valid reflection model.
| 816 |
The reflectance functions should be bidirectional, and under no circumstances
| 817 |
should the sum of reflected diffuse, transmitted diffuse, reflected specular,
| 818 |
transmitted specular and the integrated directional diffuse component be
| 819 |
greater than one.
| 820 |
.LP
| 821 |
.UL Plasdata
| 822 |
.PP
| 823 |
Plasdata is used for arbitrary BRDF's that are most conveniently
| 824 |
given as interpolated data.
| 825 |
The arguments to this material are the data file and coordinate index
| 826 |
functions, as well as a function to optionally modify the data
| 827 |
values.
| 828 |
.DS
| 829 |
mod plasdata id
| 830 |
3+n+
| 831 |
func datafile
| 832 |
funcfile x1 x2 .. xn transform
| 833 |
0
| 834 |
| 835 |
.DE
| 836 |
The coordinate indices
| 837 |
.I "(x1, x2,"
| 838 |
etc.) are themselves functions of
| 839 |
the x, y and z direction to the incident light, plus the solid angle
| 840 |
subtended by the light source (usually ignored).
| 841 |
The data function
| 842 |
.I (func)
| 843 |
takes five variables, the
| 844 |
interpolated value from the n-dimensional data file, followed by the
| 845 |
x, y and z direction to the incident light and the solid angle of the source.
| 846 |
The light source direction and size may of course be ignored by the function.
| 847 |
.LP
| 848 |
.UL Metdata
| 849 |
.PP
| 850 |
As metfunc is to plasfunc, metdata is to plasdata.
| 851 |
Metdata takes the same arguments as plasdata, but the specular
| 852 |
component is modified by the given material color.
| 853 |
.LP
| 854 |
.UL Transdata
| 855 |
.PP
| 856 |
Transdata is like plasdata but the specification includes transmittance
| 857 |
as well as reflectance.
| 858 |
The parameters are as follows.
| 859 |
.DS
| 860 |
mod transdata id
| 861 |
3+n+
| 862 |
func datafile
| 863 |
| 864 |
0
| 865 |
| 866 |
.DE
| 867 |
.LP
| 868 |
.UL BSDF
| 869 |
.PP
| 870 |
The BSDF material type loads an XML (eXtensible Markup Language)
| 871 |
file describing a bidirectional scattering distribution function.
| 872 |
Real arguments to this material may define additional
| 873 |
diffuse components that augment the BSDF data.
| 874 |
String arguments are used to define thickness for proxied
| 875 |
surfaces and the "up" orientation for the material.
| 876 |
.DS
| 877 |
mod BSDF id
| 878 |
6+ thick BSDFfile ux uy uz funcfile transform
| 879 |
0
| 880 |
0|3|6|9
| 881 |
rfdif gfdif bfdif
| 882 |
rbdif gbdif bbdif
| 883 |
rtdif gtdif btdif
| 884 |
.DE
| 885 |
The first string argument is a "thickness" parameter that may be used
| 886 |
to hide detail geometry being proxied by an aggregate BSDF material.
| 887 |
If a view or shadow ray hits a BSDF proxy with non-zero thickness,
| 888 |
it will pass directly through as if the surface were not there.
| 889 |
Similar to the illum type, this permits direct viewing and
| 890 |
shadow testing of complex geometry.
| 891 |
The BSDF is used when a scattered (indirect) ray hits the surface,
| 892 |
and any transmitted sample rays will be offset by the thickness amount
| 893 |
to avoid the hidden geometry and gather samples from the other side.
| 894 |
In this manner, BSDF surfaces can improve the results for indirect
| 895 |
scattering from complex systems without sacrificing appearance or
| 896 |
shadow accuracy.
| 897 |
If the BSDF has transmission and back-side reflection data,
| 898 |
a parallel BSDF surface may be
| 899 |
placed slightly less than the given thickness away from the front surface
| 900 |
to enclose the complex geometry on both sides.
| 901 |
The sign of the thickness is important, as it indicates whether the
| 902 |
proxied geometry is behind the BSDF surface (when thickness is positive)
| 903 |
or in front (when thickness is negative).
| 904 |
.LP
| 905 |
The second string argument is the name of the BSDF file, which is
| 906 |
found in the usual auxiliary locations.
| 907 |
The following three string parameters name variables for an "up" vector,
| 908 |
which together with the surface normal, define the
| 909 |
local coordinate system that orients the BSDF.
| 910 |
These variables, along with the thickness, are defined in a function
| 911 |
file given as the next string argument.
| 912 |
An optional transform is used to scale the thickness and reorient the up vector.
| 913 |
.LP
| 914 |
If no real arguments are given, the BSDF is used by itself to determine
| 915 |
| 916 |
If there are at least 3 real arguments, the first triplet is an
| 917 |
additional diffuse reflectance for the front side.
| 918 |
At least 6 real arguments adds diffuse reflectance to the rear side of the surface.
| 919 |
If there are 9 real arguments, the final triplet will be taken as an additional
| 920 |
diffuse transmittance.
| 921 |
All diffuse components as well as the non-diffuse transmission are
| 922 |
modified by patterns applied to this material.
| 923 |
The non-diffuse reflection from either side are unaffected.
| 924 |
Textures perturb the effective surface normal in the usual way.
| 925 |
.LP
| 926 |
The surface normal of this type is not altered to face the incoming ray,
| 927 |
so the front and back BSDF reflections may differ.
| 928 |
(Transmission is identical front-to-back by physical law.)\0
| 929 |
If back visibility is turned off during rendering and there is no
| 930 |
transmission or back-side reflection, only then the surface will be
| 931 |
invisible from behind.
| 932 |
Unlike other data-driven material types, the BSDF type is fully
| 933 |
supported and all parts of the distribution are properly sampled.
| 934 |
.LP
| 935 |
.UL Antimatter
| 936 |
.PP
| 937 |
Antimatter is a material that can "subtract" volumes from other volumes.
| 938 |
A ray passing into an antimatter object becomes blind to all the specified
| 939 |
modifiers:
| 940 |
.DS
| 941 |
mod antimatter id
| 942 |
N mod1 mod2 .. modN
| 943 |
0
| 944 |
0
| 945 |
.DE
| 946 |
The first modifier will also be used to shade the area leaving the
| 947 |
antimatter volume and entering the regular volume.
| 948 |
If mod1 is void, the antimatter volume is completely invisible.
| 949 |
Antimatter does not work properly with the material type "trans",
| 950 |
and multiple antimatter surfaces should be disjoint.
| 951 |
The viewpoint must be outside all volumes concerned for a correct
| 952 |
rendering.
| 953 |
.NH 3
| 954 |
Textures
| 955 |
.PP
| 956 |
A texture is a perturbation of the surface normal, and
| 957 |
is given by either a function or data.
| 958 |
.LP
| 959 |
.UL Texfunc
| 960 |
.PP
| 961 |
A texfunc uses an auxiliary function file
| 962 |
to specify a procedural texture:
| 963 |
.DS
| 964 |
mod texfunc id
| 965 |
4+ xpert ypert zpert funcfile transform
| 966 |
0
| 967 |
n A1 A2 .. An
| 968 |
.DE
| 969 |
.LP
| 970 |
.UL Texdata
| 971 |
.PP
| 972 |
A texdata texture uses three data files to get the surface
| 973 |
normal perturbations.
| 974 |
The variables
| 975 |
.I xfunc,
| 976 |
.I yfunc
| 977 |
and
| 978 |
.I zfunc
| 979 |
take three arguments
| 980 |
each from the interpolated values in
| 981 |
.I xdfname,
| 982 |
.I ydfname
| 983 |
and
| 984 |
.I zdfname.
| 985 |
.DS
| 986 |
mod texdata id
| 987 |
8+ xfunc yfunc zfunc xdfname ydfname zdfname vfname x0 x1 .. xf
| 988 |
0
| 989 |
n A1 A2 .. An
| 990 |
.DE
| 991 |
.NH 3
| 992 |
Patterns
| 993 |
.PP
| 994 |
Patterns are used to modify the reflectance of materials.
| 995 |
| 996 |
.LP
| 997 |
.UL Colorfunc
| 998 |
.PP
| 999 |
A colorfunc is a procedurally defined color pattern.
| 1000 |
It is specified as follows:
| 1001 |
.DS
| 1002 |
mod colorfunc id
| 1003 |
4+ red green blue funcfile transform
| 1004 |
0
| 1005 |
n A1 A2 .. An
| 1006 |
.DE
| 1007 |
.LP
| 1008 |
.UL Brightfunc
| 1009 |
.PP
| 1010 |
A brightfunc is the same as a colorfunc, except it is monochromatic.
| 1011 |
.DS
| 1012 |
mod brightfunc id
| 1013 |
| 1014 |
0
| 1015 |
n A1 A2 .. An
| 1016 |
.DE
| 1017 |
.LP
| 1018 |
.UL Colordata
| 1019 |
.PP
| 1020 |
Colordata uses an interpolated data map to modify a material's color.
| 1021 |
The map is n-dimensional, and is stored in three
| 1022 |
auxiliary files, one for each color.
| 1023 |
The coordinates used to look up and interpolate the data are
| 1024 |
defined in another auxiliary file.
| 1025 |
The interpolated data values are modified by functions of
| 1026 |
one or three variables.
| 1027 |
If the functions are of one variable, then they are passed the
| 1028 |
corresponding color component (red or green or blue).
| 1029 |
If the functions are of three variables, then they are passed the
| 1030 |
original red, green, and blue values as parameters.
| 1031 |
.DS
| 1032 |
mod colordata id
| 1033 |
7+n+
| 1034 |
rfunc gfunc bfunc rdatafile gdatafile bdatafile
| 1035 |
| 1036 |
0
| 1037 |
m A1 A2 .. Am
| 1038 |
.DE
| 1039 |
.LP
| 1040 |
.UL Brightdata
| 1041 |
.PP
| 1042 |
Brightdata is like colordata, except monochromatic.
| 1043 |
.DS
| 1044 |
mod brightdata id
| 1045 |
3+n+
| 1046 |
func datafile
| 1047 |
| 1048 |
0
| 1049 |
m A1 A2 .. Am
| 1050 |
.DE
| 1051 |
.LP
| 1052 |
.UL Colorpict
| 1053 |
.PP
| 1054 |
Colorpict is a special case of colordata, where the pattern is
| 1055 |
a two-dimensional image stored in the RADIANCE picture format.
| 1056 |
The dimensions of the image data are determined by the picture
| 1057 |
such that the smaller dimension is always 1, and the other
| 1058 |
is the ratio between the larger and the smaller.
| 1059 |
For example, a 500x338 picture would have coordinates (u,v)
| 1060 |
in the rectangle between (0,0) and (1.48,1).
| 1061 |
.DS
| 1062 |
mod colorpict id
| 1063 |
7+
| 1064 |
rfunc gfunc bfunc pictfile
| 1065 |
funcfile u v transform
| 1066 |
0
| 1067 |
m A1 A2 .. Am
| 1068 |
.DE
| 1069 |
.LP
| 1070 |
.UL Colortext
| 1071 |
.PP
| 1072 |
Colortext is dichromatic writing in a polygonal font.
| 1073 |
The font is defined in an auxiliary file, such as
| 1074 |
.I helvet.fnt.
| 1075 |
The text itself is also specified in a separate file, or
| 1076 |
can be part of the material arguments.
| 1077 |
The character size, orientation, aspect ratio and slant is
| 1078 |
determined by right and down motion vectors.
| 1079 |
The upper left origin for the text block as well as
| 1080 |
the foreground and background colors
| 1081 |
must also be given.
| 1082 |
.DS
| 1083 |
mod colortext id
| 1084 |
2 fontfile textfile
| 1085 |
0
| 1086 |
15+
| 1087 |
Ox Oy Oz
| 1088 |
Rx Ry Rz
| 1089 |
Dx Dy Dz
| 1090 |
rfore gfore bfore
| 1091 |
rback gback bback
| 1092 |
[spacing]
| 1093 |
.DE
| 1094 |
or:
| 1095 |
.DS
| 1096 |
mod colortext id
| 1097 |
2+N fontfile . This is a line with N words ...
| 1098 |
0
| 1099 |
15+
| 1100 |
Ox Oy Oz
| 1101 |
Rx Ry Rz
| 1102 |
Dx Dy Dz
| 1103 |
rfore gfore bfore
| 1104 |
rback gback bback
| 1105 |
[spacing]
| 1106 |
.DE
| 1107 |
.LP
| 1108 |
.UL Brighttext
| 1109 |
.PP
| 1110 |
Brighttext is like colortext, but the writing is monochromatic.
| 1111 |
.DS
| 1112 |
mod brighttext id
| 1113 |
2 fontfile textfile
| 1114 |
0
| 1115 |
11+
| 1116 |
Ox Oy Oz
| 1117 |
Rx Ry Rz
| 1118 |
Dx Dy Dz
| 1119 |
foreground background
| 1120 |
[spacing]
| 1121 |
.DE
| 1122 |
or:
| 1123 |
.DS
| 1124 |
mod brighttext id
| 1125 |
| 1126 |
0
| 1127 |
11+
| 1128 |
Ox Oy Oz
| 1129 |
Rx Ry Rz
| 1130 |
Dx Dy Dz
| 1131 |
| 1132 |
[spacing]
| 1133 |
.DE
| 1134 |
.LP
| 1135 |
By default, a uniform spacing algorithm is used that guarantees
| 1136 |
every character will appear in a precisely determined position.
| 1137 |
Unfortunately, such a scheme results in rather unattractive and difficult to
| 1138 |
read text with most fonts.
| 1139 |
The optional
| 1140 |
.I spacing
| 1141 |
value defines the distance between characters for proportional spacing.
| 1142 |
A positive value selects a spacing algorithm that preserves right margins and
| 1143 |
indentation, but does not provide the ultimate in proportionally spaced text.
| 1144 |
A negative value insures that characters are properly spaced, but the
| 1145 |
placement of words then varies unpredictably.
| 1146 |
The choice depends on the relative importance of spacing versus formatting.
| 1147 |
When presenting a section of formatted text, a positive spacing value is
| 1148 |
usually preferred.
| 1149 |
A single line of text will often be accompanied by a negative spacing value.
| 1150 |
A section of text meant to depict a picture, perhaps using a special purpose
| 1151 |
font such as hexbit4x1.fnt, calls for uniform spacing.
| 1152 |
Reasonable magnitudes for proportional spacing are
| 1153 |
between 0.1 (for tightly spaced characters) and 0.3 (for wide spacing).
| 1154 |
.NH 3
| 1155 |
Mixtures
| 1156 |
.PP
| 1157 |
A mixture is a blend of one or more materials or textures and patterns.
| 1158 |
| 1159 |
.LP
| 1160 |
.UL Mixfunc
| 1161 |
.PP
| 1162 |
A mixfunc mixes two modifiers procedurally.
| 1163 |
| 1164 |
.DS
| 1165 |
mod mixfunc id
| 1166 |
4+ foreground background vname funcfile transform
| 1167 |
0
| 1168 |
n A1 A2 .. An
| 1169 |
.DE
| 1170 |
Foreground and background are modifier names that must be
| 1171 |
defined earlier in the scene description.
| 1172 |
If one of these is a material, then
| 1173 |
the modifier of the mixfunc must be "void".
| 1174 |
(Either the foreground or background modifier may be "void",
| 1175 |
which serves as a form of opacity control when used with a material.)\0
| 1176 |
Vname is the coefficient defined in funcfile that determines the influence
| 1177 |
of foreground.
| 1178 |
The background coefficient is always (1-vname).
| 1179 |
.LP
| 1180 |
.UL Mixdata
| 1181 |
.PP
| 1182 |
Mixdata combines two modifiers using an auxiliary data file:
| 1183 |
.DS
| 1184 |
mod mixdata id
| 1185 |
5+n+
| 1186 |
foreground background func datafile
| 1187 |
| 1188 |
0
| 1189 |
m A1 A2 .. Am
| 1190 |
.DE
| 1191 |
.LP
| 1192 |
.UL Mixpict
| 1193 |
.PP
| 1194 |
Mixpict combines two modifiers based on a picture:
| 1195 |
.DS
| 1196 |
mod mixpict id
| 1197 |
7+
| 1198 |
foreground background func pictfile
| 1199 |
| 1200 |
0
| 1201 |
m A1 A2 .. Am
| 1202 |
.DE
| 1203 |
The mixing coefficient function "func" takes three
| 1204 |
arguments, the red, green and blue values
| 1205 |
corresponding to the pixel at (u,v).
| 1206 |
.LP
| 1207 |
.UL Mixtext
| 1208 |
.PP
| 1209 |
Mixtext uses one modifier for the text foreground, and one for the
| 1210 |
background:
| 1211 |
.DS
| 1212 |
mod mixtext id
| 1213 |
4 foreground background fontfile textfile
| 1214 |
0
| 1215 |
9+
| 1216 |
Ox Oy Oz
| 1217 |
Rx Ry Rz
| 1218 |
Dx Dy Dz
| 1219 |
[spacing]
| 1220 |
.DE
| 1221 |
or:
| 1222 |
.DS
| 1223 |
mod mixtext id
| 1224 |
4+N
| 1225 |
foreground background fontfile .
| 1226 |
| 1227 |
0
| 1228 |
9+
| 1229 |
Ox Oy Oz
| 1230 |
Rx Ry Rz
| 1231 |
Dx Dy Dz
| 1232 |
[spacing]
| 1233 |
.DE
| 1234 |
.NH 2
| 1235 |
Auxiliary Files
| 1236 |
.PP
| 1237 |
Auxiliary files used in textures and patterns
| 1238 |
are accessed by the programs during image generation.
| 1239 |
These files may be located in the working directory, or in
| 1240 |
a library directory.
| 1241 |
The environment variable
| 1242 |
.I RAYPATH
| 1243 |
can be assigned an alternate set of search directories.
| 1244 |
Following is a brief description of some common file types.
| 1245 |
.NH 3
| 1246 |
Function Files
| 1247 |
.PP
| 1248 |
A function file contains the definitions of variables, functions
| 1249 |
and constants used by a primitive.
| 1250 |
The transformation that accompanies the file name contains the necessary
| 1251 |
rotations, translations and scalings to bring the coordinates of
| 1252 |
the function file into agreement with the world coordinates.
| 1253 |
The transformation specification is the same as for the
| 1254 |
.I xform
| 1255 |
command.
| 1256 |
An example function file is given below:
| 1257 |
.DS
| 1258 |
| 1259 |
This is a comment, enclosed in curly braces.
| 1260 |
{Comments can be nested.}
| 1261 |
| 1262 |
{ standard expressions use +,-,*,/,^,(,) }
| 1263 |
vname = Ny * func(A1) ;
| 1264 |
{ constants are defined with a colon }
| 1265 |
const : sqrt(PI/2) ;
| 1266 |
{ user-defined functions add to library }
| 1267 |
func(x) = 5 + A1*sin(x/3) ;
| 1268 |
{ functions may be passed and recursive }
| 1269 |
rfunc(f,x) = if(x,f(x),f(-x)*rfunc(f,x+1)) ;
| 1270 |
{ constant functions may also be defined }
| 1271 |
cfunc(x) : 10*x / sqrt(x) ;
| 1272 |
.DE
| 1273 |
Many variables and functions are already defined by the program,
| 1274 |
and they are listed in the file
| 1275 |
.I rayinit.cal.
| 1276 |
The following variables are particularly important:
| 1277 |
.DS
| 1278 |
Dx, Dy, Dz - incident ray direction
| 1279 |
Nx, Ny, Nz - surface normal at intersection point
| 1280 |
Px, Py, Pz - intersection point
| 1281 |
T - distance from start
| 1282 |
Ts - single ray (shadow) distance
| 1283 |
Rdot - cosine between ray and normal
| 1284 |
arg(0) - number of real arguments
| 1285 |
arg(i) - i'th real argument
| 1286 |
.DE
| 1287 |
For mesh objects, the local surface coordinates are available:
| 1288 |
.DS
| 1289 |
Lu, Lv - local (u,v) coordinates
| 1290 |
.DE
| 1291 |
For BRDF types, the following variables are defined as well:
| 1292 |
.DS
| 1293 |
NxP, NyP, NzP - perturbed surface normal
| 1294 |
RdotP - perturbed dot product
| 1295 |
CrP, CgP, CbP - perturbed material color
| 1296 |
.DE
| 1297 |
A unique context is set up for each file so that the same variable
| 1298 |
may appear in different function files without conflict.
| 1299 |
The variables listed above and any others defined in
| 1300 |
rayinit.cal are available globally.
| 1301 |
If no file is needed by a given primitive because all the required
| 1302 |
variables are global, a period (`.') can be given in
| 1303 |
place of the file name.
| 1304 |
It is also possible to give an expression instead of a straight
| 1305 |
variable name in a scene file.
| 1306 |
Functions (requiring parameters)
| 1307 |
must be given as names and not as expressions.
| 1308 |
.PP
| 1309 |
Constant expressions are used as an optimization in function
| 1310 |
files.
| 1311 |
They are replaced wherever they occur in an expression by their
| 1312 |
value.
| 1313 |
Constant expressions are evaluated only once, so they must not
| 1314 |
contain any variables or values that can change, such as the ray
| 1315 |
variables Px and Ny or the primitive argument function arg().
| 1316 |
All the math library functions such as sqrt() and cos() have the
| 1317 |
constant attribute, so they will be replaced by immediate values
| 1318 |
whenever they are given constant arguments.
| 1319 |
Thus, the subexpression cos(PI*sqrt(2)) is immediately replaced
| 1320 |
by its value, -.266255342, and does not cause any additional overhead
| 1321 |
in the calculation.
| 1322 |
.PP
| 1323 |
It is generally a good idea to define constants and variables before
| 1324 |
they are referred to in a function file.
| 1325 |
Although evaluation does not take place until later, the interpreter
| 1326 |
does variable scoping and constant subexpression evaluation based on
| 1327 |
what it has compiled already.
| 1328 |
For example, a variable that is defined globally in rayinit.cal then
| 1329 |
referenced in the local context of a function file cannot
| 1330 |
subsequently be redefined in the same file because the compiler
| 1331 |
has already determined the scope of the referenced variable as global.
| 1332 |
To avoid such conflicts, one can state the scope of a variable explicitly
| 1333 |
by preceding the variable name with a context mark (a back-quote) for
| 1334 |
a local variable, or following the name with a context mark for a global
| 1335 |
variable.
| 1336 |
.NH 3
| 1337 |
Data Files
| 1338 |
.PP
| 1339 |
Data files contain n-dimensional arrays of real numbers used
| 1340 |
for interpolation.
| 1341 |
Typically, definitions in a function file determine how
| 1342 |
to index and use interpolated data values.
| 1343 |
The basic data file format is as follows:
| 1344 |
.DS
| 1345 |
N
| 1346 |
beg1 end1 m1
| 1347 |
0 0 m2 x2.1 x2.2 x2.3 x2.4 .. x2.m2
| 1348 |
| 1349 |
begN endN mN
| 1350 |
DATA, later dimensions changing faster.
| 1351 |
.DE
| 1352 |
N is the number of dimensions.
| 1353 |
For each dimension, the beginning and ending coordinate
| 1354 |
values and the dimension size is given.
| 1355 |
Alternatively, individual coordinate values can be given when
| 1356 |
the points are not evenly spaced.
| 1357 |
These values must either be increasing or decreasing monotonically.
| 1358 |
The data is m1*m2*...*mN real numbers in ASCII form.
| 1359 |
Comments may appear anywhere in the file, beginning with a pound
| 1360 |
sign ('#') and continuing to the end of line.
| 1361 |
.NH 3
| 1362 |
Font Files
| 1363 |
.PP
| 1364 |
A font file lists the polygons which make up a character set.
| 1365 |
| 1366 |
| 1367 |
All numbers are decimal integers:
| 1368 |
.DS
| 1369 |
code n
| 1370 |
x0 y0
| 1371 |
x1 y1
| 1372 |
| 1373 |
xn yn
| 1374 |
| 1375 |
.DE
| 1376 |
The ASCII codes can appear in any order.
| 1377 |
N is the number of vertices, and the last is automatically
| 1378 |
| 1379 |
Separate polygonal sections are joined by coincident sides.
| 1380 |
The character coordinate system is a square with lower left corner at
| 1381 |
(0,0), lower right at (255,0) and upper right at (255,255).
| 1382 |
.NH 2
| 1383 |
Generators
| 1384 |
.PP
| 1385 |
A generator is any program that produces a scene description
| 1386 |
as its output.
| 1387 |
They usually appear as commands in a scene description file.
| 1388 |
An example of a simple generator is
| 1389 |
.I genbox.
| 1390 |
.I Genbox
| 1391 |
takes the arguments of width, height and depth to produce
| 1392 |
a parallelepiped description.
| 1393 |
.I Genprism
| 1394 |
takes a list of 2-dimensional coordinates and extrudes them along a vector to
| 1395 |
produce a 3-dimensional prism.
| 1396 |
.I Genrev
| 1397 |
is a more sophisticated generator
| 1398 |
that produces an object of rotation from parametric functions
| 1399 |
for radius and axis position.
| 1400 |
.I Gensurf
| 1401 |
tessellates a surface defined by the
| 1402 |
parametric functions x(s,t), y(s,t), and z(s,t).
| 1403 |
.I Genworm
| 1404 |
links cylinders and spheres along a curve.
| 1405 |
.I Gensky
| 1406 |
produces a sun and sky distribution corresponding
| 1407 |
to a given time and date.
| 1408 |
.PP
| 1409 |
.I Xform
| 1410 |
is a program that transforms a scene description from one
| 1411 |
coordinate space to another.
| 1412 |
.I Xform
| 1413 |
does rotation, translation, scaling, and mirroring.
| 1414 |
.NH 1
| 1415 |
Image Generation
| 1416 |
.PP
| 1417 |
Once the scene has been described in three-dimensions, it
| 1418 |
is possible to generate a two-dimensional image from a
| 1419 |
given perspective.
| 1420 |
.PP
| 1421 |
The image generating programs use an
| 1422 |
.I octree
| 1423 |
to efficiently trace rays through the scene.
| 1424 |
An octree subdivides space into nested octants which
| 1425 |
contain sets of surfaces.
| 1426 |
In RADIANCE, an octree is created from a scene description by
| 1427 |
.I oconv.
| 1428 |
The details of this process are not important,
| 1429 |
but the octree will serve as input to the ray-tracing
| 1430 |
programs and directs the use of a scene description.
| 1431 |
.PP
| 1432 |
.I Rview
| 1433 |
is ray-tracing program for viewing a scene interactively.
| 1434 |
When the user specifies a new perspective,
| 1435 |
.I rview
| 1436 |
quickly displays a rough
| 1437 |
image on the terminal, then progressively
| 1438 |
increases the resolution as the user looks on.
| 1439 |
He can select a particular section of the image to improve,
| 1440 |
or move to a different view and start over.
| 1441 |
This mode of interaction is useful for debugging scenes
| 1442 |
as well as determining the best view for a final image.
| 1443 |
.PP
| 1444 |
.I Rpict
| 1445 |
produces a high-resolution picture of a scene from
| 1446 |
a particular perspective.
| 1447 |
This program features adaptive sampling, crash
| 1448 |
recovery and progress reporting, all of which are important
| 1449 |
for time-consuming images.
| 1450 |
.PP
| 1451 |
A number of filters are available for manipulating picture files.
| 1452 |
.I Pfilt
| 1453 |
sets the exposure and performs anti-aliasing.
| 1454 |
.I Pcompos
| 1455 |
composites (cuts and pastes) pictures.
| 1456 |
.I Pcond
| 1457 |
conditions a picture for a specific display device.
| 1458 |
.I Pcomb
| 1459 |
performs arbitrary math on one or more pictures.
| 1460 |
.I Protate
| 1461 |
rotates a picture 90 degrees clockwise.
| 1462 |
.I Pflip
| 1463 |
flips a picture horizontally, vertically, or both (180 degree rotation).
| 1464 |
.I Pvalue
| 1465 |
converts a picture to and from simpler formats.
| 1466 |
.PP
| 1467 |
Pictures may be displayed directly under X11 using the program
| 1468 |
.I ximage,
| 1469 |
or converted a standard image format.
| 1470 |
.I Ra_bmp
| 1471 |
converts to and from Microsoft Bitmap images.
| 1472 |
.I Ra_ppm
| 1473 |
converts to and from Poskanzer Portable Pixmap formats.
| 1474 |
.I Ra_ps
| 1475 |
converts to PostScript color and greyscale formats.
| 1476 |
.I Ra_rgbe
| 1477 |
converts to and from Radiance uncompressed picture format.
| 1478 |
.I Ra_t16
| 1479 |
converts to and from Targa 16 and 24-bit image formats.
| 1480 |
.I Ra_t8
| 1481 |
converts to and from Targa 8-bit image format.
| 1482 |
.I Ra_tiff
| 1483 |
converts to and from TIFF.
| 1484 |
.I Ra_xyze
| 1485 |
converts to and from Radiance CIE picture format.
| 1486 |
.NH 1
| 1487 |
License
| 1488 |
.PP
| 1489 |
.DS
| 1490 |
The Radiance Software License, Version 1.0
| 1491 |
| 1492 |
Copyright (c) 1990 - 2008 The Regents of the University of California,
| 1493 |
through Lawrence Berkeley National Laboratory. All rights reserved.
| 1494 |
| 1495 |
Redistribution and use in source and binary forms, with or without
| 1496 |
modification, are permitted provided that the following conditions
| 1497 |
are met:
| 1498 |
| 1499 |
1. Redistributions of source code must retain the above copyright
| 1500 |
notice, this list of conditions and the following disclaimer.
| 1501 |
| 1502 |
2. Redistributions in binary form must reproduce the above copyright
| 1503 |
notice, this list of conditions and the following disclaimer in
| 1504 |
the documentation and/or other materials provided with the
| 1505 |
distribution.
| 1506 |
| 1507 |
3. The end-user documentation included with the redistribution,
| 1508 |
if any, must include the following acknowledgment:
| 1509 |
"This product includes Radiance software
| 1510 |
(http://radsite.lbl.gov/)
| 1511 |
developed by the Lawrence Berkeley National Laboratory
| 1512 |
(http://www.lbl.gov/)."
| 1513 |
Alternately, this acknowledgment may appear in the software itself,
| 1514 |
if and wherever such third-party acknowledgments normally appear.
| 1515 |
| 1516 |
4. The names "Radiance," "Lawrence Berkeley National Laboratory"
| 1517 |
and "The Regents of the University of California" must
| 1518 |
not be used to endorse or promote products derived from this
| 1519 |
software without prior written permission. For written
| 1520 |
permission, please contact [email protected].
| 1521 |
| 1522 |
5. Products derived from this software may not be called "Radiance",
| 1523 |
nor may "Radiance" appear in their name, without prior written
| 1524 |
permission of Lawrence Berkeley National Laboratory.
| 1525 |
| 1526 |
THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
| 1527 |
WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
| 1528 |
OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
| 1529 |
DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
| 1530 |
ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
| 1531 |
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
| 1532 |
LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
| 1533 |
USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
| 1534 |
ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
| 1535 |
OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
| 1536 |
OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
| 1537 |
SUCH DAMAGE.
| 1538 |
.DE
| 1539 |
.NH 1
| 1540 |
Acknowledgements
| 1541 |
.PP
| 1542 |
This work was supported by the Assistant Secretary of Conservation
| 1543 |
and Renewable Energy, Office of Building Energy Research and
| 1544 |
Development, Buildings Equipment Division of the U.S. Department of
| 1545 |
Energy under Contract No. DE-AC03-76SF00098.
| 1546 |
.PP
| 1547 |
Additional work was sponsored by the Swiss federal government
| 1548 |
under the Swiss LUMEN Project and was
| 1549 |
carried out in the Laboratoire d'Energie Solaire (LESO Group) at
| 1550 |
the Ecole Polytechnique Federale de Lausanne (EPFL University)
| 1551 |
in Lausanne, Switzerland.
| 1552 |
.NH 1
| 1553 |
References
| 1554 |
.LP
| 1555 |
McNeil, A., C.J. Jonsson, D. Appelfeld, G. Ward, E.S. Lee,
| 1556 |
``A validation of a ray-tracing tool used to generate
| 1557 |
bi-directional scattering distribution functions for
| 1558 |
complex fenestration systems,''
| 1559 |
.I "Solar Energy",
| 1560 |
98, 404-14, November 2013.
| 1561 |
.LP
| 1562 |
Ward, G., R. Mistrick, E.S. Lee, A. McNeil, J. Jonsson,
| 1563 |
``Simulating the Daylight Performance of Complex Fenestration Systems
| 1564 |
Using Bidirectional Scattering Distribution Functions within Radiance,''
| 1565 |
.I "Leukos",
| 1566 |
7(4),
| 1567 |
April 2011.
| 1568 |
.LP
| 1569 |
Cater, K., A. Chalmers, G. Ward,
| 1570 |
``Detail to Attention: Exploiting Visual Tasks for Selective Rendering,''
| 1571 |
.I "Eurograhics Symposium on Rendering",
| 1572 |
June 2003.
| 1573 |
.LP
| 1574 |
Ward, G., Elena Eydelberg-Vileshin,
| 1575 |
``Picture Perfect RGB Rendering Using Spectral Prefiltering and
| 1576 |
Sharp Color Primaries,''
| 1577 |
13th Eurographics Workshop on Rendering, P. Debevec and
| 1578 |
S. Gibson (Editors), June 2002.
| 1579 |
.LP
| 1580 |
Ward, G. and M. Simmons,
| 1581 |
``The Holodeck Ray Cache: An Interactive Rendering System for Global
| 1582 |
Illumination in Nondiffuse Environments,''
| 1583 |
.I "ACM Transactions on Graphics,"
| 1584 |
18(4):361-98, October 1999.
| 1585 |
.LP
| 1586 |
Larson, G.W., H. Rushmeier, C. Piatko,
| 1587 |
``A Visibility Matching Tone Reproduction Operator for High Dynamic
| 1588 |
Range Scenes,''
| 1589 |
.I "IEEE Transactions on Visualization and Computer Graphics",
| 1590 |
3(4), 291-306, December 1997.
| 1591 |
.LP
| 1592 |
Ward, G.,
| 1593 |
``Making Global Illumination User Friendly,''
| 1594 |
.I "Sixth Eurographics Workshop on Rendering",
| 1595 |
proceedings to be published by Springer-Verlag,
| 1596 |
Dublin, Ireland, June 1995.
| 1597 |
.LP
| 1598 |
Rushmeier, H., G. Ward, C. Piatko, P. Sanders, B. Rust,
| 1599 |
``Comparing Real and Synthetic Images: Some Ideas about Metrics,''
| 1600 |
| 1601 |
| 1602 |
| 1603 |
.LP
| 1604 |
Ward, G.,
| 1605 |
``The Radiance Lighting Simulation and Rendering System,''
| 1606 |
.I "Computer Graphics",
| 1607 |
Orlando, July 1994.
| 1608 |
.LP
| 1609 |
| 1610 |
``Energy-Preserving Non-Linear Filters,''
| 1611 |
| 1612 |
Orlando, July 1994.
| 1613 |
.LP
| 1614 |
Ward, G.,
| 1615 |
``A Contrast-Based Scalefactor for Luminance Display,''
| 1616 |
.I "Graphics Gems IV",
| 1617 |
Edited by Paul Heckbert,
| 1618 |
Academic Press 1994.
| 1619 |
.LP
| 1620 |
Ward, G.,
| 1621 |
``Measuring and Modeling Anisotropic Reflection,''
| 1622 |
| 1623 |
Chicago, July 1992.
| 1624 |
.LP
| 1625 |
Ward, G., P. Heckbert,
| 1626 |
``Irradiance Gradients,''
| 1627 |
.I "Third Annual Eurographics Workshop on Rendering",
| 1628 |
to be published by Springer-Verlag, held in Bristol, UK, May 1992.
| 1629 |
.LP
| 1630 |
Ward, G.,
| 1631 |
``Adaptive Shadow Testing for Ray Tracing,''
| 1632 |
.I "Second Annual Eurographics Workshop on Rendering",
| 1633 |
to be published by Springer-Verlag, held in Barcelona, SPAIN, May 1991.
| 1634 |
.LP
| 1635 |
Ward, G.,
| 1636 |
``Visualization,''
| 1637 |
.I "Lighting Design and Application",
| 1638 |
Vol. 20, No. 6, June 1990.
| 1639 |
.LP
| 1640 |
Ward, G., F. Rubinstein, R. Clear,
| 1641 |
``A Ray Tracing Solution for Diffuse Interreflection,''
| 1642 |
| 1643 |
Vol. 22, No. 4, August 1988.
| 1644 |
.LP
| 1645 |
| 1646 |
``A New Technique for Computer Simulation of Illuminated Spaces,''
| 1647 |
.I "Journal of the Illuminating Engineering Society",
| 1648 |
Vol. 17, No. 1, Winter 1988.
