root/radiance/ray/doc/notes/rpict.options
Revision: 1.5
Committed: Wed Feb 15 15:43:43 2017 UTC (8 years, 5 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R1, rad6R0, HEAD
Changes since 1.4: +9 -5 lines
Updated -ss option and corrected remark for -aa
# User Rev Content
1 greg 1.1 SETTING RENDERING OPTIONS
2
3     The table below gives some useful ranges for some Radiance 2.4 parameters.
4     The "min" value gives the fastest, crudest rendering. It is not
5     necessarily the smallest value numerically. The "fast" value gives
6     a reasonably fast rendering. The "accur" value gives a reasonably
7     accurate rendering. The "max" value gives the ultimate in accuracy.
8
9     Param Description Min Fast Accur Max Notes
10     ===== ==================== ===== ===== ===== ===== =====
11     -ps pixel sampling rate 16 8 4 1
12     -pt sampling threshold 1 .15 .05 0
13     -pj anti-aliasing jitter 0 .6 .9 1 A
14     -pm pixel motion 0 0 1 1 B
15 greg 1.5 -pd pixel depth of field 0 0 depends inf B
16 greg 1.4 -dj source jitter 0 0 .9 1 B
17 greg 1.3 -ds source substructuring 0 .5 .15 .05
18 greg 1.1 -dt direct thresholding 1 .5 .05 0 C
19     -dc direct certainty 0 .25 .5 1
20     -dr direct relays 0 1 3 6
21     -dp direct pretest density 32 64 512 0 C
22 greg 1.5 -ss specular sampling 0 .3 32 inf B
23 greg 1.1 -st specular threshold 1 .85 .15 0 C
24     -aw ambient weight 0 100 10 inf A
25     -ab ambient bounces 0 0 2 8
26 greg 1.2 -aa ambient accuracy .5 .2 .1 0 C
27     -ar ambient resolution 8 32 256 0 C
28     -ad ambient divisions 0 128 1024 8192
29     -as ambient super-samples 0 32 512 2048
30 greg 1.1 -ms mist sampling dist. 0 10 1 .01
31 greg 1.2 -lr limit reflection 0 6 8 16
32 greg 1.1 -lw limit weight .05 .01 .002 0 C
33
34     NOTES:
35     A) This option does not affect the rendering time
36     B) This option adversely affects image sampling (ie. use -ps 1)
37     C) Maximum value disables optimization and can be very expensive
38
39     -------------------------------------------------------------------------
40
41     ARTIFACTS ASSOCIATED WITH OPTIONS
42
43     Param Artifact Solution
44     ===== =================================== =========================
45     -ps "missing pieces" to objects decrease value by 50%
46     -pt some soft edges are very jagged decrease value by 50%
47     -pj diagonal edges are like staircases increase value to 0.9
48     -pj edges look too erratic decrease value to 0.4
49 greg 1.4 -dj shadows are unnaturally sharp increase value to 0.9
50 greg 1.1 -ds large sources cast unnatural shadows decrease value by 50%
51     -dt some shadows disappear decrease value by 50%
52     -dc inaccurate values with many sources increase value to .75
53     -dr missing multiple mirror reflections increment value
54     -dp incorrect mirror reflections double value
55 greg 1.5 -ss specular reflections too fuzzy decrease value to 0.2
56     -ss specular reflections too noisy increase value to 16
57 greg 1.1 -st some specular highlights missing decrease value to 0.02
58     -aw shadows appear to glow set value to 0
59     -ab lighting in shadows too flat increment value
60     -av overall light level seems too high/low decrease/increase value
61     -aa uneven shading boundaries in shadows decrease value by 25%
62     -ar shading wrong in some areas double or quadruple value
63     -ad "splotches" of light double value
64     -as "splotches" of light increase to half of -ad setting
65     -ms "noisy" mist scattering divide value by 2
66     -lr some multiple specular reflections gone increment value
67     -lw some specular reflections gone decrease value by 50%
68
69     -------------------------------------------------------------------------
70
71     TIMINGS ASSOCIATED WITH OPTIONS
72
73     Param Effect on Execution Time
74     ===== ==================================================================
75     -ps inverse, halving value increases rendering time up to four times
76     -pt minor, decreasing value causes modest increase in rendering time
77     -pj no effect
78 greg 1.5 -pm no effect
79     -pd no effect
80 greg 1.1 -dj indirect, increasing value requires -ps parameter to be reduced
81     -ds inverse, halving value causes rendering time to approximately double
82     -dt inverse, halving value causes rendering time to increase about 50%
83     -dc direct, affects rendering time up to 50% over its 0 to 1 range
84     -dr direct, depending on the scene each new reflection can double time
85     -dp minor, affects start-up time only, higher values take longer
86 greg 1.5 -ss no effect until > 1, then linear increase for specular surfaces
87 greg 1.1 -st minor, a value of zero may increase rendering by 50% over maximum of 1
88     -ab direct, doubling this value can double rendering time
89 greg 1.5 -aa direct, halving this value approximately quadruples rendering time
90 greg 1.1 -ar direct, effect depends on scene, can quadruple time for double value
91     -ad direct, doubling value may double rendering time
92     -as direct, effectively adds to -ad parameter and its cost
93 greg 1.5 -ms direct, halving value increases time by a factor of two in mist regions
94 greg 1.1 -lr minor, increase causes very slightly longer rendering time
95     -lw minor, decrease causes very slightly longer rendering time
