| 1 | SETTING RENDERING OPTIONS |
| 2 |  |
| 3 | The table below gives some useful ranges for some Radiance 2.4 parameters. |
| 4 | The "min" value gives the fastest, crudest rendering.  It is not |
| 5 | necessarily the smallest value numerically.  The "fast" value gives |
| 6 | a reasonably fast rendering.  The "accur" value gives a reasonably |
| 7 | accurate rendering.  The "max" value gives the ultimate in accuracy. |
| 8 |  |
| 9 | Param   Description             Min     Fast    Accur   Max     Notes |
| 10 | =====   ====================    =====   =====   =====   =====   ===== |
| 11 | -ps     pixel sampling rate     16      8       4       1 |
| 12 | -pt     sampling threshold      1       .15     .05     0 |
| 13 | -pj     anti-aliasing jitter    0       .6      .9      1       A |
| 14 | -pm     pixel motion            0       0       1       1       B |
| 15 | -dj     source jitter           0       0       .9      1       B |
| 16 | -ds     source substructuring   0       .5      .15     .05 |
| 17 | -dt     direct thresholding     1       .5      .05     0       C |
| 18 | -dc     direct certainty        0       .25     .5      1 |
| 19 | -dr     direct relays           0       1       3       6 |
| 20 | -dp     direct pretest density  32      64      512     0       C |
| 21 | -sj     specular jitter         0       .3      .7      1       A |
| 22 | -st     specular threshold      1       .85     .15     0       C |
| 23 | -aw     ambient weight          0       100     10      inf     A |
| 24 | -ab     ambient bounces         0       0       2       8 |
| 25 | -aa     ambient accuracy        .5      .2      .1      0       C |
| 26 | -ar     ambient resolution      8       32      256     0       C |
| 27 | -ad     ambient divisions       0       128     1024    8192 |
| 28 | -as     ambient super-samples   0       32      512     2048 |
| 29 | -ms     mist sampling dist.     0       10      1       .01 |
| 30 | -lr     limit reflection        0       6       8       16 |
| 31 | -lw     limit weight            .05     .01     .002    0       C |
| 32 |  |
| 33 | NOTES: |
| 34 | A) This option does not affect the rendering time |
| 35 | B) This option adversely affects image sampling (ie. use -ps 1) |
| 36 | C) Maximum value disables optimization and can be very expensive |
| 37 |  |
| 38 | ------------------------------------------------------------------------- |
| 39 |  |
| 40 | ARTIFACTS ASSOCIATED WITH OPTIONS |
| 41 |  |
| 42 | Param   Artifact                                Solution |
| 43 | =====   ===================================     ========================= |
| 44 | -ps     "missing pieces" to objects             decrease value by 50% |
| 45 | -pt     some soft edges are very jagged         decrease value by 50% |
| 46 | -pj     diagonal edges are like staircases      increase value to 0.9 |
| 47 | -pj     edges look too erratic                  decrease value to 0.4 |
| 48 | -dj     shadows are unnaturally sharp           increase value to 0.9 |
| 49 | -ds     large sources cast unnatural shadows    decrease value by 50% |
| 50 | -dt     some shadows disappear                  decrease value by 50% |
| 51 | -dc     inaccurate values with many sources     increase value to .75 |
| 52 | -dr     missing multiple mirror reflections     increment value |
| 53 | -dp     incorrect mirror reflections            double value |
| 54 | -sj     specular reflections too fuzzy          decrease value to 0.2 |
| 55 | -sj     specular reflections too sharp          increase value to 1 |
| 56 | -st     some specular highlights missing        decrease value to 0.02 |
| 57 | -aw     shadows appear to glow                  set value to 0 |
| 58 | -ab     lighting in shadows too flat            increment value |
| 59 | -av     overall light level seems too high/low  decrease/increase value |
| 60 | -aa     uneven shading boundaries in shadows    decrease value by 25% |
| 61 | -ar     shading wrong in some areas             double or quadruple value |
| 62 | -ad     "splotches" of light                    double value |
| 63 | -as     "splotches" of light                    increase to half of -ad setting |
| 64 | -ms     "noisy" mist scattering                 divide value by 2 |
| 65 | -lr     some multiple specular reflections gone increment value |
| 66 | -lw     some specular reflections gone          decrease value by 50% |
| 67 |  |
| 68 | ------------------------------------------------------------------------- |
| 69 |  |
| 70 | TIMINGS ASSOCIATED WITH OPTIONS |
| 71 |  |
| 72 | Param   Effect on Execution Time |
| 73 | =====   ================================================================== |
| 74 | -ps     inverse, halving value increases rendering time up to four times |
| 75 | -pt     minor, decreasing value causes modest increase in rendering time |
| 76 | -pj     no effect |
| 77 | -dj     indirect, increasing value requires -ps parameter to be reduced |
| 78 | -ds     inverse, halving value causes rendering time to approximately double |
| 79 | -dt     inverse, halving value causes rendering time to increase about 50% |
| 80 | -dc     direct, affects rendering time up to 50% over its 0 to 1 range |
| 81 | -dr     direct, depending on the scene each new reflection can double time |
| 82 | -dp     minor, affects start-up time only, higher values take longer |
| 83 | -sj     no effect |
| 84 | -st     minor, a value of zero may increase rendering by 50% over maximum of 1 |
| 85 | -ab     direct, doubling this value can double rendering time |
| 86 | -aa     direct, doubling this value approximately quadruples rendering time |
| 87 | -ar     direct, effect depends on scene, can quadruple time for double value |
| 88 | -ad     direct, doubling value may double rendering time |
| 89 | -as     direct, effectively adds to -ad parameter and its cost |
| 90 | -lr     minor, increase causes very slightly longer rendering time |
| 91 | -lw     minor, decrease causes very slightly longer rendering time |
