| 1 |
SETTING RENDERING OPTIONS
| 2 |
| 3 |
The table below gives some useful ranges for some Radiance 2.4 parameters.
| 4 |
The "min" value gives the fastest, crudest rendering. It is not
| 5 |
necessarily the smallest value numerically. The "fast" value gives
| 6 |
a reasonably fast rendering. The "accur" value gives a reasonably
| 7 |
accurate rendering. The "max" value gives the ultimate in accuracy.
| 8 |
| 9 |
Param Description Min Fast Accur Max Notes
| 10 |
| 11 |
-ps pixel sampling rate 16 8 4 1
| 12 |
-pt sampling threshold 1 .15 .05 0
| 13 |
-pj anti-aliasing jitter 0 .6 .9 1 A
| 14 |
-pm pixel motion 0 0 1 1 B
| 15 |
-dj source jitter 0 0 .7 1 B
| 16 |
-ds source substructuring 0 .5 .15 .05
| 17 |
-dt direct thresholding 1 .5 .05 0 C
| 18 |
-dc direct certainty 0 .25 .5 1
| 19 |
-dr direct relays 0 1 3 6
| 20 |
-dp direct pretest density 32 64 512 0 C
| 21 |
-sj specular jitter 0 .3 .7 1 A
| 22 |
-st specular threshold 1 .85 .15 0 C
| 23 |
-aw ambient weight 0 100 10 inf A
| 24 |
-ab ambient bounces 0 0 2 8
| 25 |
-aa ambient accuracy .5 .2 .1 0 C
| 26 |
-ar ambient resolution 8 32 256 0 C
| 27 |
-ad ambient divisions 0 128 1024 8192
| 28 |
-as ambient super-samples 0 32 512 2048
| 29 |
-ms mist sampling dist. 0 10 1 .01
| 30 |
-lr limit reflection 0 6 8 16
| 31 |
-lw limit weight .05 .01 .002 0 C
| 32 |
| 33 |
NOTES:
| 34 |
A) This option does not affect the rendering time
| 35 |
B) This option adversely affects image sampling (ie. use -ps 1)
| 36 |
C) Maximum value disables optimization and can be very expensive
| 37 |
| 38 |
| 39 |
| 40 |
ARTIFACTS ASSOCIATED WITH OPTIONS
| 41 |
| 42 |
Param Artifact Solution
| 43 |
| 44 |
-ps "missing pieces" to objects decrease value by 50%
| 45 |
-pt some soft edges are very jagged decrease value by 50%
| 46 |
-pj diagonal edges are like staircases increase value to 0.9
| 47 |
-pj edges look too erratic decrease value to 0.4
| 48 |
-dj shadows are unnaturally sharp increase value to 0.7
| 49 |
-ds large sources cast unnatural shadows decrease value by 50%
| 50 |
-dt some shadows disappear decrease value by 50%
| 51 |
-dc inaccurate values with many sources increase value to .75
| 52 |
-dr missing multiple mirror reflections increment value
| 53 |
-dp incorrect mirror reflections double value
| 54 |
-sj specular reflections too fuzzy decrease value to 0.2
| 55 |
-sj specular reflections too sharp increase value to 1
| 56 |
-st some specular highlights missing decrease value to 0.02
| 57 |
-aw shadows appear to glow set value to 0
| 58 |
-ab lighting in shadows too flat increment value
| 59 |
-av overall light level seems too high/low decrease/increase value
| 60 |
-aa uneven shading boundaries in shadows decrease value by 25%
| 61 |
-ar shading wrong in some areas double or quadruple value
| 62 |
-ad "splotches" of light double value
| 63 |
-as "splotches" of light increase to half of -ad setting
| 64 |
-ms "noisy" mist scattering divide value by 2
| 65 |
-lr some multiple specular reflections gone increment value
| 66 |
-lw some specular reflections gone decrease value by 50%
| 67 |
| 68 |
| 69 |
| 70 |
TIMINGS ASSOCIATED WITH OPTIONS
| 71 |
| 72 |
Param Effect on Execution Time
| 73 |
| 74 |
-ps inverse, halving value increases rendering time up to four times
| 75 |
-pt minor, decreasing value causes modest increase in rendering time
| 76 |
-pj no effect
| 77 |
-dj indirect, increasing value requires -ps parameter to be reduced
| 78 |
-ds inverse, halving value causes rendering time to approximately double
| 79 |
-dt inverse, halving value causes rendering time to increase about 50%
| 80 |
-dc direct, affects rendering time up to 50% over its 0 to 1 range
| 81 |
-dr direct, depending on the scene each new reflection can double time
| 82 |
-dp minor, affects start-up time only, higher values take longer
| 83 |
-sj no effect
| 84 |
-st minor, a value of zero may increase rendering by 50% over maximum of 1
| 85 |
-ab direct, doubling this value can double rendering time
| 86 |
-aa direct, doubling this value approximately quadruples rendering time
| 87 |
-ar direct, effect depends on scene, can quadruple time for double value
| 88 |
-ad direct, doubling value may double rendering time
| 89 |
-as direct, effectively adds to -ad parameter and its cost
| 90 |
-lr minor, increase causes very slightly longer rendering time
| 91 |
-lw minor, decrease causes very slightly longer rendering time
