1 |
Photo-realistic vs. Physically-based Rendering |
2 |
3 |
Photo-realistic rendering places emphasis on the appearance of its |
4 |
output rather than the techniques used to derive it. Anything goes, |
5 |
basically, as long as the final image looks nice. There is no |
6 |
attempt to use physically realistic values for the light sources |
7 |
or the surface reflectances. In fact, the light sources themselves |
8 |
often have physically impossible characteristics like 1/r falloff (as |
9 |
opposed to 1/r^2) or there is a lot of ambient lighting that comes from |
10 |
nowhere but somehow manages to illuminate the room. (You are probably |
11 |
saying, "Hey! Doesn't Radiance use an ambient term?" The answer is |
12 |
yes, but only as a final approximation to the interreflected component. |
13 |
The renderers I'm talking about use the ambient level as a main source |
14 |
of illumination!) Also, surfaces typically have color but there is no |
15 |
reflectance given, so all the surfaces appear to have roughly the same |
16 |
brightness. |
17 |
18 |
Such numerical shortcuts are often just conveniences provided so the |
19 |
user can get results easily and quickly without having to worry about |
20 |
fussy details, like where to put the light sources and what to use |
21 |
for reflectances. As you might expect, there is a penalty paid besides |
22 |
meaningless values, and that is fake-looking images. Have you noticed |
23 |
how these renderings always look pastel and glowing? You're seeing |
24 |
the visual equivalent of AM radio. |
25 |
26 |
Physically-based rendering, on the other hand, follows the physical |
27 |
behavior of light as closely as possible in an effort to *predict* |
28 |
what the final appearance of a design will be. This is not an |
29 |
artist's conception anymore, it is a numerical simulation. The |
30 |
light sources start in the calculation by emitting with a |
31 |
specific distribution, and the simulation computes the reflections |
32 |
between surfaces until the solution converges. The most popular |
33 |
technique for this computation is usually referred to as "radiosity", |
34 |
or flux transfer, and it does this by dividing all the surfaces into |
35 |
patches that exchange light energy within a closed system. This type |
36 |
of calculation is limited for the most part to simple scenes with |
37 |
diffuse surfaces where the visibility calculation and the solution |
38 |
matrix are manageable. |
39 |
40 |
Radiance, in contrast to most flux transfer methods, uses ray tracing |
41 |
to follow light in the reverse direction and does not require the same |
42 |
discretization as radiosity techniques. This has significant |
43 |
advantages when the scene geometry is complex, and permits the modeling |
44 |
of some specular interactions between surfaces. In general, Radiance |
45 |
is faster than radiosity if the scene contains more than a few thousand |
46 |
surfaces or has significant specularity. |
