root/radiance/ray/doc/notes/rendering.note
Revision: 1.1
Committed: Sat Mar 15 17:32:55 2003 UTC (22 years, 2 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
1 Photo-realistic vs. Physically-based Rendering
2
3 Photo-realistic rendering places emphasis on the appearance of its
4 output rather than the techniques used to derive it. Anything goes,
5 basically, as long as the final image looks nice. There is no
6 attempt to use physically realistic values for the light sources
7 or the surface reflectances. In fact, the light sources themselves
8 often have physically impossible characteristics like 1/r falloff (as
9 opposed to 1/r^2) or there is a lot of ambient lighting that comes from
10 nowhere but somehow manages to illuminate the room. (You are probably
11 saying, "Hey! Doesn't Radiance use an ambient term?" The answer is
12 yes, but only as a final approximation to the interreflected component.
13 The renderers I'm talking about use the ambient level as a main source
14 of illumination!) Also, surfaces typically have color but there is no
15 reflectance given, so all the surfaces appear to have roughly the same
16 brightness.
17
18 Such numerical shortcuts are often just conveniences provided so the
19 user can get results easily and quickly without having to worry about
20 fussy details, like where to put the light sources and what to use
21 for reflectances. As you might expect, there is a penalty paid besides
22 meaningless values, and that is fake-looking images. Have you noticed
23 how these renderings always look pastel and glowing? You're seeing
24 the visual equivalent of AM radio.
25
26 Physically-based rendering, on the other hand, follows the physical
27 behavior of light as closely as possible in an effort to *predict*
28 what the final appearance of a design will be. This is not an
29 artist's conception anymore, it is a numerical simulation. The
30 light sources start in the calculation by emitting with a
31 specific distribution, and the simulation computes the reflections
32 between surfaces until the solution converges. The most popular
33 technique for this computation is usually referred to as "radiosity",
34 or flux transfer, and it does this by dividing all the surfaces into
35 patches that exchange light energy within a closed system. This type
36 of calculation is limited for the most part to simple scenes with
37 diffuse surfaces where the visibility calculation and the solution
38 matrix are manageable.
39
40 Radiance, in contrast to most flux transfer methods, uses ray tracing
41 to follow light in the reverse direction and does not require the same
42 discretization as radiosity techniques. This has significant
43 advantages when the scene geometry is complex, and permits the modeling
44 of some specular interactions between surfaces. In general, Radiance
45 is faster than radiosity if the scene contains more than a few thousand
46 surfaces or has significant specularity.
