1 |
The RADIANCE Picture File Format |
2 |
3 |
Radiance is a lighting simulation and rendering system available by |
4 |
anonymous ftp from hobbes.lbl.gov (128.3.12.38). The picture file |
5 |
format used by the program uses a floating point representation that |
6 |
provides greater fidelity and numerical accuracy over a 24-bit |
7 |
image, without taking much extra space. |
8 |
9 |
At the end of this message I have put a shar file of the routines you |
10 |
need to read and write Radiance pictures. The format has been |
11 |
enhanced slightly for the next release (in an upward compatible |
12 |
way), so you should definitely use these newer routines. |
13 |
14 |
The file format, like most binary files used by Radiance, contains |
15 |
an ASCII information header that is terminated by an empty line. |
16 |
This header typically begins with the line "#?RADIANCE", followd |
17 |
by the commands used to generate the file, along with variables |
18 |
indicating exposure, view parameters, and so on. Next there is a |
19 |
single line that indicates the resolution and pixel scanning order of |
20 |
the image. For Radiance pictures, the pixels are order as English |
21 |
text, left to right and top to bottom. This is indicated with a line |
22 |
of the form: |
23 |
24 |
-Y M +X N |
25 |
26 |
Where M and N are the y and x resolutions, respectively. The x and y |
27 |
image coordinates are always the same, starting with (0,0) at the lower |
28 |
left corner, (N,0) at the lower right, and (0,M) at the upper left. |
29 |
The y resolution appears first in our specification because it is the |
30 |
major sort, and is preceded by a minus sign because it is decreasing in |
31 |
the file. |
32 |
33 |
Finally, the floating point scanlines follow. Each pixel is represented by |
34 |
at most 4 bytes. The first three bytes are the red, green and blue mantissas |
35 |
(in that order), and the fourth byte is a common exponent. The floating point |
36 |
color (R,G,B)=(1.,.5,.25) would be represented by the bytes (128,64,32,129). |
37 |
The conversion back to floating point is possible using the ldexp() library |
38 |
routine, or it's better to use the colr_color() routine included in color.c. |
39 |
40 |
The scanlines are usually run-length encoded. My previous scheme (release 1.4 |
41 |
and earlier) used a simple count for repeated pixels. My new scheme is |
42 |
more complicated and encodes the four components separately. I don't |
43 |
recommend writing your own routine to decode it -- use what's in color.c. |
44 |
45 |
A skeletal program to read a Radiance picture file and convert to 24-bit |
46 |
gamma-corrected color looks like this: |
47 |
48 |
/* Copyright (c) 1992 Regents of the University of California */ |
49 |
50 |
#ifndef lint |
51 |
static char SCCSid[] = "@(#)ra_skel.c 2.9 2/27/94 LBL"; |
52 |
#endif |
53 |
54 |
55 |
* Skeletal 24-bit image conversion program. Replace "skel" |
56 |
* in this file with a more appropriate image type identifier. |
57 |
58 |
* The Rmakefile entry should look something like this: |
59 |
* ra_skel: ra_skel.o |
60 |
* cc $(CFLAGS) -o ra_skel ra_skel.o -lrtrad -lm |
61 |
* ra_skel.o: ../common/color.h ../common/resolu.h |
62 |
63 |
* If you like to do things the hard way, you can link directly |
64 |
* to the object files "color.o colrops.o resolu.o header.o" in |
65 |
* the common subdirectory instead of using the -lrtrad library. |
66 |
67 |
68 |
#include <stdio.h> |
69 |
#include <math.h> |
70 |
#ifdef MSDOS |
71 |
#include <fcntl.h> |
72 |
#endif |
73 |
#include "color.h" |
74 |
#include "resolu.h" |
75 |
76 |
extern char *malloc(); |
77 |
78 |
double gamcor = 2.2; /* gamma correction */ |
79 |
80 |
int bradj = 0; /* brightness adjustment */ |
81 |
82 |
char *progname; |
83 |
84 |
int xmax, ymax; |
85 |
86 |
87 |
main(argc, argv) |
88 |
int argc; |
89 |
char *argv[]; |
90 |
91 |
int reverse = 0; |
92 |
int i; |
93 |
94 |
progname = argv[0]; |
95 |
96 |
for (i = 1; i < argc; i++) |
97 |
if (argv[i][0] == '-') |
98 |
switch (argv[i][1]) { |
99 |
case 'g': /* gamma correction */ |
100 |
gamcor = atof(argv[++i]); |
101 |
break; |
102 |
case 'e': /* exposure adjustment */ |
103 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-') |
104 |
goto userr; |
105 |
bradj = atoi(argv[++i]); |
106 |
break; |
107 |
case 'r': /* reverse conversion */ |
108 |
reverse = 1; |
109 |
break; |
110 |
default: |
111 |
goto userr; |
112 |
113 |
else |
114 |
break; |
115 |
116 |
if (i < argc-2) |
117 |
goto userr; |
118 |
if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) { |
119 |
fprintf(stderr, "%s: can't open input \"%s\"\n", |
120 |
progname, argv[i]); |
121 |
exit(1); |
122 |
123 |
if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) { |
124 |
fprintf(stderr, "%s: can't open output \"%s\"\n", |
125 |
progname, argv[i+1]); |
126 |
exit(1); |
127 |
128 |
#ifdef MSDOS |
129 |
setmode(fileno(stdin), O_BINARY); |
130 |
setmode(fileno(stdout), O_BINARY); |
131 |
#endif |
132 |
setcolrgam(gamcor); /* set up gamma correction */ |
133 |
if (reverse) { |
134 |
/* get their image resolution */ |
135 |
read_skel_head(&xmax, &ymax); |
136 |
/* put our header */ |
137 |
newheader("RADIANCE", stdout); |
138 |
printargs(i, argv, stdout); |
139 |
fputformat(COLRFMT, stdout); |
140 |
putchar('\n'); |
141 |
fprtresolu(xmax, ymax, stdout); |
142 |
/* convert file */ |
143 |
skel2ra(); |
144 |
} else { |
145 |
/* get our header */ |
146 |
if (checkheader(stdin, COLRFMT, NULL) < 0 || |
147 |
fgetresolu(&xmax, &ymax, stdin) < 0) |
148 |
quiterr("bad picture format"); |
149 |
/* write their header */ |
150 |
write_skel_head(xmax, ymax); |
151 |
152 |
ra2skel(); |
153 |
154 |
exit(0); |
155 |
userr: |
156 |
fprintf(stderr, |
157 |
"Usage: %s [-r][-g gamma][-e +/-stops] [input [output]]\n", |
158 |
progname); |
159 |
exit(1); |
160 |
161 |
162 |
163 |
quiterr(err) /* print message and exit */ |
164 |
char *err; |
165 |
166 |
if (err != NULL) { |
167 |
fprintf(stderr, "%s: %s\n", progname, err); |
168 |
exit(1); |
169 |
170 |
exit(0); |
171 |
172 |
173 |
174 |
skel2ra() /* convert 24-bit scanlines to Radiance picture */ |
175 |
176 |
COLR *scanout; |
177 |
register int x; |
178 |
int y; |
179 |
/* allocate scanline */ |
180 |
scanout = (COLR *)malloc(xmax*sizeof(COLR)); |
181 |
if (scanout == NULL) |
182 |
quiterr("out of memory in skel2ra"); |
183 |
/* convert image */ |
184 |
for (y = ymax-1; y >= 0; y--) { |
185 |
for (x = 0; x < xmax; x++) { |
186 |
scanout[x][RED] = getc(stdin); |
187 |
scanout[x][GRN] = getc(stdin); |
188 |
scanout[x][BLU] = getc(stdin); |
189 |
190 |
if (feof(stdin) | ferror(stdin)) |
191 |
quiterr("error reading skel image"); |
192 |
/* undo gamma */ |
193 |
gambs_colrs(scanout, xmax); |
194 |
if (bradj) /* adjust exposure */ |
195 |
shiftcolrs(scanout, xmax, bradj); |
196 |
if (fwritecolrs(scanout, xmax, stdout) < 0) |
197 |
quiterr("error writing Radiance picture"); |
198 |
199 |
/* free scanline */ |
200 |
free((char *)scanout); |
201 |
202 |
203 |
204 |
ra2skel() /* convert Radiance scanlines to 24-bit */ |
205 |
206 |
COLR *scanin; |
207 |
register int x; |
208 |
int y; |
209 |
210 |
scanin = (COLR *)malloc(xmax*sizeof(COLR)); |
211 |
if (scanin == NULL) |
212 |
quiterr("out of memory in ra2skel"); |
213 |
214 |
215 |
if (freadcolrs(scanin, xmax, stdin) < 0) |
216 |
quiterr("error reading Radiance picture"); |
217 |
218 |
shiftcolrs(scanin, xmax, bradj); |
219 |
colrs_gambs(scanin, xmax); /* gamma correction */ |
220 |
221 |
putc(scanin[x][RED], stdout); |
222 |
putc(scanin[x][GRN], stdout); |
223 |
putc(scanin[x][BLU], stdout); |
224 |
225 |
if (ferror(stdout)) |
226 |
quiterr("error writing skel file"); |
227 |
228 |
229 |
free((char *)scanin); |
230 |
231 |
232 |
233 |
You will find all the routines you need in ray/src/common. The |
234 |
checkheader() routine is in the module header.c, fgetresolu is in resolu.c, |
235 |
freadcolrs() is in color.c, and setcolrgam() and colrs_gambs() are |
236 |
in the module colrops.c. |
237 |
238 |
If you want to convert the file to 8-bit color, the process is quite a |
239 |
bit more complicated. I suggest you take a look at the ra_t8.c program |
240 |
in the ray/src/px directory to get a better idea of what is involved. |
241 |
242 |
243 |
#! /bin/sh |
244 |
# This is a shell archive, meaning: |
245 |
# 1. Remove everything above the #! /bin/sh line. |
246 |
# 2. Save the resulting text in a file. |
247 |
# 3. Execute the file with /bin/sh (not csh) to create: |
248 |
# color.h |
249 |
# resolu.h |
250 |
# resolu.c |
251 |
# header.c |
252 |
# color.c |
253 |
# colrops.c |
254 |
# This archive created: Tue Apr 5 14:07:02 1994 |
255 |
export PATH; PATH=/bin:/usr/bin:$PATH |
256 |
if test -f 'color.h' |
257 |
then |
258 |
echo shar: "will not over-write existing file 'color.h'" |
259 |
else |
260 |
sed 's/^X//' << \SHAR_EOF > 'color.h' |
261 |
X/* Copyright (c) 1991 Regents of the University of California */ |
262 |
X |
263 |
X/* SCCSid "@(#)color.h 2.6 8/2/93 LBL" */ |
264 |
X |
265 |
X/* |
266 |
X * color.h - header for routines using pixel color values. |
267 |
X * |
268 |
X * 12/31/85 |
269 |
X * |
270 |
X * Two color representations are used, one for calculation and |
271 |
X * another for storage. Calculation is done with three floats |
272 |
X * for speed. Stored color values use 4 bytes which contain |
273 |
X * three single byte mantissas and a common exponent. |
274 |
X */ |
275 |
X |
276 |
X#define RED 0 |
277 |
X#define GRN 1 |
278 |
X#define BLU 2 |
279 |
X#define EXP 3 |
280 |
X#define COLXS 128 /* excess used for exponent */ |
281 |
X |
282 |
Xtypedef unsigned char BYTE; /* 8-bit unsigned integer */ |
283 |
X |
284 |
Xtypedef BYTE COLR[4]; /* red, green, blue, exponent */ |
285 |
X |
286 |
X#define copycolr(c1,c2) (c1[0]=c2[0],c1[1]=c2[1], \ |
287 |
X c1[2]=c2[2],c1[3]=c2[3]) |
288 |
X |
289 |
Xtypedef float COLOR[3]; /* red, green, blue */ |
290 |
X |
291 |
X#define colval(col,pri) ((col)[pri]) |
292 |
X |
293 |
X#define setcolor(col,r,g,b) ((col)[RED]=(r),(col)[GRN]=(g),(col)[BLU]=(b)) |
294 |
X |
295 |
X#define copycolor(c1,c2) ((c1)[0]=(c2)[0],(c1)[1]=(c2)[1],(c1)[2]=(c2)[2]) |
296 |
X |
297 |
X#define scalecolor(col,sf) ((col)[0]*=(sf),(col)[1]*=(sf),(col)[2]*=(sf)) |
298 |
X |
299 |
X#define addcolor(c1,c2) ((c1)[0]+=(c2)[0],(c1)[1]+=(c2)[1],(c1)[2]+=(c2)[2]) |
300 |
X |
301 |
X#define multcolor(c1,c2) ((c1)[0]*=(c2)[0],(c1)[1]*=(c2)[1],(c1)[2]*=(c2)[2]) |
302 |
X |
303 |
X#ifdef NTSC |
304 |
X#define bright(col) (.295*(col)[RED]+.636*(col)[GRN]+.070*(col)[BLU]) |
305 |
X#define normbright(c) (int)((74L*(c)[RED]+164L*(c)[GRN]+18L*(c)[BLU])>>8) |
306 |
X#else |
307 |
X#define bright(col) (.263*(col)[RED]+.655*(col)[GRN]+.082*(col)[BLU]) |
308 |
X#define normbright(c) (int)((67L*(c)[RED]+168L*(c)[GRN]+21L*(c)[BLU])>>8) |
309 |
X#endif |
310 |
X |
311 |
X /* luminous efficacies over visible spectrum */ |
312 |
X#define MAXEFFICACY 683. /* defined maximum at 550 nm */ |
313 |
X#define WHTEFFICACY 179. /* uniform white light */ |
314 |
X#define D65EFFICACY 203. /* standard illuminant D65 */ |
315 |
X#define INCEFFICACY 160. /* illuminant A (incand.) */ |
316 |
X#define SUNEFFICACY 208. /* illuminant B (solar dir.) */ |
317 |
X#define SKYEFFICACY D65EFFICACY /* skylight */ |
318 |
X#define DAYEFFICACY D65EFFICACY /* combined sky and solar */ |
319 |
X |
320 |
X#define luminance(col) (WHTEFFICACY * bright(col)) |
321 |
X |
322 |
X#define intens(col) ( (col)[0] > (col)[1] \ |
323 |
X ? (col)[0] > (col)[2] ? (col)[0] : (col)[2] \ |
324 |
X : (col)[1] > (col)[2] ? (col)[1] : (col)[2] ) |
325 |
X |
326 |
X#define colrval(c,p) ( (c)[EXP] ? \ |
327 |
X ldexp((c)[p]+.5,(int)(c)[EXP]-(COLXS+8)) : \ |
328 |
X 0. ) |
329 |
X |
330 |
X#define WHTCOLOR {1.0,1.0,1.0} |
331 |
X#define BLKCOLOR {0.0,0.0,0.0} |
332 |
X#define WHTCOLR {128,128,128,COLXS+1} |
333 |
X#define BLKCOLR {0,0,0,0} |
334 |
X |
335 |
X /* picture format identifier */ |
336 |
X#define COLRFMT "32-bit_rle_rgbe" |
337 |
X |
338 |
X /* macros for exposures */ |
339 |
X#define EXPOSSTR "EXPOSURE=" |
340 |
X#define LEXPOSSTR 9 |
341 |
X#define isexpos(hl) (!strncmp(hl,EXPOSSTR,LEXPOSSTR)) |
342 |
X#define exposval(hl) atof((hl)+LEXPOSSTR) |
343 |
X#define fputexpos(ex,fp) fprintf(fp,"%s%e\n",EXPOSSTR,ex) |
344 |
X |
345 |
X /* macros for pixel aspect ratios */ |
346 |
X#define ASPECTSTR "PIXASPECT=" |
347 |
X#define LASPECTSTR 10 |
348 |
X#define isaspect(hl) (!strncmp(hl,ASPECTSTR,LASPECTSTR)) |
349 |
X#define aspectval(hl) atof((hl)+LASPECTSTR) |
350 |
X#define fputaspect(pa,fp) fprintf(fp,"%s%f\n",ASPECTSTR,pa) |
351 |
X |
352 |
X /* macros for color correction */ |
353 |
X#define COLCORSTR "COLORCORR=" |
354 |
X#define LCOLCORSTR 10 |
355 |
X#define iscolcor(hl) (!strncmp(hl,COLCORSTR,LCOLCORSTR)) |
356 |
X#define colcorval(cc,hl) sscanf(hl+LCOLCORSTR,"%f %f %f", \ |
357 |
X &(cc)[RED],&(cc)[GRN],&(cc)[BLU]) |
358 |
X#define fputcolcor(cc,fp) fprintf(fp,"%s %f %f %f\n",COLCORSTR, \ |
359 |
X (cc)[RED],(cc)[GRN],(cc)[BLU]) |
360 |
X |
361 |
X#ifdef DCL_ATOF |
362 |
Xextern double atof(), ldexp(), frexp(); |
363 |
X#endif |
364 |
SHAR_EOF |
365 |
fi |
366 |
if test -f 'resolu.h' |
367 |
then |
368 |
echo shar: "will not over-write existing file 'resolu.h'" |
369 |
else |
370 |
sed 's/^X//' << \SHAR_EOF > 'resolu.h' |
371 |
372 |
X |
373 |
X/* SCCSid "@(#)resolu.h 2.2 6/4/93 LBL" */ |
374 |
X |
375 |
X/* |
376 |
X * Definitions for resolution line in image file. |
377 |
X * |
378 |
X * True image orientation is defined by an xy coordinate system |
379 |
X * whose origin is at the lower left corner of the image, with |
380 |
X * x increasing to the right and y increasing in the upward direction. |
381 |
X * This true orientation is independent of how the pixels are actually |
382 |
X * ordered in the file, which is indicated by the resolution line. |
383 |
X * This line is of the form "{+-}{XY} xyres {+-}{YX} yxres\n". |
384 |
X * A typical line for a 1024x600 image might be "-Y 600 +X 1024\n", |
385 |
X * indicating that the scanlines are in English text order (PIXSTANDARD). |
386 |
X */ |
387 |
X |
388 |
X /* flags for scanline ordering */ |
389 |
X#define XDECR 1 |
390 |
X#define YDECR 2 |
391 |
X#define YMAJOR 4 |
392 |
X |
393 |
X /* standard scanline ordering */ |
394 |
X#define PIXSTANDARD (YMAJOR|YDECR) |
395 |
X#define PIXSTDFMT "-Y %d +X %d\n" |
396 |
X |
397 |
X /* structure for image dimensions */ |
398 |
Xtypedef struct { |
399 |
X int or; /* orientation (from flags above) */ |
400 |
X int xr, yr; /* x and y resolution */ |
401 |
X} RESOLU; |
402 |
X |
403 |
X /* macros to get scanline length and number */ |
404 |
X#define scanlen(rs) ((rs)->or & YMAJOR ? (rs)->xr : (rs)->yr) |
405 |
X#define numscans(rs) ((rs)->or & YMAJOR ? (rs)->yr : (rs)->xr) |
406 |
X |
407 |
X /* resolution string buffer and its size */ |
408 |
X#define RESOLU_BUFLEN 32 |
409 |
Xextern char resolu_buf[RESOLU_BUFLEN]; |
410 |
X |
411 |
X /* macros for reading/writing resolution struct */ |
412 |
X#define fputsresolu(rs,fp) fputs(resolu2str(resolu_buf,rs),fp) |
413 |
X#define fgetsresolu(rs,fp) str2resolu(rs, \ |
414 |
X fgets(resolu_buf,RESOLU_BUFLEN,fp)) |
415 |
X |
416 |
X /* reading/writing of standard ordering */ |
417 |
X#define fprtresolu(sl,ns,fp) fprintf(fp,PIXSTDFMT,ns,sl) |
418 |
X#define fscnresolu(sl,ns,fp) (fscanf(fp,PIXSTDFMT,ns,sl)==2) |
419 |
X |
420 |
Xextern char *resolu2str(); |
421 |
SHAR_EOF |
422 |
fi |
423 |
if test -f 'resolu.c' |
424 |
then |
425 |
echo shar: "will not over-write existing file 'resolu.c'" |
426 |
else |
427 |
sed 's/^X//' << \SHAR_EOF > 'resolu.c' |
428 |
429 |
X |
430 |
X#ifndef lint |
431 |
Xstatic char SCCSid[] = "@(#)resolu.c 2.2 11/28/91 LBL"; |
432 |
X#endif |
433 |
X |
434 |
X/* |
435 |
X * Read and write image resolutions. |
436 |
X */ |
437 |
X |
438 |
X#include <stdio.h> |
439 |
X |
440 |
X#include "resolu.h" |
441 |
X |
442 |
X |
443 |
Xchar resolu_buf[RESOLU_BUFLEN]; /* resolution line buffer */ |
444 |
X |
445 |
X |
446 |
Xfputresolu(ord, sl, ns, fp) /* put out picture dimensions */ |
447 |
Xint ord; /* scanline ordering */ |
448 |
Xint sl, ns; /* scanline length and number */ |
449 |
XFILE *fp; |
450 |
X{ |
451 |
X RESOLU rs; |
452 |
X |
453 |
X if ((rs.or = ord) & YMAJOR) { |
454 |
X rs.xr = sl; |
455 |
X rs.yr = ns; |
456 |
X } else { |
457 |
X rs.xr = ns; |
458 |
X rs.yr = sl; |
459 |
X } |
460 |
X fputsresolu(&rs, fp); |
461 |
X} |
462 |
X |
463 |
X |
464 |
Xint |
465 |
Xfgetresolu(sl, ns, fp) /* get picture dimensions */ |
466 |
Xint *sl, *ns; /* scanline length and number */ |
467 |
XFILE *fp; |
468 |
X{ |
469 |
X RESOLU rs; |
470 |
X |
471 |
X if (!fgetsresolu(&rs, fp)) |
472 |
X return(-1); |
473 |
X if (rs.or & YMAJOR) { |
474 |
X *sl = rs.xr; |
475 |
X *ns = rs.yr; |
476 |
X } else { |
477 |
X *sl = rs.yr; |
478 |
X *ns = rs.xr; |
479 |
X } |
480 |
X return(rs.or); |
481 |
X} |
482 |
X |
483 |
X |
484 |
Xchar * |
485 |
Xresolu2str(buf, rp) /* convert resolution struct to line */ |
486 |
Xchar *buf; |
487 |
Xregister RESOLU *rp; |
488 |
X{ |
489 |
X if (rp->or&YMAJOR) |
490 |
X sprintf(buf, "%cY %d %cX %d\n", |
491 |
X rp->or&YDECR ? '-' : '+', rp->yr, |
492 |
X rp->or&XDECR ? '-' : '+', rp->xr); |
493 |
X else |
494 |
X sprintf(buf, "%cX %d %cY %d\n", |
495 |
X rp->or&XDECR ? '-' : '+', rp->xr, |
496 |
X rp->or&YDECR ? '-' : '+', rp->yr); |
497 |
X return(buf); |
498 |
X} |
499 |
X |
500 |
X |
501 |
Xstr2resolu(rp, buf) /* convert resolution line to struct */ |
502 |
503 |
Xchar *buf; |
504 |
X{ |
505 |
X register char *xndx, *yndx; |
506 |
X register char *cp; |
507 |
X |
508 |
X if (buf == NULL) |
509 |
X return(0); |
510 |
X xndx = yndx = NULL; |
511 |
X for (cp = buf; *cp; cp++) |
512 |
X if (*cp == 'X') |
513 |
X xndx = cp; |
514 |
X else if (*cp == 'Y') |
515 |
X yndx = cp; |
516 |
X if (xndx == NULL || yndx == NULL) |
517 |
X return(0); |
518 |
X rp->or = 0; |
519 |
X if (xndx > yndx) rp->or |= YMAJOR; |
520 |
X if (xndx[-1] == '-') rp->or |= XDECR; |
521 |
X if (yndx[-1] == '-') rp->or |= YDECR; |
522 |
X if ((rp->xr = atoi(xndx+1)) <= 0) |
523 |
X return(0); |
524 |
X if ((rp->yr = atoi(yndx+1)) <= 0) |
525 |
X return(0); |
526 |
X return(1); |
527 |
X} |
528 |
SHAR_EOF |
529 |
fi |
530 |
if test -f 'header.c' |
531 |
then |
532 |
echo shar: "will not over-write existing file 'header.c'" |
533 |
else |
534 |
sed 's/^X//' << \SHAR_EOF > 'header.c' |
535 |
X/* Copyright (c) 1994 Regents of the University of California */ |
536 |
X |
537 |
X#ifndef lint |
538 |
Xstatic char SCCSid[] = "@(#)header.c 2.4 2/27/94 LBL"; |
539 |
X#endif |
540 |
X |
541 |
X/* |
542 |
X * header.c - routines for reading and writing information headers. |
543 |
X * |
544 |
X * 8/19/88 |
545 |
X * |
546 |
X * newheader(t,fp) start new information header identified by string t |
547 |
X * isheadid(s) returns true if s is a header id line |
548 |
X * headidval(r,s) copy header identifier value in s to r |
549 |
X * printargs(ac,av,fp) print an argument list to fp, followed by '\n' |
550 |
X * isformat(s) returns true if s is of the form "FORMAT=*" |
551 |
X * formatval(r,s) copy the format value in s to r |
552 |
X * fputformat(s,fp) write "FORMAT=%s" to fp |
553 |
X * getheader(fp,f,p) read header from fp, calling f(s,p) on each line |
554 |
X * checkheader(i,p,o) check header format from i against p and copy to o |
555 |
X * |
556 |
X * To copy header from input to output, use getheader(fin, fputs, fout) |
557 |
X */ |
558 |
X |
559 |
560 |
X#include <ctype.h> |
561 |
X |
562 |
X#define MAXLINE 512 |
563 |
X |
564 |
X#ifndef BSD |
565 |
X#define index strchr |
566 |
X#endif |
567 |
X |
568 |
Xextern char *index(); |
569 |
X |
570 |
Xchar HDRSTR[] = "#?"; /* information header magic number */ |
571 |
X |
572 |
Xchar FMTSTR[] = "FORMAT="; /* format identifier */ |
573 |
X |
574 |
X |
575 |
Xnewheader(s, fp) /* identifying line of information header */ |
576 |
Xchar *s; |
577 |
Xregister FILE *fp; |
578 |
X{ |
579 |
X fputs(HDRSTR, fp); |
580 |
X fputs(s, fp); |
581 |
X putc('\n', fp); |
582 |
X} |
583 |
X |
584 |
X |
585 |
Xheadidval(r,s) /* get header id (return true if is id) */ |
586 |
Xregister char *r, *s; |
587 |
X{ |
588 |
X register char *cp = HDRSTR; |
589 |
X |
590 |
X while (*cp) if (*cp++ != *s++) return(0); |
591 |
X if (r == NULL) return(1); |
592 |
X while (*s) *r++ = *s++; |
593 |
X *r = '\0'; |
594 |
X return(1); |
595 |
X} |
596 |
X |
597 |
X |
598 |
Xisheadid(s) /* check to see if line is header id */ |
599 |
Xchar *s; |
600 |
X{ |
601 |
X return(headidval(NULL, s)); |
602 |
X} |
603 |
X |
604 |
X |
605 |
Xprintargs(ac, av, fp) /* print arguments to a file */ |
606 |
Xint ac; |
607 |
Xchar **av; |
608 |
609 |
X{ |
610 |
X int quote; |
611 |
X |
612 |
X while (ac-- > 0) { |
613 |
X if (index(*av, ' ') != NULL) { /* quote it */ |
614 |
X if (index(*av, '\'') != NULL) |
615 |
X quote = '"'; |
616 |
X else |
617 |
X quote = '\''; |
618 |
X putc(quote, fp); |
619 |
X fputs(*av++, fp); |
620 |
621 |
X } else |
622 |
623 |
X putc(' ', fp); |
624 |
X } |
625 |
X putc('\n', fp); |
626 |
X} |
627 |
X |
628 |
X |
629 |
Xformatval(r, s) /* get format value (return true if format) */ |
630 |
Xregister char *r; |
631 |
Xregister char *s; |
632 |
X{ |
633 |
X register char *cp = FMTSTR; |
634 |
X |
635 |
636 |
X while (isspace(*s)) s++; |
637 |
X if (!*s) return(0); |
638 |
639 |
X while(*s) *r++ = *s++; |
640 |
X while (isspace(r[-1])) r--; |
641 |
X *r = '\0'; |
642 |
X return(1); |
643 |
X} |
644 |
X |
645 |
X |
646 |
Xisformat(s) /* is line a format line? */ |
647 |
Xchar *s; |
648 |
X{ |
649 |
X return(formatval(NULL, s)); |
650 |
X} |
651 |
X |
652 |
X |
653 |
Xfputformat(s, fp) /* put out a format value */ |
654 |
Xchar *s; |
655 |
XFILE *fp; |
656 |
X{ |
657 |
X fputs(FMTSTR, fp); |
658 |
X fputs(s, fp); |
659 |
X putc('\n', fp); |
660 |
X} |
661 |
X |
662 |
X |
663 |
Xgetheader(fp, f, p) /* get header from file */ |
664 |
XFILE *fp; |
665 |
Xint (*f)(); |
666 |
Xchar *p; |
667 |
X{ |
668 |
X char buf[MAXLINE]; |
669 |
X |
670 |
X for ( ; ; ) { |
671 |
X buf[MAXLINE-2] = '\n'; |
672 |
X if (fgets(buf, MAXLINE, fp) == NULL) |
673 |
X return(-1); |
674 |
X if (buf[0] == '\n') |
675 |
X return(0); |
676 |
X#ifdef MSDOS |
677 |
X if (buf[0] == '\r' && buf[1] == '\n') |
678 |
X return(0); |
679 |
X#endif |
680 |
X if (buf[MAXLINE-2] != '\n') { |
681 |
X ungetc(buf[MAXLINE-2], fp); /* prevent false end */ |
682 |
X buf[MAXLINE-2] = '\0'; |
683 |
X } |
684 |
X if (f != NULL) |
685 |
X (*f)(buf, p); |
686 |
X } |
687 |
X} |
688 |
X |
689 |
X |
690 |
Xstruct check { |
691 |
X FILE *fp; |
692 |
X char fs[64]; |
693 |
X}; |
694 |
X |
695 |
X |
696 |
Xstatic |
697 |
Xmycheck(s, cp) /* check a header line for format info. */ |
698 |
Xchar *s; |
699 |
Xregister struct check *cp; |
700 |
X{ |
701 |
X if (!formatval(cp->fs, s) && cp->fp != NULL) |
702 |
X fputs(s, cp->fp); |
703 |
X} |
704 |
X |
705 |
X |
706 |
X/* |
707 |
X * Copymatch(pat,str) checks pat for wildcards, and |
708 |
X * copies str into pat if there is a match (returning true). |
709 |
X */ |
710 |
X |
711 |
X#ifdef COPYMATCH |
712 |
Xcopymatch(pat, str) |
713 |
Xchar *pat, *str; |
714 |
X{ |
715 |
X int docopy = 0; |
716 |
X register char *p = pat, *s = str; |
717 |
X |
718 |
X do { |
719 |
X switch (*p) { |
720 |
X case '?': /* match any character */ |
721 |
X if (!*s++) |
722 |
X return(0); |
723 |
X docopy++; |
724 |
X break; |
725 |
X case '*': /* match any string */ |
726 |
X while (p[1] == '*') p++; |
727 |
X do |
728 |
X if ( (p[1]=='?' || p[1]==*s) |
729 |
X && copymatch(p+1,s) ) { |
730 |
X strcpy(pat, str); |
731 |
X return(1); |
732 |
X } |
733 |
X while (*s++); |
734 |
X return(0); |
735 |
X case '\\': /* literal next */ |
736 |
X p++; |
737 |
X /* fall through */ |
738 |
X default: /* normal character */ |
739 |
X if (*p != *s) |
740 |
X return(0); |
741 |
X s++; |
742 |
X break; |
743 |
X } |
744 |
X } while (*p++); |
745 |
X if (docopy) |
746 |
747 |
X return(1); |
748 |
X} |
749 |
X#else |
750 |
X#define copymatch(pat, s) (!strcmp(pat, s)) |
751 |
X#endif |
752 |
X |
753 |
X |
754 |
X/* |
755 |
X * Checkheader(fin,fmt,fout) returns a value of 1 if the input format |
756 |
X * matches the specification in fmt, 0 if no input format was found, |
757 |
X * and -1 if the input format does not match or there is an |
758 |
X * error reading the header. If fmt is empty, then -1 is returned |
759 |
X * if any input format is found (or there is an error), and 0 otherwise. |
760 |
X * If fmt contains any '*' or '?' characters, then checkheader |
761 |
X * does wildcard expansion and copies a matching result into fmt. |
762 |
X * Be sure that fmt is big enough to hold the match in such cases! |
763 |
X * The input header (minus any format lines) is copied to fout |
764 |
X * if fout is not NULL. |
765 |
X */ |
766 |
X |
767 |
Xcheckheader(fin, fmt, fout) |
768 |
XFILE *fin; |
769 |
Xchar *fmt; |
770 |
XFILE *fout; |
771 |
X{ |
772 |
X struct check cdat; |
773 |
X |
774 |
X cdat.fp = fout; |
775 |
X cdat.fs[0] = '\0'; |
776 |
X if (getheader(fin, mycheck, &cdat) < 0) |
777 |
X return(-1); |
778 |
X if (cdat.fs[0] != '\0') |
779 |
X return(copymatch(fmt, cdat.fs) ? 1 : -1); |
780 |
X return(0); |
781 |
X} |
782 |
SHAR_EOF |
783 |
fi |
784 |
if test -f 'color.c' |
785 |
then |
786 |
echo shar: "will not over-write existing file 'color.c'" |
787 |
else |
788 |
sed 's/^X//' << \SHAR_EOF > 'color.c' |
789 |
790 |
X |
791 |
X#ifndef lint |
792 |
Xstatic char SCCSid[] = "@(#)color.c 2.8 3/26/94 LBL"; |
793 |
X#endif |
794 |
X |
795 |
X/* |
796 |
X * color.c - routines for color calculations. |
797 |
X * |
798 |
X * 10/10/85 |
799 |
X */ |
800 |
X |
801 |
802 |
X |
803 |
X#include <math.h> |
804 |
X |
805 |
X#include "color.h" |
806 |
X |
807 |
X#define MINELEN 8 /* minimum scanline length for encoding */ |
808 |
X#define MAXELEN 0x7fff /* maximum scanline length for encoding */ |
809 |
X#define MINRUN 4 /* minimum run length */ |
810 |
X |
811 |
X |
812 |
Xchar * |
813 |
Xtempbuffer(len) /* get a temporary buffer */ |
814 |
Xunsigned len; |
815 |
X{ |
816 |
X extern char *malloc(), *realloc(); |
817 |
X static char *tempbuf = NULL; |
818 |
X static unsigned tempbuflen = 0; |
819 |
X |
820 |
X if (len > tempbuflen) { |
821 |
X if (tempbuflen > 0) |
822 |
X tempbuf = realloc(tempbuf, len); |
823 |
X else |
824 |
X tempbuf = malloc(len); |
825 |
X tempbuflen = tempbuf==NULL ? 0 : len; |
826 |
X } |
827 |
X return(tempbuf); |
828 |
X} |
829 |
X |
830 |
X |
831 |
Xfwritecolrs(scanline, len, fp) /* write out a colr scanline */ |
832 |
Xregister COLR *scanline; |
833 |
Xunsigned len; |
834 |
835 |
X{ |
836 |
X register int i, j, beg, cnt; |
837 |
X int c2; |
838 |
X |
839 |
X if (len < MINELEN | len > MAXELEN) /* OOBs, write out flat */ |
840 |
X return(fwrite((char *)scanline,sizeof(COLR),len,fp) - len); |
841 |
X /* put magic header */ |
842 |
X putc(2, fp); |
843 |
X putc(2, fp); |
844 |
X putc(len>>8, fp); |
845 |
X putc(len&255, fp); |
846 |
X /* put components seperately */ |
847 |
X for (i = 0; i < 4; i++) { |
848 |
X for (j = 0; j < len; j += cnt) { /* find next run */ |
849 |
X for (beg = j; beg < len; beg += cnt) { |
850 |
X for (cnt = 1; cnt < 127 && beg+cnt < len && |
851 |
X scanline[beg+cnt][i] == scanline[beg][i]; cnt++) |
852 |
X ; |
853 |
X if (cnt >= MINRUN) |
854 |
X break; /* long enough */ |
855 |
X } |
856 |
X if (beg-j > 1 && beg-j < MINRUN) { |
857 |
X c2 = j+1; |
858 |
X while (scanline[c2++][i] == scanline[j][i]) |
859 |
X if (c2 == beg) { /* short run */ |
860 |
X putc(128+beg-j, fp); |
861 |
X putc(scanline[j][i], fp); |
862 |
X j = beg; |
863 |
X break; |
864 |
X } |
865 |
X } |
866 |
X while (j < beg) { /* write out non-run */ |
867 |
X if ((c2 = beg-j) > 128) c2 = 128; |
868 |
X putc(c2, fp); |
869 |
X while (c2--) |
870 |
X putc(scanline[j++][i], fp); |
871 |
X } |
872 |
X if (cnt >= MINRUN) { /* write out run */ |
873 |
X putc(128+cnt, fp); |
874 |
X putc(scanline[beg][i], fp); |
875 |
X } else |
876 |
X cnt = 0; |
877 |
X } |
878 |
X } |
879 |
X return(ferror(fp) ? -1 : 0); |
880 |
X} |
881 |
X |
882 |
X |
883 |
Xfreadcolrs(scanline, len, fp) /* read in an encoded colr scanline */ |
884 |
885 |
Xint len; |
886 |
887 |
X{ |
888 |
X register int i, j; |
889 |
X int code, val; |
890 |
X /* determine scanline type */ |
891 |
X if (len < MINELEN | len > MAXELEN) |
892 |
X return(oldreadcolrs(scanline, len, fp)); |
893 |
X if ((i = getc(fp)) == EOF) |
894 |
X return(-1); |
895 |
X if (i != 2) { |
896 |
X ungetc(i, fp); |
897 |
898 |
X } |
899 |
X scanline[0][GRN] = getc(fp); |
900 |
X scanline[0][BLU] = getc(fp); |
901 |
902 |
X return(-1); |
903 |
X if (scanline[0][GRN] != 2 || scanline[0][BLU] & 128) { |
904 |
X scanline[0][RED] = 2; |
905 |
X scanline[0][EXP] = i; |
906 |
X return(oldreadcolrs(scanline+1, len-1, fp)); |
907 |
X } |
908 |
X if ((scanline[0][BLU]<<8 | i) != len) |
909 |
X return(-1); /* length mismatch! */ |
910 |
X /* read each component */ |
911 |
X for (i = 0; i < 4; i++) |
912 |
X for (j = 0; j < len; ) { |
913 |
X if ((code = getc(fp)) == EOF) |
914 |
X return(-1); |
915 |
X if (code > 128) { /* run */ |
916 |
X code &= 127; |
917 |
X val = getc(fp); |
918 |
X while (code--) |
919 |
X scanline[j++][i] = val; |
920 |
X } else /* non-run */ |
921 |
X while (code--) |
922 |
X scanline[j++][i] = getc(fp); |
923 |
X } |
924 |
X return(feof(fp) ? -1 : 0); |
925 |
X} |
926 |
X |
927 |
X |
928 |
Xoldreadcolrs(scanline, len, fp) /* read in an old colr scanline */ |
929 |
930 |
Xint len; |
931 |
932 |
X{ |
933 |
X int rshift; |
934 |
X register int i; |
935 |
X |
936 |
X rshift = 0; |
937 |
X |
938 |
X while (len > 0) { |
939 |
X scanline[0][RED] = getc(fp); |
940 |
941 |
942 |
X scanline[0][EXP] = getc(fp); |
943 |
X if (feof(fp) || ferror(fp)) |
944 |
X return(-1); |
945 |
X if (scanline[0][RED] == 1 && |
946 |
X scanline[0][GRN] == 1 && |
947 |
X scanline[0][BLU] == 1) { |
948 |
X for (i = scanline[0][EXP] << rshift; i > 0; i--) { |
949 |
X copycolr(scanline[0], scanline[-1]); |
950 |
X scanline++; |
951 |
X len--; |
952 |
X } |
953 |
X rshift += 8; |
954 |
X } else { |
955 |
X scanline++; |
956 |
X len--; |
957 |
X rshift = 0; |
958 |
X } |
959 |
X } |
960 |
X return(0); |
961 |
X} |
962 |
X |
963 |
X |
964 |
Xfwritescan(scanline, len, fp) /* write out a scanline */ |
965 |
Xregister COLOR *scanline; |
966 |
Xint len; |
967 |
XFILE *fp; |
968 |
X{ |
969 |
X COLR *clrscan; |
970 |
X int n; |
971 |
X register COLR *sp; |
972 |
X /* get scanline buffer */ |
973 |
X if ((sp = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL) |
974 |
X return(-1); |
975 |
X clrscan = sp; |
976 |
X /* convert scanline */ |
977 |
X n = len; |
978 |
X while (n-- > 0) { |
979 |
X setcolr(sp[0], scanline[0][RED], |
980 |
X scanline[0][GRN], |
981 |
X scanline[0][BLU]); |
982 |
X scanline++; |
983 |
X sp++; |
984 |
X } |
985 |
X return(fwritecolrs(clrscan, len, fp)); |
986 |
X} |
987 |
X |
988 |
X |
989 |
Xfreadscan(scanline, len, fp) /* read in a scanline */ |
990 |
991 |
Xint len; |
992 |
XFILE *fp; |
993 |
X{ |
994 |
X register COLR *clrscan; |
995 |
X |
996 |
X if ((clrscan = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL) |
997 |
X return(-1); |
998 |
X if (freadcolrs(clrscan, len, fp) < 0) |
999 |
X return(-1); |
1000 |
1001 |
X colr_color(scanline[0], clrscan[0]); |
1002 |
X while (--len > 0) { |
1003 |
X scanline++; clrscan++; |
1004 |
X if (clrscan[0][RED] == clrscan[-1][RED] && |
1005 |
X clrscan[0][GRN] == clrscan[-1][GRN] && |
1006 |
X clrscan[0][BLU] == clrscan[-1][BLU] && |
1007 |
X clrscan[0][EXP] == clrscan[-1][EXP]) |
1008 |
X copycolor(scanline[0], scanline[-1]); |
1009 |
X else |
1010 |
1011 |
X } |
1012 |
X return(0); |
1013 |
X} |
1014 |
X |
1015 |
X |
1016 |
Xsetcolr(clr, r, g, b) /* assign a short color value */ |
1017 |
Xregister COLR clr; |
1018 |
Xdouble r, g, b; |
1019 |
X{ |
1020 |
X double d; |
1021 |
X int e; |
1022 |
X |
1023 |
X d = r > g ? r : g; |
1024 |
X if (b > d) d = b; |
1025 |
X |
1026 |
X if (d <= 1e-32) { |
1027 |
X clr[RED] = clr[GRN] = clr[BLU] = 0; |
1028 |
X clr[EXP] = 0; |
1029 |
X return; |
1030 |
X } |
1031 |
X |
1032 |
X d = frexp(d, &e) * 255.9999 / d; |
1033 |
X |
1034 |
X clr[RED] = r * d; |
1035 |
X clr[GRN] = g * d; |
1036 |
X clr[BLU] = b * d; |
1037 |
X clr[EXP] = e + COLXS; |
1038 |
X} |
1039 |
X |
1040 |
X |
1041 |
Xcolr_color(col, clr) /* convert short to float color */ |
1042 |
Xregister COLOR col; |
1043 |
1044 |
X{ |
1045 |
X double f; |
1046 |
X |
1047 |
X if (clr[EXP] == 0) |
1048 |
X col[RED] = col[GRN] = col[BLU] = 0.0; |
1049 |
X else { |
1050 |
X f = ldexp(1.0, (int)clr[EXP]-(COLXS+8)); |
1051 |
X col[RED] = (clr[RED] + 0.5)*f; |
1052 |
X col[GRN] = (clr[GRN] + 0.5)*f; |
1053 |
X col[BLU] = (clr[BLU] + 0.5)*f; |
1054 |
X } |
1055 |
X} |
1056 |
X |
1057 |
X |
1058 |
Xbigdiff(c1, c2, md) /* c1 delta c2 > md? */ |
1059 |
Xregister COLOR c1, c2; |
1060 |
Xdouble md; |
1061 |
X{ |
1062 |
X register int i; |
1063 |
X |
1064 |
X for (i = 0; i < 3; i++) |
1065 |
X if (colval(c1,i)-colval(c2,i) > md*colval(c2,i) || |
1066 |
X colval(c2,i)-colval(c1,i) > md*colval(c1,i)) |
1067 |
X return(1); |
1068 |
X return(0); |
1069 |
X} |
1070 |
SHAR_EOF |
1071 |
fi |
1072 |
if test -f 'colrops.c' |
1073 |
then |
1074 |
echo shar: "will not over-write existing file 'colrops.c'" |
1075 |
else |
1076 |
sed 's/^X//' << \SHAR_EOF > 'colrops.c' |
1077 |
X/* Copyright (c) 1992 Regents of the University of California */ |
1078 |
X |
1079 |
X#ifndef lint |
1080 |
Xstatic char SCCSid[] = "@(#)colrops.c 2.4 10/2/92 LBL"; |
1081 |
X#endif |
1082 |
X |
1083 |
X/* |
1084 |
X * Integer operations on COLR scanlines |
1085 |
X */ |
1086 |
X |
1087 |
1088 |
X |
1089 |
X#define NULL 0 |
1090 |
X |
1091 |
Xextern char *bmalloc(); |
1092 |
X |
1093 |
X#define MAXGSHIFT 31 /* maximum shift for gamma table */ |
1094 |
X |
1095 |
Xstatic BYTE *g_mant = NULL, *g_nexp = NULL; |
1096 |
X |
1097 |
Xstatic BYTE (*g_bval)[256] = NULL; |
1098 |
X |
1099 |
X#ifndef pow |
1100 |
Xextern double pow(); |
1101 |
X#endif |
1102 |
X |
1103 |
X |
1104 |
Xsetcolrcor(f, a2) /* set brightness correction */ |
1105 |
Xdouble (*f)(); |
1106 |
Xdouble a2; |
1107 |
X{ |
1108 |
X double mult; |
1109 |
1110 |
X /* allocate tables */ |
1111 |
X if (g_bval == NULL && (g_bval = |
1112 |
X (BYTE (*)[256])bmalloc((MAXGSHIFT+1)*256)) == NULL) |
1113 |
X return(-1); |
1114 |
X /* compute colr -> gamb mapping */ |
1115 |
X mult = 1.0/256.0; |
1116 |
X for (i = 0; i <= MAXGSHIFT; i++) { |
1117 |
X for (j = 0; j < 256; j++) |
1118 |
X g_bval[i][j] = 256.0 * (*f)((j+.5)*mult, a2); |
1119 |
X mult *= 0.5; |
1120 |
X } |
1121 |
X return(0); |
1122 |
X} |
1123 |
X |
1124 |
X |
1125 |
Xsetcolrinv(f, a2) /* set inverse brightness correction */ |
1126 |
Xdouble (*f)(); |
1127 |
Xdouble a2; |
1128 |
X{ |
1129 |
X double mult; |
1130 |
1131 |
1132 |
X if (g_mant == NULL && (g_mant = (BYTE *)bmalloc(256)) == NULL) |
1133 |
X return(-1); |
1134 |
X if (g_nexp == NULL && (g_nexp = (BYTE *)bmalloc(256)) == NULL) |
1135 |
X return(-1); |
1136 |
X /* compute gamb -> colr mapping */ |
1137 |
X i = 0; |
1138 |
X mult = 256.0; |
1139 |
X for (j = 255; j > 0; j--) { |
1140 |
X while ((g_mant[j] = mult * (*f)(j/256.0, a2)) < 128) { |
1141 |
X i++; |
1142 |
X mult *= 2.0; |
1143 |
X } |
1144 |
X g_nexp[j] = i; |
1145 |
X } |
1146 |
X g_mant[0] = 0; |
1147 |
X g_nexp[0] = COLXS; |
1148 |
X return(0); |
1149 |
X} |
1150 |
X |
1151 |
X |
1152 |
Xsetcolrgam(g) /* set gamma conversion */ |
1153 |
Xdouble g; |
1154 |
X{ |
1155 |
X if (setcolrcor(pow, 1.0/g) < 0) |
1156 |
X return(-1); |
1157 |
X return(setcolrinv(pow, g)); |
1158 |
X} |
1159 |
X |
1160 |
X |
1161 |
Xcolrs_gambs(scan, len) /* convert scanline of colrs to gamma bytes */ |
1162 |
Xregister COLR *scan; |
1163 |
Xint len; |
1164 |
X{ |
1165 |
X register int i, expo; |
1166 |
X |
1167 |
X if (g_bval == NULL) |
1168 |
X return(-1); |
1169 |
X while (len-- > 0) { |
1170 |
X expo = scan[0][EXP] - COLXS; |
1171 |
X if (expo < -MAXGSHIFT) { |
1172 |
X if (expo < -MAXGSHIFT-8) { |
1173 |
X scan[0][RED] = |
1174 |
X scan[0][GRN] = |
1175 |
X scan[0][BLU] = 0; |
1176 |
X } else { |
1177 |
X i = (-MAXGSHIFT-1) - expo; |
1178 |
X scan[0][RED] = |
1179 |
X g_bval[MAXGSHIFT][((scan[0][RED]>>i)+1)>>1]; |
1180 |
X scan[0][GRN] = |
1181 |
X g_bval[MAXGSHIFT][((scan[0][GRN]>>i)+1)>>1]; |
1182 |
X scan[0][BLU] = |
1183 |
X g_bval[MAXGSHIFT][((scan[0][BLU]>>i)+1)>>1]; |
1184 |
X } |
1185 |
X } else if (expo > 0) { |
1186 |
X if (expo > 8) { |
1187 |
X scan[0][RED] = |
1188 |
X scan[0][GRN] = |
1189 |
X scan[0][BLU] = 255; |
1190 |
X } else { |
1191 |
X i = (scan[0][RED]<<1 | 1) << (expo-1); |
1192 |
X scan[0][RED] = i > 255 ? 255 : g_bval[0][i]; |
1193 |
X i = (scan[0][GRN]<<1 | 1) << (expo-1); |
1194 |
X scan[0][GRN] = i > 255 ? 255 : g_bval[0][i]; |
1195 |
X i = (scan[0][BLU]<<1 | 1) << (expo-1); |
1196 |
X scan[0][BLU] = i > 255 ? 255 : g_bval[0][i]; |
1197 |
X } |
1198 |
X } else { |
1199 |
X scan[0][RED] = g_bval[-expo][scan[0][RED]]; |
1200 |
X scan[0][GRN] = g_bval[-expo][scan[0][GRN]]; |
1201 |
X scan[0][BLU] = g_bval[-expo][scan[0][BLU]]; |
1202 |
X } |
1203 |
X scan[0][EXP] = COLXS; |
1204 |
X scan++; |
1205 |
X } |
1206 |
X return(0); |
1207 |
X} |
1208 |
X |
1209 |
X |
1210 |
Xgambs_colrs(scan, len) /* convert gamma bytes to colr scanline */ |
1211 |
1212 |
Xint len; |
1213 |
X{ |
1214 |
X register int nexpo; |
1215 |
X |
1216 |
X if (g_mant == NULL | g_nexp == NULL) |
1217 |
X return(-1); |
1218 |
1219 |
X nexpo = g_nexp[scan[0][RED]]; |
1220 |
X if (g_nexp[scan[0][GRN]] < nexpo) |
1221 |
X nexpo = g_nexp[scan[0][GRN]]; |
1222 |
X if (g_nexp[scan[0][BLU]] < nexpo) |
1223 |
X nexpo = g_nexp[scan[0][BLU]]; |
1224 |
X if (nexpo < g_nexp[scan[0][RED]]) |
1225 |
X scan[0][RED] = g_mant[scan[0][RED]] |
1226 |
X >> (g_nexp[scan[0][RED]]-nexpo); |
1227 |
X else |
1228 |
X scan[0][RED] = g_mant[scan[0][RED]]; |
1229 |
X if (nexpo < g_nexp[scan[0][GRN]]) |
1230 |
X scan[0][GRN] = g_mant[scan[0][GRN]] |
1231 |
X >> (g_nexp[scan[0][GRN]]-nexpo); |
1232 |
X else |
1233 |
X scan[0][GRN] = g_mant[scan[0][GRN]]; |
1234 |
X if (nexpo < g_nexp[scan[0][BLU]]) |
1235 |
X scan[0][BLU] = g_mant[scan[0][BLU]] |
1236 |
X >> (g_nexp[scan[0][BLU]]-nexpo); |
1237 |
X else |
1238 |
X scan[0][BLU] = g_mant[scan[0][BLU]]; |
1239 |
X scan[0][EXP] = COLXS - nexpo; |
1240 |
X scan++; |
1241 |
X } |
1242 |
X return(0); |
1243 |
X} |
1244 |
X |
1245 |
X |
1246 |
Xshiftcolrs(scan, len, adjust) /* shift a scanline of colors by 2^adjust */ |
1247 |
1248 |
Xregister int len; |
1249 |
Xregister int adjust; |
1250 |
X{ |
1251 |
X int minexp; |
1252 |
X |
1253 |
X if (adjust == 0) |
1254 |
X return; |
1255 |
X minexp = adjust < 0 ? -adjust : 0; |
1256 |
1257 |
X if (scan[0][EXP] <= minexp) |
1258 |
X scan[0][RED] = scan[0][GRN] = scan[0][BLU] = |
1259 |
X scan[0][EXP] = 0; |
1260 |
X else |
1261 |
X scan[0][EXP] += adjust; |
1262 |
X scan++; |
1263 |
X } |
1264 |
X} |
1265 |
X |
1266 |
X |
1267 |
Xnormcolrs(scan, len, adjust) /* normalize a scanline of colrs */ |
1268 |
1269 |
Xint len; |
1270 |
Xint adjust; |
1271 |
X{ |
1272 |
X register int c; |
1273 |
X register int shift; |
1274 |
X |
1275 |
1276 |
X shift = scan[0][EXP] + adjust - COLXS; |
1277 |
X if (shift > 0) { |
1278 |
X if (shift > 8) { |
1279 |
X scan[0][RED] = |
1280 |
X scan[0][GRN] = |
1281 |
1282 |
X } else { |
1283 |
X shift--; |
1284 |
X c = (scan[0][RED]<<1 | 1) << shift; |
1285 |
X scan[0][RED] = c > 255 ? 255 : c; |
1286 |
X c = (scan[0][GRN]<<1 | 1) << shift; |
1287 |
X scan[0][GRN] = c > 255 ? 255 : c; |
1288 |
X c = (scan[0][BLU]<<1 | 1) << shift; |
1289 |
X scan[0][BLU] = c > 255 ? 255 : c; |
1290 |
X } |
1291 |
X } else if (shift < 0) { |
1292 |
X if (shift < -8) { |
1293 |
X scan[0][RED] = |
1294 |
X scan[0][GRN] = |
1295 |
1296 |
X } else { |
1297 |
X shift = -1-shift; |
1298 |
X scan[0][RED] = ((scan[0][RED]>>shift)+1)>>1; |
1299 |
X scan[0][GRN] = ((scan[0][GRN]>>shift)+1)>>1; |
1300 |
X scan[0][BLU] = ((scan[0][BLU]>>shift)+1)>>1; |
1301 |
X } |
1302 |
X } |
1303 |
X scan[0][EXP] = COLXS - adjust; |
1304 |
X scan++; |
1305 |
X } |
1306 |
X} |
1307 |
SHAR_EOF |
1308 |
fi |
1309 |
exit 0 |
1310 |
# End of shell archive |
