root/Development/ray/doc/notes/parallel.txt
Revision: 1.1
Committed: Sat Mar 15 17:32:55 2003 UTC (22 years, 9 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6, rad3R5, HEAD
1 Parallel Rendering on the ICSD SPARC-10's
2
3 Greg Ward
4 Energy and Environment Division
5
6
7 The Information and Computing Services Division was kind
8 enough to make 10 Sun SPARC-10's available on the network
9 for enterprising individuals who wished to perform experi-
10 ments in distributed parallel processing. This article
11 describes the method we developed to efficiently run an
12 incompletely parallelizable rendering program in a distri-
13 buted processing environment.
14
15 The lighting simulation and rendering software we have
16 developed over the past 8 years, Radiance, has only recently
17 been made to work in parallel environments. Although paral-
18 lel ray tracing programs have been kicking around the graph-
19 ics community for several years, Radiance uses a modified
20 ray tracing algorithm that does not adapt as readily to a
21 parallel implementation. The main difference is that Radi-
22 ance produces illumination information that is globally
23 reused during the rendering of an image. Thus, spawning
24 disjoint processes to work on disjoint parts of an image
25 will not result in the linear speedup desired. Each
26 independent process would create its own set of "indirect
27 irradiance" values for its section of the image, and many of
28 these values would be redundant and would represent wasted
29 CPU time. It is therefore essential that this information
30 be shared among different processes working on the same
31 scene. The question is, how to do it?
32
33 To minimize incompatibilities with different UNIX implemen-
34 tations, we decided early on in our parallel rendering work
35 to rely on the Network File System (NFS) only, imperfect as
36 it is. The chief feature that enables us to do parallel
37 rendering is NFS file locking, which is supported by most
38 current UNIX implementations. File locking allows a process
39 on the same machine or a different machine to restrict
40 access on any section of an open file that resides either
41 locally or on an NFS-mounted filesystem. Thus, data-sharing
42 is handled through the contents of an ordinary file and
43 coordinated by the network lock manager. This method can be
44 slow in states of high contention, therefore access fre-
45 quency must be kept low.
46
47 In this article, we will refer to processes rather than
48 machines because the methods presented work both in cases of
49 multiple processors on a single machine and multiple
50 machines distributed over a network.
51
52 The method we adopted for sharing our indirect irradiance
53 values is simple. Each process caches together a small
54 number of values (on the order of 16 -- enough to fill a
55 standard UNIX buffer) before appending these to a file. In
56 preparation for writing out its buffer, the process places
57 an exclusive lock on the file, then checks to see if it has
58 grown since the last time. If it has, the process reads in
59 the new information, assuming it has come from another pro-
60 cess that is legitimately working on this file. Finally,
61 the process flushes its buffer and releases the lock on the
62 file. The file thus contains the cumulative indirect irra-
63 diance calculations of all the processes, and every process
64 has this information stored also in memory (up until the
65 last time it flushed its buffer). Saving the information to
66 a file has the further advantage of providing a convenient
67 way to reuse the data for later renderings.
68
69 The image to be rendered is divided into many small pieces,
70 more pieces than there are processors. This way, if one
71 piece takes longer than the others, the processors that had
72 easy pieces are not all waiting for the processor with the
73 difficult piece to finish. Coordination between processes
74 is again handled by the network lock manager. A file con-
75 tains the position of the last piece being worked on, and as
76 soon as a processor finishes its piece, it locks the file,
77 finds out what to work on next, increments the position and
78 unlocks the file again. Thus, there is no need for a single
79 controlling process, and rendering processes may be ini-
80 tiated and terminated at will.
81
82 ICSD's offer to use their farm of SPARC-10's was an ideal
83 opportunity to test our programs under real conditions. The
84 problem at hand was producing numerically accurate, high-
85 resolution renderings of the lower deck of a ship under dif-
86 ferent lighting conditions. Three images were rendered one
87 at a time, with all 10 SPARC-10 machines working on each
88 image simultaneously. The wall time required to render one
89 image was about 4.3 hours. The first machine finished with
90 all it could do shortly after the last image piece was
91 assigned at 2.8 hours. Thus, many of the processors in our
92 test run were done before the entire image was complete.
93 This is a problem of not breaking the image into small
94 enough pieces for efficient processor allocation.
95
96 For the time that the processors were running, all but one
97 had 98% or 99% CPU utilization. The one exception was the
98 file server, which had 94% CPU utilization. This means that
99 the processors were well saturated while working on our job,
100 not waiting for image piece assignments, disk access, etc.
101
102 If we include the time at the end when some processors had
103 finished while others were still going, the effective CPU
104 utilization averaged 84%, with the lowest at 75%. Again,
105 this low figure was due to the fact that the picture should
106 have been divided into more than the 49 pieces we specified.
107 (The overall utilization was really better than this, since
108 we set the jobs up to run one after the other and once a
109 processor finished its part on one image it went on to work
110 on the next image.)
111
112 The real proof of a parallel implementation is not CPU util-
113 ization, however, it is the speedup factor. To examine
114 this, it was necessary to start the job over, running on a
115 single processor. Running alone, one SPARC-10 took about 35
116 hours to finish an image, with 99% CPU utilization. That is
117 about 8.2 times as long as the total time required by 10
118 processors to finish the image (due mostly to idle proces-
119 sors at the end). This ratio, 8.2/10, is very close to the
120 average effective CPU utilization value of 84%, indicating
121 that parallel processing does not result in a lot of redun-
122 dant calculation.
123
124 Our experience showed that an incompletely parallelizable
125 problem could be solved efficiently on distributed proces-
126 sors using NFS as a data sharing mechanism. The principle
127 lesson we learned from this exercise is that good utiliza-
128 tion of multiple processors requires that the job be broken
129 into small enough chunks. It is perhaps significant that
130 the time spent idle, 16%, corresponds roughly to the percen-
131 tage of the total time required by a processor to finish one
132 piece (since there were about 5 chunks for each processor).
133 If we were to decrease the size of the pieces so that each
134 processor got 20 pieces on average, we should expect the
135 idle time to go down to around 5%.
