root/radiance/ray/doc/notes/gamma_corr
Revision: 1.1
Committed: Sat Mar 15 17:32:55 2003 UTC (21 years, 1 month ago) by greg
1 SETTING GAMMA FOR A SPECIFIC MONITOR
2
3 Gamma correction is a crude way of compensating for the nonlinear
4 response function of a display device. Most CRT monitors roughly follow
5 a power law in their response function, ie:
6
7 output luminance = signal ^ gamma
8
9 where gamma is typically between 1.5 and 3. Some system software
10 attempts to partially compensate for this natural response function, but
11 usually does not completely eliminate it (which would have other
12 undesirable effects).
13
14 Most of the Radiance display drivers look at an environment variable
15 called "DISPLAY_GAMMA" to determine how to set the gamma correction for the
16 current monitor. Many programs also have a -g option for setting the
17 gamma value explicitly, but the environment variable is the only way to
18 control gamma correction for rview, for example.
19
20 To determine the approximate gamma for your monitor, display of the
21 distributed picture file ray/lib/lib/gamma.pic like so:
22
23 % ximage -g 1 -b ray/lib/lib/gamma.pic &
24
25 Note that the gamma here has been explicitly set to 1, effectively
26 turning gamma correction off for this test.
27
28 Now, set the contrast and brightness controls on the monitor to what you
29 would consider your normal settings. Stand back from the monitor a bit
30 and try to match up the average brightness of the stripes on the left of
31 the image with a patch on the right of the image. This will be the
32 gamma value for this monitor.
33
34 All that's left to do is to put a line of the form:
35
36 setenv DISPLAY_GAMMA 2.2
37
38 in your .login or .cshrc file for C-shell users, or:
39
40 DISPLAY_GAMMA=2.2
41 export DISPLAY_GAMMA
42
43 in your .profile for Bourne shell users. You may also use a more
44 complicated setting for different monitors if you use many displays, eg:
45
46 if ( $?DISPLAY && ! $?DISPLAY_GAMMA ) then
47 switch ($DISPLAY)
48 case pink*:
49 case floyd*:
50 setenv DISPLAY_GAMMA 1.8
51 breaksw
52 case hobbes*:
53 case demo460*:
54 setenv DISPLAY_GAMMA 2.6
55 breaksw
56 case wimsey*:
57 setenv DISPLAY_GAMMA 1.7
58 breaksw
59 endsw
60 endif
