root/radiance/ray/doc/notes/compile_switches
Revision: 1.6
Committed: Mon Sep 19 15:27:19 2005 UTC (18 years, 2 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R1, rad4R0, rad3R8, rad3R9, rad4R2P1
Changes since 1.5: +3 -6 lines
Minor corrections to description of -DAVGREFL & changed -DALIGN to -DALIGNT
# User Rev Content
1 greg 1.1 Here is a list of compile switches, used to customize Radiance code
2     for specific machines and users:
3
4 greg 1.6 -DALIGNT=(type) Alignment type, machine-dependent. Most RISC
5 greg 1.1 architectures align on 8-word boundaries (double).
6     The default alignment type is int.
7
8 greg 1.2 -DWFLUSH=(rays) Override for number of rays before flush in rvu.
9 greg 1.1
10 greg 1.6 -DBSD Operating system has a strong Berkeley flavor, which
11 schorsch 1.5 affects certain system calls, such as signal handling and
12     resource tracking.
13 greg 1.1
14 greg 1.2 -DSMLMEM The system has little RAM available, so size hash
15     tables and the like accordingly. Only allows for
16     small scene descriptions (32,256 primitives).
17 greg 1.1
18     -DSMLFLT This setting tells Radiance to use short floats
19 greg 1.2 (32 bits) throughout, which saves lots of memory
20 greg 1.1 but can cause calculation inaccuracies in many
21     cases. Its use has been discontinued for this reason.
22 greg 1.2
23     -DSHADCACHE=N The array size to use for caching occluders.
24     Setting this to 0 turns off this optimization.
25     Values greater than 20 use over 4 Kbytes per
26     light source, which can add up to a lot of
27     memory in scenes with many sources.
28 greg 1.3
29     -DAVGREFL=R Set the average surface reflectance for the purpose
30     of indirect irradiance calculations to R, where
31     R is a real number in the range (0,1.0). The
32 greg 1.6 default value is 0.50 (50%).
