root/radiance/ray/doc/notes/compile_switches
Tue May 31 10:31:42 2016 UTC (9 years, 1 month ago) by rschregle
CVS Tags: HEAD, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Diff to previous 1.7
Minor corrections to compile_switches
Mon May 30 12:21:56 2016 UTC (9 years, 1 month ago) by rschregle
Changes since 1.6: +55 -0 lines
Diff to previous 1.6
Documented PMAP options in compile_switches
Mon Sep 19 15:27:19 2005 UTC (19 years, 10 months ago) by greg
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Changes since 1.5: +3 -6 lines
Diff to previous 1.5
Minor corrections to description of -DAVGREFL & changed -DALIGN to -DALIGNT
Mon Sep 19 11:35:38 2005 UTC (19 years, 10 months ago) by schorsch
Changes since 1.4: +3 -12 lines
Diff to previous 1.4
Updated notes about eliminated and changed compile options.
Mon Jun 13 20:07:56 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.3: +0 -5 lines
Diff to previous 1.3
Wed Feb 23 18:24:00 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.2: +8 -0 lines
Diff to previous 1.2
Added ability to redefine AVGREFL with a compile switch
Thu Jan 1 19:31:45 2004 UTC (21 years, 6 months ago) by greg
Changes since 1.1: +12 -7 lines
Diff to previous 1.1
Sat Mar 15 17:32:55 2003 UTC (22 years, 4 months ago) by greg
