| 1 |
Here is a list of compile switches, used to customize Radiance code
| 2 |
for specific machines and users:
| 3 |
| 4 |
-DALIGNT=(type) Alignment type, machine-dependent. Most RISC
| 5 |
architectures align on 8-word boundaries (double).
| 6 |
The default alignment type is int.
| 7 |
| 8 |
-DWFLUSH=(rays) Override for number of rays before flush in rvu.
| 9 |
| 10 |
-DBSD Operating system has a strong Berkeley flavor, which
| 11 |
affects certain system calls, such as signal handling and
| 12 |
resource tracking.
| 13 |
| 14 |
-DSMLMEM The system has little RAM available, so size hash
| 15 |
tables and the like accordingly. Only allows for
| 16 |
small scene descriptions (32,256 primitives).
| 17 |
| 18 |
-DSMLFLT This setting tells Radiance to use short floats
| 19 |
(32 bits) throughout, which saves lots of memory
| 20 |
but can cause calculation inaccuracies in many
| 21 |
cases. Its use has been discontinued for this reason.
| 22 |
| 23 |
-DSHADCACHE=N The array size to use for caching occluders.
| 24 |
Setting this to 0 turns off this optimization.
| 25 |
Values greater than 20 use over 4 Kbytes per
| 26 |
light source, which can add up to a lot of
| 27 |
memory in scenes with many sources.
| 28 |
| 29 |
-DAVGREFL=R Set the average surface reflectance for the purpose
| 30 |
of indirect irradiance calculations to R, where
| 31 |
R is a real number in the range (0,1.0). The
| 32 |
default value is 0.50 (50%).
| 33 |
| 34 |
-DPMAP_OOC Builds the out-of-core photon map. The photon data resides
| 35 |
in a leaf file on disk with suffix ".leaf" and is loaded on
| 36 |
demand. This is intended for very large photon maps (up to
| 37 |
4.3 billion photons) particularly for annual simulations
| 38 |
with rcontrib. This switch is disabled by default, which
| 39 |
builds the in-core photon map used in previous releases;
| 40 |
this resides entirely in main memory. These options are
| 41 |
mutually exclusive, and the resulting photon map files are
| 42 |
incompatible.
| 43 |
| 44 |
-DPMAP_PRIMARYPOS
| 45 |
Stores photon primary hitpoints for binning using the -f
| 46 |
option with rcontrib if the function file requires them.
| 47 |
This consumes an additional 3 floats and is disabled per
| 48 |
default to reduce the size of the resulting photon maps.
| 49 |
| 50 |
-DPMAP_FLOAT_FLUX
| 51 |
Stores photon flux as floats instead of more compact RGBE
| 52 |
(the default). In terms of accuracy, the difference would
| 53 |
only be noticeable with highly saturated colours.
| 54 |
| 55 |
-DPMAP_ROI Enables the -api option to mkpmap. This constrains photon
| 56 |
deposition only to the specified region of interest (defined
| 57 |
as a bounding volume) for situations where it is known a
| 58 |
priori that photon map lookups will occur outside this
| 59 |
region. This is disabled per default as it can lead to
| 60 |
biased results outside the ROI, or near its boundaries. Ziss
| 61 |
option for ze eckspertz only!
| 62 |
| 63 |
-DPMAP_RUNAWAY_WARN
| 64 |
Causes mkpmap to issue a warning if a photon reaches the
| 65 |
maximum number of bounces (as specified with -apm) and is
| 66 |
terminated.
| 67 |
| 68 |
-DPMAP_LOOKUP_WARN
| 69 |
Causes rtrace et al to issue warnings when short photon
| 70 |
lookups occur, i.e. fewer photons are found than specified
| 71 |
as lookup bandwidth with -ap. This is generally not fatal,
| 72 |
but can increase noise, and may indicate a higher bandwidth
| 73 |
is needed. This is disabled per default as it can result in
| 74 |
excessive console clutter.
| 75 |
| 76 |
-DPMAP_LOOKUP_REDO
| 77 |
Causes rtrace et al to repeat short photon map
| 78 |
lookups with a progressively larger radius until the
| 79 |
target photon count specified with -ap is met. This switch
| 80 |
has no effect in conjunction with the -am option, since this
| 81 |
disables lookup radius adaptation.
| 82 |
| 83 |
-DPMAP_EPANECHNIKOV
| 84 |
Causes rtrace et al to apply an Epanechnikov filter during
| 85 |
photon density estimates. This weights photons according to
| 86 |
the inverse distance to the lookup point in order to reduce
| 87 |
bias. The default behaviour does not perform filtering.
