--- ray/doc/notes/compile_switches 2016/05/30 12:21:56 1.7 +++ ray/doc/notes/compile_switches 2016/05/31 10:31:42 1.8 @@ -55,7 +55,7 @@ for specific machines and users: -DPMAP_ROI Enables the -api option to mkpmap. This constrains photon deposition only to the specified region of interest (defined as a bounding volume) for situations where it is known a - priori that photon map lookups will occur outside this + priori that photon map lookups will only occur inside this region. This is disabled per default as it can lead to biased results outside the ROI, or near its boundaries. Ziss option for ze eckspertz only!
