--- ray/doc/notes/compile_switches 2005/09/19 11:35:38 1.5 +++ ray/doc/notes/compile_switches 2016/05/30 12:21:56 1.7 @@ -1,13 +1,13 @@ Here is a list of compile switches, used to customize Radiance code for specific machines and users: --DALIGN=(type) Alignment type, machine-dependent. Most RISC +-DALIGNT=(type) Alignment type, machine-dependent. Most RISC architectures align on 8-word boundaries (double). The default alignment type is int. -DWFLUSH=(rays) Override for number of rays before flush in rvu. --DBSD Operating system has a strong Berkeley flavor, which +-DBSD Operating system has a strong Berkeley flavor, which affects certain system calls, such as signal handling and resource tracking. @@ -29,7 +29,59 @@ for specific machines and users: -DAVGREFL=R Set the average surface reflectance for the purpose of indirect irradiance calculations to R, where R is a real number in the range (0,1.0). The - default value is 0.50 (50%). This value indirectly - controls the maximum number of ambient bounces, - which can never be more than the log of the -ad - setting times the log of AVGREFL. + default value is 0.50 (50%). + +-DPMAP_OOC Builds the out-of-core photon map. The photon data resides + in a leaf file on disk with suffix ".leaf" and is loaded on + demand. This is intended for very large photon maps (up to + 4.3 billion photons) particularly for annual simulations + with rcontrib. This switch is disabled by default, which + builds the in-core photon map used in previous releases; + this resides entirely in main memory. These options are + mutually exclusive, and the resulting photon map files are + incompatible. + +-DPMAP_PRIMARYPOS + Stores photon primary hitpoints for binning using the -f + option with rcontrib if the function file requires them. + This consumes an additional 3 floats and is disabled per + default to reduce the size of the resulting photon maps. + +-DPMAP_FLOAT_FLUX + Stores photon flux as floats instead of more compact RGBE + (the default). In terms of accuracy, the difference would + only be noticeable with highly saturated colours. + +-DPMAP_ROI Enables the -api option to mkpmap. This constrains photon + deposition only to the specified region of interest (defined + as a bounding volume) for situations where it is known a + priori that photon map lookups will occur outside this + region. This is disabled per default as it can lead to + biased results outside the ROI, or near its boundaries. Ziss + option for ze eckspertz only! + +-DPMAP_RUNAWAY_WARN + Causes mkpmap to issue a warning if a photon reaches the + maximum number of bounces (as specified with -apm) and is + terminated. + +-DPMAP_LOOKUP_WARN + Causes rtrace et al to issue warnings when short photon + lookups occur, i.e. fewer photons are found than specified + as lookup bandwidth with -ap. This is generally not fatal, + but can increase noise, and may indicate a higher bandwidth + is needed. This is disabled per default as it can result in + excessive console clutter. + +-DPMAP_LOOKUP_REDO + Causes rtrace et al to repeat short photon map + lookups with a progressively larger radius until the + target photon count specified with -ap is met. This switch + has no effect in conjunction with the -am option, since this + disables lookup radius adaptation. + +-DPMAP_EPANECHNIKOV + Causes rtrace et al to apply an Epanechnikov filter during + photon density estimates. This weights photons according to + the inverse distance to the lookup point in order to reduce + bias. The default behaviour does not perform filtering.
