1 |
Here is a list of compile switches, used to customize Radiance code |
2 |
for specific machines and users: |
3 |
4 |
-DMC If set, switches from default low-discrepency sequence |
5 |
sampling to true (pseudorandom) Monte Carlo. Use if |
6 |
the "brushed" appearance of specular highlights and |
7 |
penumbras bothers you. |
8 |
9 |
-DALIGN=(type) Alignment type, machine-dependent. Most RISC |
10 |
architectures align on 8-word boundaries (double). |
11 |
The default alignment type is int. |
12 |
13 |
-DSPEED=(MIPS) Millions of instructions per second for this |
14 |
processor (approximate). This is used to decide |
15 |
certain unimportant timing issues such as how many |
16 |
rays to trace before checking input in rvu and |
17 |
whether or not to optimize the color table in ximage |
18 |
on 8-bit displays. |
19 |
20 |
-DWFLUSH=(rays) Override for number of rays before flush in rvu. |
21 |
22 |
-DBSD Operating system has a strong Berkeley flavor, meaning |
23 |
that bcopy() and bzero() are present but maybe memcpy() |
24 |
and memset() are not. (See common/standard.h for other |
25 |
things this flag affects.) Also affects certain system |
26 |
calls, such as signal handling and resource tracking. |
27 |
28 |
-DSMLMEM The system has little RAM available, so size hash |
29 |
tables and the like accordingly. Only allows for |
30 |
small scene descriptions (32,256 primitives). |
31 |
32 |
-DSMLFLT This setting tells Radiance to use short floats |
33 |
(32 bits) throughout, which saves lots of memory |
34 |
but can cause calculation inaccuracies in many |
35 |
cases. Its use has been discontinued for this reason. |
36 |
37 |
-DSHADCACHE=N The array size to use for caching occluders. |
38 |
Setting this to 0 turns off this optimization. |
39 |
Values greater than 20 use over 4 Kbytes per |
40 |
light source, which can add up to a lot of |
41 |
memory in scenes with many sources. |
42 |
43 |
-DAVGREFL=R Set the average surface reflectance for the purpose |
44 |
of indirect irradiance calculations to R, where |
45 |
R is a real number in the range (0,1.0). The |
46 |
default value is 0.50 (50%). This value indirectly |
47 |
controls the maximum number of ambient bounces, |
48 |
which can never be more than the log of the -ad |
49 |
setting times the log of AVGREFL. |
