| 1 |
Here is a list of compile switches, used to customize Radiance code
| 2 |
for specific machines and users:
| 3 |
| 4 |
-DALIGN=(type) Alignment type, machine-dependent. Most RISC
| 5 |
architectures align on 8-word boundaries (double).
| 6 |
The default alignment type is int.
| 7 |
| 8 |
-DSPEED=(MIPS) Millions of instructions per second for this
| 9 |
processor (approximate). This is used to decide
| 10 |
certain unimportant timing issues such as how many
| 11 |
rays to trace before checking input in rvu and
| 12 |
whether or not to optimize the color table in ximage
| 13 |
on 8-bit displays.
| 14 |
| 15 |
-DWFLUSH=(rays) Override for number of rays before flush in rvu.
| 16 |
| 17 |
-DBSD Operating system has a strong Berkeley flavor, meaning
| 18 |
that bcopy() and bzero() are present but maybe memcpy()
| 19 |
and memset() are not. (See common/standard.h for other
| 20 |
things this flag affects.) Also affects certain system
| 21 |
calls, such as signal handling and resource tracking.
| 22 |
| 23 |
-DSMLMEM The system has little RAM available, so size hash
| 24 |
tables and the like accordingly. Only allows for
| 25 |
small scene descriptions (32,256 primitives).
| 26 |
| 27 |
-DSMLFLT This setting tells Radiance to use short floats
| 28 |
(32 bits) throughout, which saves lots of memory
| 29 |
but can cause calculation inaccuracies in many
| 30 |
cases. Its use has been discontinued for this reason.
| 31 |
| 32 |
-DSHADCACHE=N The array size to use for caching occluders.
| 33 |
Setting this to 0 turns off this optimization.
| 34 |
Values greater than 20 use over 4 Kbytes per
| 35 |
light source, which can add up to a lot of
| 36 |
memory in scenes with many sources.
| 37 |
| 38 |
-DAVGREFL=R Set the average surface reflectance for the purpose
| 39 |
of indirect irradiance calculations to R, where
| 40 |
R is a real number in the range (0,1.0). The
| 41 |
default value is 0.50 (50%). This value indirectly
| 42 |
controls the maximum number of ambient bounces,
| 43 |
which can never be more than the log of the -ad
| 44 |
setting times the log of AVGREFL.
