root/Development/ray/doc/notes/compile_switches
Revision: 1.8
Committed: Tue May 31 10:31:42 2016 UTC (9 years, 4 months ago) by rschregle
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R1, rad6R0, HEAD
Minor corrections to compile_switches
# User Rev Content
1 greg 1.1 Here is a list of compile switches, used to customize Radiance code
2     for specific machines and users:
3
4 greg 1.6 -DALIGNT=(type) Alignment type, machine-dependent. Most RISC
5 greg 1.1 architectures align on 8-word boundaries (double).
6     The default alignment type is int.
7
8 greg 1.2 -DWFLUSH=(rays) Override for number of rays before flush in rvu.
9 greg 1.1
10 greg 1.6 -DBSD Operating system has a strong Berkeley flavor, which
11 schorsch 1.5 affects certain system calls, such as signal handling and
12     resource tracking.
13 greg 1.1
14 greg 1.2 -DSMLMEM The system has little RAM available, so size hash
15     tables and the like accordingly. Only allows for
16     small scene descriptions (32,256 primitives).
17 greg 1.1
18     -DSMLFLT This setting tells Radiance to use short floats
19 greg 1.2 (32 bits) throughout, which saves lots of memory
20 greg 1.1 but can cause calculation inaccuracies in many
21     cases. Its use has been discontinued for this reason.
22 greg 1.2
23     -DSHADCACHE=N The array size to use for caching occluders.
24     Setting this to 0 turns off this optimization.
25     Values greater than 20 use over 4 Kbytes per
26     light source, which can add up to a lot of
27     memory in scenes with many sources.
28 greg 1.3
29     -DAVGREFL=R Set the average surface reflectance for the purpose
30     of indirect irradiance calculations to R, where
31     R is a real number in the range (0,1.0). The
32 greg 1.6 default value is 0.50 (50%).
33 rschregle 1.7
34     -DPMAP_OOC Builds the out-of-core photon map. The photon data resides
35     in a leaf file on disk with suffix ".leaf" and is loaded on
36     demand. This is intended for very large photon maps (up to
37     4.3 billion photons) particularly for annual simulations
38     with rcontrib. This switch is disabled by default, which
39     builds the in-core photon map used in previous releases;
40     this resides entirely in main memory. These options are
41     mutually exclusive, and the resulting photon map files are
42     incompatible.
43
44     -DPMAP_PRIMARYPOS
45     Stores photon primary hitpoints for binning using the -f
46     option with rcontrib if the function file requires them.
47     This consumes an additional 3 floats and is disabled per
48     default to reduce the size of the resulting photon maps.
49
50     -DPMAP_FLOAT_FLUX
51     Stores photon flux as floats instead of more compact RGBE
52     (the default). In terms of accuracy, the difference would
53     only be noticeable with highly saturated colours.
54
55     -DPMAP_ROI Enables the -api option to mkpmap. This constrains photon
56     deposition only to the specified region of interest (defined
57     as a bounding volume) for situations where it is known a
58 rschregle 1.8 priori that photon map lookups will only occur inside this
59 rschregle 1.7 region. This is disabled per default as it can lead to
60     biased results outside the ROI, or near its boundaries. Ziss
61     option for ze eckspertz only!
62
63     -DPMAP_RUNAWAY_WARN
64     Causes mkpmap to issue a warning if a photon reaches the
65     maximum number of bounces (as specified with -apm) and is
66     terminated.
67
68     -DPMAP_LOOKUP_WARN
69     Causes rtrace et al to issue warnings when short photon
70     lookups occur, i.e. fewer photons are found than specified
71     as lookup bandwidth with -ap. This is generally not fatal,
72     but can increase noise, and may indicate a higher bandwidth
73     is needed. This is disabled per default as it can result in
74     excessive console clutter.
75
76     -DPMAP_LOOKUP_REDO
77     Causes rtrace et al to repeat short photon map
78     lookups with a progressively larger radius until the
79     target photon count specified with -ap is met. This switch
80     has no effect in conjunction with the -am option, since this
81     disables lookup radius adaptation.
82
83     -DPMAP_EPANECHNIKOV
84     Causes rtrace et al to apply an Epanechnikov filter during
85     photon density estimates. This weights photons according to
86     the inverse distance to the lookup point in order to reduce
87     bias. The default behaviour does not perform filtering.
