| 1 |
| 2 |
Version 1.2 (Released 3/9/90)
| 3 |
| 4 |
Added a -p option to rpict and pfilt to set the pixel aspect ratio for
| 5 |
output. Instead of giving the absolute x and y resolutions, the user
| 6 |
now gives rpict and pfilt the maximum desired resolution for x and y
| 7 |
and the pixel aspect ratio is used along with the given view to
| 8 |
calculate appropriate values within this boundary. This makes for
| 9 |
much more natural view specifications. For example, for a 512x400
| 10 |
device with a pixel aspect ratio of 1.0, the pfilt command:
| 11 |
| 12 |
pfilt -x 512 -y 400 -p 1
| 13 |
| 14 |
will always produce the appropriate output, regardless of the aspect
| 15 |
ratio of the input picture. If necessary, the x or y output resolution
| 16 |
will be reduced to accommodate the device's resolution. A square image
| 17 |
would occupy a region of 400x400 pixels.
| 18 |
| 19 |
View shift and lift options were added to the list of standard view
| 20 |
parameters, for specifying views for panoramas and holograms.
| 21 |
| 22 |
Rview no longer takes options for x and y resolution, but instead
| 23 |
gets them from the device driver along with the pixel ratio. This
| 24 |
makes it much easier to change the view aspect ratio (with the vh
| 25 |
and vv parameters).
| 26 |
| 27 |
A -z option was added to rpict to write out the distances for each
| 28 |
pixel in an image. This may be useful for z-buffer operations, and
| 29 |
is used by the new program pinterp, described below.
| 30 |
| 31 |
A program called pinterp was added to the burgeoning list of
| 32 |
picture filters and converters. This program is designed primarily
| 33 |
to interpolate animated frames for walk-throughs of static scenes,
| 34 |
but it has a number of other useful functions besides. It takes as
| 35 |
its input one or more rendered pictures (with their corresponding z
| 36 |
value files) and desired viewpoint (hopefully not too far afield from
| 37 |
the given images). Pinterp then takes the input frames and moves the
| 38 |
pixels to their new computed location. Filling operations make sure
| 39 |
that the final image does not have large unpainted regions.
| 40 |
| 41 |
Added smoothing option to gensurf, using bilinear Phong surface normal
| 42 |
interpolation. Not perfect, but it's better than nothing and permits
| 43 |
the use of fewer polygons to represent smoothly curved surfaces.
| 44 |
| 45 |
| 46 |
Version 1.3 (Released 10/22/90)
| 47 |
| 48 |
Added conversion utility for IES (Illuminating Engineering Society) standard
| 49 |
format luminaire data. The translator, called ies2rad, takes any number
| 50 |
of luminaire data files and creates the necessary Radiance geometric
| 51 |
descriptions and data files and puts them in the specified library location.
| 52 |
A new data format was added to accommodate irregularly-spaced data points.
| 53 |
| 54 |
Added rview driver for NeWS for Sun and Silicon Graphics workstations.
| 55 |
This work was done by Isaac Kwo.
| 56 |
| 57 |
Fixed oconv for scenes with many overlapping instances (runs faster now).
| 58 |
| 59 |
Added consitency checks intended to detect stale octrees without restricting
| 60 |
changes to surface modifiers. (But you still can't change total number of
| 61 |
objects). Stale octrees caused some of the strangest behavior...
| 62 |
| 63 |
Finally broke down and wrote my own malloc(3) routines. There is a
| 64 |
CalTech module floating around Berkeley that caused a lot of trouble
| 65 |
for bmalloc(), resulting in about twice the needed memory use.
| 66 |
| 67 |
Added translator for Architrion. Arch2rad uses mapping rules to assign
| 68 |
materials to surfaces from input file. This is a general method (dreamed
| 69 |
up by Charles Ehrlich) that allows users to assign materials based on
| 70 |
whatever information is available from the CAD file. See the accompanying
| 71 |
description file on translators in the ray/doc/notes directory.
| 72 |
| 73 |
Added fisheye view types to rpict and rview, useful for looking at
| 74 |
entire scenes and for LEEP virtual reality wide field stereo viewer.
| 75 |
| 76 |
Wrote xshowtrace, a fun program for watching rays as they are being
| 77 |
traced on an X11 display.
| 78 |
| 79 |
Write ra_pr24 for converting between 24-bit Sun rasterfiles and
| 80 |
Radiance pictures. Perhaps this should be incorporated in ra_pr, as
| 81 |
ra_t8 and ra_t16 should be one program, but the algorithms and memory
| 82 |
requirements are totally different for colormapped images.
| 83 |
| 84 |
Added routines for performing 24-bit gamma correction in integer domain,
| 85 |
making programs like ra_pr24 and ra_t16 run faster.
| 86 |
| 87 |
| 88 |
Version 1.4 (Released early 1991?)
| 89 |
| 90 |
Fixed bug in IES translator that resulted in the incorrect
| 91 |
interpretation of type B photometric data. (1.3.1)
| 92 |
| 93 |
Added types for using BRDF data: plasfunc, metfunc, plasdata and metdata.
| 94 |
| 95 |
Added interpretation of source color to ies2rad and color corrective
| 96 |
filtering to pfilt. Reference file used by both is "lamp.tab" in
| 97 |
library directory.
| 98 |
| 99 |
Added picture flipping program, pflip, and pattern preprocessing script,
| 100 |
normpat.csh, to the px directory.
| 101 |
| 102 |
Fixed bug in ra_pr24 that caused the reversal of red and blue values.
| 103 |
New version accepts both RT_STANDARD and RT_FORMAT_RGB files but
| 104 |
produces only RT_STANDARD rasterfiles as output.
| 105 |
| 106 |
Added -m option to xform to change modifiers for surfaces.
| 107 |
| 108 |
Wrote replmarks program to replace markers in a Radiance scene file
| 109 |
for light sources or other objects.
| 110 |
| 111 |
Added global compilation script, makeall.
| 112 |
| 113 |
Fixed calculation of luminance in display programs and gensky to use
| 114 |
white light assumption.
| 115 |
| 116 |
Added options and features to pcomb.
| 117 |
| 118 |
Added FORMAT= line to all Radiance file headers for improved error
| 119 |
checking and clarity.
| 120 |
| 121 |
Added icon bitmaps for rview and x11image under X11 and fixed a bug
| 122 |
that caused x11image to ignore keyboard input.
| 123 |
| 124 |
****** COMPATIBILITY CHANGE ********
| 125 |
Added constant definitions to cal files using ':' instead of '='.
| 126 |
This makes for faster calculations since many more constant
| 127 |
expressions can be reduced at "compile" time.
| 128 |
| 129 |
Created glare calculation programs in util directory. Findglare locates
| 130 |
glare sources, xglaresrc circles sources on a displayed image, and
| 131 |
glarendx computes various glare indices.
| 132 |
| 133 |
| 134 |
Version 2.0 (Released 11/26/91)
| 135 |
| 136 |
Added -i option to renderers for computing irradiance rather than
| 137 |
radiance. Eliminated redundant -oI option from rtrace and added
| 138 |
-I option to replace old -oi. This hack ignores glass and similar
| 139 |
surfaces during the calculation.
| 140 |
| 141 |
Changed icon for x11image (renamed ximage) to miniature bitmap of
| 142 |
picture.
| 143 |
| 144 |
Fixed bug in xshowtrace that prevented it from working with twm.
| 145 |
| 146 |
Added memory recovery feature to rview so that when it refines
| 147 |
itself out of memory it doesn't quit but instead gives the user
| 148 |
a command line saying "out of memory:", which allows the output to
| 149 |
be written and so forth before quitting or restarting the image.
| 150 |
| 151 |
Added -g (gamma correction) option to pvalue.
| 152 |
| 153 |
Added the more general BRTDfunc for procedural definition of bidirectional
| 154 |
reflectance-transmittance distribution functions. Also added transfunc
| 155 |
and transdata types.
| 156 |
| 157 |
Changed trans types to modify the color of the transmitted specular
| 158 |
component.
| 159 |
| 160 |
Fixed a bug in ra_t16 introduced in the last change which caused
| 161 |
problems for the (default) 16-bit output mode.
| 162 |
| 163 |
Improved Monte Carlo sampling for penumbras (-dj) and ambient
| 164 |
super-samples (-as) using stratified random number sequence introduced
| 165 |
by Christophe Schlick at '91 Eurographics workshop on rendering.
| 166 |
| 167 |
Wrote falsecolor program to transform images to false color with
| 168 |
value labels.
| 169 |
| 170 |
Modified pcomb to allow different output sizes and access to local
| 171 |
pixel neighborhood for specialty filtering applications.
| 172 |
| 173 |
Made cone and sphere routines more forgiving of negative radii,
| 174 |
switching between inverted types as necessary and giving warning
| 175 |
messages instead of bombing. Cones with equal radii are now
| 176 |
silently converted into cylinders. Hopefully, these changes will
| 177 |
make writing Radiance scene file translators a little bit easier.
| 178 |
Unfortunately, we still bomb for zero-sized cones and spheres.
| 179 |
| 180 |
Wrote a program called getbbox that just computes the bounding box
| 181 |
for a set of Radiance scene files. It is basically a modified version
| 182 |
of oconv that doesn't store objects in memory and doesn't care about
| 183 |
undefined modifiers.
| 184 |
| 185 |
Added -a and -l options to pcompos and made both pcompos and pcomb
| 186 |
read from commands as well as files.
| 187 |
| 188 |
Substantially improved the accuracy and appearance of the interreflection
| 189 |
calculation by computing gradients at the same time as primary values and
| 190 |
then using a first order interpolation scheme. This affects the information
| 191 |
stored in ambient files, so old files will have to be thrown away.
| 192 |
| 193 |
Added secondary light sources from planar mirror, prismatic and
| 194 |
holographic surfaces. This created the new options -dr (direct relays)
| 195 |
and -dp (direct presample density) to the renderers. The document
| 196 |
secsrc.note describes this feature in greater detail.
| 197 |
| 198 |
Put many of the routines into a common library.
| 199 |
| 200 |
Wrote a replacement for makedist, called mkillum, which generates
| 201 |
light distribtuions and illum descriptions for windows, skylights,
| 202 |
etc. in a much more natural and automatic fashion.
| 203 |
| 204 |
Fixed long-standing bug in text routines which caused slanted text
| 205 |
to slant the wrong way!
| 206 |
| 207 |
Added -e option to ra_bn, ra_pr, ra_pr24, ra_t8 and ra_t16 programs
| 208 |
for faster and more convenient image conversion w/o using pfilt.
| 209 |
| 210 |
| 211 |
Finally added contexts to calcomp routines so identical names in
| 212 |
different function files no longer conflict. Loading of function
| 213 |
files also works automatically without those nasty "key" variables.
| 214 |
New context marks (backquote characters) appear in some local variables
| 215 |
defined in some of the cal files. This is inconsistent with older
| 216 |
versions, and must be changed back to and underscore or some other legal
| 217 |
character if these files are used by 1.4 and earlier.
| 218 |
| 219 |
Wrote ra_tiff program, using Sam Leffler's libtiff package to read
| 220 |
and write 24-bit TIFF images.
| 221 |
| 222 |
Wrote ra_ppm program to convert to and from Poskanzer Pixmaps.
| 223 |
| 224 |
| 225 |
Changed run-length encoding of Radiance pictures to gain better
| 226 |
compression. Routines can still read old format, but new ra_rgbe
| 227 |
program must be used to write convert images to a more generic format
| 228 |
that can be read by release 1.4 and earlier.
| 229 |
| 230 |
Defined U and V parameters in rayinit.cal for more convenient (and
| 231 |
sloppy) use of 2-dimensional textures and patterns on planar surfaces.
| 232 |
| 233 |
Beefed up lampcolor program to compute spectral radiance for diffuse
| 234 |
emitters. This was a previously a pain in the butt and a serious
| 235 |
source of error for scenes not modeled using IES data files.
| 236 |
| 237 |
Added version reporting to rpict, rtrace and rview. Use standalone
| 238 |
-version option.
| 239 |
| 240 |
Changed to quincunx initial sampling pattern in rpict. This should
| 241 |
reduce artifacts from adaptive image sampling at no added cost.
| 242 |
| 243 |
Added -rgb option to ra_pr24 to produce RT_FORMAT_RGB files.
| 244 |
| 245 |
Added -ds option to renderers to make source sampling more accurate
| 246 |
for large area sources. It is no longer necessary or recommended
| 247 |
to break large sources (such as windows) into smaller pieces with
| 248 |
gensurf unless their output distribution changes over their surface.
| 249 |
Also, cylinders can now be used as light sources, provided they are not
| 250 |
too short compared to their radius (causing them to be frequently missed).
| 251 |
| 252 |
Added -I option to xform to invert surfaces.
| 253 |
| 254 |
Added SMLFLT and BIGMEM defines to better control the sizes of data
| 255 |
structures during compilation. Made their setting relatively
| 256 |
straightforward in makeall and created a separate rmake program to
| 257 |
hold the options generated by makeall.
| 258 |
| 259 |
Made the programs more forgiving of machine differences on octrees.
| 260 |
| 261 |
| 262 |
Fixed incorrect conversion factor between radiance and luminance.
| 263 |
The correct luminous efficacy value is now defined in color.h as
| 264 |
WHTEFFICACY. It was 470 lumens/watt previously, now it has been
| 265 |
corrected to 179 lumens/watt. This affects the absolute values
| 266 |
in the output of programs like gensky and ies2rad. Thus, these
| 267 |
programs should be rerun to generate corrected files for this
| 268 |
version of Radiance. Also, the new versions of display programs
| 269 |
like ximage will give different values with the 'l' command on
| 270 |
an image generated with 1.4 and previous releases. The following
| 271 |
alias may be used to fix the radiance values in a picture generated
| 272 |
using previous versions of gensky and ies2rad:
| 273 |
| 274 |
alias pfixabs '( echo EXPOSURE=.381 ; cat \!:1 ) > \!:1.$$ ; mv \!:1.$$ \!:1'
| 275 |
| 276 |
Improved accuracy of glass material type and added option for
| 277 |
user-supplied index of refraction.
| 278 |
| 279 |
Added sgi to rt/Makefile and px/Makefile SPECIAL category for compiling
| 280 |
Isaac Kwo's NeWS driver for rview and the glimage program by Jim Winget.
| 281 |
Also fixed various compile problems for the SGI.
| 282 |
| 283 |
Improved handling of alternate scanline orientations. The programs
| 284 |
pflip and protate (used to be prot) now affect the scanline ordering
| 285 |
of the file without messing up the view parameters for programs like
| 286 |
pinterp and findglare.
| 287 |
| 288 |
| 289 |
Version 2.1 (Released 5/20/92)
| 290 |
| 291 |
| 292 |
Changed function specifications to allow the use of expressions as
| 293 |
well as variables in scene files. Use of this feature may result
| 294 |
in some loss of backwards compatibility as older software does not
| 295 |
support it.
| 296 |
| 297 |
Added makeall option for NeXT machine and changed code to suit.
| 298 |
| 299 |
| 300 |
Added off-specular sampling and anisotropic materials plastic2,
| 301 |
metal2 and trans2. The old options -sp, -sj, -st and -p have
| 302 |
been renamed to -ps, -pj, -pt and -pa, respectively. New options
| 303 |
-sj and -st have been introduced.
| 304 |
| 305 |
Improved ray intersection calculations using -DSMLFLT option by
| 306 |
increasing epsilon used in tests. This eliminates most of the
| 307 |
errors that occured when this compile option was used in version 2.0.
| 308 |
| 309 |
Added capability to gensurf to read height or point data from a
| 310 |
file. This makes it more convenient to make (optionally smoothed)
| 311 |
landscapes from recorded measurements and the like.
| 312 |
| 313 |
Corrected irradiance gradient calculation. New formula predicts
| 314 |
gradient better and thus reduces artifacts in indirect calculation.
| 315 |
| 316 |
Modified replmarks to accept multiple markers.
| 317 |
| 318 |
Added -aI and -aE options to read ambient include/exclude materials
| 319 |
from a file.
| 320 |
| 321 |
Reduced effect of light leaks during interreflection calculation.
| 322 |
| 323 |
Added -ang option to gensky for giving solar angles explicitly.
| 324 |
| 325 |
Added ability of "view" command within rview to accept view options.
| 326 |
| 327 |
Fixed a long-standing bug in gensky that caused it to report
| 328 |
inaccurate values for the ground ambient level. Since the dayfact
| 329 |
script uses this value in calculating its results, version 2.0 will
| 330 |
be in error (by as much as 30 or 40%).
| 331 |
| 332 |
Fixed a bug in the reflectance normalization for isotropic and
| 333 |
anisotropic Gaussian highlights that caused too much light to
| 334 |
be reflected near grazing angles. Much thanks to the folks at
| 335 |
Ohio State University (Steve Spencer and Kevin Simon) who
| 336 |
pointed this out to me!
| 337 |
| 338 |
Fixed bug in xshowtrace introduced in 2.0. It absolutely didn't work
| 339 |
after my most recent changes to image.c. (Sorry about that!)
| 340 |
| 341 |
Finally fixed shortcoming of view reading routines so they can get
| 342 |
the views from pictures created with absolute program paths
| 343 |
(eg. /usr/local/bin/rpict). This affects programs like
| 344 |
xshowtrace and glare, as well as the recover option of rpict.
| 345 |
| 346 |
Fixed isotropic Gaussian distribution (highlights for types "metal"
| 347 |
and "plastic") to make them more accurate and bring them into line
| 348 |
with the new anisotropic Gaussian models ("metal2" and "plastic2").
| 349 |
This may affect the appearance of some hightlights.
| 350 |
| 351 |
Added -H and -R options to pvalue to control resolution strings
| 352 |
and color ordering.
| 353 |
| 354 |
Fixed byte ordering for 24-bit color displays in ximage.
| 355 |
| 356 |
| 357 |
Version 2.2 (No official release)
| 358 |
| 359 |
Made more fixes in rview and ximage for different display hardware.
| 360 |
Philip Thompson and Peter Apian helped with suggestions and testing.
| 361 |
| 362 |
Fixed bug in -e option of xform that kept it from fully expanding
| 363 |
some scene files.
| 364 |
| 365 |
Added proportional text spacing (-s option for psign, new argument
| 366 |
for text primitives). Added antialiasing (3x3 super-sampling) to psign.
| 367 |
| 368 |
Added code in display drivers to read environment variable called
| 369 |
"GAMMA" to set gamma correction for different monitors. See notes in
| 370 |
this directory on gamma_corr.
| 371 |
| 372 |
Added CC defines to all the Rmakefiles so that other C compilers may be
| 373 |
used consistently.
| 374 |
| 375 |
Added -x and -y options to psign to control output dimensions directly.
| 376 |
| 377 |
Decreased value of FTINY with SMLFLT option once again in an attempt to
| 378 |
further reduce errors.
| 379 |
| 380 |
Reinstated rtrace's capability to produce 32-bit_rle_rgbe directly.
| 381 |
| 382 |
Added -S and -o options to rpict for more flexible production of
| 383 |
multiple images and slave operation. Rpict will also accept a recover
| 384 |
file name the same as the output file for more convenient recovery.
| 385 |
| 386 |
Added ra_ps program to translate Radiance picture into PostScript file.
| 387 |
| 388 |
| 389 |
Made ambient files machine-independent so they can be conveniently moved
| 390 |
and reused on any system. Also added coordinated reads and writes so
| 391 |
that multiple processes may use the same ambient file at the same time.
| 392 |
Along with the -S option of rpict, this should greatly facilitate parallel
| 393 |
rendering. The new ambient file format also contains a header that
| 394 |
can be read by getinfo. Lookamb now has a -h option.
| 395 |
| 396 |
Created rpiece program for parallel rendering of a single image on
| 397 |
multiple processors and workstations.
| 398 |
| 399 |
Eliminated star artifacts in mkillum distribution patterns by improving
| 400 |
data interpolation method. Improved ability of mkillum to correctly
| 401 |
sample non-axis-aligned polygons.
| 402 |
| 403 |
Added -s and -o options to pcompos for slightly more convenient use
| 404 |
of the -a option. Also eliminated incompatibility between -a and -y
| 405 |
options.
| 406 |
| 407 |
Fixed bug in spotlight sources that caused incorrect boundaries to be
| 408 |
cast by mirrors.
| 409 |
| 410 |
Fixed rounding of scanlines in ra_pr24 to 16-bit boundaries.
| 411 |
| 412 |
Added @file and $envar expansion capabilities to rtrace, rpict and
| 413 |
rview. This is primarily to overcome the 128-byte command limit of
| 414 |
MS-DOS.
| 415 |
| 416 |
Added -r option to gensky for the direct specification of solar
| 417 |
brightness.
| 418 |
| 419 |
Added -oN option to rtrace for reporting unperturbed surface normals,
| 420 |
and changed -on to report perturbed surface normals (used to be
| 421 |
unperturbed).
| 422 |
| 423 |
Changed -di switch of rtrace, rpict and rview to -dv and changed
| 424 |
sense. Thus, instead of having a boolean variable called "source
| 425 |
invisibility" that is normally off, there is now a boolean variable
| 426 |
called "source visibility" that is normally on. More logical, and
| 427 |
also allows for the addition of -di and -de options for direct
| 428 |
include and exclude in the future.
| 429 |
| 430 |
Fixed bug in image.c associated with -DSMLFLT that caused angular
| 431 |
fisheye views to repeat the center pixel in the middle of an image.
| 432 |
| 433 |
Modified colordata and colorpict to take functions of a single variable
| 434 |
instead of always requiring functions of three variables (red, green, blue).
| 435 |
| 436 |
Modified objview script to work in original object coordinates.
| 437 |
| 438 |
Added -P and -PP options to rpict and rtrace for persistent and parallel
| 439 |
processing, respectively. The -P option is most useful with the -fr
| 440 |
option of pinterp, since rtrace doesn't have to be restarted for every
| 441 |
frame in a long animation sequence. The -PP option is most useful when
| 442 |
running rpiece on a multiprocessing platform, to get acceptable memory
| 443 |
sharing without the hassle of threaded code.
| 444 |
| 445 |
Changed signal handling in rpict so CONT is now used to elicit
| 446 |
asynchronous progress reports. ALRM now causes rpict to die
| 447 |
unconditionally.
| 448 |
| 449 |
Created executive program called "rad" to run oconv, rview, rpict and
| 450 |
pfilt automatically. This should greatly simplify use of Radiance and
| 451 |
reduce the problems associated with poorly chosen parameter values.
| 452 |
| 453 |
Added slave driver to rview to make it easier to run from other
| 454 |
graphics applications. (Thanks to Chris Nicholas of Sun for the
| 455 |
suggestion.)
| 456 |
| 457 |
Fixed error in ies2rad.c and source.cal that caused incorrect
| 458 |
interpretation of asymmetric Type C (A) fixture photometry. Note the
| 459 |
new definition of src_phi in source.cal. This change may affect
| 460 |
manually entered photometry.
| 461 |
| 462 |
Added '@' command to ximage to adjust exposure based on Blackwell's
| 463 |
model of human contrast sensitivity.
| 464 |
| 465 |
Added functions to pcomb to get the ray origin and direction from the
| 466 |
input picture view specifications.
| 467 |
| 468 |
Removed Fresnel approximation to specular reflection from Radiance materials,
| 469 |
since the direct component was not being computed correctly. This
| 470 |
may have a slight affect on the appearance of surfaces, but it can't be
| 471 |
helped.
| 472 |
| 473 |
| 474 |
Changed the definition of the BRTDfunc type so as to be more general and to
| 475 |
allow for different reflection properties depending on what side of the
| 476 |
surface the ray is incident. Any scene and function files using the
| 477 |
old definition of BRTDfunc must be updated. Implemented the approximation
| 478 |
used in Window 4 to reflection from coated glazings in lib/glazing.cal.
| 479 |
| 480 |
Added -ti, -te, -tI and -tE options to rtrace for including or
| 481 |
excluding surfaces from those reported by the trace output specifier.
| 482 |
| 483 |
Fixed long-standing bug in pfilt gaussian filter option, which caused
| 484 |
the image to be excessively defocused.
| 485 |
| 486 |
Added -m option to pfilt for image sample smoothing. This helps get rid
| 487 |
of some of the "speckle" associated with specular sampling.
| 488 |
| 489 |
Made -ovt* compatible with -I option of rtrace.
| 490 |
| 491 |
Changed ximage to work with multiple pictures. It now opens one window
| 492 |
for each picture file.
| 493 |
| 494 |
Fixed error reporting in rpict for most machines. (Many thanks to Peter
| 495 |
Apian-Bennewitz for his help and suggestions.)
| 496 |
| 497 |
| 498 |
Added intermediate sky to gensky and changed its options slightly.
| 499 |
The new gensky uses a new version of skybright.cal, so any old
| 500 |
gensky output in files must be recomputed with the new gensky before
| 501 |
it will work. (A "skybright: undefined" error should clue you in.)
| 502 |
| 503 |
| 504 |
Version 2.3 (Released 11/16/93)
| 505 |
| 506 |
No changes from the above, but the official release was designated 2.3
| 507 |
to avoid confusion with previous beta releases of 2.2.
| 508 |
| 509 |
| 510 |
Version 2.4 (Released 4/20/94)
| 511 |
| 512 |
Philip Thompson of MIT added use of a radiance.gamma resource to ximage
| 513 |
and we added it to the x11 driver of rview as well. This is an alternative
| 514 |
to setting the GAMMA environment variable for X11 servers.
| 515 |
| 516 |
Added MLIB variable to Rmakefile's for defining alternate math libraries.
| 517 |
I discovered that the default version of sqrt() under IRIX is a whole
| 518 |
lot slower than what's in the libfastm.a library, and not much better.
| 519 |
This can make a significant difference to the renderers, since sqrt()
| 520 |
is relied on quite a bit, and it's assumed to be fast.
| 521 |
| 522 |
Added =SS option to pcompos to allow anchor points for image positions
| 523 |
other than the lower left corner.
| 524 |
| 525 |
Wrote raddepend script for finding dependencies in scene files.
| 526 |
| 527 |
Fixed a bug in mkillum that caused it to incorrectly sample ring sources.
| 528 |
| 529 |
Finally allowed mixtures to work with materials, thanks to the encouragement
| 530 |
and advice of Peter Apian-Bennewitz.
| 531 |
| 532 |
Wrote a triangular mesh converter, called tmesh2rad. I defined my own
| 533 |
format, since I wasn't too familiar with anyone else's format and I
| 534 |
wanted to support some additional possibilities (most notably patterns).
| 535 |
| 536 |
Added initial "#?RADIANCE" line to headers to simplify Radiance file
| 537 |
identification by programs used to magic numbers.
| 538 |
| 539 |
Created a translator for Wavefront .obj files, called obj2rad. It uses
| 540 |
the same type of mapping rules as arch2rad.
| 541 |
| 542 |
| 543 |
Version 2.5 (Released 6/26/95)
| 544 |
| 545 |
Wrote translators to and from the new MGF (Materials and Geometry
| 546 |
Format) specification.
| 547 |
| 548 |
Changed color conversion routines to make light source colors (from
| 549 |
lamp.tab) consistent with uniform white light standard.
| 550 |
| 551 |
Fixed a bug that caused very small local sources not to be sampled
| 552 |
at all!
| 553 |
| 554 |
Added the ability for rview to read commands from its standard input
| 555 |
under X11.
| 556 |
| 557 |
****************** COMPATIBILITY CHANGE ***********************
| 558 |
Changed GAMMA environment variable to DISPLAY_GAMMA, to bring it in
| 559 |
line with the xli program, so users don't have to give two variables
| 560 |
for the same value!
| 561 |
| 562 |
Added -t (touch) option to rad, to make it easier to deal with minor
| 563 |
changes to input files.
| 564 |
| 565 |
Created graphical user interface to rad, called trad. Based on Tcl/Tk,
| 566 |
this should finally get people to start using this program!
| 567 |
| 568 |
Added -vo and -va (view fore and view aft) clipping plane options to
| 569 |
Radiance view parameters.
| 570 |
| 571 |
Added -bv option for (opaque) back face visibility control.
| 572 |
| 573 |
Added -q, -a and -e options to pinterp, and made it faster. (These
| 574 |
should be big improvements.)
| 575 |
| 576 |
Created tabfunc program for converting data tables to functional
| 577 |
language.
| 578 |
| 579 |
Wrote mgf2meta program to convert MGF data to line drawing.
| 580 |
| 581 |
Updated ies2rad program to interpret MGF geometry in IESNA-LM-63-1995
| 582 |
files.
| 583 |
| 584 |
Added sorting of ambient values according to access times to improve
| 585 |
reference locality for better virtual memory performance.
| 586 |
| 587 |
Added source solid angle argument to BRTD functions for averaging
| 588 |
values.
| 589 |
| 590 |
Wrote genclock program to create an analog clock.
| 591 |
| 592 |
Fixed a bug for bitmaps using hexbit4x1.fnt with brighttext, which
| 593 |
caused thin lines to appear.
| 594 |
| 595 |
| 596 |
Version 3.0 (Released 6/19/96)
| 597 |
| 598 |
Added comments to data and font files.
| 599 |
| 600 |
Changed behavior of mirror to allow void alternate material.
| 601 |
| 602 |
Added cylindrical view type for Quicktime VR authoring and other
| 603 |
interesting applications.
| 604 |
| 605 |
Increased default rtrace parameters for more accurate calculations when
| 606 |
options are not specified.
| 607 |
| 608 |
Added RAWFILE and ZFILE variables to rad for saving raw picture file and
| 609 |
Z (distance) information from rpict.
| 610 |
| 611 |
Ported trad for newer (4.0) version of Tk (wish). Thanks to Bob Lipman
| 612 |
of NIST for helping me track down the changes.
| 613 |
| 614 |
Added -B option to pinterp to blur multiple views into a single image,
| 615 |
useful for motion blur and depth of field simulation.
| 616 |
| 617 |
Created pdfblur script and modified vwright to automate depth-of-field
| 618 |
simulation with pinterp.
| 619 |
| 620 |
Added -c option for color PostScript output from ra_ps, and made both
| 621 |
this program and psmeta produce EPS-compatible files.
| 622 |
| 623 |
Created macbethcal program for calibrating color image scanners and
| 624 |
film recorders or printers using the Macbeth ColorChecker chart.
| 625 |
| 626 |
Created ra_xyze program for converting to and from new Radiance CIE XYZE
| 627 |
picture type and calibrating monitor colors. Modified Radiance picture
| 628 |
filters (pcompos, pflip, pcomb, pinterp, protate and pfilt) to handle
| 629 |
new picture type without complaint.
| 630 |
| 631 |
Added automatic ambient value computation to improve accuracy of results
| 632 |
no matter what -av value is given. (Only works for -ab > 0.) This was
| 633 |
a fairly obvious optomization I should have thought of ages ago.
| 634 |
(Default is old behavior -- -aw option puts in new code.)
| 635 |
| 636 |
Modified interreflection calculation to take textures (surface normal
| 637 |
perturbations) into account in indirect illumination. This should
| 638 |
improve the accuracy and appearance of textured surfaces in shadowed
| 639 |
regions.
| 640 |
| 641 |
Added -T option to rpiece to limit execution time.
| 642 |
| 643 |
Fixed bug in mixtext type introduced in last release -- caused improper
| 644 |
calculation of mixed modifiers.
| 645 |
| 646 |
Added basic options and functionality for participating media. New material
| 647 |
type "mist" and rendering options -me, -ma, -mg and -ms. This should permit
| 648 |
the modeling of visible light beams, uniform smoke, fog, and some types
| 649 |
of clouds.
| 650 |
| 651 |
Added -o option to ximage to control output of 't' command (and
| 652 |
middle mouse button). This adds the ability to produce pixel
| 653 |
position, radiance value and luminance. The default action is
| 654 |
the same as before.
| 655 |
| 656 |
Created pmblur script to generate views for camera motion blur in
| 657 |
walk-through animations.
| 658 |
| 659 |
Added "inpic" variable to picture.cal for determining when the edge
| 660 |
of a non-repeating image has been reached. Use with mixfunc primitive.
| 661 |
| 662 |
Created ranimate program to control walk-through and dynamic animations
| 663 |
on multiple hosts.
| 664 |
| 665 |
Fixed problem with antimatter type referring to final definition of
| 666 |
material names. Now, it uses the most recent ones.
| 667 |
| 668 |
Added an MC macro for true Monte Carlo sampling rather than the default
| 669 |
Quasi Monte Carlo. To enable, add -DMC to the OPT= line in rmake.
| 670 |
| 671 |
Fixed bug in pfilt -m option that caused floating point exceptions on
| 672 |
Alphas.
| 673 |
| 674 |
Wrote xyzimage script for X11 display of XYZE and corrected RGBE pictures.
| 675 |
Takes the same options as ximage with an added -p option, and checks
| 676 |
the environment variable DISPLAY_PRIMARIES for setting of monitor
| 677 |
primaries. (See the ra_xyze manual page for further explanation.)
| 678 |
| 679 |
Made colorpict's use much less memory by storing data in RGBE format
| 680 |
rather than floating point (takes 1/3 the space). This should help with
| 681 |
large image patterns.
| 682 |
| 683 |
At the insistence of Henrik Wann Jensen, changed the specular sampling
| 684 |
code so that very rough specular surfaces will sample more truly,
| 685 |
eliminating some strange mirror appearances evident using the old
| 686 |
method.
| 687 |
| 688 |
Added drawing of small and skinny light sources so rpict won't miss
| 689 |
these from inadequate image sampling. The method used may not work
| 690 |
perfectly for warped views (-vta, -vth and -vtc) having long,
| 691 |
cylindrical light sources. (Rob Shakespeare, take note!)
| 692 |
| 693 |
Added corner rounding to genprism command (-r option).
| 694 |
| 695 |
Changed mixtures so that mixing material with void is allowed, allowing
| 696 |
for opacity maps. Also altered general behavior so that surfaces
| 697 |
without materials in their modifier list are invisible, not only
| 698 |
surfaces with void modifiers.
| 699 |
| 700 |
| 701 |
The behavior of xform has been changed to make object library
| 702 |
organization and usage simpler.
| 703 |
1) The RAYPATH directories are searched for matching file names.
| 704 |
2) Filenames beginning with '.', '/' or '~' do not result in searches.
| 705 |
3) Xform performs a chdir to the found file's directory, obviating
| 706 |
the need for peculiar inclusion names in subdirectories.
| 707 |
4) The array option (-a) now works when xform reads from stdin.
| 708 |
5) The expand option (-e) is now the default -- -c gets
| 709 |
back old behavior.
| 710 |
| 711 |
| 712 |
Version 3.1 (Released 7/24/97)
| 713 |
| 714 |
Changed gensky so it will accept hour specifications as HH:MM, with
| 715 |
designations for standard North American and European time zones.
| 716 |
| 717 |
Increased buffer size for in-line commands from 512 to 1024.
| 718 |
| 719 |
Added T(n), S(n), WE and pa(n) functions and constants to pcomb.
| 720 |
| 721 |
Created histo utility to compute 1-dimensional histograms from data files.
| 722 |
| 723 |
Created pacuity, pveil and psquish scripts (later combined in "pcond"):
| 724 |
| 725 |
o The pacuity program takes a Radiance picture and defocuses it
| 726 |
in places where the human eye loses resolution. Unless the
| 727 |
scene contains very low luminances (below .1 cd/m^2 or so),
| 728 |
this will not have an appreciable effect. The output can then
| 729 |
be adjusted according to the Ferwerda, Pattanaik and Shirley
| 730 |
tone mapping function using pcomb with the file
| 731 |
src/cal/cal/ferwerda.cal. (See the header comments therein.)
| 732 |
| 733 |
o The pveil program finds sources of glare in an image and adds
| 734 |
a corresponding amount of background luminance surrounding each
| 735 |
glare source according to the adaptation response of the human
| 736 |
eye. This has the effect of reducing contrast around glare
| 737 |
sources.
| 738 |
| 739 |
o The psquish program is probably the most useful of the three,
| 740 |
and must be applied after the other two if the others are
| 741 |
used. With the -a option, psquish uses the human visual
| 742 |
response to compress the dynamic range of an image to fit within
| 743 |
the limited dynamic range of a display (assumed to go from 1 to
| 744 |
100 cd/m^2), and also reduces color visibility in pictures with
| 745 |
low light levels (below 1 cd/m^2). Without the -a option,
| 746 |
psquish simply does the best it can to fit a picture's dynamic
| 747 |
range into what can be readily displayed, without regard to
| 748 |
human visual response. This has the effect of making problem
| 749 |
scenes viewable, such as indoor scenes with windows looking out
| 750 |
to bright exteriors.
| 751 |
| 752 |
Created pcond program, which combines pacuity, pveil and psquish in a
| 753 |
more efficient, robust package. (See man page for details.)
| 754 |
| 755 |
Renamed Perlin noise function partial functions, noise3a(), noise3b()
| 756 |
and noise3c() to noise3x(), noise3y() and noise3z(). Added backward
| 757 |
compatibility defines to rayinit.cal so nothing should be broken.
| 758 |
| 759 |
Fixed double-counting bug in calculation of specular transmission of
| 760 |
light sources for trans type. This might have caused unrealistically
| 761 |
high estimates for illumination beneath trans surfaces with non-zero
| 762 |
roughnesses when the interreflection calculation was used (-ab 1).
| 763 |
| 764 |
Added routines for reading and writing separate RGB files in pvalue.
| 765 |
Also added -pP (where P is one of 'R', 'G' or 'B' upper or lower case)
| 766 |
and -s option to skip specified number of bytes on header. Finally,
| 767 |
added a -n option for non-interleaved RGB input and output.
| 768 |
| 769 |
Fixed obscure bug in rcalc that caused it to return "Bad call to
| 770 |
argument!" for certain combinations of function and output channel
| 771 |
definitions.
| 772 |
| 773 |
Added "-e auto" and "-e human" options to ximage(1) and corresponding
| 774 |
'a' and 'h' commands to perform dynamic range compression similar to
| 775 |
pcond(1).
| 776 |
| 777 |
| 778 |
Version 3.4 (Released 1/28/02)
| 779 |
| 780 |
Fixed bug in rpiece that caused it to incorrectly compute -vs and -vl
| 781 |
(view shift and lift) offsets. (Included in 3.1.1.)
| 782 |
| 783 |
Fixed bug in xform handling mist's with > 5 real arguments.
| 784 |
| 785 |
| 786 |
Fixed bug in mist handling routines that caused some incorrect calculations
| 787 |
for distant sources. (Included in 3.1.1.)
| 788 |
| 789 |
Added ability for lam utility to read from commands.
| 790 |
| 791 |
Created vwrays command to compute ray origins and directions for specified
| 792 |
views or pictures.
| 793 |
| 794 |
Changed rtrace behavior to send bogus record when ray direction is zero.
| 795 |
(Before, it only flushed values with no corresponding record.) This
| 796 |
change was needed to facilitate its use with the new vwrays program.
| 797 |
| 798 |
Modified ies2rad so that it no longer produces glow sources for the sides
| 799 |
of objects, which caused unnatural dark bands near the ceilings of
| 800 |
direct/indirect installations. (Included in 3.1.4.)
| 801 |
| 802 |
Fixed bug in rpiece that caused the -pa option to fail. (Included in 3.1.2.)
| 803 |
| 804 |
Made ximage emphasize pixels in the selected region for the 'a' and 'h'
| 805 |
commands to adjust the exposure using histogram compression.
| 806 |
| 807 |
| 808 |
Fixed bug in trad which caused it to fail when there were tabs in the input.
| 809 |
(Included in 3.1.3.)
| 810 |
| 811 |
Fixed bug in pcond that caused it to white-out borders of some fisheye views.
| 812 |
| 813 |
| 814 |
Added facility to ra_tiff to read and write new LogLuv high dynamic-range
| 815 |
image formats.
| 816 |
| 817 |
Changed ambient value averaging in rendering programs (-aw option) to use
| 818 |
geometric mean rather than arithmetic mean, which tended to arrive at
| 819 |
too-high estimates and cause runaway calculations. (Included in 3.1.4.)
| 820 |
| 821 |
Added -g, -p, -m and -d options for gamma, paper size, margins and dpi
| 822 |
to the ra_ps program. This allows for much better control over output
| 823 |
to PostScript printers.
| 824 |
| 825 |
Fixed compiles for AIX -- select() incompatibility and macro conflicts.
| 826 |
(Included in 3.1.6.)
| 827 |
| 828 |
Increased table sizes to allow up to 4 million primitives when -DBIGMEM
| 829 |
is defined, provided there's enough virtual memory to hold them!
| 830 |
| 831 |
Fixed error in viewloc() for computing view locations for cylindrical views.
| 832 |
| 833 |
Wrote rholo, rhcopy, rhpict, and rhoptimize programs for holodeck
| 834 |
creation, display, and manipulation. This is a much more powerful way
| 835 |
to view a model than rview, though it lacks many of the utility commands.
| 836 |
| 837 |
Added the ability to separate concatanated animation frames using ra_rgbe.
| 838 |
This output facility of rpict was previously useless because nothing could
| 839 |
get anything past the first frame.
| 840 |
| 841 |
Wrote compamb program to compute a good ambient value for a rad input file.
| 842 |
Using this script is preferable to setting the -aw option of rpict, which
| 843 |
seems to result in splotchy artifacts in many situations.
| 844 |
| 845 |
Changed rad so it doesn't use the -aw option, which was causing some rather
| 846 |
annoying artifacts. (Added as patch to 3.1.8.)
| 847 |
| 848 |
Modified ranimate to change directories before running transfer or archive
| 849 |
commands.
| 850 |
| 851 |
Added -pm option to rpict to perform jittered motion blurring.
| 852 |
| 853 |
Created phisto script and added -I option to pcond for computing
| 854 |
multiple, identical exposures.
| 855 |
| 856 |
Fixed time zone specifications in gensky. (Added as patch to 3.1.9.)
| 857 |
| 858 |
Fixed bug in mixture functions that caused erroneous modifier loops.
| 859 |
(Added as patch to 3.1.10.)
| 860 |
| 861 |
Wrote glrad program for interactive display of Radiance scenes using OpenGL.
| 862 |
Modified objview program to use rad and glrad for rendering.
| 863 |
| 864 |
Changed the way ray weights are computed for participating media (including
| 865 |
dielectrics) so they more accurately reflect a ray's contribution, avoiding
| 866 |
some artifacts with unsealed dielectric objects and the ambient calculation.
| 867 |
| 868 |
Fixed problem with dielectric materials with textures where rays that should
| 869 |
have penetrated or reflected do the opposite.
| 870 |
| 871 |
Created ra_hexbit program to generate bitmap files for use with hexbit4x1.fnt.
| 872 |
| 873 |
| 874 |
Altered mixtures to take the most recent modifier definition
| 875 |
rather than the last one in the entire description. Made the
| 876 |
same change for illum's and mirror's. Also, fixed a bug in
| 877 |
the antimatter type where it didn't always get the correct
| 878 |
material for shading.
| 879 |
| 880 |
Wrote normtiff program to quickly tone-map and convert Radiance pictures
| 881 |
and SGILOG-encoded TIFF's to flat RGB TIFF output.
| 882 |
| 883 |
Added -r option to protate for CCW rotations.
| 884 |
| 885 |
Added ability to load values from read-only ambient file in rpict,
| 886 |
rtrace and rview. This may be useful when starting with the same
| 887 |
values on many processors, where NFS lock contention would slow
| 888 |
things down if they also wrote values back to the file.
| 889 |
| 890 |
Wrote rhinfo program for printing out holodeck section information.
| 891 |
| 892 |
Modified rad "scene" variable to allow in-line command specifications.
| 893 |
| 894 |
Added added -s and -b options to ra_ppm for changing output scale and
| 895 |
forcing greyscale output.
| 896 |
| 897 |
Now allow negative distances for the fore clipping plane in rpict.
| 898 |
This may be useful for rendering holographic stereograms.
| 899 |
| 900 |
Added -f option to xform to read arguments from files. This can save
| 901 |
a lot of scene loading time by reducing multiple xform invocations.
| 902 |
| 903 |
Added support for 15-bit TrueColor visuals in ximage.
| 904 |
| 905 |
Added (undocumented) -P option to macbethcal for picking chart corners
| 906 |
directly using ximage.
| 907 |
| 908 |
Added -r option to rholo for opening holodeck files read-only.
| 909 |
| 910 |
Added correction factor for solid angle change in dielectrics as
| 911 |
noted in Eric Veach's thesis.
| 912 |
| 913 |
Added von Kries white balance transform for color conversion using
| 914 |
CMCCAT2000 matrix.
| 915 |
| 916 |
Added CAPDATE field to rendering headers to record render date.
| 917 |
| 918 |
Added mixpict primitive for using pictures to generate mixtures.
| 919 |
| 920 |
Fixed bug in Type B photometry angle calculation in source.cal discovered
| 921 |
by Erich Phillips.
| 922 |
| 923 |
| 924 |
Version 3.5 (Released 3/21/03)
| 925 |
| 926 |
Fixed bug in replmarks pointed out by Georg Mischler, which caused
| 927 |
garbage to be output under specific conditions (unscaled, unrotated
| 928 |
instances).
| 929 |
| 930 |
Fixed bug in normtiff that caused occassional weird colors
| 931 |
on human tone-mapping of 32-bit LogLuv inputs (tmapluv.c).
| 932 |
| 933 |
Fixed -o option of pcomb so it resets le(i) and color exposure functions
| 934 |
to unity.
| 935 |
| 936 |
Fixed a bug in Type B photometry in ies2rad source.cal introduced
| 937 |
in last fix where spherical sources were getting symmetric
| 938 |
distributions front-to-back.
| 939 |
| 940 |
Fixed another bug in ies2rad for 90-270 bilaterally symmetric fixtures, which
| 941 |
seems to have been there from the beginning. Thanks to Jack de Valpine
| 942 |
for pointing it out.
| 943 |
| 944 |
Added NORANDOM symbol for tests with all random sampling turned off.
| 945 |
| 946 |
Fixed a bug in expression evaluation code that was causing unneeded
| 947 |
evaluations of constants. This is a fix on an earlier fix of a more
| 948 |
serious bug prior to the 3.4 release, where the expression clock
| 949 |
was wrapping silently and allowing values to go stale.
| 950 |
| 951 |
Fixed an even more serious bug in ies2rad for thin fixtures, where
| 952 |
it was using "flatcorr" without the proper correction for the
| 953 |
emitting area. Thanks again to Jack de Valpine for spotting this.
| 954 |
| 955 |
--- All of the above was put into a 3.4.1 patch release 4/1/2002
| 956 |
| 957 |
Added a facility to gensurf to make holes in the mesh using a
| 958 |
valid(s,t) function.
| 959 |
| 960 |
Fixed bug in pcond that caused a bus error on images with large dark
| 961 |
regions when acuity switch was set.
| 962 |
| 963 |
Fixed bug in pcomb that caused the S(n) function to return half
| 964 |
the solid angle value it should have. (Thanks to John Mardaljevic
| 965 |
for discovering this error.)
| 966 |
| 967 |
Made rpict/rpiece/vwrays -vf option accept "-" as a synonym
| 968 |
for standard input.
| 969 |
| 970 |
Fixed bug in persist functions (-P and -PP) with FreeBSD
| 971 |
(including MacOS X) having to do with altered system function
| 972 |
behaviors. Neither mknod() nor freopen() behave as they
| 973 |
used to.
| 974 |
| 975 |
Improved accuracy of irradiance gradient calculation near
| 976 |
specular surfaces by using the effective ray distance
| 977 |
rather than the first surface intersection. (John
| 978 |
Mardaljevic had pointed out some errors he was seeing
| 979 |
with a particular atrium model.)
| 980 |
| 981 |
Reinstated my favorite little Fresnel approximation for
| 982 |
perfectly smooth materials, so grazing angles show an
| 983 |
accurate gradient. Simultaneously revised the computation
| 984 |
of the direct component for proper energy balance.
| 985 |
(Thanks to Phillip Greenup for nagging John M. who nagged me.)
| 986 |
| 987 |
Improved the accuracy and appearance of indirect irradiance
| 988 |
interpolation for smoothed surfaces. (Thanks to Bernhard
| 989 |
Spanlang for noticing the problem.)
| 990 |
| 991 |
Fixed intolerance for carriage-returns in mkillum's input files,
| 992 |
which caused problems for files imported from DOS/Windows.
| 993 |
| 994 |
Fixed apparent bug that I couldn't reproduce in rpict for very
| 995 |
narrow views, which sent it into an infinite loop under Linux.
| 996 |
(Rich Gillibrand of Bristol Univ. pointed it out.)
| 997 |
| 998 |
Improved movement in rholo for low-detail holodecks on fast
| 999 |
graphics processors by inserting 50 ms pause during motion
| 1000 |
feedback.
| 1001 |
| 1002 |
Finally fixed ages-old consistency error where ambient value
| 1003 |
lists were sorted incorrectly with the GNU-C compiler,
| 1004 |
causing the dreaded "address not found in avlmemi" crash. All
| 1005 |
this time, I thought it was due to a faulty qsort(3) routine,
| 1006 |
when in fact it was due to the way GNU-C compares pointers.
| 1007 |
The fix was to change a single word in ambient.c from "AMBVAL"
| 1008 |
to "char" and now it all magically works. No more -Dtracktime=0,
| 1009 |
hurrah!
| 1010 |
| 1011 |
Fixed pcond veil behavior for scenes that have their contrast
| 1012 |
reduced by primary tone-mapping algorithms. Previously, the
| 1013 |
veil would come out looking like a fog because it was applied
| 1014 |
prior to dynamic range compression and did not consider the
| 1015 |
overall effect. In the new version, the veil is adjusted
| 1016 |
after dynamic range compression so that the net reduction
| 1017 |
in visibility is approximately correct over the whole image.
| 1018 |
(Later made this optional on compile with the ADJ_VEIL symbol, as I
| 1019 |
noticed more artifacts than improvements in the resulting images.)
| 1020 |
| 1021 |
Fixed bug in BRTDfunc that caused an error in the calculation
| 1022 |
of the diffuse transmitted ambient component. This must have
| 1023 |
been introduced early on, but never noticed by me or anyone.
| 1024 |
| 1025 |
Wrote an interactive script called "glaze" (src/gen/glaze.csh)
| 1026 |
that computes a good material model for fritted and low-E glazing
| 1027 |
systems. Thanks to Visarc (Jack de Valpine) for paying for its
| 1028 |
development and permitting it into the general distribution.
| 1029 |
| 1030 |
Increased scanline window in pcomb to 64 (+/- 32 pixels) to allow
| 1031 |
for larger kernels in filtered images.
| 1032 |
| 1033 |
| 1034 |
Changed behavior of pfilt gaussian blur to match more precise
| 1035 |
definition. A blur radius of 0.6 is now preferred over the
| 1036 |
previous value of 1.0.
| 1037 |
| 1038 |
Added ANSI function prototypes to the header files in
| 1039 |
src/common/ and src/rt/ and cleaned up the options processing
| 1040 |
in the rpict, rtrace, and rview main procedures so that the
| 1041 |
core Radiance rendering code can be more easily
| 1042 |
called by new application programs. Changed src/rt/Rmakefile
| 1043 |
to create a rendering library called "libradiance.a" and
| 1044 |
to install it in the src/lib/ directory along with the new
| 1045 |
raycalls.o module, which should facilitate the building
| 1046 |
of new applications outside the src/rt/ directory. The
| 1047 |
raypcalls.o module, also installed in src/lib, manages
| 1048 |
parallel rendering on multiprocessors with shared memories.
| 1049 |
| 1050 |
Wrote new ranimove animation rendering program, which is an
| 1051 |
alternative to ranimate. The key difference is that
| 1052 |
ranimove is optimized for moving scenes, and includes
| 1053 |
a complete blur simulation for camera and object motion.
| 1054 |
It also incorporates an sophisticated model of perceivable
| 1055 |
error based on visual focus, and allows progressive
| 1056 |
animation so one can explicitly control rendering time
| 1057 |
and/or accuracy. See the man page for details.
| 1058 |
| 1059 |
| 1060 |
The sense of the MBLUR setting has been changed for the ranimate
| 1061 |
command. The first value is now the fraction of a frame during
| 1062 |
which the shutter is open, and the _second_ argument (which is
| 1063 |
optional) is the number of samples to specify to pmblur.
| 1064 |
| 1065 |
Enhanced octree reader behavior so it will accept command
| 1066 |
specifications preceded by an exclamation mark ('!'). This
| 1067 |
enables rtrace and rview to take octrees from commands similar
| 1068 |
to rpict reading its octree from the standard input. All
| 1069 |
programs taking octrees as arguments will be affected by this
| 1070 |
change. However, since rad needs to get the modified date
| 1071 |
from the octree, rad will refuse such an octree command
| 1072 |
specification.
| 1073 |
| 1074 |
Fixed a bug in src/common/fgetline.c where it failed to elide
| 1075 |
carriage-returns in Windows files.
| 1076 |
| 1077 |
Modified src/common/fgetword.c so it accepts single- or
| 1078 |
double-quoted words with spaces in preparation for the
| 1079 |
Windows version, which needs to allow spaces in file
| 1080 |
paths. Since fgetword() is called by all programs that
| 1081 |
read in string arguments in scene files, these may now
| 1082 |
be quoted with the expected behavior. Also added a
| 1083 |
fputword() call to the library to automatically quote
| 1084 |
words on output that contain white space. This routine
| 1085 |
is now called from all the right places, I hope! The
| 1086 |
code does not support spaces in primitive identifiers,
| 1087 |
and you will get peculiar errors if you try them.
| 1088 |
| 1089 |
Eliminated virtually all symbolic links from the source
| 1090 |
tree, most of which were links to compatibility routines
| 1091 |
and the calcomp functions for expression parsing.
| 1092 |
Replaced -D* defines used in cal* routines with "esupport"
| 1093 |
global that allows calling programs to set which language
| 1094 |
options they want to support at runtime. More programs now
| 1095 |
link against the -lrt library. Consolidated the src/cal
| 1096 |
subdirectories in the process.
| 1097 |
| 1098 |
Added -dw option to pvalue program to input and output
| 1099 |
16-bit word values (-dW for byte swapping).
| 1100 |
| 1101 |
Changed call ordering in material shaders to ensure
| 1102 |
proper surface normal perturbation for two-sided,
| 1103 |
textured surfaces.
| 1104 |
| 1105 |
Added a new "mesh" primitive, which permits very
| 1106 |
complicated geometries with associated (u,v) coordinates
| 1107 |
using the new obj2mesh converter and the new -o option
| 1108 |
of gensurf for .OBJ output. Mesh compilation takes
| 1109 |
roughly 500 bytes/triangle in obj2mesh, but memory
| 1110 |
access is well-ordered compared to rendering, which
| 1111 |
takes about 50 bytes/triangle with full surface normal
| 1112 |
and (u,v) coordinate interpolation. (The actual mesh
| 1113 |
is represented in 15 bytes/triangle, and the rest is
| 1114 |
taken by the octree structure and malloc overhead.)
| 1115 |
Local coordinates are set with the "vt" statement
| 1116 |
in the Wavefront .OBJ file and accessed via the new
| 1117 |
"Lu" and "Lv" variables in a Radiance .cal file.
| 1118 |
Multiple instances of the same mesh with different
| 1119 |
transformations take little additional space during
| 1120 |
rendering, permitting scanned relief surfaces and
| 1121 |
displacement-map-like effects to be repeated as desired.
| 1122 |
| 1123 |
Changed internal representation of alias'es in order
| 1124 |
to maintain information about links for programs like
| 1125 |
rshow that work from frozen octrees. Added a special
| 1126 |
alias modifier keyword, "inherit", to indicate that
| 1127 |
an alias should get the same modifier as the original
| 1128 |
target to simplify common alias usage for material
| 1129 |
substitution.
| 1130 |
| 1131 |
Increased default oconv -n value to 6. Since triangle
| 1132 |
meshes commonly have six faces joining at each vertex,
| 1133 |
values less than this cause resolution-limited voxel
| 1134 |
subdivision. Increased default -r option to 16384
| 1135 |
as well. Also increased maximum internal set size
| 1136 |
from 127 to 511, to accommodate difficult mesh
| 1137 |
models where many faces come together at a point.
| 1138 |
This required a little reprogramming in for couple
| 1139 |
of recursive routines using sets to avoid overrunning
| 1140 |
the stack limit.
| 1141 |
| 1142 |
| 1143 |
Version 3.6 (Released 10/21/04)
| 1144 |
| 1145 |
Modified 4-byte RGBE encoding routine to avoid problems
| 1146 |
when one or two primary values is negative and the other(s)
| 1147 |
positive. This used to generate some strange color values.
| 1148 |
| 1149 |
Added -oc option to rtrace to output local (u,v) coordinates.
| 1150 |
| 1151 |
Fixed bugs in local uv and j unit vector variables in src/rt/func.c.
| 1152 |
| 1153 |
Added warning message to OpenGL rendering routines about new
| 1154 |
mesh primitive, which we cannot currently render.
| 1155 |
| 1156 |
Added -if, -id, -of, and -od options to rcalc to provide for
| 1157 |
binary float and double i/o.
| 1158 |
| 1159 |
| 1160 |
Changed holodeck format to used off_t instead of long for beam
| 1161 |
positions, which allows holodecks to grow to system file size limit.
| 1162 |
| 1163 |
Fixed wrapping long in source hit test code, which would cause
| 1164 |
odd horizontal lines in some very long renderings.
| 1165 |
| 1166 |
Added -f and -w options to ra_tiff to create IEEE float and 16-bit/primary
| 1167 |
TIFF output, respectively. These formats are also understood on reverse
| 1168 |
conversion. (16-bit/primary has been understood for some time, but not
| 1169 |
IEEE float.)
| 1170 |
| 1171 |
Added -N option to rad to start multiple rendering processes in
| 1172 |
parallel.
| 1173 |
| 1174 |
Fixed bug where mesh instances were not being freed, so subsequent calls
| 1175 |
in programs like ranimove would refer to bogus data.
| 1176 |
| 1177 |
Added support in normtiff for floating-point and 16-bit/sample TIFF input
| 1178 |
files.
| 1179 |
| 1180 |
Changed marksources() routine (src/rt/source.c) to check all
| 1181 |
primitives in the modifier chain for emitting types, not only
| 1182 |
the first. This permits sources to be described with intervening
| 1183 |
modifiers before the light/illum/glow primitive and allows aliases
| 1184 |
as well.
| 1185 |
| 1186 |
Fixed bug in xform where it was neglecting to add transform arguments
| 1187 |
to new mesh primitive.
| 1188 |
| 1189 |
Added -dF and -dD options to pvalue for byte-swapped floats and
| 1190 |
doubles, respectively.
| 1191 |
| 1192 |
Changed meta2tga to output correct colors.
| 1193 |
| 1194 |
Changed local coordinate index from 32-bits to 16-bits, which requires
| 1195 |
that Radiance mesh files be recompiled. (Later decided against this
| 1196 |
change, as it caused problems with some models.)
| 1197 |
| 1198 |
Changed integer tone-mapping routines to better deal with images
| 1199 |
containing large, constant regions.
| 1200 |
| 1201 |
Improved interaction with rholo -o ogl driver under OS X, which was
| 1202 |
returning bad values from the depth buffer.
| 1203 |
| 1204 |
Minor bug fix in ranimove where it was restarting processes when it
| 1205 |
didn't need to.
| 1206 |
| 1207 |
Increased accuracy of default ambient parameters in rpict, rview, and
| 1208 |
rtrace. In rad program, doubled -ar value, -ad value, and -as value,
| 1209 |
and decreased -aa value a bit. Also adjusted -lr upwards and -lw
| 1210 |
downwards. I should have done these things long ago, as processors
| 1211 |
have been getting faster and faster over the years.
| 1212 |
| 1213 |
Fixed bug discovered by Marcus Jacobs where oconv was dumping core
| 1214 |
when it was given too many modifiers.
| 1215 |
| 1216 |
Fixed problem with rpict where it was drawing illum sources badly
| 1217 |
even when they weren't all that small in the view.
| 1218 |
| 1219 |
Added in(i) function to rcalc for more flexible channel evaluation.
| 1220 |
| 1221 |
Replaced all calls to vfork() with regular fork() calls.
| 1222 |
| 1223 |
Fixed bug in glarendx for dgr calculation with sources behind view.
| 1224 |
| 1225 |
Added -p option to histo to print percentages/percentiles r.t. counts.
| 1226 |
| 1227 |
Added a source occluder cache to accelerate shadow testing. This
| 1228 |
can save up to 50% of the calculation time in scenes with many
| 1229 |
light sources, especially ones containing large occluders. This
| 1230 |
optimization may be tuned or switched off with the -DSHADCACHE=N
| 1231 |
compile switch, where N is the resolution of the shadow cache, or
| 1232 |
0 to disable it. Since this is purely a time vs. memory trade-off,
| 1233 |
I decided not to make it a new command-line option. (We already
| 1234 |
have plenty.)
| 1235 |
| 1236 |
| 1237 |
Changed the following command names to avoid conflicts:
| 1238 |
rview -> rvu (with symbolic link back to rview)
| 1239 |
calc -> icalc
| 1240 |
lam -> rlam
| 1241 |
gencat -> gencatenary
| 1242 |
| 1243 |
Improved -f option of normpat, which caused odd color changes before.
| 1244 |
| 1245 |
Created pgblur script which does fast Gaussian blur of image without changing
| 1246 |
its dimensions. This is very useful in certain types of image processing
| 1247 |
calculations, such as finding or removing low frequencies.
| 1248 |
| 1249 |
| 1250 |
Changed little-used objpict script so that it takes scene files rather than
| 1251 |
rpict options on the command line, and puts everything into the right
| 1252 |
coordinate position automatically rather than requiring the user to do it.
| 1253 |
| 1254 |
Added -I option to replmarks for mesh instancing.
| 1255 |
| 1256 |
Made similar change for virtual sources to allow modifiers and aliases
| 1257 |
on the mirror and prism types to work properly.
| 1258 |
| 1259 |
Rob Guglielmetti added -lw and -lh options to falsecolor to control the
| 1260 |
legend dimensions. Made it so -lw 0 and/or -lh 0 turns legend off.
| 1261 |
| 1262 |
Made it so pcompos will read everything from a stream even if it doesn't
| 1263 |
need it, so input commands will not receive a hangup signal.
| 1264 |
| 1265 |
Wrote ra_bmp program to convert to and from Windows BMP files (finally).
| 1266 |
It's the most horrible image format I've ever seen, and I've seen a lot.
| 1267 |
| 1268 |
Increased -aa default value for all renderers (and also -ad and -as in
| 1269 |
rview) at Schorsch's suggestion. I think this undid my earlier decrease
| 1270 |
of -aa last time, which I guess was ill-considered.
| 1271 |
| 1272 |
Modified oconv to keep subdividing the octree if there are too many
| 1273 |
objects in a voxel even when the -r resolution limit has been
| 1274 |
reached. This was not done before due to problems with recursion,
| 1275 |
and still, it will only continue to 256 times the original -r limit.
| 1276 |
If that isn't enough, then there's probably no hope, anyway.
| 1277 |
| 1278 |
Added -l option to obj2mesh to search for material files in library
| 1279 |
locations.
| 1280 |
| 1281 |
Increased polygon vertex limit to 512 in obj2mesh and obj2rad and added
| 1282 |
warning if this limit is exceeded.
| 1283 |
| 1284 |
Added tone-mapping and monitor primary options to ra_bmp. This gives
| 1285 |
new functionality similar to normtiff and ximage. It would be nice to
| 1286 |
add this feature to the other ra_* programs as well... someday.
| 1287 |
| 1288 |
Fixed long-standing bug in reported pixel ordering out of certain
| 1289 |
protate commands.
| 1290 |
| 1291 |
Added -p option to rcalc for "passive mode" that transmits
| 1292 |
unrecognized input -- useful for substituting data in the
| 1293 |
middle of a stream.
| 1294 |
| 1295 |
Fixed a very obscure bug in rpict that caused a dark horizontal
| 1296 |
line in certain cylindrical projections due to improper drawing
| 1297 |
of the sky dome source in rt/srcdraw.c.
| 1298 |
| 1299 |
Fixed problems with effective ray lengths computed for dielectric
| 1300 |
and BRTDfunc materials. This was most evident in breakup of holodeck
| 1301 |
views when VDISTANCE=True.
| 1302 |
| 1303 |
Fixed rad so that 'scene' variable may consist only of inline commands.
| 1304 |
| 1305 |
Fixed bug introduced in shadow caching routines where sources in the
| 1306 |
middle of spheres were not illuminating properly. Thanks to Guilio
| 1307 |
Antonutto for spotting this problem.
| 1308 |
| 1309 |
Modified gensky behavior so if time is given with standard time zone
| 1310 |
designation, any -m option is ignored.
| 1311 |
| 1312 |
Added -n option to mkillum for (shared memory) parallel processing.
| 1313 |
| 1314 |
Fixed a long-standing bug in parallel processing code that only
| 1315 |
seemed to manifest with the new mkillum -n option, where rtrace
| 1316 |
would deadlock upon termination. The reason it never showed up
| 1317 |
before is because I always closed processes in the reverse order
| 1318 |
of opening them in other programs. I went through and found similar
| 1319 |
(potential) bugs in the rview device subprocess code and util/netproc.c.
| 1320 |
| 1321 |
Corrected the normalization of the Gaussian reflectance model. This will
| 1322 |
cause an increase in specularity for low-lying light sources.
| 1323 |
Thanks to Don Walters of Boeing and Arne Duer of the Univ. of Innsbruck
| 1324 |
for pointing out this error. The square root used for the two cosines
| 1325 |
in the denominator of the normalization factor should not be present.
| 1326 |
This was a serious mistake I made in the original model, which went
| 1327 |
undiscovered (at least to my knowledge) for over a decade. I think
| 1328 |
Bruce Walter of Cornell may have known about it, but I never heard
| 1329 |
the details of his discovery.
| 1330 |
| 1331 |
Enabled the -p option for primary conversion without tone-mapping
| 1332 |
in ra_bmp. Also provides for XYZE input conversion to RGB.
| 1333 |
| 1334 |
Fixed what I consider a bug in pvalue -o when taking XYZE files on input,
| 1335 |
where it was inappropriately undoing the exposure value so that it always
| 1336 |
reported radiance rather than XYZ values with Y in cd/m^2.
| 1337 |
| 1338 |
Made it so ra_bmp only produces run-length encoded 8-bit output for
| 1339 |
grayscale images that are tone-mapped. This minimizes circumstances
| 1340 |
under which output scanline order is reversed.
| 1341 |
| 1342 |
Fixed bug in rcalc where it sometimes wasn't parsing the input format
| 1343 |
correctly.
| 1344 |
| 1345 |
| 1346 |
Version 3.7 (Released 7/25/05)
| 1347 |
| 1348 |
Fixed bug in source occluder cache which caused consistency error
| 1349 |
for distant sources and mist materials. (Thanks to Mark Stock for
| 1350 |
finding the problem.)
| 1351 |
| 1352 |
Fixed serious bug in source drawing routines for rpict, where the edges
| 1353 |
of light sources were appearing through obstructions. (Thanks to Veronica
| 1354 |
Sundstedt for pointing this out.)
| 1355 |
| 1356 |
(The above were included in the 3.6.1 patch release.)
| 1357 |
| 1358 |
Changed default temporary directory from /usr/tmp, which doesn't exist
| 1359 |
on a lot of systems these days, to /tmp.
| 1360 |
| 1361 |
Eliminated many unused files and programs from the distribution, including
| 1362 |
the following programs that were being built but no longer used:
| 1363 |
oki20 - printer driver for OkiMate 20 printer (B&W)
| 1364 |
oki20c - printer driver for OkiMate 20 color printer
| 1365 |
pcwarp - intended as more general substitute for macbetcal,
| 1366 |
but never quite worked
| 1367 |
ra_avs - convert to & from AVS image format
| 1368 |
ra_bn - convert to & from Barneyscann format
| 1369 |
ra_pr - convert to & from 8-bit Sun rasterfile format
| 1370 |
ra_pr24 - convert to & from 24-bit Sun rasterfile format
| 1371 |
thf2rad - convert GDS "things file" to Radiance scene format
| 1372 |
If anyone is still wanting any of the above programs, let us know and we'll
| 1373 |
reinstate it.
| 1374 |
| 1375 |
Fixed bug in pcond's acuity simulation for small view angles (less than
| 1376 |
4 degrees horizontally or vertically). Thanks to James Lee for figuring
| 1377 |
this out.
| 1378 |
| 1379 |
Added script to convert to/from ICT's Poskanzer Float Map, which I don't
| 1380 |
care to support officially due to its machine-dependent byte order.
| 1381 |
| 1382 |
Fixed bug that caused incorrect reporting of non-surface in set when
| 1383 |
mixing meshes and instances. (Thanks to Jack de Valpine for discovery.)
| 1384 |
| 1385 |
Fixed inaccuracy in calculation of diffuse transmission in the presence
| 1386 |
of pure specular (Fresnel reflection) using "trans" material. Thanks
| 1387 |
to Christoph Reinhart for pointing out the error.
| 1388 |
| 1389 |
Made internal change to tone-mapping library to use structure pointer
| 1390 |
rather than stack, making code re-entrant and more up to modern standards.
| 1391 |
| 1392 |
Added -pd option to handle depth-of-field blur in rpict. This requires
| 1393 |
that the view directon (-vd option) include focal distance information,
| 1394 |
which is now preserved by the various view file routines, and reported
| 1395 |
by the vwright command.
| 1396 |
| 1397 |
Added DBLUR variable to ranimate and pmdblur script to handle simultaneous
| 1398 |
motion and depth-of-field blurring. Thanks to Visarc for funding this work.
| 1399 |
| 1400 |
Added setting of focus distance in rvu ("focus" command) and rholo
| 1401 |
('f'/"frame" command).
| 1402 |
| 1403 |
Changed default remote shell in ranimate to "ssh" rather than "rsh",
| 1404 |
which has been abandoned on most Unix systems due to security issues.
| 1405 |
| 1406 |
Fixed behavior of source primitive using illum with no alternate
| 1407 |
material. These now become transparent so one can see the sky or
| 1408 |
light-probe background for use in image-based lighting. Previously,
| 1409 |
the user needed to specify the background glow as the alternate
| 1410 |
material for a distant illum source to behave properly. (This still
| 1411 |
works.)
| 1412 |
| 1413 |
Fixed some minor problems and inconsistencies with 16-bit/channel
| 1414 |
TIFF i/o in ra_tiff.
| 1415 |
| 1416 |
Created mksource program to generate distant sources for improved
| 1417 |
image-based lighting with light probes.
| 1418 |
| 1419 |
Changed ambient calculation so that -ad will not limit recursion
| 1420 |
depth, and a minimum of 27 samples will be sent out for each stored
| 1421 |
ambient value, or 3 samples if -aa is 0 (caching off).
| 1422 |
| 1423 |
Added -oM option to rtrace to report material (rather than modifier)
| 1424 |
for cases where actual material is aliased or further up modifier chain.
| 1425 |
| 1426 |
Rearranged the way ray contributions are computed so that it might be
| 1427 |
possible to use rtrace to derive daylight coefficients and optical
| 1428 |
transfer functions. The new -oTW option of rtrace produces color
| 1429 |
contribution weights for each ray, which combined with the -ti (or -tI)
| 1430 |
option permits the contribution of selected surfaces or sources to
| 1431 |
be determined. Using the -oTW option, one should also specify
| 1432 |
options "-dt 0 -aa 0 -as 0" for optimal results. In particular,
| 1433 |
one cannot expect reasonable tallies with -ab >= 1 and irradiance
| 1434 |
caching on (-aa > 0).
| 1435 |
| 1436 |
The same code modifications included a change to the indirect computation
| 1437 |
with caching switched off (-aa 0). Whereas before, the number of secondary
| 1438 |
rays after the first bounce were half of the previous generation, they are
| 1439 |
now determined by the surface reflectance, making for a better and faster
| 1440 |
calculation. It should now be possible to compute many bounces with -aa 0,
| 1441 |
which used to be prohibitively expensive.
| 1442 |
| 1443 |
Added -T option to xshowtrace to trace rays to light sources.
| 1444 |
| 1445 |
Added meta2bmp program to produce BMP files from metafile graphics.
| 1446 |
| 1447 |
Added cct_x(t) and cct_y(t) to src/cal/cal/blackbody.cal to interpolate
| 1448 |
CIE chromaticities for particular black-body temperatures.
| 1449 |
| 1450 |
Increased maximum number of input pictures in pcomb and pcompos to 512.
| 1451 |
| 1452 |
Created rtcontrib program for computing ray contribution coefficients.
| 1453 |
This tool may be used to do standard optical ray tracing or daylight
| 1454 |
coefficient calculations for annual simulations, among other uses.
| 1455 |
| 1456 |
Added tilde ('~') output option as part of the -o* specification of
| 1457 |
rtrace. This permits ray trees to be parsed more easily in binary
| 1458 |
output mode, as needed by rtcontrib.
| 1459 |
| 1460 |
Implemented Russian roulette ray termination with -lr <= 0.
| 1461 |
Made -lr -10 the default in rtcontrib.
| 1462 |
| 1463 |
Made rtcontrib -f option search RAYPATH directories.
| 1464 |
| 1465 |
Made it so -o option of rtcontrib can pipe -o output to a command.
| 1466 |
| 1467 |
Added -if and -of options to total for binary i/o (following rcalc mold).
| 1468 |
| 1469 |
Switched default options in rtrace to use Russian roulette. (Rpict and rvu
| 1470 |
still use biased ray termination.)
| 1471 |
| 1472 |
Added rtcontrib -r option to recover partial output.
| 1473 |
| 1474 |
Added -u rendering option for pure Monte Carlo sampling.
| 1475 |
(Got rid of -DMC compile option, which this makes superfluous.)
| 1476 |
| 1477 |
Changed -t option of rlam to accept strings as well as single characters.
| 1478 |
| 1479 |
Fixed bug in rcalc with -l option where it would sometimes go into an
| 1480 |
infinite loop.
| 1481 |
| 1482 |
Fixed truly ancient bug in bounding box computation for cones, which
| 1483 |
could (and did) cause missing segments.
| 1484 |
| 1485 |
Added -z option to normtiff to output LZW-compressed files.
| 1486 |
| 1487 |
Last change to total causes it to produce results when it sees an empty
| 1488 |
line on the input. This was not intentional, but I decided I like this
| 1489 |
behavior so I documented it rather than changing it.
| 1490 |
| 1491 |
| 1492 |
Version 3.8 (Released 10/17/06)
| 1493 |
| 1494 |
Fixed Russian roulette ray termination, which was doing the opposite of
| 1495 |
what it should have been doing, resulting in overestimated values below
| 1496 |
minimum ray sampling weight (serious).
| 1497 |
| 1498 |
Changed mksource to use 98th percentile (rather than 99th) for threshold.
| 1499 |
| 1500 |
(Above changes included in 3.7.1 patch release.)
| 1501 |
| 1502 |
Eliminated writing of EXPOSURE= line in ra_tiff -r when source TIFF
| 1503 |
does not have STONITS set.
| 1504 |
| 1505 |
Fixed bug in ambient calculation that caused black values for multiple
| 1506 |
bounces in some scenes. Thanks to Mark Stock for creating and sharing
| 1507 |
the sophisticated test scene that demonstrated this problem.
| 1508 |
| 1509 |
Fixed bug in antimatter using Russian Roulette sampling.
| 1510 |
| 1511 |
(Above changes included in 3.7.2 patch release 22 Aug 2005.)
| 1512 |
| 1513 |
Created fieldcomb script to combine alternate fields in a rendering
| 1514 |
sequence. (Development generously sponsored by Iebele Abel.)
| 1515 |
| 1516 |
Added missing preload of mesh objects for more efficient memory use
| 1517 |
during parallel rendering -- this was a serious oversight.
| 1518 |
| 1519 |
Created ran2tiff program to automate exposure setting of animation
| 1520 |
sequences using a moving histogram in combination with pcond, and
| 1521 |
converting frames to TIFF.
| 1522 |
| 1523 |
Eliminated SPEED macro from makeall and source tree.
| 1524 |
| 1525 |
Added -pj option to vwrays to allow jittering of sample locations.
| 1526 |
| 1527 |
Fixed bug in rtcontrib where it occasionally missed writing the
| 1528 |
final bin file. (Pretty serious, actually.)
| 1529 |
| 1530 |
Added -Dfseeko=fseek to MACH= line for linux, as fseeko(3) seems to be
| 1531 |
broken in current versions of Linux. (Need to remove this later.)
| 1532 |
| 1533 |
Rearranged struct's for better efficiency on 64-bit architectures.
| 1534 |
| 1535 |
Added -i option to rlam so it works with binary input formats.
| 1536 |
| 1537 |
Added rtcontrib -bn option to specify number of bins and fixed bug
| 1538 |
in recovery of files containing multiple values per record.
| 1539 |
| 1540 |
Added rtcontrib -fo option to write over existing files, which it now
| 1541 |
refuses to do without this option.
| 1542 |
| 1543 |
Made rtcontrib flush output when handed a zero-length ray vector,
| 1544 |
to match behavior of rtrace.
| 1545 |
| 1546 |
Improved color scale for falsecolor output.
| 1547 |
| 1548 |
Added threshold test for Fresnel approximation to prevent its use
| 1549 |
on smooth surfaces with unrealistically low specularities (less than 1.8%).
| 1550 |
Water has a specular reflectance of 2.1% at room temperture.
| 1551 |
| 1552 |
Removed NICE macro settings in rpict and rtrace, which was slowing down
| 1553 |
the processes under Mac OS X (10.4) by about 60% due to processor napping.
| 1554 |
| 1555 |
Made xform, replmarks and rad2mgf handle quoted modifiers and names properly.
| 1556 |
| 1557 |
Fixed problem in genblinds, where it was generating slats that were too
| 1558 |
wide with the +/-r option. (Thanks to Helena Buelow-Huebe for discovering
| 1559 |
this bug.)
| 1560 |
| 1561 |
Fixed bug in ra_ppm for 16-bit/sample i/o, where it was getting the byte
| 1562 |
order wrong (apparently).
| 1563 |
| 1564 |
Added -V option to rtcontrib to report actual contributions, rather than
| 1565 |
just ray coefficients.
| 1566 |
| 1567 |
Fixed bug in ranimate that caused it to fail in continuation of renderings.
| 1568 |
| 1569 |
Renamed librt.a to librtrad.a, to avoid conflict on Solaris. Almost
| 1570 |
everything now gets linked to -lrtrad instead of -lrt.
| 1571 |
| 1572 |
Fixed problem with large sample sets, so -u+ option now is truly random.
| 1573 |
Thanks to Rick Mistrick and Younju Yoon for identifying this problem,
| 1574 |
which was related to a poorly designed hash function.
| 1575 |
| 1576 |
Changed -u+ to be the default setting in rtrace (only).
| 1577 |
| 1578 |
Fixed binary i/o for rlam and vwrays under Windows.
| 1579 |
| 1580 |
Added tmCvLums() to tone-mapping routines using a 16-bit lookup table
| 1581 |
on IEEE floats, which is also used to improve speed of COLOR conversions,
| 1582 |
especially on machines with slow log() calls. The first call to
| 1583 |
tmCvLums(), tmCvGrays(), or tmCvColors() initializes the table.
| 1584 |
| 1585 |
Created optics2rad.csh script to convert from Optics 5 material output
| 1586 |
to something correct for Radiance. Built on old glazing.cal function,
| 1587 |
which is actually incorrect so removed from the distribution.
| 1588 |
| 1589 |
Fixed nuisance bug in ximage under some SGI machines that caused it to
| 1590 |
choose an inappropriate visual and display incorrect colors. (Thanks
| 1591 |
to Oskar Itzinger for debugging the problem.)
| 1592 |
| 1593 |
Fixed long-standing inaccuracy of pcompos -t and +t thresholding options.
| 1594 |
| 1595 |
Fixed bug in handling of views with tabs rather than spaces.
| 1596 |
| 1597 |
Fixed bug related to alias of alias.
| 1598 |
| 1599 |
| 1600 |
Changed default sky turbidity in gensky from the original default of
| 1601 |
2.75 to the CIE 110-1994 standard value of 2.45. Thanks to Marilyne
| 1602 |
Anderson of MIT for pointing out this discrepancy.
| 1603 |
| 1604 |
Added -o option to ra_xyze to produce original pixel values.
| 1605 |
| 1606 |
Fixed bug in tracing of virtual sources, where intervening glazing was
| 1607 |
not being accounted for properly.
| 1608 |
| 1609 |
Added -h option to pcompos and pcomb to eliminate verbose headers.
| 1610 |
| 1611 |
| 1612 |
Version 3.9 (Released 3/30/08)
| 1613 |
| 1614 |
Added -spec option to falsecolor to restore original spectral color scale.
| 1615 |
Also added "-s auto" option to automatically set the maximum value.
| 1616 |
| 1617 |
Added byte-swapping input and output to rcalc.
| 1618 |
| 1619 |
Additional error-checking for source surfaces.
| 1620 |
| 1621 |
Re-fixed bug in octree code that caused it to allocate 8 times as
| 1622 |
much memory as it actually used(!) -- this was pointed out way back
| 1623 |
in 1999 by Erik Reinhard and Erik Jansen, but the fix they gave me
| 1624 |
got lost in the slightly broken release process at the time. This
| 1625 |
should make a big difference in memory usage, especially for the
| 1626 |
new mesh primitive. (I measured 30% less memory usage.)
| 1627 |
| 1628 |
Corrected ray weights for material mixtures.
| 1629 |
| 1630 |
Reduced the default -n setting for obj2mesh to take better advantage
| 1631 |
of the smaller octree structure size.
| 1632 |
| 1633 |
Fixed bug in shadow cache where it was adding surfaces with antimatter
| 1634 |
holes cut in them to the obstructor list. Thanks to John Mardaljevic
| 1635 |
for discovering and reporting the problem.
| 1636 |
| 1637 |
Adding ability in mkillum to incorporate BSDF data in calculation.
| 1638 |
Internal interface (raypcalls) now used in place of rtrace process(es).
| 1639 |
| 1640 |
Fixed pixel alignment in pcomb for size reduction and enlargement.
| 1641 |
| 1642 |
Allow rtcontrib user to set -P and -PP options for persistent rendering.
| 1643 |
The only caveat is that -n setting > 1 requires -PP rather than -P.
| 1644 |
| 1645 |
Added -c option to rtcontrib to facilitate cumulative calculations.
| 1646 |
| 1647 |
| 1648 |
Fixed long-standing bug in source.cal, which caused it to produce
| 1649 |
reversed anisotropic photometric distributions due to the
| 1650 |
misorientation of the y-axis. Thanks to Zack Rogers for discovering
| 1651 |
and helping debug this problem.
| 1652 |
| 1653 |
Fixed long-standing bug in replmarks, where triangles with X-side
| 1654 |
aligned with Z-axis would cause incorrect rotations. Thanks to
| 1655 |
Zack Rogers for finding this error.
| 1656 |
| 1657 |
Added rsensor program to compute sensor signal for daylighting controls.
| 1658 |
Funding for this component was provided by the Architectural Energy
| 1659 |
Corporation in Boulder, CO, and directed by Zack Rogers.
| 1660 |
| 1661 |
Added "planisphere" (stereographic) fisheye view type for traditional
| 1662 |
daylighting analysis. Feature requested & explained by Axel Jacobs.
| 1663 |
| 1664 |
Modified -c option to rtcontrib so it can take a number of input
| 1665 |
rays to average over, rather than only produce a single accumulated
| 1666 |
record (which can now be done with -c 0).
| 1667 |
| 1668 |
| 1669 |
Version 4.0 (Released 3/12/10)
| 1670 |
| 1671 |
Added -n option to rvu to provide parallel rendering.
| 1672 |
| 1673 |
| 1674 |
Changed ".pic" extension to ".hdr" in all sources and documentation
| 1675 |
to improve interoperability with other software, since this has become
| 1676 |
the de facto extension for Radiance RGBE and XYZE pictures. Since file
| 1677 |
extensions were never more than a convention in Radiance, this does not
| 1678 |
affect operation, but may require the update of scripts, etc. written
| 1679 |
by others that assume the ".pic" suffix for Radiance output.
| 1680 |
| 1681 |
Added -N option to objview to support multiprocessing.
| 1682 |
| 1683 |
Improved sampling of circular sources (source, sphere, ring types) with
| 1684 |
quite a bit of help from David Geisler-Moroder.
| 1685 |
| 1686 |
Added "rpict" and "rvu" variables to rad, and made these as well as
| 1687 |
the "oconv", "mkillum" and "pfilt" variables accept an alternate
| 1688 |
command path in each case. Change suggested by Lars Grobe based
| 1689 |
on similar Radzilla (radz) facility by Carsten Bauer.
| 1690 |
| 1691 |
Fixed rad -v N specification to use actual view name if one.
| 1692 |
| 1693 |
Fixed error in mkillum calculation where it neglected indirect
| 1694 |
source contributions from BTDF illum's.
| 1695 |
| 1696 |
Added GMT and LATLONG header lines for Greenwich Mean Time and
| 1697 |
degrees North Latitude / East Longitude.
| 1698 |
| 1699 |
Added gendaylit to distribution (finally).
| 1700 |
| 1701 |
Added ability in vwright(1) to get view from command line arguments.
| 1702 |
| 1703 |
Created genklemsamp(1) utility to generate samples suitable for
| 1704 |
BSDF-based annual calculations. This is the first Perl script to
| 1705 |
be added to Radiance. Hopefully, others will follow.
| 1706 |
| 1707 |
Added klems_int.cal file to compute Klems bins for windows.
| 1708 |
| 1709 |
Created genskyvec utility to sample a particular sky and
| 1710 |
evaluate average radiance over the standard Tregenza sky patches.
| 1711 |
| 1712 |
Created dctimestep program to compute a set of sensor values or
| 1713 |
a combined image for a particular time using the daylight
| 1714 |
coefficient method.
| 1715 |
| 1716 |
Created src/rt/rayfifo.c for first-in/first-out handling of
| 1717 |
multiprocessing by raypcalls.c.
| 1718 |
| 1719 |
Added -n option to rtrace for executing on multiple cores
| 1720 |
using new rayfifo calls.
| 1721 |
| 1722 |
| 1723 |
Version 4.1 (Released 11/04/2011)
| 1724 |
| 1725 |
Changed ranimate behavior so remote login under a different user
| 1726 |
doesn't necessarily require the presence of the originating user's
| 1727 |
home directory.
| 1728 |
| 1729 |
Changed standard transmission function normalization back to what
| 1730 |
it was in version 3.5, following recommendation of David Geisler-Moroder,
| 1731 |
who pointed out that the revised BTDF increased too much at grazing.
| 1732 |
| 1733 |
Changed rad behavior with -N >1 on single view to call rpiece.
| 1734 |
| 1735 |
Updated SCons build system for MINGW compilation, thanks to Christian
| 1736 |
Kohler.
| 1737 |
| 1738 |
Added -u option to rlam for unbuffered output.
| 1739 |
| 1740 |
Modified dctimestep to accept sky vector and daylight coefficient matrix
| 1741 |
or list of images to sum together, as suggested by Andy McNeil.
| 1742 |
| 1743 |
Created genBSDF script to generate BSDF in Windows XML format.
| 1744 |
| 1745 |
Modified mkillum to accept detailed geometry from BSDF XML files.
| 1746 |
| 1747 |
Altered obj2rad to ignore zero normals (thanks to Jack de Valpine for
| 1748 |
suggestions and help).
| 1749 |
| 1750 |
Fixed bug in genklemsamp that caused non-uniform sampling over surfaces.
| 1751 |
| 1752 |
Fixed bugs in rhoptimize and rhcopy for 64-bit compilation.
| 1753 |
| 1754 |
Made a change to avoid problem using gcc --fast-math compile option.
| 1755 |
| 1756 |
| 1757 |
Changed behavior of rtrace and rtcontrib so that every scanline is
| 1758 |
not flushed when both -x and -y are set. This avoids flush delays
| 1759 |
in rtcontrib for large numbers of output files and delays while
| 1760 |
rendering images using rtrace with the -n option.
| 1761 |
| 1762 |
Added ability for rsensor to output ray origins and directions
| 1763 |
rather than actually loading octree and computing sensor value.
| 1764 |
| 1765 |
Fixed old bug in obj2rad where it would stop processing and
| 1766 |
report a syntax error if the "void" type is used in the map file.
| 1767 |
| 1768 |
Updated reflection model according to EGSR 2010 paper by David
| 1769 |
Geisler-Moroder and Arne Duer.
| 1770 |
| 1771 |
Replaced C-shell version of falsecolor with Perl script written
| 1772 |
by Axel Jacobs.
| 1773 |
| 1774 |
| 1775 |
Changed -sj (specular jitter) option to something called specular
| 1776 |
sampling (-ss), which if set less than 1 has the same behavior as
| 1777 |
the old -sj, but when set greater than 1, spawns multiple ray
| 1778 |
samples from semi-specular surfaces.
| 1779 |
| 1780 |
Fixed bug noticed by Randolph Fritz that caused ambient sync errors.
| 1781 |
| 1782 |
Fixed bug in findglare for reading picture files under Windows.
| 1783 |
| 1784 |
Added options to pvalue to note other color spaces on reverse conversion.
| 1785 |
Thanks to Erich Philips for the feature request.
| 1786 |
| 1787 |
Added BSDF data-driven material type with full sampling support.
| 1788 |
| 1789 |
Added BRDF calculations to genBSDF.
| 1790 |
| 1791 |
Bug fixes in rsensor thanks to help from David Geisler-Moroder.
| 1792 |
| 1793 |
Added variable-resolution BSDF support in renderers and genBSDF.
| 1794 |
| 1795 |
Created pkgBSDF program to extract BSDF geometry and put it
| 1796 |
together with surface description suitable for inclusion in
| 1797 |
a Radiance scene.
| 1798 |
| 1799 |
Muted warning for "no light sources found" when there is at least
| 1800 |
one glow object and interreflections are on (-ab > 0).
| 1801 |
| 1802 |
Fixed long-standing bug that caused underestimation of reflection
| 1803 |
when specular component was below -st threshold in non-metals.
| 1804 |
| 1805 |
Checked in cross-platform cmake build system created by Bill Hoffman
| 1806 |
of KitWare and sponsored by NREL. This includes a qt-based
| 1807 |
driver for rvu, which is built in the new subdirectory src/qtrvu.
| 1808 |
| 1809 |
| 1810 |
Version 4.2 (Release date 7/31/2014)
| 1811 |
| 1812 |
Axel Jacobs added -cp and -palettes options to falsecolor.
| 1813 |
| 1814 |
Fixed bug in matrix output of genBSDF introduced shortly before 4.1 release.
| 1815 |
| 1816 |
Made rvu more responsive in multi-processing mode when changing parameters.
| 1817 |
Explicit "new" command not needed to show changes, because it goes back
| 1818 |
to "immediate mode" once something is changed. Processing will be slow
| 1819 |
but response time quick until next "new" command.
| 1820 |
| 1821 |
Fixed major bug in transmitting proxy material sampling.
| 1822 |
| 1823 |
Patched cmake build tools (changes by Zack Galbreath).
| 1824 |
| 1825 |
Removed requirement for pflip -h to be given input file (can pipe from stdin).
| 1826 |
| 1827 |
Added "Number of processes" slider to trad "Action" pane to control rad -N
| 1828 |
option for rvu and batch rendering.
| 1829 |
| 1830 |
Added -c option to vwrays to repeat pixels for rtcontrib.
| 1831 |
| 1832 |
Reworked rtcontrib program and renamed to rcontrib. New version runs much
| 1833 |
faster, especially on multiprocessor systems, and doesn't require as much
| 1834 |
memory. No longer calls rtrace; instead does all the work itself.
| 1835 |
| 1836 |
Added -d option to genskyvec to produce direct-only (sun no sky) vector.
| 1837 |
| 1838 |
Added Ashikhmin-Shirley anisotropic BRDF model (ashik2) with help
| 1839 |
from Nicolas Boneel.
| 1840 |
| 1841 |
Added Ruby rewrite of objview.csh by Rob Guglielmetti.
| 1842 |
| 1843 |
Fixed bug in reciprocity for tensor tree BTDF representations. Thanks
| 1844 |
to Andy McNeil for identifying the problem.
| 1845 |
| 1846 |
Added MNAME and ZNAME variables to ranimove for debugging & testing.
| 1847 |
| 1848 |
Created pmblur2 command to take motion and depth buffers from ranimove
| 1849 |
to compute a better motion blur.
| 1850 |
| 1851 |
****** COMPATIBILITY CHANGE ********
| 1852 |
Changed BSDF routines to use updated/corrected XML specification and
| 1853 |
removed depracated BSDF support from mkillum.
| 1854 |
| 1855 |
Fixed behavior of i/o flushing in rcontrib with -c > 1 (averaging). Thanks
| 1856 |
to Lars Grobe for help identifying this problem.
| 1857 |
| 1858 |
Fixed bug in depth-of-field blur where view distance was measured from
| 1859 |
fore clipping plane rather than viewpoint. Thanks to Peter A-B for
| 1860 |
pointing this out.
| 1861 |
| 1862 |
Added options to dctimestep to allow multiple time steps (-n)
| 1863 |
and multiple output pictures or sensor files (-o). Also added -i
| 1864 |
option to specify float (-if) or double (-id) input for sky matrix.
| 1865 |
| 1866 |
Created gendaymtx program to compute annual sky patch matrix based
| 1867 |
on Ian Ashdown's implementation of Perez all-weather sky model.
| 1868 |
Output can be sent directly to dctimestep in ASCII or binary stream.
| 1869 |
| 1870 |
Replaced existing gendaylit.c with improved version from Wendelin Sprenger
| 1871 |
and Jan Wienold of ISE.
| 1872 |
| 1873 |
Improved accuracy of ambient calculation for large -ad settings. Thanks
| 1874 |
to Lars Grobe for noticing the problem.
| 1875 |
| 1876 |
Added -r option to gendaymtx to rotate the sky the specified number of
| 1877 |
degrees about the zenith as suggested by A. McNeil.
| 1878 |
| 1879 |
Axel Jacobs added -pal eco color map that does a blue-red-yellow scale.
| 1880 |
| 1881 |
Created bsdf2klems tool to convert from various BSDF representations to
| 1882 |
Klems basis matrix in XML file.
| 1883 |
| 1884 |
Fixed problem with inappropriate reciprocity enforcement on tensor
| 1885 |
tree reduction in genBSDF. (Thanks to A.McNeil for discovering issue.)
| 1886 |
| 1887 |
Fixed bug in isotropic tensor tree sampling for impinging rays
| 1888 |
exactly normal to surface. Thanks to Peter Apian-Bennewitz for
| 1889 |
discovering and pointing out the error.
| 1890 |
| 1891 |
Fixed double-counting bug in mirror material with alternate type.
| 1892 |
Thanks to David Geisler-Moroder for spotting the problem and helping
| 1893 |
to fix it.
| 1894 |
| 1895 |
Created rcollate program to resize and transpose matrix data for Andy
| 1896 |
McNeil's 5-phase annual simulation method.
| 1897 |
| 1898 |
Added epw2wea conversion program by Christoph Reinhart.
| 1899 |
| 1900 |
Implemented Perlin's improved noise function with help from Rahul Narain.
| 1901 |
This will change the appearance of renderings using this function.
| 1902 |
| 1903 |
Added "origin" command to rvu as requested by John Mardaljevic
| 1904 |
to place view origin at selected point in scene.
| 1905 |
| 1906 |
Switch to Perl versions of objview and objpict written by Axel Jacobs.
| 1907 |
| 1908 |
Improved rendering speed of scenes with aliases by not entering new
| 1909 |
modifiers into table if they are the same as the previously defined
| 1910 |
modifier for that name.
| 1911 |
| 1912 |
Made it so icalc and rcalc search RAYPATH directories for *.cal files
| 1913 |
given on command line. This simplifies script writing and makes these
| 1914 |
utilities consistent with other tools in Radiance.
| 1915 |
| 1916 |
Added triangulation routine to handle convex polygons in obj2mesh.
| 1917 |
| 1918 |
| 1919 |
Made backface visibility apply to all material types, including
| 1920 |
transparent and translucent materials (except dielectric and interface).
| 1921 |
This makes the option useful in cases where adjacent trans surfaces
| 1922 |
are placed next to each other by a modeler that only understands
| 1923 |
volumetric objects.
| 1924 |
| 1925 |
Changed dctimestep so that output matrices (-n > 1) are preceded by a
| 1926 |
header, and added support for float and double output formats with -o[fd].
| 1927 |
| 1928 |
Introduced eplus_adduvf program to compute user view factors for EnergyPlus.
| 1929 |
| 1930 |
Changed image-plane sampling in rpict to use Hilbert curve, which gives
| 1931 |
less of a brushed/striped appearance to output pixels with -u- (default).
| 1932 |
| 1933 |
Added ltview and ltpict Perl scripts contributed by Axel Jacobs, inspired
| 1934 |
| 1935 |
| 1936 |
Added header variables for NROWS, NCOLS and NCOMP to help standardize
| 1937 |
matrix files. This functionality has been incorporated into
| 1938 |
rcollate, gendaymtx, and dctimestep.
| 1939 |
| 1940 |
Created rmtxop utility to operate on multi-component matrices. This
| 1941 |
facilitates some daylight matrix calculations, and provides a general
| 1942 |
tool for manipulating matrix data.
| 1943 |
| 1944 |
| 1945 |
Introduced new Hessian-based error control in irradiance caching (ambient)
| 1946 |
calculation. Since the format of the stored ambient values is different,
| 1947 |
the old files will be rejected with an error message and must be removed.
| 1948 |
The programs may be compiled with the -DOLDAMB option if this is a problem.
| 1949 |
| 1950 |
Added -p option to rcontrib to set function file parameters on a per-modifier
| 1951 |
basis to simplify bin evaluation.
| 1952 |
| 1953 |
Created rfluxmtx program to compute flux transfer matrices from a sender
| 1954 |
surface to one or more receiver surfaces. (Renamed the file klems_int.cal
| 1955 |
to klems_full.cal in the process.)
| 1956 |
| 1957 |
Added "-c" option to getinfo to execute command on data segment.
| 1958 |
| 1959 |
| 1960 |
Version 5.0 (Released 9/18/2015)
| 1961 |
| 1962 |
Changed rmtxop so it writes out same type as lesser of inputs unless
| 1963 |
directed otherwise using -f? option.
| 1964 |
| 1965 |
Changed order of oconv arguments in rfluxmtx so user can specify input
| 1966 |
octree using -i option at the end instead of (or in addition to) a
| 1967 |
list of scene files.
| 1968 |
| 1969 |
Added support for argument expansion to rfluxmtx and bug fixes.
| 1970 |
| 1971 |
Fixed bug in indirect hemisphere sampling for some corner cases.
| 1972 |
| 1973 |
Added default specular lobe to BSDF interpolation.
| 1974 |
| 1975 |
Set minimum number of shadow checks before direct optimization (4).
| 1976 |
| 1977 |
(Above changes included in 4.2.1 patch release.)
| 1978 |
| 1979 |
| 1980 |
Made header input and output the default behavior for dctimestep and
| 1981 |
genskyvec.
| 1982 |
| 1983 |
| 1984 |
Changed pabopto2bsdf default behavior to add 90-degree rotation
| 1985 |
to bring pgII's definition of "up" in line with Klems axis
| 1986 |
conventions. Introduced a new header variable "upphi" to
| 1987 |
control this added rotation. Using "#upphi 90" in each
| 1988 |
BSDF input file gets back the original behavior, where it
| 1989 |
assumes that the up direction is 90-degrees from the X-axis.
| 1990 |
The default value of 0 corresponds to PAB's definition of
| 1991 |
the X-axis as being "up".
| 1992 |
| 1993 |
Fixed bug in rsensor related to having many rows (altitude) and
| 1994 |
few columns (azimuth) in sensitivity file.
| 1995 |
| 1996 |
Fixed floating point round-off error in new Hessian calculation
| 1997 |
for some sytems (Windows, primarily).
| 1998 |
| 1999 |
Fixed bug in tensor tree BSDF code that caused bus error on
| 2000 |
some systems, and may have been source of other errors as well.
| 2001 |
| 2002 |
(Above changes included in 4.2.2 patch release.)
| 2003 |
| 2004 |
Improved ambient extrapolation to avoid zero values. Actual
| 2005 |
threshold set to 5% of recorded value.
| 2006 |
| 2007 |
Changed anisotropic Gaussian and Ashikhmin models so that
| 2008 |
illegal orientation vectors are dealt with more gracefully.
| 2009 |
| 2010 |
Created wrapBSDF tool and incorporated into genBSDF along
| 2011 |
with new rfluxmtx computation.
| 2012 |
| 2013 |
Initial check-in of Roland Schregle's photon map integration.
| 2014 |
New 5.0a version designation as suggested by Andy McNeil.
| 2015 |
| 2016 |
Added left-hand coordinate sytems to rfluxmtx to correct
| 2017 |
problems with coordinate axis orientations pointed out by
| 2018 |
| 2019 |
| 2020 |
Added color output to genBSDF (+C option) and support for
| 2021 |
color rendering of Klems and tensor tree data.
| 2022 |
| 2023 |
Fixed another bug in rsensor that caused rays to be generated
| 2024 |
on opposite side of hemisphere even where sensitivity was zero.
| 2025 |
| 2026 |
Fixed bug discovered by Jacob Jonsson in Klems BSDF
| 2027 |
interpolator that caused it to over-predict normal
| 2028 |
transmittance and reflectance.
| 2029 |
| 2030 |
Added ability to read input from commands in dctimestep
| 2031 |
and rmtxop.
| 2032 |
| 2033 |
Added photon map support to rad. Fixed some double-counting
| 2034 |
issues in photon-mapping spotted by David Geisler-Moroder.
| 2035 |
| 2036 |
Added photon map support to trad.
| 2037 |
| 2038 |
Fixed bug in antimatter source testing when antimatter
| 2039 |
definition follows potential obstructor in input.
| 2040 |
| 2041 |
Fixed issue with missing character type identifier at head
| 2042 |
of genBSDF XML output.
| 2043 |
| 2044 |
Prompted by Roland S., added option to have pcompos -a order
| 2045 |
rows from top rather than bottom of image.
| 2046 |
| 2047 |
Changed dctimestep to accept matrix as well as BTDF input
| 2048 |
in the VTDs invocation mode. This permits the output of
| 2049 |
rmtxop to be used in a pinch when combining multiple BTDF
| 2050 |
layers, although interreflection between layers is not
| 2051 |
accounted for properly as it is in the WINDOW program.
| 2052 |
| 2053 |
Added Jan Wienold et al.'s evalglare to distribution.
| 2054 |
| 2055 |
Hopeful fix to deadlock issue under Mac OS X 10.10.x (Yosemite).
| 2056 |
| 2057 |
Fixed early exit of rcontrib with internal error (sample behind sender)
| 2058 |
discovered by Rob G.
| 2059 |
| 2060 |
| 2061 |
Version 5.1 (Released 8/17/2017)
| 2062 |
| 2063 |
Fixed issue with vchars.mta and symbols.mta not being installed in
| 2064 |
the appropriate metafile library location, with help from Rob G.
| 2065 |
| 2066 |
Added ability to give quoted strings to output= directive in rfluxmtx.
| 2067 |
| 2068 |
| 2069 |
Added ability to digest color (CIE-XYZ) input in pabopto2bsdf.
| 2070 |
This change alters the .sir (interpolant) format, so these files
| 2071 |
will need to be regenerated. Use the new "#colorimetry: CIE-XYZ" tag
| 2072 |
to enable on input.
| 2073 |
| 2074 |
Rewrote bsdf2klems to support tristimulus color and call wrapBSDF.
| 2075 |
Did the same for bsdf2ttree. Function specifications still gray only.
| 2076 |
| 2077 |
Reduced a problem where rvu or rholo would be slow to quit when
| 2078 |
run with many processes on a large model or one with a large
| 2079 |
ambient file (taking lots of memory). We were waiting for
| 2080 |
processes to quit one-by-one, which takes some time for each
| 2081 |
process as it disentangles its shared memory. We now
| 2082 |
wait for all the processes together, so they can disentangle
| 2083 |
in parallel. It can still take up to a minute in some cases,
| 2084 |
but not 10 minutes like it was taking before the fix.
| 2085 |
| 2086 |
Enabled ambient cache value corral for all levels, not just final two.
| 2087 |
This may reduce errors in certain pathological scenes.
| 2088 |
| 2089 |
Added -in option to rcalc, rlam, and total to limit the number of
| 2090 |
input records in hopes of circumventing Windows EOF issues on binary data.
| 2091 |
Also added -on option to rcalc and total for logical symmetry.
| 2092 |
| 2093 |
Increased modifier limit to 10,000 in rcontrib.
| 2094 |
| 2095 |
Fixed issues with glrad and added zoom response to mouse wheel input.
| 2096 |
| 2097 |
Added missing definition of "ashik2" material type to reference manual.
| 2098 |
| 2099 |
Changed genBSDF to calculate device thickness assuming Zmax==0 so
| 2100 |
pkgBSDF will generate correct proxy geometry.
| 2101 |
| 2102 |
Created pabopto2xyz tool to combine different sensor measurements
| 2103 |
into a single CIE-XYZ measurement file for color BSDF interpolation.
| 2104 |
| 2105 |
Jan Wienold updated evalglare to version 1.30
| 2106 |
| 2107 |
Roland Schregle added out-of-core photon mapping routines, which
| 2108 |
may be compiled using the PMAP_OOC macro.
| 2109 |
| 2110 |
Added -a option to getinfo for easy addition of header lines.
| 2111 |
| 2112 |
Fixed issue with multiple records on picture output in rcontrib (and rfluxmtx).
| 2113 |
Credit to Sarith Subramaniam for pointing out the problem.
| 2114 |
| 2115 |
Made mkillum more tolerant of non-planar polygons in its sampling routines.
| 2116 |
| 2117 |
Added "-recover" option to genBSDF to pick up where it left off.
| 2118 |
| 2119 |
Fixed genBSDF issue that was created incorrect normalization of
| 2120 |
Klems output. Thanks to David G-M and Christian Knoflach for
| 2121 |
discovering the error. Also improved sampling of indirect irradiance
| 2122 |
that showed some slight bias due to poor sample collision avoidance.
| 2123 |
| 2124 |
Fixed long-standing issue with -aa 0 neglecting textures in calculating
| 2125 |
surface shading.
| 2126 |
| 2127 |
Fixed bug in ranimove introduced during photon map integration.
| 2128 |
| 2129 |
Added check for steep sections of BSDF in pabopto2bsdf, creating narrower
| 2130 |
peakes in those places and mitigating some normalization issues.
| 2131 |
| 2132 |
Added view360stereo.cal by Mark Stock to handle 360-degree over/under
| 2133 |
stereo views.
| 2134 |
| 2135 |
Added MAX2SHADE macro to place limit on number of light sources
| 2136 |
to precheck for obstructions. (Currently set to 200.) This
| 2137 |
avoids excessive start-up times for scenes with many light sources.
| 2138 |
Thanks to Axel Jacobs for pointing out the problem.
| 2139 |
| 2140 |
Added -v option to obj2mesh to print out mesh statistics.
| 2141 |
| 2142 |
Rewrote bsdf2rad from ground up and made it a standard part of build.
| 2143 |
| 2144 |
Fixed bug in orientation of Reinhart/Tregenza sample generator in rfluxmtx.
| 2145 |
| 2146 |
Added ability to perform shadow-testing through unproxied BSDFs with strong
| 2147 |
through (direct-direct) component.
| 2148 |
| 2149 |
Added {+|-}a options to genBSDF and bsdf2ttree for switching off reciprocity
| 2150 |
averaging.
| 2151 |
| 2152 |
Added bias to see through BTDFs with a strong "through" component
| 2153 |
rather than scattering view rays. This is in lieu of peak extraction,
| 2154 |
which looked to be too difficult from an implementation standpoint.
| 2155 |
| 2156 |
Added bsdfview tool analogous to objview but for BSDF files (XML and SIR),
| 2157 |
which calls bsdf2rad then rad with a few useful default views.
| 2158 |
| 2159 |
| 2160 |
Version 5.2 (Release October 8, 2018)
| 2161 |
| 2162 |
Created psketch program to apply non-photorealistic rendering to selected
| 2163 |
objects, identified by modifier name(s).
| 2164 |
| 2165 |
Added '*' and '/' operations to rmtxop for element-wise multiplication and
| 2166 |
division of same-sized matrices.
| 2167 |
| 2168 |
Changed falsecolor so "-s" option is adjusted to match legend if one.
| 2169 |
| 2170 |
Falsecolor legend changes and improvements by David G-M and Stephen W.
| 2171 |
| 2172 |
Fixed bug in peak extraction code that generated
| 2173 |
"Bad call to SDqueryTreProjSA" error, reported by Lars Grobe.
| 2174 |
| 2175 |
Increased maximum luminance to 10^7 in pcond to fix issue noticed
| 2176 |
by Axel Jacobs where veiling glare not added for the sun under
| 2177 |
some conditions.
| 2178 |
| 2179 |
Increased maximum number of open files in rcontrib to the system upper
| 2180 |
limit of 2048 rather than the default 512 under Windows.
| 2181 |
| 2182 |
Added top-level resources directory with files from Rob Guglielmetti.
| 2183 |
| 2184 |
Improved accuracy for peaky BSDFs and small light sources.
| 2185 |
| 2186 |
Fixed issue with pmapdump noted by Axel Jacobs.
| 2187 |
| 2188 |
Improved accuracy of bsdf2ttree when converting scattering interpolation
| 2189 |
representatons with strong peaks.
| 2190 |
| 2191 |
Tweaked peak-extraction code to work more reliably.
| 2192 |
| 2193 |
Georg Mischler updated SCons build system.
| 2194 |
| 2195 |
Rob Guglielmetti and Alex Swindler updated CMake build system.
| 2196 |
| 2197 |
Modified pcomb so the first view seen in the inputs is written into header.
| 2198 |
| 2199 |
Wrote rtpict script to run rtrace in parallel mode and simulate rpict with
| 2200 |
-n option.
| 2201 |
| 2202 |
Added ability to move forwards/backwards specified distance in rvu "origin"
| 2203 |
command. Feature requested by John Mardaljevic, who essentially owns this
| 2204 |
command, now.
| 2205 |
| 2206 |
Reduced bias in ambient super-sampling method.
| 2207 |
| 2208 |
Fixed bugs associated with zero transmission in chromatic tensor trees.
| 2209 |
Thanks to Lars Grobe for pointing out issues.
| 2210 |
| 2211 |
Added RAYPATH searching for -f options to genrev, gensurf, genworm,
| 2212 |
bsdf2klems, bsdf2ttree, and pcomb. This makes behavior consistent
| 2213 |
with rcalc, calc, and rendering tools.
| 2214 |
| 2215 |
Worked with Randolph Fritz to fix some issues with ies2rad and newer
| 2216 |
IESNA63 standards.
| 2217 |
| 2218 |
Resurrected original bsdf2rad test program, renaming it bsdf2rado. Still an
| 2219 |
optional build in src/cv/.
| 2220 |
| 2221 |
Fixed bug in rcontrib with virtual sources, where pretest was adding
| 2222 |
to modifier accumulation buffers. Reported by Mostapha.
| 2223 |
| 2224 |
Added an "aBSDF" material type that explicitly checks for peak extraction.
| 2225 |
Its arguments are the same as the original "BSDF" type, but without the
| 2226 |
thickness parameter, as proxy geometry is not supported by this new type.
| 2227 |
The old "BSDF" type no longer does peak extraction under any circumstances,
| 2228 |
since this behavior is superfluous for proxied geometry.
| 2229 |
| 2230 |
Added -r option to bsdf2rad (and bsdfview) to fix BSDF min and max range
| 2231 |
for comparing BSDFs.
| 2232 |
| 2233 |
Fixed issue with pfilt -m option and uneven image size changes pointed
| 2234 |
out by Rob Shakespeare.
| 2235 |
| 2236 |
Updates to evalglare and gendaylit from Jan Wienold, including new
| 2237 |
colored sky option.
| 2238 |
| 2239 |
| 2240 |
Version 5.3 (Released September 1, 2020)
| 2241 |
| 2242 |
Created radcompare program to compare Radiance tool output to reference outputs
| 2243 |
during unit-testing.
| 2244 |
| 2245 |
Fixed issue reading very large files (> 2 GBytes) in rcollate.
| 2246 |
| 2247 |
Made picking function in rvu ignore transparent and void surfaces.
| 2248 |
| 2249 |
Added -orRxX options to rtrace to enable output of mirrored and unmirrored
| 2250 |
contributions and distances to enable new types of reprojections. This also
| 2251 |
cleaned up and unified handling of effective ray lengths throughout code.
| 2252 |
| 2253 |
Bug fixes from Jan Wienold for evalglare.
| 2254 |
| 2255 |
Changed indexed (numbered) output from dctimestep to start from 0 rather
| 2256 |
than 1, to make it more consistent with expected input naming.
| 2257 |
| 2258 |
Increased default sampling in bsdf2klems (-n option) to 1024.
| 2259 |
| 2260 |
Fixed an issue noticed by David G-M that was causing genBSDF to bias
| 2261 |
isotropic tensor tree samples resulting in subsequent failure of
| 2262 |
peak extraction with "aBSDF" type.
| 2263 |
| 2264 |
Introduced max() and min() functions to .cal library.
| 2265 |
| 2266 |
Added random incident patch sampling to bsdf2klems to improve accuracy
| 2267 |
with scattering interpolation representation input (e.g., from
| 2268 |
pabopto2bsdf). The other input types already sampled incident patch area.
| 2269 |
| 2270 |
Added gendaymtx -A option to compute average sky over all the input
| 2271 |
time steps.
| 2272 |
| 2273 |
Added ability to output color image from rtrace with any of -ovrx options.
| 2274 |
Also fixed inconsistency of -oN output when ray casting versus full trace.
| 2275 |
Before, it would flip normal to front side unless ray casting. Now, -oN
| 2276 |
always reports the unflipped normal.
| 2277 |
| 2278 |
Changed rlam behavior so -iaN reads N lines from a stream rather than N
| 2279 |
characters. This seems more useful, since -ibN is somewhat redundant with
| 2280 |
the old behavior.
| 2281 |
| 2282 |
Created rsplit program as compliment to rlam and to handle more complex
| 2283 |
rtrace output into separate files or streams.
| 2284 |
| 2285 |
Improved getinfo so that it can also hop over resolution string with -c
| 2286 |
and header elide mode. Use +d to include resolution string in output,
| 2287 |
and -d to elide with - and -c options.
| 2288 |
| 2289 |
Made pvalue -u option mean "uncompressed" with -r. Also, allow skipping
| 2290 |
bytes on standard input.
| 2291 |
| 2292 |
Created rcode_depth tool to convert to and from a 16-bit/pixel portable
| 2293 |
depth image encoding that uses a mix of linear and reciprocal distance
| 2294 |
with explicit representations of 0 and infinity. Code for loading these
| 2295 |
depth maps is in src/common/depthcodec.{h,c}.
| 2296 |
| 2297 |
Created rcode_norm tool to convert to and from 32-bit/pixel portable
| 2298 |
surface normal representation, matching the one in src/common/dircode.c.
| 2299 |
Code for loading normal maps is in src/common/normcodec.{h,c}.
| 2300 |
| 2301 |
Created rcode_ident tool to create indexed identifier files.
| 2302 |
Code for loading these files is in src/common/idmap.{h,c}.
| 2303 |
| 2304 |
Added -o* option to rtpict to produce layered images that handle most
| 2305 |
output types from rtrace (colors, surface normals, distances, IDs).
| 2306 |
| 2307 |
Created rcode2bmp script to create images from new rcode_* output maps.
| 2308 |
| 2309 |
Improved efficiency of rmtxop in cases where matrix multiplication is
| 2310 |
faster evaluated right-to-left, as when the final component is a
| 2311 |
column vector. Also added ability to apply trailing unary operators
| 2312 |
(-t, and -s or -c) to resulting matrix.
| 2313 |
| 2314 |
Added new depth, normal, and ID file types to radcompare.
| 2315 |
| 2316 |
Added BigEndian= header line for automatic byte-swapping in rmtxop
| 2317 |
and radcompare.
| 2318 |
| 2319 |
Added new "turbo" palette to falsecolor (thanks to Taoning).
| 2320 |
| 2321 |
Nathaniel Jones created the "dcglare" program for annual glare
| 2322 |
simulations when the sun and sky are visible through the window.
| 2323 |
Tutorial is posted at
| 2324 |
"https://github.com/nljones/Accelerad/wiki/The-Imageless-Method-for-Spatial-and-Annual-Glare-Analysis".
| 2325 |
| 2326 |
Added support for loading RGBE images into matrices in dctimestep.
| 2327 |
| 2328 |
Added -y option to gensky and gendaylit to support more accurate Michalsky
| 2329 |
solar position calculation.
| 2330 |
| 2331 |
Changed rsplit, so specifying a space as the separator parses words
| 2332 |
between whitespace.
| 2333 |
| 2334 |
Added ability of vwrays, pinterp, and pmblur2 to read encoded depth files.
| 2335 |
| 2336 |
Added -o RxCxR1xC1 facility to perform blocking in rcollate.
| 2337 |
| 2338 |
Made it so number of segments in genworm, genrev, and gensurf can be
| 2339 |
given as expressions of previously defined variables, etc.
| 2340 |
| 2341 |
Added -D and -n option to gendaymtx to output sun description and skip
| 2342 |
matrix output on request. A -M option was also added to output solar
| 2343 |
modifiers for rcontrib. Support also added for leap days in WEA input.
| 2344 |
Enhancements sponsored by Ladybug Tools.
| 2345 |
| 2346 |
Updated eplus_uvf to work with IDF version 9.x, checking version number.
| 2347 |
| 2348 |
Fix to glarendx issues with dgi calculation.
| 2349 |
| 2350 |
Made it so rmtxop and dctimestep undo any exposure applied to Radiance
| 2351 |
pictures they may load.
| 2352 |
| 2353 |
Added robjutil utility to manipulate Wavefront .OBJ files.
| 2354 |
| 2355 |
Fixed a crash related to rtrace -om or -oM with mesh instances containing
| 2356 |
materials.
| 2357 |
| 2358 |
Improved rtrace flushing function to handle any value for -x without
| 2359 |
deadlock on controlling process.
| 2360 |
| 2361 |
Eliminated unnecessary start-up procedures for rtrace when only ray-casting
| 2362 |
is needed (i.e., no tracing or value output).
| 2363 |
| 2364 |
Improved isotropic sampling method in bsdf2ttree using "zipper" approach
| 2365 |
applied in genBSDF.
| 2366 |
| 2367 |
Added limit to memory used by high-resolution tensor tree BSDFs for
| 2368 |
cumulative cache during MC sampling (rendering). Limit set to 250MBytes
| 2369 |
per BSDF for standard architectures.
| 2370 |
| 2371 |
Added -n and -s options to bsdf2ttree to provide some user control
| 2372 |
over super-sampling.
| 2373 |
| 2374 |
Improved surface normal codec used by ambient file to store orthonormal
| 2375 |
directions exactly.
| 2376 |
| 2377 |
Improved peak extraction method, which was undervaluing transmission
| 2378 |
in many cases.
| 2379 |
| 2380 |
New version of evalglare from Jan Wienold.
| 2381 |
| 2382 |
Added -u option to gendaymtx to elide data columns (time steps) when
| 2383 |
the sun is not visible above the horizon.
| 2384 |
| 2385 |
| 2386 |
Version 5.4
| 2387 |
| 2388 |
Added rcollate -c option to force operation to continue even if it
| 2389 |
seems unnecessary. Made tool more robust.
| 2390 |
| 2391 |
Added -t option to rcontrib (and rfluxmtx) to report progress after the
| 2392 |
given number of seconds.
| 2393 |
| 2394 |
Added "test" target to makeall to run unit tests.
| 2395 |
| 2396 |
Modified bsdf2ttree to allow different parameters per input SIR file.
| 2397 |
| 2398 |
Fixed issues with very large matrix files (> 2GB) in dctimestep, rmtxop,
| 2399 |
and rcollate.
| 2400 |
| 2401 |
Added -rf and -rb options to rmtxop to load front or back reflectance
| 2402 |
matrix data from XML file rather than transmission. (Lars Grobe suggested.)
| 2403 |
| 2404 |
Improved behavior for coincident surfaces with different materials.
| 2405 |
Rather than returning one surface or the other based on floating-point
| 2406 |
vagaries, opaque materials are now preferred over transparent ones.
| 2407 |
If the materials are both transparent or both opaque, then whichever
| 2408 |
surface appeared later in the scene description will be selected.
| 2409 |
This came of a request for consistent behavior with legal CAD output
| 2410 |
from Peter Apian-Bennewitz.
| 2411 |
| 2412 |
Added explicit tests for on-edge intersections with polygons. This should
| 2413 |
eliminate stray rays and tiny light leaks that often appear even in
| 2414 |
well-constructed geometry.
| 2415 |
| 2416 |
Added "-s up" option to pabopto2bsdf to allow for 180 degree symmetry,
| 2417 |
meaning that data repeats after 180 degree rotation (as distinguished
| 2418 |
from "-s bilateral" whose data is mirrored about a vertical plane).
| 2419 |
Thanks to Helen Rose Wilson for the suggestion and informing me that
| 2420 |
such a thing exists.
| 2421 |
| 2422 |
Removed upper limit on number of modifiers in rcontrib.
| 2423 |
| 2424 |
Put cap on maximum ambient gradient to avoid over-extrapolation of
| 2425 |
poorly computed irradiance cache values.
| 2426 |
| 2427 |
Added robjutil +T option to triangulate all faces in .OBJ description.
| 2428 |
| 2429 |
Altered BSDF library to have both front and back diffuse transmittance
| 2430 |
values, which can be different. This was necessary to avoid issues
| 2431 |
caused by measurement and modeling discrepancies.
| 2432 |
| 2433 |
Added pabopto2bsdf -g option to cull near-grazing scattering to avoid
| 2434 |
issues with noise and negative values.
| 2435 |
| 2436 |
Increased default dynamic range from 32 to 100 in pcond and normtiff.
| 2437 |
| 2438 |
Added -o and -n options to genbox to create .OBJ output and segment
| 2439 |
edges and corners for transparent materials. Also added -s option
| 2440 |
to control smoothing for .OBJ and Radiance with segmented rounding.
| 2441 |
| 2442 |
Made it so robjutil with the +r option for Radiance output now
| 2443 |
produces normal smoothing unless normals are removed with -n.
| 2444 |
| 2445 |
Added exposure preservation to pcompos when possible (i.e., when
| 2446 |
there is only one input or inputs agree on exposure).
| 2447 |
| 2448 |
Added -DSHARP_RGB compile-time option to use sharp RGB color space
| 2449 |
rather than historic default. This can make for more accurate color
| 2450 |
calculations, but requires that materials be recalibrated. The
| 2451 |
PRIMARIES= line is also produced on output from rpict or rvu with
| 2452 |
the correct set of primaries based on how the system was compiled.
| 2453 |
| 2454 |
Added automatic flushing to the output of total, except when the -r
| 2455 |
(running subtotals) option is used.
| 2456 |
| 2457 |
Improved behavior of little-used -aw option, so that it avoids sea-level
| 2458 |
rise caused by adding its own estimate back into the ambient level remainder.
| 2459 |
It ended up being simple enough to derate the final average by the factor
| 2460 |
corresponding to average surface absorpition, thus removing the average
| 2461 |
from the final bounce estimate.
| 2462 |
| 2463 |
Introduced ies2rad upgrades by Randolph Fritz. Randolph says it
| 2464 |
fixes the following problems:
| 2465 |
| 2466 |
1. Generates correct Radiance geometry for spheres in 1995, 2002,
| 2467 |
and 2019 IES files.
| 2468 |
| 2469 |
2. Generates correct Radiance geometry for vertical cylinders that
| 2470 |
are taller than they are wide.
| 2471 |
| 2472 |
3. Ignores the file source ("File Generation Type") field in the
| 2473 |
2019 version of the file, which would otherwise be incorrectly used
| 2474 |
as an output multiplier.
| 2475 |
| 2476 |
It also offers the following enhancements:
| 2477 |
| 2478 |
1. Shape information is included in the .rad file comments.
| 2479 |
| 2480 |
2. 1995, 2002, and 2019-version luminous opening geometry is
| 2481 |
accounted for.
| 2482 |
| 2483 |
3. The 2002 and 2019 IES file versions are recognized and
| 2484 |
processed appropriately.
| 2485 |
| 2486 |
4. I have made an attempt to do something intelligent with less
| 2487 |
common "luminous opening" shapes in the 1995, 2002, and 2019 versions
| 2488 |
of the standard, though I have not implemented any support for new
| 2489 |
geometry; approximations are substituted and warning messages issued.
| 2490 |
Unfortunately, this code is not tested, since I don't have any IES
| 2491 |
files that use these shapes.
| 2492 |
| 2493 |
Added support for depth-of-field blurring in vwrays using -pd option.
| 2494 |
Also, made -c count work with vwrays -i, producing multiple samples
| 2495 |
per indicated pixel position. At the same time, support for the -pd
| 2496 |
option was added to rtpict, which calls on vwrays for its samples.
| 2497 |
| 2498 |
Fixed issue with BSDFs that didn't obey reciprocity, where direct
| 2499 |
sampling wasn't following exactly with indirect sampling. This was
| 2500 |
discovered and reported by Jon Sargent.
| 2501 |
| 2502 |
Created checkBSDF tool to test XML BSDF reciprocity and perform similar
| 2503 |
sanity checks.
| 2504 |
| 2505 |
Added -O option to pvalue and pextrem to report watts/sr/m^2 even if
| 2506 |
picture is XYZE.
| 2507 |
| 2508 |
Made subtle changes to header i/o routines to preserve alignment in
| 2509 |
binary file formats to enable memory-mapping. Implemented memory-mapped
| 2510 |
matrix loading in rmtxop for binary double files.
| 2511 |
| 2512 |
Removed ambient value sorting, which was written when ambient caches
| 2513 |
could overwhelm available memory. This is rarely the case these days,
| 2514 |
and the added code complexity and updating of cache values with LRU
| 2515 |
counts dirties pages that would otherwise remain clean, so it was
| 2516 |
often a loss even when VM was an issue.
| 2517 |
| 2518 |
Added iso2klems script to compute a Klems BSDF based on specular
| 2519 |
and diffuse measurements as a function of incident angle.
| 2520 |
| 2521 |
Fixed issue with over-counting diffuse component during aBSDF
| 2522 |
peak extraction.
| 2523 |
| 2524 |
Added dctimestep -x and -y options to specify image dimensions
| 2525 |
for multiple outputs corresponding to result vectors.
| 2526 |
| 2527 |
Added -P option to rcalc to pass formatted input when cond is <= 0.
| 2528 |
| 2529 |
Created rcrop utility for cropping matrices and pictures more
| 2530 |
conveniently, correcting view information. Expect it to be handy
| 2531 |
for extracting rows and columns from matrices, mostly.
| 2532 |
| 2533 |
Changed pcomb so -o option elides original exposure values
| 2534 |
from indented source headers.
| 2535 |
| 2536 |
Added getinfo -r option, which is similar to -a except it will
| 2537 |
replace indicated lines with new ones.
| 2538 |
| 2539 |
Slight change to vwrays -d option to not spit out "-ld-", and to
| 2540 |
produce "-ld+" without requiring input picture as argument.
| 2541 |
| 2542 |
Added automatic overture calculation to rtpict with -n > 1 if
| 2543 |
ambient cache is on and file is named. If straight image output
| 2544 |
is requested, we randomize all samples and avoid cache collisions.
| 2545 |
| 2546 |
Added cnt -s option to shuffle output.
| 2547 |
| 2548 |
Fixed issue with divide-by-zero errors in the ambient super-sampling
| 2549 |
routine discovered by Jon Sargent of Solemma. This affected regions
| 2550 |
that had zero radiance, such as black backgrounds or unlit areas
| 2551 |
with -av 0 0 0, when super-sampling was effectively disabled, causing
| 2552 |
some loss in accuracy of the results.
| 2553 |
| 2554 |
Updated Klems Half- and Quarter-bases to match angles currently used
| 2555 |
in WINDOW.
| 2556 |
| 2557 |
Eliminated most aiming failures for triangular light sources, at the
| 2558 |
expense of conservative sampling near the centroid. Thanks to
| 2559 |
David Geisler-Moroder for his help on this.
| 2560 |
| 2561 |
Increased maximum set size to 8191 to avoid set overflow errors.
| 2562 |
| 2563 |
Added source obstruction test to statistics being kept on which
| 2564 |
sources were visible in adaptive shadow testing code. Previous
| 2565 |
behavior was likely over-estimating source contributions.
| 2566 |
| 2567 |
Added diffuse components into maximum directional hemispherical
| 2568 |
reported by checkBSDF, so comparing to 100% is easier for each
| 2569 |
component.
| 2570 |
| 2571 |
Fixed incorrect calculations in iso2klems script, thanks to
| 2572 |
help from Jacob Jonnson.
| 2573 |
| 2574 |
Updated official copyright and license according to new wording
| 2575 |
provided by Jean Haemmerle at the LBNL Intellectual Property Office.
| 2576 |
Both were copied verbatim from e-mail I received from Taoning Wang
| 2577 |
on 8/20/2022.
| 2578 |
| 2579 |
Added -features option to rpict, rtrace, and rcontrib to check
| 2580 |
which features are present or look for specific feature support.
| 2581 |
This addition was suggested by Peter Apian-Bennewitz as an easier
| 2582 |
way to determine which version of Radiance is installed and what
| 2583 |
it supports, and is timely as we begin our refactoring of the
| 2584 |
rendering code. There are no current plans to add this to rvu.
| 2585 |
| 2586 |
Added falsecolor -odim, -orct, and -c0 options to overlay grid of
| 2587 |
values on image. This was requested by Rob Shakespeare.
| 2588 |
| 2589 |
Added -i* and -o* options in rhcopy for reading rays from the
| 2590 |
standard input and writing rays from holodeck to standard output.
| 2591 |
This will hopefully be useful in combining rholo with rcontrib.
| 2592 |
| 2593 |
Added further checking for coincident (overlapping) flat surfaces,
| 2594 |
preferring front sides to back sides in the ray intersection
| 2595 |
calculation. This only applies to rings and faces, as the other
| 2596 |
surface types would have required additional calculations to
| 2597 |
make them work. Material transparency is still the primary
| 2598 |
consideration, now followed by ray hit side, followed by
| 2599 |
modifier definition order in the input.
| 2600 |
| 2601 |
Increased octree and object limits to allow scenes with billions
| 2602 |
of primitives.
| 2603 |
| 2604 |
Made reciprocity averaging default to "off" in bsdf2ttree, as it seems
| 2605 |
to create more problems than it solves.
| 2606 |
| 2607 |
| 2608 |
Version 6.0
| 2609 |
| 2610 |
Extensive changes to enable spectral rendering, which defaults to "off"
| 2611 |
to maintain backwards-compatibility with previous versions, with the
| 2612 |
exception of the ambient file format, which is changed. The MAXCSAMP
| 2613 |
macro, which defaults to 24, sets the maximum number of spectral samples.
| 2614 |
The actual number of samples is set by the "-cs" option, which defaults
| 2615 |
to 3 for rpict, rtrace, and rcontrib. The latter two programs support
| 2616 |
straight spectral output, but rpict is initially restricted to
| 2617 |
tristimulus output pictures. New pattern primitives "spectrum",
| 2618 |
"specfile", and "specfunc" have been added as a means to specify
| 2619 |
spectral reflectance, emittance, etc. to materials that still have
| 2620 |
only 3 color channels. Those RGB channels will still affect the
| 2621 |
spectrum if used. Unfortunately photon-mapping is currently broken when
| 2622 |
spectral sampling is enabled, but we will fix this as soon as possible.
| 2623 |
Calculation overhead appears to be approximately 10-15% for RGB
| 2624 |
renderings compared to version 5.4a.
| 2625 |
| 2626 |
Added spectral rendering to rvu as well, and made -cs and -cw
| 2627 |
options standard across the rendering library. I also brought
| 2628 |
mkillum, ranimove, rsensor, and mksource into the fold. These
| 2629 |
tools were broken in the initial release. (Hopefully, they are
| 2630 |
working now, but none have been tested as yet.)
| 2631 |
There was also an indexing bug in the spectral->RGB conversions
| 2632 |
that made reds into blues and vice versa, which has been fixed.
| 2633 |
| 2634 |
Added i/o for spectral pictures to rmtxop, the first program that can
| 2635 |
ingest them. (Only rtrace, rcontrib, and rfluxmtx can render them.)
| 2636 |
New symbolic rmtxop -c options, such as RGB, XYZ, S (for scotopic)
| 2637 |
and M (for melanopic) make color conversions simpler. Alternatively,
| 2638 |
a reference matrix or picture may be given and the color space of
| 2639 |
that file will be used. The -C option takes either a symbolic
| 2640 |
color space or reference file and is "sticky," so it applies to
| 2641 |
all subsequent input files that do not have their own -c right ahead
| 2642 |
of them.
| 2643 |
| 2644 |
Added spectral picture support to rcrop and radcompare.
| 2645 |
| 2646 |
Added new utility, rcomb, which is something like a combination
| 2647 |
of rmtxop and pcomb, it works with all the inputs and
| 2648 |
outputs that rmtxop handles, but allows for general expressions
| 2649 |
like those in pcomb for putting matrices together, working on
| 2650 |
an element at a time. (No resizing of matrices or accessing
| 2651 |
neighboring elements, as permitted in pcomb.) It saves memory
| 2652 |
over rmtxop by operating on a row at a time, so can handle
| 2653 |
input and output matrices with any number of rows. It does
| 2654 |
provide for a single matrix-multiplication operation at the end,
| 2655 |
which only requires memory for that final matrix.
| 2656 |
| 2657 |
Added support for filtering hyperspectral images to pfilt.
| 2658 |
| 2659 |
Added support for 1- and 3-component float matrix i/o to
| 2660 |
pcomb to allow for better interoperability.
| 2661 |
| 2662 |
Added support for -co+ option to rtpict, so it can directly
| 2663 |
produce hyperspectral images.
| 2664 |
| 2665 |
Added new "specdata" and "specpict" primitives to support
| 2666 |
interpolated spectral data files and hyperspectral images
| 2667 |
as patterns.
| 2668 |
| 2669 |
Added support for multispectal sampling in rsensor, which will
| 2670 |
put out as many color channels as specified in any -cs option
| 2671 |
(default is 3 for RGB).
| 2672 |
| 2673 |
Added ability of mgf2rad to convert spectral data at least
| 2674 |
for light, glow, plastic, and metal primitive types. Need
| 2675 |
to use new '-s' option to get new output.
| 2676 |
| 2677 |
Added handling of spectral images to rcode2bmp script.
| 2678 |
| 2679 |
Minor change to rcollate to allow explicit byte records to
| 2680 |
be any specified length without checks against header input.
| 2681 |
| 2682 |
Added new hemisphere type to rfluxmtx, "h=cie" for CIE sky
| 2683 |
scanner positions. These are 145 patches with identical
| 2684 |
row counts to Tregenza, but starting from a different
| 2685 |
azimuth and reversing row directions at adjacent altitudes.
| 2686 |
| 2687 |
Added optimization for long argument lists and arrays in
| 2688 |
the calcomp routines used for rendering and in rcalc, etc.
