root/radiance/ray/doc/notes/ReleaseNotes
Revision: 1.422
Committed: Wed Oct 19 21:25:20 2022 UTC (2 years, 6 months ago) by greg
Changes since 1.421: +7 -0 lines
1 =========================
3
11
12 pfilt -x 512 -y 400 -p 1
13
18
21
25 and vv parameters).
26
30
40
44
45 =========================
47
53
56
58
62
66
72
75
77 traced on an X11 display.
78
83
86
87 =========================
89
92
94
97 library directory.
98
101
105
107
110
112
114 white light assumption.
115
117
119 checking and clarity.
120
123
128
132
133 =========================
135
140
142 picture.
143
145
150
152
155 and transdata types.
156
158 component.
159
162
166
168 value labels.
169
172
179
183 undefined modifiers.
184
187
192
197
199
203
205 to slant the wrong way!
206
209
218
221
223
229
232
236
238 -version option.
239
242
244
251
253
258
260
273
275
278
282
286 pinterp and findglare.
287
290
295 support it.
296
298
304
308
312
315
317
319 from a file.
320
322
324
326
331
336 pointed this out to me!
337
340
345
350
352 and color ordering.
353
355
358
361
363 some scene files.
364
367
371
373 used consistently.
374
376
378 further reduce errors.
379
381
385
387
395
398
402
405 options.
406
408 cast by mirrors.
409
411
414 MS-DOS.
415
417 brightness.
418
421 unperturbed).
422
429
432
435
437
444
447 unconditionally.
448
452
455 suggestion.)
456
461
464
467
471 helped.
472
479
482
485
488
490
492 for each picture file.
493
496
502
505
508
511
515
521
524
526
528
531
535
538
541
544
546 Format) specification.
547
550
552 at all!
553
555 under X11.
556
560 for the same value!
561
563 changes to input files.
564
567
569 Radiance view parameters.
570
572
575
577 language.
578
580
582 files.
583
586
588 values.
589
591
594
597
599
601
603 interesting applications.
604
607
610
613
616
618 simulation with pinterp.
619
622
625
630
635
639 regions.
640
642
645
649 of clouds.
650
654 the same as before.
655
657 walk-through animations.
658
661
663 on multiple hosts.
664
667
670
672 Alphas.
673
678
681 large image patterns.
682
686 method.
687
692
694
699
709 back old behavior.
710
713
716
718
720
722
724
732
737 sources.
738
750 to bright exteriors.
751
754
758
763
768
771 definitions.
772
775 pcond(1).
776
779
782
784 (Included in 3.1.1.)
785
788
790
792 views or pictures.
793
797
801
803
806 (Included in 3.1.4.)
807
809 (Included in 3.1.3.)
810
812 (Included in 3.1.3.)
813
815 image formats.
816
820
823 to PostScript printers.
824
826 (Included in 3.1.6.)
827
830
832
836
840
844
847
849 commands.
850
852
855
857
860
863
867
870
872
878 material for shading.
879
882
884
889
891
893
895 forcing greyscale output.
896
899
902
904
906 directly using ximage.
907
909
912
914 CMCCAT2000 matrix.
915
917
919
921 by Erich Phillips.
922
925
928 instances).
929
932
934 to unity.
935
939
942 for pointing it out.
943
945
950
954
956
958 valid(s,t) function.
959
962
966
968 for standard input.
969
973 used to.
974
980
986
990
993
997
1000 feedback.
1001
1009 hurrah!
1010
1020
1024
1029
1032
1036 previous value of 1.0.
1037
1049
1058
1064
1072 specification.
1073
1076
1088
1097
1100
1103 textured surfaces.
1104
1122
1129 substitution.
1130
1140 the stack limit.
1141
1143 Version 3.6 (Released 10/21/04)
1144
1148
1150
1152
1155
1158
1162
1165
1169 IEEE float.)
1170
1172 parallel.
1173
1176
1178 files.
1179
1184 as well.
1185
1187 to new mesh primitive.
1188
1190 doubles, respectively.
1191
1193
1197
1200
1203
1205 didn't need to.
1206
1212
1215
1218
1220
1222
1224
1226
1234 have plenty.)
1235
1239 calc -> icalc
1240 lam -> rlam
1241 gencat -> gencatenary
1242
1244
1248
1253
1255
1258
1261
1264
1267
1271
1277
1279 locations.
1280
1283
1287
1289 protate commands.
1290
1293 middle of a stream.
1294
1298
1302
1304
1308
1311
1313
1320
1330
1333
1337
1341
1343 correctly.
1344
1345 =====================
1346 Version 3.7 (Released 7/25/05)
1347
1350 finding the problem.)
1351
1355
1357
1360
1366 but never quite worked
1373 reinstate it.
1374
1377 this out.
1378
1381
1384
1388
1391
1395 by the vwright command.
1396
1399
1401 ('f'/"frame" command).
1402
1405
1411 works.)
1412
1414 TIFF i/o in ra_tiff.
1415
1418
1422
1425
1434 caching on (-aa > 0).
1435
1442
1444
1446
1449
1451
1455
1459
1462
1464
1466
1468
1471
1473
1476
1478
1480 infinite loop.
1481
1484
1486
1490
1491 =====================
1492 Version 3.8 (Released 10/17/06)
1493
1497
1499
1501
1504
1508
1510
1512
1515
1518
1522
1524
1526
1529
1532
1534
1536
1539
1542
1545
1547
1551
1554
1556
1559 this bug.)
1560
1563
1565 just ray coefficients.
1566
1568
1571
1575
1577
1579
1584
1588
1592
1594
1596
1598
1603
1605
1608
1610
1611 =====================
1612 Version 3.9 (Released 3/30/08)
1613
1616
1618
1620
1624 got lost in the slightly broken release process at the time. This
1627
1629
1632
1636
1639
1640 Fixed pixel alignment in pcomb for size reduction and enlargement.
1641
1642 Allow rtcontrib user to set -P and -PP options for persistent rendering.
1643 The only caveat is that -n setting > 1 requires -PP rather than -P.
1644
1645 Added -c option to rtcontrib to facilitate cumulative calculations.
1646
1647 ****** COMPATIBILITY CHANGE ********
1648 Fixed long-standing bug in source.cal, which caused it to produce
1649 reversed anisotropic photometric distributions due to the
1650 misorientation of the y-axis. Thanks to Zack Rogers for discovering
1651 and helping debug this problem.
1652
1653 Fixed long-standing bug in replmarks, where triangles with X-side
1654 aligned with Z-axis would cause incorrect rotations. Thanks to
1655 Zack Rogers for finding this error.
1656
1657 Added rsensor program to compute sensor signal for daylighting controls.
1658 Funding for this component was provided by the Architectural Energy
1659 Corporation in Boulder, CO, and directed by Zack Rogers.
1660
1661 Added "planisphere" (stereographic) fisheye view type for traditional
1662 daylighting analysis. Feature requested & explained by Axel Jacobs.
1663
1664 Modified -c option to rtcontrib so it can take a number of input
1665 rays to average over, rather than only produce a single accumulated
1666 record (which can now be done with -c 0).
1667
1668 =====================
1669 Version 4.0 (Released 3/12/10)
1670
1671 Added -n option to rvu to provide parallel rendering.
1672
1673 ****** COMPATIBILITY CHANGE ********
1674 Changed ".pic" extension to ".hdr" in all sources and documentation
1675 to improve interoperability with other software, since this has become
1676 the de facto extension for Radiance RGBE and XYZE pictures. Since file
1677 extensions were never more than a convention in Radiance, this does not
1678 affect operation, but may require the update of scripts, etc. written
1679 by others that assume the ".pic" suffix for Radiance output.
1680
1681 Added -N option to objview to support multiprocessing.
1682
1683 Improved sampling of circular sources (source, sphere, ring types) with
1684 quite a bit of help from David Geisler-Moroder.
1685
1686 Added "rpict" and "rvu" variables to rad, and made these as well as
1687 the "oconv", "mkillum" and "pfilt" variables accept an alternate
1688 command path in each case. Change suggested by Lars Grobe based
1689 on similar Radzilla (radz) facility by Carsten Bauer.
1690
1691 Fixed rad -v N specification to use actual view name if one.
1692
1693 Fixed error in mkillum calculation where it neglected indirect
1694 source contributions from BTDF illum's.
1695
1696 Added GMT and LATLONG header lines for Greenwich Mean Time and
1697 degrees North Latitude / East Longitude.
1698
1699 Added gendaylit to distribution (finally).
1700
1701 Added ability in vwright(1) to get view from command line arguments.
1702
1703 Created genklemsamp(1) utility to generate samples suitable for
1704 BSDF-based annual calculations. This is the first Perl script to
1705 be added to Radiance. Hopefully, others will follow.
1706
1707 Added klems_int.cal file to compute Klems bins for windows.
1708
1709 Created genskyvec utility to sample a particular sky and
1710 evaluate average radiance over the standard Tregenza sky patches.
1711
1712 Created dctimestep program to compute a set of sensor values or
1713 a combined image for a particular time using the daylight
1714 coefficient method.
1715
1716 Created src/rt/rayfifo.c for first-in/first-out handling of
1717 multiprocessing by raypcalls.c.
1718
1719 Added -n option to rtrace for executing on multiple cores
1720 using new rayfifo calls.
1721
1722 =====================
1723 Version 4.1 (Released 11/04/2011)
1724
1725 Changed ranimate behavior so remote login under a different user
1726 doesn't necessarily require the presence of the originating user's
1727 home directory.
1728
1729 Changed standard transmission function normalization back to what
1730 it was in version 3.5, following recommendation of David Geisler-Moroder,
1731 who pointed out that the revised BTDF increased too much at grazing.
1732
1733 Changed rad behavior with -N >1 on single view to call rpiece.
1734
1735 Updated SCons build system for MINGW compilation, thanks to Christian
1736 Kohler.
1737
1738 Added -u option to rlam for unbuffered output.
1739
1740 Modified dctimestep to accept sky vector and daylight coefficient matrix
1741 or list of images to sum together, as suggested by Andy McNeil.
1742
1743 Created genBSDF script to generate BSDF in Windows XML format.
1744
1745 Modified mkillum to accept detailed geometry from BSDF XML files.
1746
1747 Altered obj2rad to ignore zero normals (thanks to Jack de Valpine for
1748 suggestions and help).
1749
1750 Fixed bug in genklemsamp that caused non-uniform sampling over surfaces.
1751
1752 Fixed bugs in rhoptimize and rhcopy for 64-bit compilation.
1753
1754 Made a change to avoid problem using gcc --fast-math compile option.
1755
1756 ****** COMPATIBILITY CHANGE ********
1757 Changed behavior of rtrace and rtcontrib so that every scanline is
1758 not flushed when both -x and -y are set. This avoids flush delays
1759 in rtcontrib for large numbers of output files and delays while
1760 rendering images using rtrace with the -n option.
1761
1762 Added ability for rsensor to output ray origins and directions
1763 rather than actually loading octree and computing sensor value.
1764
1765 Fixed old bug in obj2rad where it would stop processing and
1766 report a syntax error if the "void" type is used in the map file.
1767
1768 Updated reflection model according to EGSR 2010 paper by David
1769 Geisler-Moroder and Arne Duer.
1770
1771 Replaced C-shell version of falsecolor with Perl script written
1772 by Axel Jacobs.
1773
1774 ****** COMPATIBILITY CHANGE ********
1775 Changed -sj (specular jitter) option to something called specular
1776 sampling (-ss), which if set less than 1 has the same behavior as
1777 the old -sj, but when set greater than 1, spawns multiple ray
1778 samples from semi-specular surfaces.
1779
1780 Fixed bug noticed by Randolph Fritz that caused ambient sync errors.
1781
1782 Fixed bug in findglare for reading picture files under Windows.
1783
1784 Added options to pvalue to note other color spaces on reverse conversion.
1785 Thanks to Erich Philips for the feature request.
1786
1787 Added BSDF data-driven material type with full sampling support.
1788
1789 Added BRDF calculations to genBSDF.
1790
1791 Bug fixes in rsensor thanks to help from David Geisler-Moroder.
1792
1793 Added variable-resolution BSDF support in renderers and genBSDF.
1794
1795 Created pkgBSDF program to extract BSDF geometry and put it
1796 together with surface description suitable for inclusion in
1797 a Radiance scene.
1798
1799 Muted warning for "no light sources found" when there is at least
1800 one glow object and interreflections are on (-ab > 0).
1801
1802 Fixed long-standing bug that caused underestimation of reflection
1803 when specular component was below -st threshold in non-metals.
1804
1805 Checked in cross-platform cmake build system created by Bill Hoffman
1806 of KitWare and sponsored by NREL. This includes a qt-based
1807 driver for rvu, which is built in the new subdirectory src/qtrvu.
1808
1809 =====================
1810 Version 4.2 (Release date 7/31/2014)
1811
1812 Axel Jacobs added -cp and -palettes options to falsecolor.
1813
1814 Fixed bug in matrix output of genBSDF introduced shortly before 4.1 release.
1815
1816 Made rvu more responsive in multi-processing mode when changing parameters.
1817 Explicit "new" command not needed to show changes, because it goes back
1818 to "immediate mode" once something is changed. Processing will be slow
1819 but response time quick until next "new" command.
1820
1821 Fixed major bug in transmitting proxy material sampling.
1822
1823 Patched cmake build tools (changes by Zack Galbreath).
1824
1825 Removed requirement for pflip -h to be given input file (can pipe from stdin).
1826
1827 Added "Number of processes" slider to trad "Action" pane to control rad -N
1828 option for rvu and batch rendering.
1829
1830 Added -c option to vwrays to repeat pixels for rtcontrib.
1831
1832 Reworked rtcontrib program and renamed to rcontrib. New version runs much
1833 faster, especially on multiprocessor systems, and doesn't require as much
1834 memory. No longer calls rtrace; instead does all the work itself.
1835
1836 Added -d option to genskyvec to produce direct-only (sun no sky) vector.
1837
1838 Added Ashikhmin-Shirley anisotropic BRDF model (ashik2) with help
1839 from Nicolas Boneel.
1840
1841 Added Ruby rewrite of objview.csh by Rob Guglielmetti.
1842
1843 Fixed bug in reciprocity for tensor tree BTDF representations. Thanks
1844 to Andy McNeil for identifying the problem.
1845
1846 Added MNAME and ZNAME variables to ranimove for debugging & testing.
1847
1848 Created pmblur2 command to take motion and depth buffers from ranimove
1849 to compute a better motion blur.
1850
1851 ****** COMPATIBILITY CHANGE ********
1852 Changed BSDF routines to use updated/corrected XML specification and
1853 removed depracated BSDF support from mkillum.
1854
1855 Fixed behavior of i/o flushing in rcontrib with -c > 1 (averaging). Thanks
1856 to Lars Grobe for help identifying this problem.
1857
1858 Fixed bug in depth-of-field blur where view distance was measured from
1859 fore clipping plane rather than viewpoint. Thanks to Peter A-B for
1860 pointing this out.
1861
1862 Added options to dctimestep to allow multiple time steps (-n)
1863 and multiple output pictures or sensor files (-o). Also added -i
1864 option to specify float (-if) or double (-id) input for sky matrix.
1865
1866 Created gendaymtx program to compute annual sky patch matrix based
1867 on Ian Ashdown's implementation of Perez all-weather sky model.
1868 Output can be sent directly to dctimestep in ASCII or binary stream.
1869
1870 Replaced existing gendaylit.c with improved version from Wendelin Sprenger
1871 and Jan Wienold of ISE.
1872
1873 Improved accuracy of ambient calculation for large -ad settings. Thanks
1874 to Lars Grobe for noticing the problem.
1875
1876 Added -r option to gendaymtx to rotate the sky the specified number of
1877 degrees about the zenith as suggested by A. McNeil.
1878
1879 Axel Jacobs added -pal eco color map that does a blue-red-yellow scale.
1880
1881 Created bsdf2klems tool to convert from various BSDF representations to
1882 Klems basis matrix in XML file.
1883
1884 Fixed problem with inappropriate reciprocity enforcement on tensor
1885 tree reduction in genBSDF. (Thanks to A.McNeil for discovering issue.)
1886
1887 Fixed bug in isotropic tensor tree sampling for impinging rays
1888 exactly normal to surface. Thanks to Peter Apian-Bennewitz for
1889 discovering and pointing out the error.
1890
1891 Fixed double-counting bug in mirror material with alternate type.
1892 Thanks to David Geisler-Moroder for spotting the problem and helping
1893 to fix it.
1894
1895 Created rcollate program to resize and transpose matrix data for Andy
1896 McNeil's 5-phase annual simulation method.
1897
1898 Added epw2wea conversion program by Christoph Reinhart.
1899
1900 Implemented Perlin's improved noise function with help from Rahul Narain.
1901 This will change the appearance of renderings using this function.
1902
1903 Added "origin" command to rvu as requested by John Mardaljevic
1904 to place view origin at selected point in scene.
1905
1906 Switch to Perl versions of objview and objpict written by Axel Jacobs.
1907
1908 Improved rendering speed of scenes with aliases by not entering new
1909 modifiers into table if they are the same as the previously defined
1910 modifier for that name.
1911
1912 Made it so icalc and rcalc search RAYPATH directories for *.cal files
1913 given on command line. This simplifies script writing and makes these
1914 utilities consistent with other tools in Radiance.
1915
1916 Added triangulation routine to handle convex polygons in obj2mesh.
1917
1918 ****** COMPATIBILITY CHANGE ********
1919 Made backface visibility apply to all material types, including
1920 transparent and translucent materials (except dielectric and interface).
1921 This makes the option useful in cases where adjacent trans surfaces
1922 are placed next to each other by a modeler that only understands
1923 volumetric objects.
1924
1925 Changed dctimestep so that output matrices (-n > 1) are preceded by a
1926 header, and added support for float and double output formats with -o[fd].
1927
1928 Introduced eplus_adduvf program to compute user view factors for EnergyPlus.
1929
1930 Changed image-plane sampling in rpict to use Hilbert curve, which gives
1931 less of a brushed/striped appearance to output pixels with -u- (default).
1932
1933 Added ltview and ltpict Perl scripts contributed by Axel Jacobs, inspired
1934 by Rob Guglielmetti.
1935
1936 Added header variables for NROWS, NCOLS and NCOMP to help standardize
1937 matrix files. This functionality has been incorporated into
1938 rcollate, gendaymtx, and dctimestep.
1939
1940 Created rmtxop utility to operate on multi-component matrices. This
1941 facilitates some daylight matrix calculations, and provides a general
1942 tool for manipulating matrix data.
1943
1944 ****** COMPATIBILITY CHANGE ********
1945 Introduced new Hessian-based error control in irradiance caching (ambient)
1946 calculation. Since the format of the stored ambient values is different,
1947 the old files will be rejected with an error message and must be removed.
1948 The programs may be compiled with the -DOLDAMB option if this is a problem.
1949
1950 Added -p option to rcontrib to set function file parameters on a per-modifier
1951 basis to simplify bin evaluation.
1952
1953 Created rfluxmtx program to compute flux transfer matrices from a sender
1954 surface to one or more receiver surfaces. (Renamed the file klems_int.cal
1955 to klems_full.cal in the process.)
1956
1957 Added "-c" option to getinfo to execute command on data segment.
1958
1959 ================================
1960 Version 5.0 (Released 9/18/2015)
1961
1962 Changed rmtxop so it writes out same type as lesser of inputs unless
1963 directed otherwise using -f? option.
1964
1965 Changed order of oconv arguments in rfluxmtx so user can specify input
1966 octree using -i option at the end instead of (or in addition to) a
1967 list of scene files.
1968
1969 Added support for argument expansion to rfluxmtx and bug fixes.
1970
1971 Fixed bug in indirect hemisphere sampling for some corner cases.
1972
1973 Added default specular lobe to BSDF interpolation.
1974
1975 Set minimum number of shadow checks before direct optimization (4).
1976
1977 (Above changes included in 4.2.1 patch release.)
1978
1979 ****** COMPATIBILITY CHANGE ********
1980 Made header input and output the default behavior for dctimestep and
1981 genskyvec.
1982
1983 ****** COMPATIBILITY CHANGE ********
1984 Changed pabopto2bsdf default behavior to add 90-degree rotation
1985 to bring pgII's definition of "up" in line with Klems axis
1986 conventions. Introduced a new header variable "upphi" to
1987 control this added rotation. Using "#upphi 90" in each
1988 BSDF input file gets back the original behavior, where it
1989 assumes that the up direction is 90-degrees from the X-axis.
1990 The default value of 0 corresponds to PAB's definition of
1991 the X-axis as being "up".
1992
1993 Fixed bug in rsensor related to having many rows (altitude) and
1994 few columns (azimuth) in sensitivity file.
1995
1996 Fixed floating point round-off error in new Hessian calculation
1997 for some sytems (Windows, primarily).
1998
1999 Fixed bug in tensor tree BSDF code that caused bus error on
2000 some systems, and may have been source of other errors as well.
2001
2002 (Above changes included in 4.2.2 patch release.)
2003
2004 Improved ambient extrapolation to avoid zero values. Actual
2005 threshold set to 5% of recorded value.
2006
2007 Changed anisotropic Gaussian and Ashikhmin models so that
2008 illegal orientation vectors are dealt with more gracefully.
2009
2010 Created wrapBSDF tool and incorporated into genBSDF along
2011 with new rfluxmtx computation.
2012
2013 Initial check-in of Roland Schregle's photon map integration.
2014 New 5.0a version designation as suggested by Andy McNeil.
2015
2016 Added left-hand coordinate sytems to rfluxmtx to correct
2017 problems with coordinate axis orientations pointed out by
2018 David Geisler-Moroder.
2019
2020 Added color output to genBSDF (+C option) and support for
2021 color rendering of Klems and tensor tree data.
2022
2023 Fixed another bug in rsensor that caused rays to be generated
2024 on opposite side of hemisphere even where sensitivity was zero.
2025
2026 Fixed bug discovered by Jacob Jonsson in Klems BSDF
2027 interpolator that caused it to over-predict normal
2028 transmittance and reflectance.
2029
2030 Added ability to read input from commands in dctimestep
2031 and rmtxop.
2032
2033 Added photon map support to rad. Fixed some double-counting
2034 issues in photon-mapping spotted by David Geisler-Moroder.
2035
2036 Added photon map support to trad.
2037
2038 Fixed bug in antimatter source testing when antimatter
2039 definition follows potential obstructor in input.
2040
2041 Fixed issue with missing character type identifier at head
2042 of genBSDF XML output.
2043
2044 Prompted by Roland S., added option to have pcompos -a order
2045 rows from top rather than bottom of image.
2046
2047 Changed dctimestep to accept matrix as well as BTDF input
2048 in the VTDs invocation mode. This permits the output of
2049 rmtxop to be used in a pinch when combining multiple BTDF
2050 layers, although interreflection between layers is not
2051 accounted for properly as it is in the WINDOW program.
2052
2053 Added Jan Wienold et al.'s evalglare to distribution.
2054
2055 Hopeful fix to deadlock issue under Mac OS X 10.10.x (Yosemite).
2056
2057 Fixed early exit of rcontrib with internal error (sample behind sender)
2058 discovered by Rob G.
2059
2060 =================================
2061 Version 5.1 (Released 8/17/2017)
2062
2063 Fixed issue with vchars.mta and symbols.mta not being installed in
2064 the appropriate metafile library location, with help from Rob G.
2065
2066 Added ability to give quoted strings to output= directive in rfluxmtx.
2067
2068 ****** COMPATIBILITY CHANGE ********
2069 Added ability to digest color (CIE-XYZ) input in pabopto2bsdf.
2070 This change alters the .sir (interpolant) format, so these files
2071 will need to be regenerated. Use the new "#colorimetry: CIE-XYZ" tag
2072 to enable on input.
2073
2074 Rewrote bsdf2klems to support tristimulus color and call wrapBSDF.
2075 Did the same for bsdf2ttree. Function specifications still gray only.
2076
2077 Reduced a problem where rvu or rholo would be slow to quit when
2078 run with many processes on a large model or one with a large
2079 ambient file (taking lots of memory). We were waiting for
2080 processes to quit one-by-one, which takes some time for each
2081 process as it disentangles its shared memory. We now
2082 wait for all the processes together, so they can disentangle
2083 in parallel. It can still take up to a minute in some cases,
2084 but not 10 minutes like it was taking before the fix.
2085
2086 Enabled ambient cache value corral for all levels, not just final two.
2087 This may reduce errors in certain pathological scenes.
2088
2089 Added -in option to rcalc, rlam, and total to limit the number of
2090 input records in hopes of circumventing Windows EOF issues on binary data.
2091 Also added -on option to rcalc and total for logical symmetry.
2092
2093 Increased modifier limit to 10,000 in rcontrib.
2094
2095 Fixed issues with glrad and added zoom response to mouse wheel input.
2096
2097 Added missing definition of "ashik2" material type to reference manual.
2098
2099 Changed genBSDF to calculate device thickness assuming Zmax==0 so
2100 pkgBSDF will generate correct proxy geometry.
2101
2102 Created pabopto2xyz tool to combine different sensor measurements
2103 into a single CIE-XYZ measurement file for color BSDF interpolation.
2104
2105 Jan Wienold updated evalglare to version 1.30
2106
2107 Roland Schregle added out-of-core photon mapping routines, which
2108 may be compiled using the PMAP_OOC macro.
2109
2110 Added -a option to getinfo for easy addition of header lines.
2111
2112 Fixed issue with multiple records on picture output in rcontrib (and rfluxmtx).
2113 Credit to Sarith Subramaniam for pointing out the problem.
2114
2115 Made mkillum more tolerant of non-planar polygons in its sampling routines.
2116
2117 Added "-recover" option to genBSDF to pick up where it left off.
2118
2119 Fixed genBSDF issue that was created incorrect normalization of
2120 Klems output. Thanks to David G-M and Christian Knoflach for
2121 discovering the error. Also improved sampling of indirect irradiance
2122 that showed some slight bias due to poor sample collision avoidance.
2123
2124 Fixed long-standing issue with -aa 0 neglecting textures in calculating
2125 surface shading.
2126
2127 Fixed bug in ranimove introduced during photon map integration.
2128
2129 Added check for steep sections of BSDF in pabopto2bsdf, creating narrower
2130 peakes in those places and mitigating some normalization issues.
2131
2132 Added view360stereo.cal by Mark Stock to handle 360-degree over/under
2133 stereo views.
2134
2135 Added MAX2SHADE macro to place limit on number of light sources
2136 to precheck for obstructions. (Currently set to 200.) This
2137 avoids excessive start-up times for scenes with many light sources.
2138 Thanks to Axel Jacobs for pointing out the problem.
2139
2140 Added -v option to obj2mesh to print out mesh statistics.
2141
2142 Rewrote bsdf2rad from ground up and made it a standard part of build.
2143
2144 Fixed bug in orientation of Reinhart/Tregenza sample generator in rfluxmtx.
2145
2146 Added ability to perform shadow-testing through unproxied BSDFs with strong
2147 through (direct-direct) component.
2148
2149 Added {+|-}a options to genBSDF and bsdf2ttree for switching off reciprocity
2150 averaging.
2151
2152 Added bias to see through BTDFs with a strong "through" component
2153 rather than scattering view rays. This is in lieu of peak extraction,
2154 which looked to be too difficult from an implementation standpoint.
2155
2156 Added bsdfview tool analogous to objview but for BSDF files (XML and SIR),
2157 which calls bsdf2rad then rad with a few useful default views.
2158
2159 =========================
2160 Version 5.2 (Release October 8, 2018)
2161
2162 Created psketch program to apply non-photorealistic rendering to selected
2163 objects, identified by modifier name(s).
2164
2165 Added '*' and '/' operations to rmtxop for element-wise multiplication and
2166 division of same-sized matrices.
2167
2168 Changed falsecolor so "-s" option is adjusted to match legend if one.
2169
2170 Falsecolor legend changes and improvements by David G-M and Stephen W.
2171
2172 Fixed bug in peak extraction code that generated
2173 "Bad call to SDqueryTreProjSA" error, reported by Lars Grobe.
2174
2175 Increased maximum luminance to 10^7 in pcond to fix issue noticed
2176 by Axel Jacobs where veiling glare not added for the sun under
2177 some conditions.
2178
2179 Increased maximum number of open files in rcontrib to the system upper
2180 limit of 2048 rather than the default 512 under Windows.
2181
2182 Added top-level resources directory with files from Rob Guglielmetti.
2183
2184 Improved accuracy for peaky BSDFs and small light sources.
2185
2186 Fixed issue with pmapdump noted by Axel Jacobs.
2187
2188 Improved accuracy of bsdf2ttree when converting scattering interpolation
2189 representatons with strong peaks.
2190
2191 Tweaked peak-extraction code to work more reliably.
2192
2193 Georg Mischler updated SCons build system.
2194
2195 Rob Guglielmetti and Alex Swindler updated CMake build system.
2196
2197 Modified pcomb so the first view seen in the inputs is written into header.
2198
2199 Wrote rtpict script to run rtrace in parallel mode and simulate rpict with
2200 -n option.
2201
2202 Added ability to move forwards/backwards specified distance in rvu "origin"
2203 command. Feature requested by John Mardaljevic, who essentially owns this
2204 command, now.
2205
2206 Reduced bias in ambient super-sampling method.
2207
2208 Fixed bugs associated with zero transmission in chromatic tensor trees.
2209 Thanks to Lars Grobe for pointing out issues.
2210
2211 Added RAYPATH searching for -f options to genrev, gensurf, genworm,
2212 bsdf2klems, bsdf2ttree, and pcomb. This makes behavior consistent
2213 with rcalc, calc, and rendering tools.
2214
2215 Worked with Randolph Fritz to fix some issues with ies2rad and newer
2216 IESNA63 standards.
2217
2218 Resurrected original bsdf2rad test program, renaming it bsdf2rado. Still an
2219 optional build in src/cv/.
2220
2221 Fixed bug in rcontrib with virtual sources, where pretest was adding
2222 to modifier accumulation buffers. Reported by Mostapha.
2223
2224 Added an "aBSDF" material type that explicitly checks for peak extraction.
2225 Its arguments are the same as the original "BSDF" type, but without the
2226 thickness parameter, as proxy geometry is not supported by this new type.
2227 The old "BSDF" type no longer does peak extraction under any circumstances,
2228 since this behavior is superfluous for proxied geometry.
2229
2230 Added -r option to bsdf2rad (and bsdfview) to fix BSDF min and max range
2231 for comparing BSDFs.
2232
2233 Fixed issue with pfilt -m option and uneven image size changes pointed
2234 out by Rob Shakespeare.
2235
2236 Updates to evalglare and gendaylit from Jan Wienold, including new
2237 colored sky option.
2238
2239 =========================
2240 Version 5.3 (Released September 1, 2020)
2241
2242 Created radcompare program to compare Radiance tool output to reference outputs
2243 during unit-testing.
2244
2245 Fixed issue reading very large files (> 2 GBytes) in rcollate.
2246
2247 Made picking function in rvu ignore transparent and void surfaces.
2248
2249 Added -orRxX options to rtrace to enable output of mirrored and unmirrored
2250 contributions and distances to enable new types of reprojections. This also
2251 cleaned up and unified handling of effective ray lengths throughout code.
2252
2253 Bug fixes from Jan Wienold for evalglare.
2254
2255 Changed indexed (numbered) output from dctimestep to start from 0 rather
2256 than 1, to make it more consistent with expected input naming.
2257
2258 Increased default sampling in bsdf2klems (-n option) to 1024.
2259
2260 Fixed an issue noticed by David G-M that was causing genBSDF to bias
2261 isotropic tensor tree samples resulting in subsequent failure of
2262 peak extraction with "aBSDF" type.
2263
2264 Introduced max() and min() functions to .cal library.
2265
2266 Added random incident patch sampling to bsdf2klems to improve accuracy
2267 with scattering interpolation representation input (e.g., from
2268 pabopto2bsdf). The other input types already sampled incident patch area.
2269
2270 Added gendaymtx -A option to compute average sky over all the input
2271 time steps.
2272
2273 Added ability to output color image from rtrace with any of -ovrx options.
2274 Also fixed inconsistency of -oN output when ray casting versus full trace.
2275 Before, it would flip normal to front side unless ray casting. Now, -oN
2276 always reports the unflipped normal.
2277
2278 Changed rlam behavior so -iaN reads N lines from a stream rather than N
2279 characters. This seems more useful, since -ibN is somewhat redundant with
2280 the old behavior.
2281
2282 Created rsplit program as compliment to rlam and to handle more complex
2283 rtrace output into separate files or streams.
2284
2285 Improved getinfo so that it can also hop over resolution string with -c
2286 and header elide mode. Use +d to include resolution string in output,
2287 and -d to elide with - and -c options.
2288
2289 Made pvalue -u option mean "uncompressed" with -r. Also, allow skipping
2290 bytes on standard input.
2291
2292 Created rcode_depth tool to convert to and from a 16-bit/pixel portable
2293 depth image encoding that uses a mix of linear and reciprocal distance
2294 with explicit representations of 0 and infinity. Code for loading these
2295 depth maps is in src/common/depthcodec.{h,c}.
2296
2297 Created rcode_norm tool to convert to and from 32-bit/pixel portable
2298 surface normal representation, matching the one in src/common/dircode.c.
2299 Code for loading normal maps is in src/common/normcodec.{h,c}.
2300
2301 Created rcode_ident tool to create indexed identifier files.
2302 Code for loading these files is in src/common/idmap.{h,c}.
2303
2304 Added -o* option to rtpict to produce layered images that handle most
2305 output types from rtrace (colors, surface normals, distances, IDs).
2306
2307 Created rcode2bmp script to create images from new rcode_* output maps.
2308
2309 Improved efficiency of rmtxop in cases where matrix multiplication is
2310 faster evaluated right-to-left, as when the final component is a
2311 column vector. Also added ability to apply trailing unary operators
2312 (-t, and -s or -c) to resulting matrix.
2313
2314 Added new depth, normal, and ID file types to radcompare.
2315
2316 Added BigEndian= header line for automatic byte-swapping in rmtxop
2317 and radcompare.
2318
2319 Added new "turbo" palette to falsecolor (thanks to Taoning).
2320
2321 Nathaniel Jones created the "dcglare" program for annual glare
2322 simulations when the sun and sky are visible through the window.
2323 Tutorial is posted at
2324 "https://github.com/nljones/Accelerad/wiki/The-Imageless-Method-for-Spatial-and-Annual-Glare-Analysis".
2325
2326 Added support for loading RGBE images into matrices in dctimestep.
2327
2328 Added -y option to gensky and gendaylit to support more accurate Michalsky
2329 solar position calculation.
2330
2331 Changed rsplit, so specifying a space as the separator parses words
2332 between whitespace.
2333
2334 Added ability of vwrays, pinterp, and pmblur2 to read encoded depth files.
2335
2336 Added -o RxCxR1xC1 facility to perform blocking in rcollate.
2337
2338 Made it so number of segments in genworm, genrev, and gensurf can be
2339 given as expressions of previously defined variables, etc.
2340
2341 Added -D and -n option to gendaymtx to output sun description and skip
2342 matrix output on request. A -M option was also added to output solar
2343 modifiers for rcontrib. Support also added for leap days in WEA input.
2344 Enhancements sponsored by Ladybug Tools.
2345
2346 Updated eplus_uvf to work with IDF version 9.x, checking version number.
2347
2348 Fix to glarendx issues with dgi calculation.
2349
2350 Made it so rmtxop and dctimestep undo any exposure applied to Radiance
2351 pictures they may load.
2352
2353 Added robjutil utility to manipulate Wavefront .OBJ files.
2354
2355 Fixed a crash related to rtrace -om or -oM with mesh instances containing
2356 materials.
2357
2358 Improved rtrace flushing function to handle any value for -x without
2359 deadlock on controlling process.
2360
2361 Eliminated unnecessary start-up procedures for rtrace when only ray-casting
2362 is needed (i.e., no tracing or value output).
2363
2364 Improved isotropic sampling method in bsdf2ttree using "zipper" approach
2365 applied in genBSDF.
2366
2367 Added limit to memory used by high-resolution tensor tree BSDFs for
2368 cumulative cache during MC sampling (rendering). Limit set to 250MBytes
2369 per BSDF for standard architectures.
2370
2371 Added -n and -s options to bsdf2ttree to provide some user control
2372 over super-sampling.
2373
2374 Improved surface normal codec used by ambient file to store orthonormal
2375 directions exactly.
2376
2377 Improved peak extraction method, which was undervaluing transmission
2378 in many cases.
2379
2380 New version of evalglare from Jan Wienold.
2381
2382 Added -u option to gendaymtx to elide data columns (time steps) when
2383 the sun is not visible above the horizon.
2384
2385 =========================
2386 Version 5.4
2387
2388 Added rcollate -c option to force operation to continue even if it
2389 seems unnecessary. Made tool more robust.
2390
2391 Added -t option to rcontrib (and rfluxmtx) to report progress after the
2392 given number of seconds.
2393
2394 Added "test" target to makeall to run unit tests.
2395
2396 Modified bsdf2ttree to allow different parameters per input SIR file.
2397
2398 Fixed issues with very large matrix files (> 2GB) in dctimestep, rmtxop,
2399 and rcollate.
2400
2401 Added -rf and -rb options to rmtxop to load front or back reflectance
2402 matrix data from XML file rather than transmission. (Lars Grobe suggested.)
2403
2404 Improved behavior for coincident surfaces with different materials.
2405 Rather than returning one surface or the other based on floating-point
2406 vagaries, opaque materials are now preferred over transparent ones.
2407 If the materials are both transparent or both opaque, then whichever
2408 surface appeared later in the scene description will be selected.
2409 This came of a request for consistent behavior with legal CAD output
2410 from Peter Apian-Bennewitz.
2411
2412 Added explicit tests for on-edge intersections with polygons. This should
2413 eliminate stray rays and tiny light leaks that often appear even in
2414 well-constructed geometry.
2415
2416 Added "-s up" option to pabopto2bsdf to allow for 180 degree symmetry,
2417 meaning that data repeats after 180 degree rotation (as distinguished
2418 from "-s bilateral" whose data is mirrored about a vertical plane).
2419 Thanks to Helen Rose Wilson for the suggestion and informing me that
2420 such a thing exists.
2421
2422 Removed upper limit on number of modifiers in rcontrib.
2423
2424 Put cap on maximum ambient gradient to avoid over-extrapolation of
2425 poorly computed irradiance cache values.
2426
2427 Added robjutil +T option to triangulate all faces in .OBJ description.
2428
2429 Altered BSDF library to have both front and back diffuse transmittance
2430 values, which can be different. This was necessary to avoid issues
2431 caused by measurement and modeling discrepancies.
2432
2433 Added pabopto2bsdf -g option to cull near-grazing scattering to avoid
2434 issues with noise and negative values.
2435
2436 Increased default dynamic range from 32 to 100 in pcond and normtiff.
2437
2438 Added -o and -n options to genbox to create .OBJ output and segment
2439 edges and corners for transparent materials. Also added -s option
2440 to control smoothing for .OBJ and Radiance with segmented rounding.
2441
2442 Made it so robjutil with the +r option for Radiance output now
2443 produces normal smoothing unless normals are removed with -n.
2444
2445 Added exposure preservation to pcompos when possible (i.e., when
2446 there is only one input or inputs agree on exposure).
2447
2448 Added -DSHARP_RGB compile-time option to use sharp RGB color space
2449 rather than historic default. This can make for more accurate color
2450 calculations, but requires that materials be recalibrated. The
2451 PRIMARIES= line is also produced on output from rpict or rvu with
2452 the correct set of primaries based on how the system was compiled.
2453
2454 Added automatic flushing to the output of total, except when the -r
2455 (running subtotals) option is used.
2456
2457 Improved behavior of little-used -aw option, so that it avoids sea-level
2458 rise caused by adding its own estimate back into the ambient level remainder.
2459 It ended up being simple enough to derate the final average by the factor
2460 corresponding to average surface absorpition, thus removing the average
2461 from the final bounce estimate.
2462
2463 Introduced ies2rad upgrades by Randolph Fritz. Randolph says it
2464 fixes the following problems:
2465
2466 1. Generates correct Radiance geometry for spheres in 1995, 2002,
2467 and 2019 IES files.
2468
2469 2. Generates correct Radiance geometry for vertical cylinders that
2470 are taller than they are wide.
2471
2472 3. Ignores the file source ("File Generation Type") field in the
2473 2019 version of the file, which would otherwise be incorrectly used
2474 as an output multiplier.
2475
2476 It also offers the following enhancements:
2477
2478 1. Shape information is included in the .rad file comments.
2479
2480 2. 1995, 2002, and 2019-version luminous opening geometry is
2481 accounted for.
2482
2483 3. The 2002 and 2019 IES file versions are recognized and
2484 processed appropriately.
2485
2486 4. I have made an attempt to do something intelligent with less
2487 common "luminous opening" shapes in the 1995, 2002, and 2019 versions
2488 of the standard, though I have not implemented any support for new
2489 geometry; approximations are substituted and warning messages issued.
2490 Unfortunately, this code is not tested, since I don't have any IES
2491 files that use these shapes.
2492
2493 Added support for depth-of-field blurring in vwrays using -pd option.
2494 Also, made -c count work with vwrays -i, producing multiple samples
2495 per indicated pixel position. At the same time, support for the -pd
2496 option was added to rtpict, which calls on vwrays for its samples.
2497
2498 Fixed issue with BSDFs that didn't obey reciprocity, where direct
2499 sampling wasn't following exactly with indirect sampling. This was
2500 discovered and reported by Jon Sargent.
2501
2502 Created checkBSDF tool to test XML BSDF reciprocity and perform similar
2503 sanity checks.
2504
2505 Added -O option to pvalue and pextrem to report watts/sr/m^2 even if
2506 picture is XYZE.
2507
2508 Made subtle changes to header i/o routines to preserve alignment in
2509 binary file formats to enable memory-mapping. Implemented memory-mapped
2510 matrix loading in rmtxop for binary double files.
2511
2512 Removed ambient value sorting, which was written when ambient caches
2513 could overwhelm available memory. This is rarely the case these days,
2514 and the added code complexity and updating of cache values with LRU
2515 counts dirties pages that would otherwise remain clean, so it was
2516 often a loss even when VM was an issue.
2517
2518 Added iso2klems script to compute a Klems BSDF based on specular
2519 and diffuse measurements as a function of incident angle.
2520
2521 Fixed issue with over-counting diffuse component during aBSDF
2522 peak extraction.
2523
2524 Added dctimestep -x and -y options to specify image dimensions
2525 for multiple outputs corresponding to result vectors.
2526
2527 Added -P option to rcalc to pass formatted input when cond is <= 0.
2528
2529 Created rcrop utility for cropping matrices and pictures more
2530 conveniently, correcting view information. Expect it to be handy
2531 for extracting rows and columns from matrices, mostly.
2532
2533 Changed pcomb so -o option elides original exposure values
2534 from indented source headers.
2535
2536 Added getinfo -r option, which is similar to -a except it will
2537 replace indicated lines with new ones.
2538
2539 Slight change to vwrays -d option to not spit out "-ld-", and to
2540 produce "-ld+" without requiring input picture as argument.
2541
2542 Added automatic overture calculation to rtpict with -n > 1 if
2543 ambient cache is on and file is named. If straight image output
2544 is requested, we randomize all samples and avoid cache collisions.
2545
2546 Added cnt -s option to shuffle output.
2547
2548 Fixed issue with divide-by-zero errors in the ambient super-sampling
2549 routine discovered by Jon Sargent of Solemma. This affected regions
2550 that had zero radiance, such as black backgrounds or unlit areas
2551 with -av 0 0 0, when super-sampling was effectively disabled, causing
2552 some loss in accuracy of the results.
2553
2554 Updated Klems Half- and Quarter-bases to match angles currently used
2555 in WINDOW.
2556
2557 Eliminated most aiming failures for triangular light sources, at the
2558 expense of conservative sampling near the centroid. Thanks to
2559 David Geisler-Moroder for his help on this.
2560
2561 Increased maximum set size to 8191 to avoid set overflow errors.
2562
2563 Added source obstruction test to statistics being kept on which
2564 sources were visible in adaptive shadow testing code. Previous
2565 behavior was likely over-estimating source contributions.
2566
2567 Added diffuse components into maximum directional hemispherical
2568 reported by checkBSDF, so comparing to 100% is easier for each
2569 component.
2570
2571 Fixed incorrect calculations in iso2klems script, thanks to
2572 help from Jacob Jonnson.
2573
2574 Updated official copyright and license according to new wording
2575 provided by Jean Haemmerle at the LBNL Intellectual Property Office.
2576 Both were copied verbatim from e-mail I received from Taoning Wang
2577 on 8/20/2022.
2578
2579 Added -features option to rpict, rtrace, and rcontrib to check
2580 which features are present or look for specific feature support.
2581 This addition was suggested by Peter Apian-Bennewitz as an easier
2582 way to determine which version of Radiance is installed and what
2583 it supports, and is timely as we begin our refactoring of the
2584 rendering code. There are no current plans to add this to rvu.
