Revision: 1.26
Committed: Thu Jan 1 19:31:45 2004 UTC (22 years ago) by greg
Changes since 1.25: +7 -0 lines
1 =========================
3
11
12 pfilt -x 512 -y 400 -p 1
13
18
21
25 and vv parameters).
26
30
40
44
45 =========================
47
53
56
58
62
66
72
75
77 traced on an X11 display.
78
83
86
87 =========================
89
92
94
97 library directory.
98
101
105
107
110
112
114 white light assumption.
115
117
119 checking and clarity.
120
123
128
132
133 =========================
135
140
142 picture.
143
145
150
152
155 and transdata types.
156
158 component.
159
162
166
168 value labels.
169
172
179
183 undefined modifiers.
184
187
192
197
199
203
205 to slant the wrong way!
206
209
218
221
223
229
232
236
238 -version option.
239
242
244
251
253
258
260
273
275
278
282
286 pinterp and findglare.
287
290
295 support it.
296
298
304
308
312
315
317
319 from a file.
320
322
324
326
331
336 pointed this out to me!
337
340
345
350
352 and color ordering.
353
355
358
361
363 some scene files.
364
367
371
373 used consistently.
374
376
378 further reduce errors.
379
381
385
387
395
398
402
405 options.
406
408 cast by mirrors.
409
411
414 MS-DOS.
415
417 brightness.
418
421 unperturbed).
422
429
432
435
437
444
447 unconditionally.
448
452
455 suggestion.)
456
461
464
467
471 helped.
472
479
482
485
488
490
492 for each picture file.
493
496
502
505
508
511
515
521
524
526
528
531
535
538
541
544
546 Format) specification.
547
550
552 at all!
553
555 under X11.
556
560 for the same value!
561
563 changes to input files.
564
567
569 Radiance view parameters.
570
572
575
577 language.
578
580
582 files.
583
586
588 values.
589
591
594
597
599
601
603 interesting applications.
604
607
610
613
616
618 simulation with pinterp.
619
622
625
630
635
639 regions.
640
642
645
649 of clouds.
650
654 the same as before.
655
657 walk-through animations.
658
661
663 on multiple hosts.
664
667
670
672 Alphas.
673
678
681 large image patterns.
682
686 method.
687
692
694
699
709 back old behavior.
710
713
716
718
720
722
724
732
737 sources.
738
750 to bright exteriors.
751
754
758
763
768
771 definitions.
772
775 pcond(1).
776
779
782
784 (Included in 3.1.1.)
785
788
790
792 views or pictures.
793
797
801
803
806 (Included in 3.1.4.)
807
809 (Included in 3.1.3.)
810
812 (Included in 3.1.3.)
813
815 image formats.
816
820
823 to PostScript printers.
824
826 (Included in 3.1.6.)
827
830
832
836
840
844
847
849 commands.
850
852
855
857
860
863
867
870
872
878 material for shading.
879
882
884
889
891
893
895 forcing greyscale output.
896
899
902
904
906 directly using ximage.
907
909
912
914 CMCCAT2000 matrix.
915
917
919
921 by Erich Phillips.
922
925
928 instances).
929
932
934 to unity.
935
939
942 for pointing it out.
943
945
950
954
956
958 valid(s,t) function.
959
962
966
968 for standard input.
969
973 used to.
974
980
986
990
993
997
1000 feedback.
1001
1009 hurrah!
1010
1020
1024
1029
1032
1036 previous value of 1.0.
1037
1049
1058
1064
1072 specification.
1073
1076
1088
1097
1100
1103 textured surfaces.
1104
1122
1129 substitution.
1130
1140 the stack limit.
1141
1143 Version 3.6
1144
1148
1150
1152
1155
1158
1162
1165
1169 IEEE float.)
1170
1172 parallel.
1173
1175 in programs like ranimate would refer to bogus data.
1176
1178 files.
1179
1183 modifiers before the light/illum/glow primitive.
1184
1185 Fixed bug in xform where it was neglecting to add transform arguments
1186 to new mesh primitive.
1187
1188 Added -dF and -dD options to pvalue for byte-swapped floats and
1189 doubles, respectively.
1190
1191 Changed meta2tga to output correct colors.
1192
1193 ****** COMPATIBILITY CHANGE ********
1195 that Radiance mesh files be recompiled.
1196
1197 Changed integer tone-mapping routines to better deal with images
1198 containing large, constant regions.
1199
1200 Improved interaction with rholo -o ogl driver under OS X, which was
1201 returning bad values from the depth buffer.
1202
1203 Minor bug fix in ranimove where it was restarting processes when it
1204 didn't need to.
1205
1206 Increased accuracy of default ambient parameters in rpict, rview, and
1207 rtrace. In rad program, doubled -ar value, -ad value, and -as value,
1208 and decreased -aa value a bit. Also adjusted -lr upwards and -lw
1209 downwards. I should have done these things long ago, as processors
1210 have been getting faster and faster over the years.
1211
1212 Fixed bug discovered by Marcus Jacobs where oconv was dumping core
1213 when it was given too many modifiers.
1214
1215 Fixed problem with rpict where it was drawing illum sources badly
1216 even when they weren't all that small in the view.
1217
1218 Added in(i) function to rcalc for more flexible channel evaluation.
1219
1220 Replaced all calls to vfork() with regular fork() calls.
1221
1222 Fixed bug in glarendx for dgr calculation with sources behind view.
1223
1224 Added -p option to histo to print percentages/percentiles r.t. counts.
1225
1226 Added a source occluder cache to accelerate shadow testing. This
1227 can save up to 50% of the calculation time in scenes with many
1228 light sources, especially ones containing large occluders. This
1229 optimization may be tuned or switched off with the -DSHADCACHE=N
1230 compile switch, where N is the resolution of the shadow cache, or
1231 0 to disable it. Since this is purely a time vs. memory trade-off,
1232 I decided not to make it a new command-line option. (We already
1233 have plenty.)
1234
1235 ****** COMPATIBILITY CHANGE ********
1236 Changed the following command names to avoid conflicts:
1237 rview -> rvu (with symbolic link back to rview)
1238 calc -> icalc
1239 lam -> rlam
1240 gencat -> gencatenary
