--- ray/doc/notes/ReleaseNotes 2025/05/08 14:44:01 1.487 +++ ray/doc/notes/ReleaseNotes 2025/09/26 04:01:43 1.500 @@ -2383,7 +2383,7 @@ Added -u option to gendaymtx to elide data columns (ti the sun is not visible above the horizon. ========================= -Version 5.4 +Version 5.4 (Released November 5, 2023) Added rcollate -c option to force operation to continue even if it seems unnecessary. Made tool more robust. @@ -2605,7 +2605,7 @@ Made reciprocity averaging default to "off" in bsdf2tt to create more problems than it solves. ==================== -Version 6.0 +Version 6.0 (Released July 23, 2025) Extensive changes to enable spectral rendering, which defaults to "off" to maintain backwards-compatibility with previous versions, with the @@ -2672,9 +2672,11 @@ put out as many color channels as specified in any -cs Added ability of mgf2rad to convert spectral data at least for light, glow, plastic, and metal primitive types. Need -to use new '-s' option to get new output. +to use new '-s' option to get new output. Added support for +new WGMDfunc type as well, which is considerably more flexible +at supporting different spectral components. -Added handling of spectral images to rcode2bmp script. +Added handling of spectral pictures (HSR) to rcode2bmp script. Minor change to rcollate to allow explicit byte records to be any specified length without checks against header input. @@ -2718,7 +2720,7 @@ Wrote rxpiece tool that will render pictures using til can handle different output formats and hyperspectral pictures. Only runs on a single machine, however -- no NFS locking on shared volumes. Mainly a demonstration tool for RpictSimulManager -C++ class, but may have its uses. +C++ class, but later added to standard Rmakefile targets. Fixed a bug in BSDF sampling of sources pointed out by David Geisler-Moroder, which tended to overestimate specular @@ -2740,7 +2742,7 @@ results are still reported in RGB. Added accurate conversion of hyperspectral pictures to ra_xyze. Added hyperspectral picture conversion to ra_tiff, with accurate -color when targeting 16-bit/comp., LogLuv, and float utput, +color when targeting 16-bit/comp., LogLuv, and float output, and the approximate method for 24-bit RGB. Taoning added genssky -L option to specify global and diffuse @@ -2813,3 +2815,48 @@ spectral glazing materials based on CGDB data and mode Fixed bug that caused inf and nan errors with -cw setting where longer wavelength was substantially less than limits of specified spectra. + +Created bsdfpeaks utility to identify and report full-width, +half-maximum sizes of peaks in SIR and XML inputs. + +Changed default super-sampling in bsdf2ttree from 256 to 64, +since there doesn't seem to be much benefit to the higher +sampling rate for most BSDFs. + +Fixed problem with "mirror" primitive, which was not permitting +indirect rays to transmit through alternate material type. +Thanks to Jon Sargent for finding problem and help resolving it. + +Added experimental C++ based rxpiece tool to default installation +in makeall/Rmakefile. + +Added rcomb -mt option to transpose concatenation matrix. + +==================== +Version 6.1 (Released July 24, 2025) + +Fixed array limit bug in EPW file loader. + +Fixed bug in rcomb, rmtxop -c and -C option not accepting file paths +starting with '.' + +Fixed ordering of spectral data in gensdaymtx output. + +Fixed crash in new Poisson sampling routines for large settings of -ad. + +Fixed reversal of direct and diffuse values in EPW files. (Thanks to +Taoning Wang for spotting the error.) + +Fixed issue with zero radiation values in gensdaymtx (TW). + +(The above fixes were released as official patch 6.0.1) + +Fixed issues with rtpict running under Windows. Thanks to Mehlika +Inanici for help finding problems and testing. + +Added metadata i/o to ra_bmp in both directions, preserving +color space, gamma, and typical Radiance header settings. + +Updated evalglare with new 3.0x version from Jan Wienold. + +Fixed issue with genBSDF -t3 option under Windows.
