--- ray/doc/notes/ReleaseNotes 2025/05/08 14:44:01 1.487 +++ ray/doc/notes/ReleaseNotes 2025/06/04 20:32:24 1.491 @@ -2813,3 +2813,16 @@ spectral glazing materials based on CGDB data and mode Fixed bug that caused inf and nan errors with -cw setting where longer wavelength was substantially less than limits of specified spectra. + +Created bsdfpeaks utility to identify and report full-width, +half-maximum sizes of peaks in SIR and XML inputs. + +Changed default super-sampling in bsdf2ttree from 256 to 64, +since there doesn't seem to be much benefit to the higher +sampling rate for most BSDFs. + +Fixed problem with "mirror" primitive, which was not permitting +indirect rays to transmit through alternate material type. +Thanks to Jon Sargent for finding problem and help resolving it. + +Added experimental C++ based rxpiece tool to default installation.
