--- ray/doc/notes/ReleaseNotes 2019/09/09 17:19:51 1.357 +++ ray/doc/notes/ReleaseNotes 2025/04/04 18:06:48 1.481 @@ -2237,7 +2237,7 @@ Updates to evalglare and gendaylit from Jan Wienold, i colored sky option. ========================= -Version 5.3 +Version 5.3 (Released September 1, 2020) Created radcompare program to compare Radiance tool output to reference outputs during unit-testing. @@ -2314,11 +2314,478 @@ column vector. Also added ability to apply trailing u Added new depth, normal, and ID file types to radcompare. Added BigEndian= header line for automatic byte-swapping in rmtxop -and radcompare. Doesn't work quite as automatically as it should -for pvalue -r, currently. +and radcompare. Added new "turbo" palette to falsecolor (thanks to Taoning). Nathaniel Jones created the "dcglare" program for annual glare simulations when the sun and sky are visible through the window. -Tutorial is posted at "https://github.com/nljones/Accelerad/wiki/The-Imageless-Method-for-Spatial-and-Annual-Glare-Analysis". +Tutorial is posted at +"https://github.com/nljones/Accelerad/wiki/The-Imageless-Method-for-Spatial-and-Annual-Glare-Analysis". + +Added support for loading RGBE images into matrices in dctimestep. + +Added -y option to gensky and gendaylit to support more accurate Michalsky +solar position calculation. + +Changed rsplit, so specifying a space as the separator parses words +between whitespace. + +Added ability of vwrays, pinterp, and pmblur2 to read encoded depth files. + +Added -o RxCxR1xC1 facility to perform blocking in rcollate. + +Made it so number of segments in genworm, genrev, and gensurf can be +given as expressions of previously defined variables, etc. + +Added -D and -n option to gendaymtx to output sun description and skip +matrix output on request. A -M option was also added to output solar +modifiers for rcontrib. Support also added for leap days in WEA input. +Enhancements sponsored by Ladybug Tools. + +Updated eplus_uvf to work with IDF version 9.x, checking version number. + +Fix to glarendx issues with dgi calculation. + +Made it so rmtxop and dctimestep undo any exposure applied to Radiance +pictures they may load. + +Added robjutil utility to manipulate Wavefront .OBJ files. + +Fixed a crash related to rtrace -om or -oM with mesh instances containing +materials. + +Improved rtrace flushing function to handle any value for -x without +deadlock on controlling process. + +Eliminated unnecessary start-up procedures for rtrace when only ray-casting +is needed (i.e., no tracing or value output). + +Improved isotropic sampling method in bsdf2ttree using "zipper" approach +applied in genBSDF. + +Added limit to memory used by high-resolution tensor tree BSDFs for +cumulative cache during MC sampling (rendering). Limit set to 250MBytes +per BSDF for standard architectures. + +Added -n and -s options to bsdf2ttree to provide some user control +over super-sampling. + +Improved surface normal codec used by ambient file to store orthonormal +directions exactly. + +Improved peak extraction method, which was undervaluing transmission +in many cases. + +New version of evalglare from Jan Wienold. + +Added -u option to gendaymtx to elide data columns (time steps) when +the sun is not visible above the horizon. + +========================= +Version 5.4 + +Added rcollate -c option to force operation to continue even if it +seems unnecessary. Made tool more robust. + +Added -t option to rcontrib (and rfluxmtx) to report progress after the +given number of seconds. + +Added "test" target to makeall to run unit tests. + +Modified bsdf2ttree to allow different parameters per input SIR file. + +Fixed issues with very large matrix files (> 2GB) in dctimestep, rmtxop, +and rcollate. + +Added -rf and -rb options to rmtxop to load front or back reflectance +matrix data from XML file rather than transmission. (Lars Grobe suggested.) + +Improved behavior for coincident surfaces with different materials. +Rather than returning one surface or the other based on floating-point +vagaries, opaque materials are now preferred over transparent ones. +If the materials are both transparent or both opaque, then whichever +surface appeared later in the scene description will be selected. +This came of a request for consistent behavior with legal CAD output +from Peter Apian-Bennewitz. + +Added explicit tests for on-edge intersections with polygons. This should +eliminate stray rays and tiny light leaks that often appear even in +well-constructed geometry. + +Added "-s up" option to pabopto2bsdf to allow for 180 degree symmetry, +meaning that data repeats after 180 degree rotation (as distinguished +from "-s bilateral" whose data is mirrored about a vertical plane). +Thanks to Helen Rose Wilson for the suggestion and informing me that +such a thing exists. + +Removed upper limit on number of modifiers in rcontrib. + +Put cap on maximum ambient gradient to avoid over-extrapolation of +poorly computed irradiance cache values. + +Added robjutil +T option to triangulate all faces in .OBJ description. + +Altered BSDF library to have both front and back diffuse transmittance +values, which can be different. This was necessary to avoid issues +caused by measurement and modeling discrepancies. + +Added pabopto2bsdf -g option to cull near-grazing scattering to avoid +issues with noise and negative values. + +Increased default dynamic range from 32 to 100 in pcond and normtiff. + +Added -o and -n options to genbox to create .OBJ output and segment +edges and corners for transparent materials. Also added -s option +to control smoothing for .OBJ and Radiance with segmented rounding. + +Made it so robjutil with the +r option for Radiance output now +produces normal smoothing unless normals are removed with -n. + +Added exposure preservation to pcompos when possible (i.e., when +there is only one input or inputs agree on exposure). + +Added -DSHARP_RGB compile-time option to use sharp RGB color space +rather than historic default. This can make for more accurate color +calculations, but requires that materials be recalibrated. The +PRIMARIES= line is also produced on output from rpict or rvu with +the correct set of primaries based on how the system was compiled. + +Added automatic flushing to the output of total, except when the -r +(running subtotals) option is used. + +Improved behavior of little-used -aw option, so that it avoids sea-level +rise caused by adding its own estimate back into the ambient level remainder. +It ended up being simple enough to derate the final average by the factor +corresponding to average surface absorpition, thus removing the average +from the final bounce estimate. + +Introduced ies2rad upgrades by Randolph Fritz. Randolph says it +fixes the following problems: + + 1. Generates correct Radiance geometry for spheres in 1995, 2002, + and 2019 IES files. + + 2. Generates correct Radiance geometry for vertical cylinders that + are taller than they are wide. + + 3. Ignores the file source ("File Generation Type") field in the + 2019 version of the file, which would otherwise be incorrectly used + as an output multiplier. + + It also offers the following enhancements: + + 1. Shape information is included in the .rad file comments. + + 2. 1995, 2002, and 2019-version luminous opening geometry is + accounted for. + + 3. The 2002 and 2019 IES file versions are recognized and + processed appropriately. + + 4. I have made an attempt to do something intelligent with less + common "luminous opening" shapes in the 1995, 2002, and 2019 versions + of the standard, though I have not implemented any support for new + geometry; approximations are substituted and warning messages issued. + Unfortunately, this code is not tested, since I don't have any IES + files that use these shapes. + +Added support for depth-of-field blurring in vwrays using -pd option. +Also, made -c count work with vwrays -i, producing multiple samples +per indicated pixel position. At the same time, support for the -pd +option was added to rtpict, which calls on vwrays for its samples. + +Fixed issue with BSDFs that didn't obey reciprocity, where direct +sampling wasn't following exactly with indirect sampling. This was +discovered and reported by Jon Sargent. + +Created checkBSDF tool to test XML BSDF reciprocity and perform similar +sanity checks. + +Added -O option to pvalue and pextrem to report watts/sr/m^2 even if +picture is XYZE. + +Made subtle changes to header i/o routines to preserve alignment in +binary file formats to enable memory-mapping. Implemented memory-mapped +matrix loading in rmtxop for binary double files. + +Removed ambient value sorting, which was written when ambient caches +could overwhelm available memory. This is rarely the case these days, +and the added code complexity and updating of cache values with LRU +counts dirties pages that would otherwise remain clean, so it was +often a loss even when VM was an issue. + +Added iso2klems script to compute a Klems BSDF based on specular +and diffuse measurements as a function of incident angle. + +Fixed issue with over-counting diffuse component during aBSDF +peak extraction. + +Added dctimestep -x and -y options to specify image dimensions +for multiple outputs corresponding to result vectors. + +Added -P option to rcalc to pass formatted input when cond is <= 0. + +Created rcrop utility for cropping matrices and pictures more +conveniently, correcting view information. Expect it to be handy +for extracting rows and columns from matrices, mostly. + +Changed pcomb so -o option elides original exposure values +from indented source headers. + +Added getinfo -r option, which is similar to -a except it will +replace indicated lines with new ones. + +Slight change to vwrays -d option to not spit out "-ld-", and to +produce "-ld+" without requiring input picture as argument. + +Added automatic overture calculation to rtpict with -n > 1 if +ambient cache is on and file is named. If straight image output +is requested, we randomize all samples and avoid cache collisions. + +Added cnt -s option to shuffle output. + +Fixed issue with divide-by-zero errors in the ambient super-sampling +routine discovered by Jon Sargent of Solemma. This affected regions +that had zero radiance, such as black backgrounds or unlit areas +with -av 0 0 0, when super-sampling was effectively disabled, causing +some loss in accuracy of the results. + +Updated Klems Half- and Quarter-bases to match angles currently used +in WINDOW. + +Eliminated most aiming failures for triangular light sources, at the +expense of conservative sampling near the centroid. Thanks to +David Geisler-Moroder for his help on this. + +Increased maximum set size to 8191 to avoid set overflow errors. + +Added source obstruction test to statistics being kept on which +sources were visible in adaptive shadow testing code. Previous +behavior was likely over-estimating source contributions. + +Added diffuse components into maximum directional hemispherical +reported by checkBSDF, so comparing to 100% is easier for each +component. + +Fixed incorrect calculations in iso2klems script, thanks to +help from Jacob Jonnson. + +Updated official copyright and license according to new wording +provided by Jean Haemmerle at the LBNL Intellectual Property Office. +Both were copied verbatim from e-mail I received from Taoning Wang +on 8/20/2022. + +Added -features option to rpict, rtrace, and rcontrib to check +which features are present or look for specific feature support. +This addition was suggested by Peter Apian-Bennewitz as an easier +way to determine which version of Radiance is installed and what +it supports, and is timely as we begin our refactoring of the +rendering code. There are no current plans to add this to rvu. + +Added falsecolor -odim, -orct, and -c0 options to overlay grid of +values on image. This was requested by Rob Shakespeare. + +Added -i* and -o* options in rhcopy for reading rays from the +standard input and writing rays from holodeck to standard output. +This will hopefully be useful in combining rholo with rcontrib. + +Added further checking for coincident (overlapping) flat surfaces, +preferring front sides to back sides in the ray intersection +calculation. This only applies to rings and faces, as the other +surface types would have required additional calculations to +make them work. Material transparency is still the primary +consideration, now followed by ray hit side, followed by +modifier definition order in the input. + +Increased octree and object limits to allow scenes with billions +of primitives. + +Made reciprocity averaging default to "off" in bsdf2ttree, as it seems +to create more problems than it solves. + +==================== +Version 6.0 + +Extensive changes to enable spectral rendering, which defaults to "off" +to maintain backwards-compatibility with previous versions, with the +exception of the ambient file format, which is changed. The MAXCSAMP +macro, which defaults to 24, sets the maximum number of spectral samples. +The actual number of samples is set by the "-cs" option, which defaults +to 3 for rpict, rtrace, and rcontrib. The latter two programs support +straight spectral output, but rpict is initially restricted to +tristimulus output pictures. New pattern primitives "spectrum", +"specfile", and "specfunc" have been added as a means to specify +spectral reflectance, emittance, etc. to materials that still have +only 3 color channels. Those RGB channels will still affect the +spectrum if used. Unfortunately photon-mapping is currently broken when +spectral sampling is enabled, but we will fix this as soon as possible. +Calculation overhead appears to be approximately 10-15% for RGB +renderings compared to version 5.4a. + +Added spectral rendering to rvu as well, and made -cs and -cw +options standard across the rendering library. I also brought +mkillum, ranimove, rsensor, and mksource into the fold. These +tools were broken in the initial release. (Hopefully, they are +working now, but none have been tested as yet.) +There was also an indexing bug in the spectral->RGB conversions +that made reds into blues and vice versa, which has been fixed. + +Added i/o for spectral pictures to rmtxop, the first program that can +ingest them. (Only rtrace, rcontrib, and rfluxmtx can render them.) +New symbolic rmtxop -c options, such as RGB, XYZ, S (for scotopic) +and M (for melanopic) make color conversions simpler. Alternatively, +a reference matrix or picture may be given and the color space of +that file will be used. The -C option takes either a symbolic +color space or reference file and is "sticky," so it applies to +all subsequent input files that do not have their own -c right ahead +of them. + +Added spectral picture support to rcrop and radcompare. + +Added new utility, rcomb, which is something like a combination +of rmtxop and pcomb, it works with all the inputs and +outputs that rmtxop handles, but allows for general expressions +like those in pcomb for putting matrices together, working on +an element at a time. (No resizing of matrices or accessing +neighboring elements, as permitted in pcomb.) It saves memory +over rmtxop by operating on a row at a time, so can handle +input and output matrices with any number of rows. It does +provide for a single matrix-multiplication operation at the end, +which only requires memory for that final matrix. + +Added support for filtering hyperspectral images to pfilt. + +Added support for 1- and 3-component float matrix i/o to +pcomb to allow for better interoperability. + +Added support for -co+ option to rtpict, so it can directly +produce hyperspectral images. + +Added new "specdata" and "specpict" primitives to support +interpolated spectral data files and hyperspectral images +as patterns. + +Added support for multispectal sampling in rsensor, which will +put out as many color channels as specified in any -cs option +(default is 3 for RGB). + +Added ability of mgf2rad to convert spectral data at least +for light, glow, plastic, and metal primitive types. Need +to use new '-s' option to get new output. + +Added handling of spectral images to rcode2bmp script. + +Minor change to rcollate to allow explicit byte records to +be any specified length without checks against header input. + +Added new hemisphere type to rfluxmtx, "h=cie" for CIE sky +scanner positions. These are 145 patches with identical +row counts to Tregenza, but starting from a different +azimuth and reversing row directions at adjacent altitudes. + +Added optimization for long argument lists and arrays in +the calcomp routines used for rendering and in rcalc, etc. + +Added error estimate spreading to ambient super-sampling +algorithm (-as) to improve performance especially in +scenes with sharp cut-offs. + +Added -i option to gendaymtx to match -i option of gendaylit. +Thanks to Yongqing for initial implementation. + +Changed rcrop so negative #rows or #cols counts back from end. + +Added rcomb -n option for multi-processing of very large matrices. + +Made it so rsplit and rlam can handle any number of input files +up to active open file descriptor limit. + +Taoning Wang added genssky tool for generating spectral sky +descriptions. + +Taoning added gensdaymtx utility based on gendaymtx, and +added epw2wea -a option to include required information. + +Fixed bug introduced in Auguest 2022 (5.4 release) in distant +light source sampling, which caused aiming failures. (Thanks +to Mike DiPompeo of LightStanza for reporting the issue.) + +Added rxpict rendering tool based on C++ RpictSimulManager class. +Multi-processing and spectral output are supported. + +Wrote rxpiece tool that will render pictures using tiling and +can handle different output formats and hyperspectral pictures. +Only runs on a single machine, however -- no NFS locking on +shared volumes. Mainly a demonstration tool for RpictSimulManager +C++ class, but may have its uses. + +Fixed a bug in BSDF sampling of sources pointed out by +David Geisler-Moroder, which tended to overestimate specular +contributions for some BSDFs. + +Added crude ability to read and convert spectra to RGB in ximage, +ra_bmp, ra_ps, and ra_rgbe programs. Also updated fast tone-mapping +library to handle spectral HSR inputs at the same time. HSR +input handling was added in a similar fashion to pcond and pvalue +for convenience. + +Added handling of hyperspectral images to normtiff, a handy program +for quickly tone-mapping Radiance RGBE, XYZE, and now hyperspectral +pictures, as well as IEEE float or LogLuv TIFFs. + +Added handling of hyperspectral pictures to pextrem, though +results are still reported in RGB. + +Added accurate conversion of hyperspectral pictures to ra_xyze. + +Added hyperspectral picture conversion to ra_tiff, with accurate +color when targeting 16-bit/comp., LogLuv, and float utput, +and the approximate method for 24-bit RGB. + +Taoning added genssky -L option to specify global and diffuse +illuminance values for output calibration. + +Created C++ class for rcontrib and example tool rxcontrib, which +is an optional compile in the src/rt directory. The output +model is more general in some respects and the operations more +efficient, but standard output is not supported, nor is ASCII +results data. + +Added strnstr.c compatibility module in ray/src/common, since +it isn't present on Linux derivatives. + +Added WGMDfunc material type with programmable roughness and +separate modifier paths for the different components. + +Added gensurf -i option at the request of Peter Apian-Bennewitz +to reverse surface normals, mostly for data input, when it is +a bit more difficult to adjust. + +Added rad -N option to rholo call for multiprocessing when +mkillum and/or mkpmap are involved in octree prep. + +Added ability of gendaymtx to read EPW as well as WEA files. +When EPW input is provided, the 3-hour average dew point is +used to compute a more accurate precipitable water content +value. It currently does not use these data directly from +the EPW input, relying instead on a dew-point-to-W calculation. +This follows the request and recommendations of David G-M. + +Removed limitation in rfluxmtx, which was disallowing distant +and local receivers. Found this to be a perfectly valid approach +for some annual daylighting scenarios. + +Wrote new pvsum tool to handle cases dctimestep can't, like +spectral input pictures. It also adds a -N option for multi- +processing on Unix machines, which utilizes memory-mapped +inputs for efficient i/o sharing. + +Made it so genBSDF can use spectral rendering for a +more accurate photometric result. + +Changed default matrix representation to float rather than +double, which uses less RAM and supports faster operations +in general. Build with compiler flag: + -DDTnativeDTrmx_native=DTdouble +to get back higher precision representation.
