--- ray/doc/notes/ReleaseNotes 2025/03/19 01:18:20 1.478 +++ ray/doc/notes/ReleaseNotes 2025/04/10 23:30:58 1.482 @@ -2775,3 +2775,20 @@ This follows the request and recommendations of David Removed limitation in rfluxmtx, which was disallowing distant and local receivers. Found this to be a perfectly valid approach for some annual daylighting scenarios. + +Wrote new pvsum tool to handle cases dctimestep can't, like +spectral input pictures. It also adds a -N option for multi- +processing on Unix machines, which utilizes memory-mapped +inputs for efficient i/o sharing. + +Made it so genBSDF can use spectral rendering for a +more accurate photometric result. + +Changed default matrix representation to float rather than +double, which uses less RAM and supports faster operations +in general. Build with compiler flag: + -DDTnativeDTrmx_native=DTdouble +to get back higher precision representation. + +Taoning Wang updated genssky and gensdaymtx to provide illuminance +calibration and accept EPW files directly as input.
