--- ray/doc/notes/ReleaseNotes 2025/01/23 22:03:59 1.475 +++ ray/doc/notes/ReleaseNotes 2025/05/05 19:20:16 1.486 @@ -2716,7 +2716,7 @@ Multi-processing and spectral output are supported. Wrote rxpiece tool that will render pictures using tiling and can handle different output formats and hyperspectral pictures. -Only runs on a single machine, however -- now NFS locking on +Only runs on a single machine, however -- no NFS locking on shared volumes. Mainly a demonstration tool for RpictSimulManager C++ class, but may have its uses. @@ -2752,22 +2752,60 @@ model is more general in some respects and the operati efficient, but standard output is not supported, nor is ASCII results data. -Added experimental source-skipping method to rpict for scenes -with large number of light sources. Currently works with -rcontrib and separate srcsamp image-processing tool. Controlling -rpict options are -dS for skip bitmap specification and -dC -for correction coefficient image. Compile using -DSSKIPOPT -to include this option. - Added strnstr.c compatibility module in ray/src/common, since -it isn't present on Linux-derivatives. +it isn't present on Linux derivatives. Added WGMDfunc material type with programmable roughness and separate modifier paths for the different components. Added gensurf -i option at the request of Peter Apian-Bennewitz -to reverse surface normals, mostly for data input when it is +to reverse surface normals, mostly for data input, when it is a bit more difficult to adjust. -Added rad -N option to rholo run for multiprocessing when +Added rad -N option to rholo call for multiprocessing when mkillum and/or mkpmap are involved in octree prep. + +Added ability of gendaymtx to read EPW as well as WEA files. +When EPW input is provided, the 3-hour average dew point is +used to compute a more accurate precipitable water content +value. It currently does not use these data directly from +the EPW input, relying instead on a dew-point-to-W calculation. +This follows the request and recommendations of David G-M. + +Removed limitation in rfluxmtx, which was disallowing distant +and local receivers. Found this to be a perfectly valid approach +for some annual daylighting scenarios. + +Wrote new pvsum tool to handle cases dctimestep can't, like +spectral input pictures. It also adds a -N option for multi- +processing on Unix machines, which utilizes memory-mapped +inputs for efficient i/o sharing. + +Made it so genBSDF can use spectral rendering for a +more accurate photometric result. + +Changed default matrix representation to float rather than +double, which uses less RAM and supports faster operations +in general. Build with compiler flag: + -DDTnativeDTrmx_native=DTdouble +to get back higher precision representation. + +Taoning Wang updated genssky and gensdaymtx to provide illuminance +calibration and accept EPW files directly as input. + +Added -e expr and -f file.cal options to all rendering tools, not +just rcontrib/rxcontrib. Feature request from Peter A-B. + +Fixed slight bias in indirect calculation caused by ambient +collision detection, pointed out by Jon Sargent. New code +keeps track of rejected samples and sells them back to +later calls to get something closer to a true Poisson +sampling method. + +Altered rvu "origin" command to take shift amounts forward, +right, and up rather than taking an explicit origin, which +can be done easily enough with the "view" command. Peter A-B +requested (sort of). + +Added genglaze tool created by Taoning Wang to generate +spectral glazing materials based on CGDB data and models.
