--- ray/doc/notes/ReleaseNotes 2024/09/20 17:39:12 1.461 +++ ray/doc/notes/ReleaseNotes 2024/12/09 00:44:29 1.471 @@ -2714,11 +2714,6 @@ to Mike DiPompeo of LightStanza for reporting the issu Added rxpict rendering tool based on C++ RpictSimulManager class. Multi-processing and spectral output are supported. -Added crude ability to read and convert spectra to RGB in ximage, -ra_bmp, and ra_rgbe programs. Also updated fast tone-mapping -library to handle spectral HSR inputs at the same time. HSR -input handling was added in a similar fashion to pcond and pvalue. - Wrote rxpiece tool that will render pictures using tiling and can handle different output formats and hyperspectral pictures. Only runs on a single machine, however -- now NFS locking on @@ -2729,5 +2724,43 @@ Fixed a bug in BSDF sampling of sources pointed out by David Geisler-Moroder, which tended to overestimate specular contributions for some BSDFs. +Added crude ability to read and convert spectra to RGB in ximage, +ra_bmp, ra_ps, and ra_rgbe programs. Also updated fast tone-mapping +library to handle spectral HSR inputs at the same time. HSR +input handling was added in a similar fashion to pcond and pvalue +for convenience. + +Added handling of hyperspectral images to normtiff, a handy program +for quickly tone-mapping Radiance RGBE, XYZE, and now hyperspectral +pictures, as well as IEEE float or LogLuv TIFFs. + Added handling of hyperspectral pictures to pextrem, though results are still reported in RGB. + +Added accurate conversion of hyperspectral pictures to ra_xyze. + +Added hyperspectral picture conversion to ra_tiff, with accurate +color when targeting 16-bit/comp., LogLuv, and float utput, +and the approximate method for 24-bit RGB. + +Taoning added genssky -L option to specify global and diffuse +illuminance values for output calibration. + +Created C++ class for rcontrib and example tool rxcontrib, which +is an optional compile in the src/rt directory. The output +model is more general in some respects and the operations more +efficient, but standard output is not supported, nor is ASCII +results data. + +Added experimental source-skipping method to rpict for scenes +with large number of light sources. Currently works with +rcontrib and separate srcsamp image-processing tool. Controlling +rpict options are -dS for skip bitmap specification and -dC +for correction coefficient image. Compile using -DSSKIPOPT +to include this option. + +Added strnstr.c compatibility module in ray/src/common, since +it isn't present on Linux-derivatives. + +Added WGMDfunc material type with programmable roughness and +separate modifier paths for the different components.
