--- ray/doc/notes/ReleaseNotes 2024/09/20 17:39:12 1.461 +++ ray/doc/notes/ReleaseNotes 2025/04/10 23:30:58 1.482 @@ -2714,14 +2714,9 @@ to Mike DiPompeo of LightStanza for reporting the issu Added rxpict rendering tool based on C++ RpictSimulManager class. Multi-processing and spectral output are supported. -Added crude ability to read and convert spectra to RGB in ximage, -ra_bmp, and ra_rgbe programs. Also updated fast tone-mapping -library to handle spectral HSR inputs at the same time. HSR -input handling was added in a similar fashion to pcond and pvalue. - Wrote rxpiece tool that will render pictures using tiling and can handle different output formats and hyperspectral pictures. -Only runs on a single machine, however -- now NFS locking on +Only runs on a single machine, however -- no NFS locking on shared volumes. Mainly a demonstration tool for RpictSimulManager C++ class, but may have its uses. @@ -2729,5 +2724,71 @@ Fixed a bug in BSDF sampling of sources pointed out by David Geisler-Moroder, which tended to overestimate specular contributions for some BSDFs. +Added crude ability to read and convert spectra to RGB in ximage, +ra_bmp, ra_ps, and ra_rgbe programs. Also updated fast tone-mapping +library to handle spectral HSR inputs at the same time. HSR +input handling was added in a similar fashion to pcond and pvalue +for convenience. + +Added handling of hyperspectral images to normtiff, a handy program +for quickly tone-mapping Radiance RGBE, XYZE, and now hyperspectral +pictures, as well as IEEE float or LogLuv TIFFs. + Added handling of hyperspectral pictures to pextrem, though results are still reported in RGB. + +Added accurate conversion of hyperspectral pictures to ra_xyze. + +Added hyperspectral picture conversion to ra_tiff, with accurate +color when targeting 16-bit/comp., LogLuv, and float utput, +and the approximate method for 24-bit RGB. + +Taoning added genssky -L option to specify global and diffuse +illuminance values for output calibration. + +Created C++ class for rcontrib and example tool rxcontrib, which +is an optional compile in the src/rt directory. The output +model is more general in some respects and the operations more +efficient, but standard output is not supported, nor is ASCII +results data. + +Added strnstr.c compatibility module in ray/src/common, since +it isn't present on Linux derivatives. + +Added WGMDfunc material type with programmable roughness and +separate modifier paths for the different components. + +Added gensurf -i option at the request of Peter Apian-Bennewitz +to reverse surface normals, mostly for data input, when it is +a bit more difficult to adjust. + +Added rad -N option to rholo call for multiprocessing when +mkillum and/or mkpmap are involved in octree prep. + +Added ability of gendaymtx to read EPW as well as WEA files. +When EPW input is provided, the 3-hour average dew point is +used to compute a more accurate precipitable water content +value. It currently does not use these data directly from +the EPW input, relying instead on a dew-point-to-W calculation. +This follows the request and recommendations of David G-M. + +Removed limitation in rfluxmtx, which was disallowing distant +and local receivers. Found this to be a perfectly valid approach +for some annual daylighting scenarios. + +Wrote new pvsum tool to handle cases dctimestep can't, like +spectral input pictures. It also adds a -N option for multi- +processing on Unix machines, which utilizes memory-mapped +inputs for efficient i/o sharing. + +Made it so genBSDF can use spectral rendering for a +more accurate photometric result. + +Changed default matrix representation to float rather than +double, which uses less RAM and supports faster operations +in general. Build with compiler flag: + -DDTnativeDTrmx_native=DTdouble +to get back higher precision representation. + +Taoning Wang updated genssky and gensdaymtx to provide illuminance +calibration and accept EPW files directly as input.
