--- ray/doc/notes/ReleaseNotes 2024/02/08 02:26:01 1.446 +++ ray/doc/notes/ReleaseNotes 2024/09/10 20:24:42 1.457 @@ -2683,3 +2683,37 @@ Added new hemisphere type to rfluxmtx, "h=cie" for CIE scanner positions. These are 145 patches with identical row counts to Tregenza, but starting from a different azimuth and reversing row directions at adjacent altitudes. + +Added optimization for long argument lists and arrays in +the calcomp routines used for rendering and in rcalc, etc. + +Added error estimate spreading to ambient super-sampling +algorithm (-as) to improve performance especially in +scenes with sharp cut-offs. + +Added -i option to gendaymtx to match -i option of gendaylit. +Thanks to Yongqing for initial implementation. + +Changed rcrop so negative #rows or #cols counts back from end. + +Added rcomb -n option for multi-processing of very large matrices. + +Made it so rsplit and rlam can handle any number of input files +up to active open file descriptor limit. + +Taoning Wang added genssky tool for generating spectral sky +descriptions. + +Taoning added gensdaymtx utility based on gendaymtx, and +added epw2wea -a option to include required information. + +Fixed bug introduced in Auguest 2022 (5.4 release) in distant +light source sampling, which caused aiming failures. (Thanks +to Mike DiPompeo of LightStanza for reporting the issue.) + +Added rxpict rendering tool based on C++ RpictSimulManager class. +Multi-processing and spectral output are supported. + +Added crude ability to read and convert spectra to RGB in ximage, +ra_bmp, and ra_rgbe programs. Also updated fast tone-mapping +library to handle spectral HSR inputs at the same time.
