--- ray/doc/notes/ReleaseNotes 2024/01/04 01:55:42 1.442 +++ ray/doc/notes/ReleaseNotes 2024/10/02 15:58:56 1.463 @@ -2671,4 +2671,70 @@ put out as many color channels as specified in any -cs (default is 3 for RGB). Added ability of mgf2rad to convert spectral data at least -for light, glow, plastic, and metal primitive types. +for light, glow, plastic, and metal primitive types. Need +to use new '-s' option to get new output. + +Added handling of spectral images to rcode2bmp script. + +Minor change to rcollate to allow explicit byte records to +be any specified length without checks against header input. + +Added new hemisphere type to rfluxmtx, "h=cie" for CIE sky +scanner positions. These are 145 patches with identical +row counts to Tregenza, but starting from a different +azimuth and reversing row directions at adjacent altitudes. + +Added optimization for long argument lists and arrays in +the calcomp routines used for rendering and in rcalc, etc. + +Added error estimate spreading to ambient super-sampling +algorithm (-as) to improve performance especially in +scenes with sharp cut-offs. + +Added -i option to gendaymtx to match -i option of gendaylit. +Thanks to Yongqing for initial implementation. + +Changed rcrop so negative #rows or #cols counts back from end. + +Added rcomb -n option for multi-processing of very large matrices. + +Made it so rsplit and rlam can handle any number of input files +up to active open file descriptor limit. + +Taoning Wang added genssky tool for generating spectral sky +descriptions. + +Taoning added gensdaymtx utility based on gendaymtx, and +added epw2wea -a option to include required information. + +Fixed bug introduced in Auguest 2022 (5.4 release) in distant +light source sampling, which caused aiming failures. (Thanks +to Mike DiPompeo of LightStanza for reporting the issue.) + +Added rxpict rendering tool based on C++ RpictSimulManager class. +Multi-processing and spectral output are supported. + +Added crude ability to read and convert spectra to RGB in ximage, +ra_bmp, and ra_rgbe programs. Also updated fast tone-mapping +library to handle spectral HSR inputs at the same time. HSR +input handling was added in a similar fashion to pcond and pvalue. + +Wrote rxpiece tool that will render pictures using tiling and +can handle different output formats and hyperspectral pictures. +Only runs on a single machine, however -- now NFS locking on +shared volumes. Mainly a demonstration tool for RpictSimulManager +C++ class, but may have its uses. + +Fixed a bug in BSDF sampling of sources pointed out by +David Geisler-Moroder, which tended to overestimate specular +contributions for some BSDFs. + +Added handling of hyperspectral pictures to pextrem, though +results are still reported in RGB. + +Added conversion of hyperspectral pictures to ra_xyze, although +it is even slower than rcomb for this process. It is more +accurate than most of the other tools, at least. + +Added handling of hyperspectral images to normtiff, a little-used +but handy program for quickly tone-mapping pictures and TIFFs.
