--- ray/doc/notes/ReleaseNotes 2023/11/27 22:04:45 1.433 +++ ray/doc/notes/ReleaseNotes 2023/12/16 03:30:35 1.441 @@ -2634,5 +2634,39 @@ that made reds into blues and vice versa, which has be Added i/o for spectral pictures to rmtxop, the first program that can ingest them. (Only rtrace, rcontrib, and rfluxmtx can render them.) New symbolic rmtxop -c options, such as RGB, XYZ, S (for scotopic) -and M (for melanopic) make color conversions simpler. -Also added spectral picture support to rcrop and radcompare. +and M (for melanopic) make color conversions simpler. Alternatively, +a reference matrix or picture may be given and the color space of +that file will be used. The -C option takes either a symbolic +color space or reference file and is "sticky," so it applies to +all subsequent input files that do not have their own -c right ahead +of them. + +Added spectral picture support to rcrop and radcompare. + +Added new utility, rcomb, which is hard to type and hard to +pronounce, and probably equally difficult to use. Sort of a +combination of rmtxop and pcomb, it works with all the inputs and +outputs that rmtxop handles, but allows for general expressions +like those in pcomb for putting matrices together, working on +an element at a time. (No resizing of matrices or accessing +neighboring elements, as permitted in pcomb.) It saves memory +over rmtxop by operating on a row at a time, so can handle +input and output matrices with any number of rows. It does +provide for a single matrix-multiplication operation at the end, +which only requires memory for that final matrix. + +Added support for filtering hyperspectral images to pfilt. + +Added support for 1- and 3-component float matrix i/o to +pcomb to allow for better interoperability. + +Added support for -co+ option to rtpict, so it can directly +produce hyperspectral images. + +Added new "specdata" and "specpict" primitives to support +interpolated spectral data files and hyperspectral images +as patterns. + +Added support for multispectal sampling in rsensor, which will +put out as many color channels as specified in any -cs option +(default is 3 for RGB).
