--- ray/doc/notes/ReleaseNotes 2021/12/04 16:29:29 1.398 +++ ray/doc/notes/ReleaseNotes 2023/03/16 00:25:24 1.425 @@ -2494,3 +2494,106 @@ Added support for depth-of-field blurring in vwrays us Also, made -c count work with vwrays -i, producing multiple samples per indicated pixel position. At the same time, support for the -pd option was added to rtpict, which calls on vwrays for its samples. + +Fixed issue with BSDFs that didn't obey reciprocity, where direct +sampling wasn't following exactly with indirect sampling. This was +discovered and reported by Jon Sargent. + +Created checkBSDF tool to test XML BSDF reciprocity and perform similar +sanity checks. + +Added -O option to pvalue and pextrem to report watts/sr/m^2 even if +picture is XYZE. + +Made subtle changes to header i/o routines to preserve alignment in +binary file formats to enable memory-mapping. Implemented memory-mapped +matrix loading in rmtxop for binary double files. + +Removed ambient value sorting, which was written when ambient caches +could overwhelm available memory. This is rarely the case these days, +and the added code complexity and updating of cache values with LRU +counts dirties pages that would otherwise remain clean, so it was +often a loss even when VM was an issue. + +Added iso2klems script to compute a Klems BSDF based on specular +and diffuse measurements as a function of incident angle. + +Fixed issue with over-counting diffuse component during aBSDF +peak extraction. + +Added dctimestep -x and -y options to specify image dimensions +for multiple outputs corresponding to result vectors. + +Added -P option to rcalc to pass formatted input when cond is <= 0. + +Created rcrop utility for cropping matrices and pictures more +conveniently, correcting view information. Expect it to be handy +for extracting rows and columns from matrices, mostly. + +Changed pcomb so -o option elides original exposure values +from indented source headers. + +Added getinfo -r option, which is similar to -a except it will +replace indicated lines with new ones. + +Slight change to vwrays -d option to not spit out "-ld-", and to +produce "-ld+" without requiring input picture as argument. + +Added automatic overture calculation to rtpict with -n > 1 if +ambient cache is on and file is named. If straight image output +is requested, we randomize all samples and avoid cache collisions. + +Added cnt -s option to shuffle output. + +Fixed issue with divide-by-zero errors in the ambient super-sampling +routine discovered by Jon Sargent of Solemma. This affected regions +that had zero radiance, such as black backgrounds or unlit areas +with -av 0 0 0, when super-sampling was effectively disabled, causing +some loss in accuracy of the results. + +Updated Klems Half- and Quarter-bases to match angles currently used +in WINDOW. + +Eliminated most aiming failures for triangular light sources, at the +expense of conservative sampling near the centroid. Thanks to +David Geisler-Moroder for his help on this. + +Increased maximum set size to 8191 to avoid set overflow errors. + +Added source obstruction test to statistics being kept on which +sources were visible in adaptive shadow testing code. Previous +behavior was likely over-estimating source contributions. + +Added diffuse components into maximum directional hemispherical +reported by checkBSDF, so comparing to 100% is easier for each +component. + +Fixed incorrect calculations in iso2klems script, thanks to +help from Jacob Jonnson. + +Updated official copyright and license according to new wording +provided by Jean Haemmerle at the LBNL Intellectual Property Office. +Both were copied verbatim from e-mail I received from Taoning Wang +on 8/20/2022. + +Added -features option to rpict, rtrace, and rcontrib to check +which features are present or look for specific feature support. +This addition was suggested by Peter Apian-Bennewitz as an easier +way to determine which version of Radiance is installed and what +it supports, and is timely as we begin our refactoring of the +rendering code. There are no current plans to add this to rvu. + +Added falsecolor -odim, -orct, and -c0 options to overlay grid of +values on image. This was requested by Rob Shakespeare. + +Added -i* and -o* options in rhcopy for reading rays from the +standard input and writing rays from holodeck to standard output. +This will hopefully be useful in combining rholo with rcontrib. + +Added further checking for coincident (overlapping) flat surfaces, +preferring front sides to back sides in the ray intersection +calculation. This only applies to rings and faces, as the other +surface types would have required additional calculations to +make them work. Material transparency is still the primary +consideration, now followed by ray hit side, followed by +modifier definition order in the input.
