--- ray/doc/notes/ReleaseNotes 2022/11/16 00:12:49 1.424 +++ ray/doc/notes/ReleaseNotes 2023/03/17 20:43:16 1.426 @@ -2589,3 +2589,14 @@ values on image. This was requested by Rob Shakespear Added -i* and -o* options in rhcopy for reading rays from the standard input and writing rays from holodeck to standard output. This will hopefully be useful in combining rholo with rcontrib. + +Added further checking for coincident (overlapping) flat surfaces, +preferring front sides to back sides in the ray intersection +calculation. This only applies to rings and faces, as the other +surface types would have required additional calculations to +make them work. Material transparency is still the primary +consideration, now followed by ray hit side, followed by +modifier definition order in the input. + +Increased octree and object limits to allow scenes with billions +of primitives.
