--- ray/doc/notes/ReleaseNotes 2022/04/26 03:00:02 1.415 +++ ray/doc/notes/ReleaseNotes 2022/08/12 23:55:00 1.420 @@ -2550,3 +2550,23 @@ routine discovered by Jon Sargent of Solemma. This af that had zero radiance, such as black backgrounds or unlit areas with -av 0 0 0, when super-sampling was effectively disabled, causing some loss in accuracy of the results. + +Updated Klems Half- and Quarter-bases to match angles currently used +in WINDOW. + +Eliminated most aiming failures for triangular light sources, at the +expense of conservative sampling near the centroid. Thanks to +David Geisler-Moroder for his help on this. + +Increased maximum set size to 8191 to avoid set overflow errors. + +Added source obstruction test to statistics being kept on which +sources were visible in adaptive shadow testing code. Previous +behavior was likely over-estimating source contributions. + +Added diffuse components into maximum directional hemispherical +reported by checkBSDF, so comparing to 100% is easier for each +component. + +Fixed incorrect calculations in iso2klems script, thanks to +help from Jacob Jonnson.
