--- ray/doc/notes/ReleaseNotes 2022/04/11 04:03:36 1.413 +++ ray/doc/notes/ReleaseNotes 2022/04/26 03:00:02 1.415 @@ -2542,3 +2542,11 @@ produce "-ld+" without requiring input picture as argu Added automatic overture calculation to rtpict with -n > 1 if ambient cache is on and file is named. If straight image output is requested, we randomize all samples and avoid cache collisions. + +Added cnt -s option to shuffle output. + +Fixed issue with divide-by-zero errors in the ambient super-sampling +routine discovered by Jon Sargent of Solemma. This affected regions +that had zero radiance, such as black backgrounds or unlit areas +with -av 0 0 0, when super-sampling was effectively disabled, causing +some loss in accuracy of the results.
